Audi TT (8J) 2007 - Setting DRLs and Dimming Parking Lights
SwissJetPilot
Switzerland
C?ID=317276
I have a German spec 2007 3.2 Quattro Roadster and recently replaced the OEM DLR bulbs with LEDs. In addition, I've changed the DLR setting to "Scandanavian" so the tail lights are on too.
So now when the car is running and the DLRs are on -
1 - DLRs come on and front parking light comes on
2 - When the master light switch is turned to "parking lights" the DLRs dim and the front parking lights remain on
3 - When the master light switch is turned to "head lights" the DLRs dim and the front parking lights remain on
What I would like to have is -
1 - DLRs on ONLY with no front parking lights
2 - When the master light switch is turned to "parking light", ONLY the parking lights come on.
3 - When the master light switch is turned to "head lights" ONLY the headlights come on.
I'm guessing the changes can be made in 09-Cent. Elect by chaning Byte 8 (Daytime Running Light Dimming) and Byte 11 (Front Parking Light Dimming)
Question is - is this possible and how do you change the values?
Light functions with DLR on -
09-Cent. Elect Setting for Byte 8 and 11 -
hadez16
C?ID=289891
The question for me is why are your parking lights on at all?
Please provide a full Auto-Scan as mentioned.
NEtech
Denmark
C?ID=56995
Change the number at "Dec1"
If you for example want 50%, you change the 3 or 0, to 50 and press [Enter].
SwissJetPilot
Switzerland
C?ID=317276
@ Dana - Scan is provided below.
@ Hadez16 - They're on because this the default setting for a 2007 German spec Audi TT; when the DLRs are turned on, the front parking lights come on.
@ NEtech - I'll give that a try and see what happens.
Just to be sure I understand this, where Dec1: 24 x 1 = 24, the number 24 means the bulb is at 24% brightness where 100% is the maximum brightness.
For the notation where Dec1: 0 x 1 = 0, is this fully on (100%) or completely off (0%)?
Here are my current setting & scan -
Byte 7 Dec1: 0 x 1 = 0 Turn Signal Front left/right as Parking Light Front left/right (USA and Canada)
Byte 8 Dec1: 3 x 1 = 3 Daytime Running Light Dimming
Byte 9 Dec1: 24 x 1 = 24 Rear Brake Light as Parking Light
Byte 10 Dec1: 0 x 1 = 0 Rear Fog Light as Parking Light
Byte 11 Dec1: 0 x 1 = 0 Front Parking Light Dimming
Byte 12 Dec1: 24 x 1 = 24 Rear Parking Light Dimming
Byte 13 Dec1: 0 x 1 = 0 Backup Function: Rear ide Turn Signal as Parking/Brake Light
Byte 14 Dec1: 0 x 1 = 0 Backup Function: Front Parking Light as Side Turn Signal
Byte 15 Dec1: 0 x 1 = 0 Backup Function: Rear Parking Light as SIde Turn Signal
Byte 16 Dec1: 0 x 1 = 0 Backup Function: Front Fog Lights as Low Beam Headlights
Byte 20 Dec1: 90 x 1 = 90 Front Fog Light Dimming (Standard SC)
 Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 22 25 26 37 42 44 46 47 4C 52 55 56 77
VIN: TRUZZZ8J0XXXXXXXX   Mileage: 89450km-55581miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 HJ    HW: 022 906 032 GP
   Component: MOTRONIC ME7.1.1G   0672
   Revision: --H02---    Serial number: AUX7Z0FNFNO025
   Coding: 0000178
   Shop #: WSC 01236 785 00200
   VCID: 5AEC62511019F9475F3-800E
   Part No SW: 02E 300 011 BL    HW: 02E 927 770 AD
   Component: GSG DSG         082 1397
   Revision: 05308020    Serial number: 00001101290813
   Shop #: WSC 44551 111 44551
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517     HW: 8J0 614 517
   Component: ESP MK60E1          0130
   Revision: 00H52001
   Coding: 0026177
   VCID: 6A8C3291C07969C7CF3-803E
   Part No SW: 8J0 820 043 S    HW: 8J0 820 043 S
   Component: J255  Klima 1 Zone  0060
   Revision: 00H07003    Serial number: 00000001024259
   Coding: 1048838
   VCID: 3634D6E1C441FD279BB-8062
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 H    HW: 8P0 907 279 H
   Component: Bordnetz-SG     H46 1802
   Revision: 00H46000    Serial number: 00000006498723
   Coding: 09068E8380141C0003180000180000000009EE075A260802
   VCID: 42DCBA3198895187273-8016
   Subsystem 1 - Part No: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H05 0060
   Coding: 00064784
   Shop #: WSC 01236
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376     HW: 8J0 907 376 A
   Component: J250 Raddaempfung   0050
   Revision: --H16---    Serial number: 190DPH 6286036
   Coding: 0000014
   VCID: 6C803489CA8D77F7BDF-8038
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -s Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K000LPMB
