@ Dana - Scan is provided below.
@ Hadez16 - They're on because this the default setting for a 2007 German spec Audi TT; when the DLRs are turned on, the front parking lights come on.
@ NEtech - I'll give that a try and see what happens.
Just to be sure I understand this, where Dec1: 24 x 1 =
24, the number
24 means the bulb is at 24% brightness where 100% is the maximum brightness.
For the notation where Dec1: 0 x 1 =
0, is this fully on (100%) or completely off (0%)?
Here are my current setting & scan -
Byte 7 Dec1: 0 x 1 = 0 Turn Signal Front left/right as Parking Light Front left/right (USA and Canada)
Byte 8 Dec1: 3 x 1 = 3 Daytime Running Light Dimming
Byte 9 Dec1: 24 x 1 = 24 Rear Brake Light as Parking Light
Byte 10 Dec1: 0 x 1 = 0 Rear Fog Light as Parking Light
Byte 11 Dec1: 0 x 1 = 0 Front Parking Light Dimming
Byte 12 Dec1: 24 x 1 = 24 Rear Parking Light Dimming
Byte 13 Dec1: 0 x 1 = 0 Backup Function: Rear ide Turn Signal as Parking/Brake Light
Byte 14 Dec1: 0 x 1 = 0 Backup Function: Front Parking Light as Side Turn Signal
Byte 15 Dec1: 0 x 1 = 0 Backup Function: Rear Parking Light as SIde Turn Signal
Byte 16 Dec1: 0 x 1 = 0 Backup Function: Front Fog Lights as Low Beam Headlights
Byte 20 Dec1: 90 x 1 = 90 Front Fog Light Dimming (Standard SC)
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 22 25 26 37 42 44 46 47 4C 52 55 56 77
VIN: TRUZZZ8J0XXXXXXXX Mileage: 89450km-55581miles
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 HJ HW: 022 906 032 GP
Component: MOTRONIC ME7.1.1G 0672
Revision: --H02--- Serial number: AUX7Z0FNFNO025
Coding: 0000178
Shop #: WSC 01236 785 00200
VCID: 5AEC62511019F9475F3-800E
Part No SW: 02E 300 011 BL HW: 02E 927 770 AD
Component: GSG DSG 082 1397
Revision: 05308020 Serial number: 00001101290813
Shop #: WSC 44551 111 44551
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0026177
VCID: 6A8C3291C07969C7CF3-803E
Part No SW: 8J0 820 043 S HW: 8J0 820 043 S
Component: J255 Klima 1 Zone 0060
Revision: 00H07003 Serial number: 00000001024259
Coding: 1048838
VCID: 3634D6E1C441FD279BB-8062
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 H HW: 8P0 907 279 H
Component: Bordnetz-SG H46 1802
Revision: 00H46000 Serial number: 00000006498723
Coding: 09068E8380141C0003180000180000000009EE075A260802
VCID: 42DCBA3198895187273-8016
Subsystem 1 - Part No: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H05 0060
Coding: 00064784
Shop #: WSC 01236
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 HW: 8J0 907 376 A
Component: J250 Raddaempfung 0050
Revision: --H16--- Serial number: 190DPH 6286036
Coding: 0000014
VCID: 6C803489CA8D77F7BDF-8038
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -s Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K000LPMB
Coding: 0011635
VCID: 79AE1DDDB5DFD25F369-802C
Subsystem 1 - Serial number: 6332DRB404784E12N
Subsystem 2 - Serial number: 6342DRB4047DD29C1
Subsystem 3 - Serial number: 63729RB401E3149CR
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0013141
VCID: 41DEB53D9D8F4A9F3E9-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY7.lbl
Part No SW: 8J0 920 930 C HW: 8J0 920 930 C
Component: KOMBIINSTR. VDO H21 0070
Revision: D0H21004 Serial number: 224NF004018275
Coding: 0081018
Shop #: WSC 24097 002 1048576
VCID: 2C00F4890A0DB7F7FDF-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106B22025F
Coding: FF0F23CA67005100
VCID: 2F3AE3853B1BCCEFD8D-807A
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Revision: D0H21004 Serial number: AUX7Z0FNFNO025
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 B
Component: 256 VSG TT H13 0100
VCID: 3E24CEC1EC71356743B-806A
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 192 HW: 8J0 035 192
Component: RNS-E HIGH EU H10 0650
Revision: 01S Serial number: AUZBZ7G3500391
Coding: 0619717
Shop #: WSC 23321 823 59458
VCID: 669446A1D4614DA7EBB-8032
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J7 959 801 C
Component: Tuer-SG H02 0060
Coding: 0000053
VCID: 3C20C4C9FA6D27776DF-8068
Part No: 8J1 909 143 B
Component: EPS_ZFLS Kl.155 H07 1807
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433
Component: KSG H07 0070
Coding: 9890300241182D098505488AD673
VCID: 73B22FF597B3A80F7C5-8026
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 C HW: 8J0 035 223 C
Component: J525 Amp High H04 0110
Revision: PROD_01 Serial number: 00000000003111
Coding: 0246126
VCID: 24101CA962DD7FB735F-8070
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 HW: 8J0 907 274
Component: J502 RKA+ H04 0130
Coding: 0614100
VCID: 6FBA2385FB9B8CEF98D-803A
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8J7 959 802 C
Coding: 0000053
VCID: 3D26C9CDE1772E7F5A1-8068
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 G
Coding: 0000011
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619717
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005063935
Coding: 0011402
VCID: 3B22C7D5FF63204F645-806E
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.9V. VIgn 11.8V)-----
