VW TOUAREG MARKET MODEL
Fredrick Awuor
Kenya
C?ID=309834
Hello everyone,I really appreciate the help I have gotten here ever since I purchased my treasured HEX V2 PRO....now i have a Touareg here with thousands of DTCs and before I embark on any repair intervention,Id like to download WD and relevant repair info on erWin but not sure of the market model so that i hit the right buttons on erWin,can anyone shed light on whether it is a NAR or ROW model,I have tried VIN on numerous sites online but so far no helpful info is available
Saturday,16,June,2018,11:53:33:48669
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVGZZZ7PZGD003385   License Plate: 7P
Mileage: 22148km-13762mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
          6C 6D 72
VIN: WVGZZZ7PZGD003385   Mileage: 22148km-13762miles
02-Auto Trans -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
17-Instruments -- Status: Malfunction 0110
42-Door Elect, Driver -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
72-Door, Rear Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 A    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---
   Coding: 292A4012232E01020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P1907401A 001002
   ROD: EV_ECM30TDI0117P1907401A.rod
   VCID: 2E060755509CA4A7D3B-807A
13 Faults Found:
14627 - Fuel Pump Control Module
          P025A 00 [167] - Electrical Fault
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:49
                    Engine speed: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 18 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 11.480 V
                    Shut-off timer: last engine shut-off time: 2 s
                    Control module temp.: max. value: 57.4 °C
                    Mean injection quantity: 0.00 mg/stroke
                    Ambient temperature: 18.0 °C
                    Control Module temperature: 45.6 °C
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:51
                    Voltage terminal 30: 11.440 V
                    Control Module temperature: 39.7 °C
                    EGR_governor_deviation: 1270.9 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardised airflow ratio: 3.9999
                    Air mass at air mass meter 1: 0.0 kg/h
                    Actual charge pressure: 834 hPa
4481 - Cruise Control Switch (E45)
          P0568 00 [036] - Implausible Signal
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:44:36
                    Coolant temperature: 54 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.120 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 193
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:49
                    Voltage terminal 30: 11.380 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 4
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:49
4367 - Powertrain Databus
          U0001 00 [036] - Unspecified Malfunction
                    Fault Frequency: 8
                    Mileage: 22149 km
                    Vehicle speed: 255 km/h
                    Coolant temperature: 73 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.540 V
                    CAN status - engine control module-Bits 0-7: 136
                    Cruise Control System (CCS): status-Bits 0-7: 12
                    selected gear-Bits 0-7: 0
5615 - Door Control Module - Driver's Door
          U0199 00 [039] - No Communications
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:50
                    Voltage terminal 30: 11.540 V
                    selected gear-Bits 0-7: 8
10587 - Door Control Module - Rear Right
          U0202 00 [039] - No Communications
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:50
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:37:50
4718 - No Communication with Transmission Control Module
          U0101 00 [039] - -
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:44:43
                    Voltage terminal 30: 12.040 V
17262 - Terminal 30
          U140A 00 [036] - Open Circuit
          [Terminal 30Open circuit]
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Shut-off timer: last engine shut-off time: 0 s
                    Control module temp.: max. value: -273.1 °C
                    Ambient temperature: -273.1 °C
                    Control Module temperature: -273.1 °C
5618 - Engine Off Timer Performance
          P150A 00 [096] - -
4629 - ECM Power Relay Load Circuit
          P068A 00 [039] - Opens Too Early
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Address 02: Auto Trans
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 41485555650048
   Coding: 5B6B13C34B242556DAF7C89BD2D7A470F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CC26DDDC640F6B7DDF-8018
9 Faults Found:
336397 - Databus
          U1123 00 [072] - Received Error Message
          [Motorsteuergerät: bitte Fehlerspeicher auslesen]
                    Reset counter: 16
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:53:52
                    Standard Freeze  Frame Dynamic: 00 3D 00 00 00 00 00 07 00 00 01 20 01
171010 - Supply voltage
          U1011 00 [072] - Voltage too Low
          [Insuff. voltage]
                    Reset counter: 16
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 13:27:29
                    Standard Freeze  Frame Dynamic: 00 21 FF FD 20 00 00 07 00 00 01 00 80
171009 - Supply voltage
          U1012 00 [072] - Voltage too High
          [Bordspannung Kl. 30 oberer Grenzwert überschritten]
                    Reset counter: 16