   Coding: 0011635
   VCID: 79AE1DDDB5DFD25F369-802C
   Subsystem 1 - Serial number: 6332DRB404784E12N
   Subsystem 2 - Serial number: 6342DRB4047DD29C1
   Subsystem 3 - Serial number: 63729RB401E3149CR
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0013141
   VCID: 41DEB53D9D8F4A9F3E9-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY7.lbl
   Part No SW: 8J0 920 930 C    HW: 8J0 920 930 C
   Component: KOMBIINSTR. VDO H21 0070
   Revision: D0H21004    Serial number: 224NF004018275
   Coding: 0081018
   Shop #: WSC 24097 002 1048576
   VCID: 2C00F4890A0DB7F7FDF-8078
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 3300106B22025F
   Coding: FF0F23CA67005100
   VCID: 2F3AE3853B1BCCEFD8D-807A
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   Revision: D0H21004    Serial number: AUX7Z0FNFNO025
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 B
   Component: 256 VSG TT      H13 0100
   VCID: 3E24CEC1EC71356743B-806A
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8J0 035 192     HW: 8J0 035 192
   Component: RNS-E HIGH EU   H10 0650
   Revision:      01S    Serial number: AUZBZ7G3500391
   Coding: 0619717
   Shop #: WSC 23321 823 59458
   VCID: 669446A1D4614DA7EBB-8032
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 8J7 959 801 C
   Component: Tuer-SG         H02 0060
   Coding: 0000053
   VCID: 3C20C4C9FA6D27776DF-8068
   Part No: 8J1 909 143 B
   Component: EPS_ZFLS Kl.155 H07 1807
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433
   Component:    KSG          H07 0070
   Coding: 9890300241182D098505488AD673
   VCID: 73B22FF597B3A80F7C5-8026
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor      H03 0020
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 C    HW: 8J0 035 223 C
   Component: J525 Amp High   H04 0110
   Revision: PROD_01     Serial number: 00000000003111
   Coding: 0246126
   VCID: 24101CA962DD7FB735F-8070
Address 4C: Tire Pressure II        Labels: 8J0-907-274.lbl
   Part No SW: 8J0 907 274     HW: 8J0 907 274
   Component: J502  RKA+      H04 0130
   Coding: 0614100
   VCID: 6FBA2385FB9B8CEF98D-803A
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 8J7 959 802 C
   Coding: 0000053
   VCID: 3D26C9CDE1772E7F5A1-8068
   Part No: 8P0 907 357 G
   Coding: 0000011
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0619717
   Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005063935
   Coding: 0011402
   VCID: 3B22C7D5FF63204F645-806E
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.9V. VIgn 11.8V)-----
NEtech
Denmark
C?ID=56995
0% dimming means no light, 100% is maximum light.
SwissJetPilot
Switzerland
C?ID=317276
@ NEtech -
"0% dimming means no light, 100% is maximum light."
That's what I though too. Then can you explain why my front parking lights are on as shown in the pictures above given Byte 11 has the following setting?
Or is Byte 11 not the correct point for setting these lights??
NEtech
Denmark
C?ID=56995
First if it was me, I would try some of the others with dimming and change them, to see what result it gives.
SwissJetPilot
Switzerland
C?ID=317276
I changed the setting in Byte 11 to see what would happen with different values. The only value I could change was the first digit Dec; 1 x 1 = 1
To make the change, input the value you want, then press enter and exit the window to go back to the previous screen and select [Do it!] This will immediatley implement the change and you can look at the lights to see how much dimmer or brighter they are.
1.) 0 is 100% bright.
2.) 1 is as dim as you can get, with all increasing values making it brighter up to 99. (See image)
It will not accept decimal values (.01) and it doesn't seem possible to turn it off either.
United States
I haven't tinkered with a Mk5 for a while but if 0 is 100% bright please see if changing Byte 7 happens to change anything. If not I might experiment in Byte 14.
This was the factory NAR config from a 2008 GTI:
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
Although that was the 30 Byte module ... the lighting bytes in question have identical text descriptions. Our cars have additional "parking" lights in the bumper so I'm not sure which coding Bytes applied to the ones in the headlamp itself.
SwissJetPilot
Switzerland
C?ID=317276
Hi Dana - Okay, I'll go through the 09-Cent. Elect. options and play around with the settings. Now that I know how to do it, it's not quite so scary! LOL!
