7SPEED DSG FAULT
Fredrick Awuor
Kenya
C?ID=309834
hello anyone,my client has shipped this mechatronic for repairs in the UK[ecutesting.com] before car hopped into my place,it had,
;P177C - 003 - Tolerance Limit Reached - Intermittent
                    Fault Status: 00100011
                    Reset counter: 9
                    Mileage: 82858 km
                    Date: 2011.09.18
                    Time: 15:24:44,
client share this in January this year,then last month it developed driveability issues and popped a new different code,hence its flight to uk'However ecutesting.com have tested and indicated that it is not faulty,does anyone have a hint at what could be the issue since online info is scant on this......can we use a different mechatronic oil,if so which one,because the current code comes back after a few minutes drive, I have done basic settings and the defined test drive,code comes back immediately,any insight will be greatly appreciated
LATEST CODE
Wednesday,30,May,2018,09:57:50:48669
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZ8U025818   License Plate: KCF577V
Mileage: 122330km-76012mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ8U025818   Mileage: 122330km-76012miles
Address 01: Engine (CAX)       Labels: 03C-906-022-CAX.clb
   Part No SW: 03C 906 022 AL    HW: 03C 906 022 J
   Component: MED17.5.20          5936
   Revision: D5H03---    Serial number: VWX7Z0GD2411BP
   Coding: 0000077
   Shop #: WSC 66020 981 94185
   VCID: 6696BF75B46C2CE7EBB-8032
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501306046781
   Shop #: WSC 66020 981 115161
   VCID: 392C24099552731F769-806C
006298 - Clutch 1
               P189A - 000 - Clearance too Small - Intermittent
                    Reset counter: 10
                    Mileage: 122305 km
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0019074
   Shop #: WSC 00046 000 00000
   VCID: 688AB14DBE783A97D97-803C
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6B80CE41AF8E118FB45-803E
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000008031669
   Coding: A08D0F27000415005F1400001400000000097B0F5C000110000000000000
   Shop #: WSC 00046 412 12345
   VCID: 6FB8DA519B96EDAF98D-803A
   Component: Wischer 290208 020  0501
   Coding: 00049141
   Shop #: WSC 00046
   Component: 15 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0A95W3
   Coding: 0012597
   Shop #: WSC 00046 412 00000
   VCID: 6C82CD5DAA8016B7BDF-8038
   Subsystem 1 - Serial number: 6332MSME344144483
   Subsystem 2 - Serial number: 6342MSME2C25746AK
   Subsystem 3 - Serial number: 6352QSME510434352
   Subsystem 4 - Serial number: 6362QSME4C2B2639R
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           752 0100
   Coding: 0010012
   VCID: 77A8E231E3C6A56F40D-8022
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 864 A    HW: 1K0 920 864 A
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0GD2411BP
   Coding: 0000001
   Shop #: WSC 49837 000 104857
   VCID: 2A0E0B4560F4C8870F3-807E
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K081050028
   Coding: ED807F060002020003
   Shop #: WSC 00046 123 12345
   VCID: 303A192D4628B257C17-8064
                    Reset counter: 226
                    Mileage: 122304 km
                    Time: 12:02:19
01304 - Radio
                    Reset counter: 226
                    Mileage: 122304 km
                    Time: 12:02:23
   Component: IMMO            3HL 1212
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1210
   Coding: 0000694
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 36362F35A44C9C679BB-8062
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 999002005103087F2D0484057008DF03E0FCA0
   VCID: 71BCDC298DA2FB5F8E9-8024
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000950
   VCID: 3A2E3B05905478077F3-806E
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   VCID: 382A210DAE586A17897-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----------(Elapsed Time: 01:09, VBatt start/end: 12.2V/12.1V)-----------
Wednesday,30,May,2018,11:07:01:48669
   Coding: 0000077
   Revision: 00H14001
   Coding: 0019074
   Coding: 00049141
   Shop #: WSC 00046
02389 - Release Signal Transmission; Position P/N
                    Reset counter: 12
                    Mileage: 122332 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.35 V
   Coding: 0012597
   Coding: 0010012
00576 - Terminal 15
   Coding: 0210487
                    Reset counter: 226
                    Mileage: 122304 km
                    Time: 12:02:19
01304 - Radio
                    Reset counter: 226
                    Mileage: 122304 km
                    Time: 12:02:23
   Coding: 0000694
   Coding: 0000950
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:04, VBatt start/end: 12.1V/12.1V)-----------
DrPeter
16.4905° S, 151.7375° W
I suggest you have a look at the Volkswagen Technical Service Bulletin - 2021821, for this fault code P189A, it states
"The clutch free play K1 is too small, because of premature wear adjustment."
and
"Replace multiple clutch"
But ... before replacing any parts, I would read the most recent version of the TSB, the Official Factory Repair Information and check with your manufactures parts department for the latest information about these parts.
'Trust but verify." :)
Hope this helps,
drpeter
Fredrick Awuor
Kenya
C?ID=309834
and
Hope this helps,
drpeter
Thanks Dr Peter,I will visit the local dealer