                    Standard Freeze  Frame Dynamic: 00 6F FF FD 00 00 00 07 00 00 01 10 44
336520 - ROD - Unknown Error Code
          - 00 [072]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:35:40
                    Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 03 00 00 01 20 19
336644 - Databus
          U1121 00 [137] - Missing Message
          [Getriebesteuergerät: kein Signal/Kommunikation]
                    Reset counter: 16
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:44:59
                    Standard Freeze  Frame Dynamic: 00 3D 00 00 00 00 00 00 00 00 01 20 03
340740 - Databus
          [Steuergerät fürFahrertür Antrieb :kein Signal/Kommunikation]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:20
                    Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 03 00 00 01 20 5E
126212 - Sensor Units for ESP
          C1024 31 [137] - No Signal
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:20
                    Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 03 00 00 01 30 00
336516 - Databus
          [Motorsteuergerät: kein Signal/Kommunikation]
                    Reset counter: 16
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:29:10
                    Standard Freeze  Frame Dynamic: 00 37 00 00 20 00 00 02 01 00 01 20 02
74252 - Rear Left Wheel Speed Sensor
          C101C 01 [137] - Electrical Failure
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Standard Freeze  Frame Dynamic: 00 3D 00 00 00 00 00 07 00 00 01 00 40
   Part No SW: 4H0 907 064 GM    HW: 4H0 907 064 GM
   Component: BCM2 2.0      H37 0572
   Coding: 01B60010000000000000
   VCID: 7AAEFB05DCD4B8073F3-802E
   Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 3615000131272010
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3215000103491001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 68
                    Reset counter: 16
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 20:08:58
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 11
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 13:25:18
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 13:27:26
Address 08: Auto HVAC
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00001099326802
   Coding: 26000014D0345D010029400300005D4C431D470827010241000000000040110000000000000000
   VCID: 6A8ECB45AC740887CF3-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    150530  033 0021
   Serial number: 90243401150609064450
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000000806150060
19 Faults Found:
                    Reset counter: 16
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:45:05
                    Fault Frequency: 21
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:29:26
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 14:11:11
                    Reset counter: 17
                    Mileage: 1048574 km
                    Date: 2016.11.13
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:03
                    Fault Status: 01101100
                    Fault Frequency: 9
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:04
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:40
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:40
00576 - Terminal 15
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:41
                    Fault Status: 00100001
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:49
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:42
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 16
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:01
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:42
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:44
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:44
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:45
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:46
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:12:33
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:12:33
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231515602380
   Coding: 308504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D245FDEE103EF715F-8010
7 Faults Found:
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [009] - Open Circuit
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:19
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:17
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 13:25:18
13636096 - Supply voltage
          U1012 00 [008] - Voltage too High
          [Versorgungsspannung - zu hoch]
                    Reset counter: 56
                    Mileage: 22148 km
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 13:25:18
13893888 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
          [Funktionseinschränkung durch Überspannung - oberer Grenzwert überschritten]
                    Reset counter: 56
12648720 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Getriebesteuergerät - Getriebe_03 - kein Signal/keine Kommunikation]
                    Reset counter: 16
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:47:53
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag00T H10 0044
   Revision: --------    Serial number: 003S80004K7R
   Coding: 000000000000000000000000000000003054
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 357  RB4000000000004
   Serial number: 3585LRB405736CAM7H56
   Serial number: 3517ARB405F39P82G8C%
   Serial number: 3527ARB405H39P826OVR
   Serial number: 3557BRB40553EENA80B.
   Serial number: 3567BRB40573EENAE866
14 Faults Found:
9443091 - Driver's Side Airbag Crash Sensor
          B1017 13 [137] - Open Circuit
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:19
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9442587 - Igniter for battery interrupt
          B1015 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9441563 - Rear; driver's side; side-airbag igniter
          B1011 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9438490 - Igniter for Driver head airbag
          B1005 1A [137] - Resistance Too Low
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 1048574 km
                    Date: 2016.11.13
                    Time: 00:05:21
9441307 - Rear; passenger's side; side-airbag igniter
          B1010 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
          B1006 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:21
          [Powersupply upper threshold exceeded]
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:03:11
          [Powersupply lower threshold fall short of]
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:23:48
1057536 - Databus
          [CAN: 0x105 Motor_03 Timeout]
                    Fault Frequency: 44
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:29:12
   Part No SW: 4H0 953 568 K    HW: 7P6 953 507 AB
   Component: Lenks.Modul   H06 0005
   Revision: --------    Serial number: 01374OFH000JJ
   Coding: 000015
   VCID: 3B203E01936E410F645-806E
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0032921 TRW 20150408
11 Faults Found:
01750 - Multi-Function Switch in Steering Wheel (E440); Left
                    Fault Status: 00101100
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 10:31:58
01751 - Multi-Function Switch in Steering Wheel(E441); Right
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 10:35:01
01426 - Controls in Steering Wheel (E221)
                    Fault Frequency: 240
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 10:45:59
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 10:45:59
00886 - Turn Signal Switch (E2)
                    Fault Frequency: 8
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:25:20
00895 - Cruise Control Switch (E45)
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:29:09
                    Fault Frequency: 8
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 13:27:24
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 14:14:55
                    Reset counter: 56
                    Reset counter: 56
                    Fault Frequency: 49
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:19
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 B    HW: 7P6 920 883 B
   Component: Kombi         H13 0515
   Revision: 13240302    Serial number: 658160615592042
   Coding: 332731003A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3D2430198DFA4F3F5A1-8068
          [Supply voltage too low]
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 14:08:48
          [Supply voltage too high]
                    Reset counter: 56
                    Mileage: 22148 km
          U1401 00 [008] - -
                    Reset counter: 56
16776971 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Motor_03 keine Kommunikation]
                    Fault Frequency: 58
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:29:11
16776976 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Gateway_04: BCM1_Aussen_Temp_ungef: Fehlerwert]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:19
   Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6042
   Revision: --------    Serial number: 00000001886663
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 42DE43E5F40430C7273-8016
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 32153D08125701151386
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 15158000763021200181
16 Faults Found:
5055 - No Communications with HVAC Control Module (J301)
          U0164 00 [009] - -
          [No signal/communication to Aircondition- ECU (Climatronic)]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:40
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 14 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4226 - No Communication with Transmission Control Module
          U0101 00 [009] - -
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:23
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 38 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [008] - -
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:35
                    Control Module temperature: 15 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5057 - Body Control Module (Central Electric)
          U0140 00 [024] - No Communications
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:13
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5072 - Door Control Module - Driver's Door
          U0199 00 [009] - No Communications
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:40
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5075 - Door Control Module - Rear Right
          U0202 00 [009] - No Communications
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:40
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [008] - No Communication
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:38
                    Voltage terminal 30: 12.0 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [008] - -
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:38
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6657 - Generator
          U1052 00 [008] - No Communication
                    Fault Frequency: 8
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:03:15
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 18 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Fault Frequency: 60
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:24
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 11.8 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6681 - Voltage Regulator Stage 2
          C10AF F5 [008] - Short to GND
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:03:36
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 19 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0257 - Powertrain Databus
          U0002 00 [008] - No Communications
                    Fault Frequency: 45
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:40
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0259 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [Vehicle Communication Bus C Bus Performance]
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:38
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0264 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
          U0009 00 [008] - -
          [Datenbus Antrieb Eindraht]
                    Fault Frequency: 19
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:07:21
                    Control Module temperature: 29 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 21
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:10
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0019 - Terminal 15
          U1405 00 [008] - Implausible signal
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:39
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AF    HW: 7P0 907 553 AF
   Component: PASM          H05 0750
   Revision: 00000000    Serial number: 00000151600295
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001005
   ROD: EV_PASMConti.rod
   VCID: 7BA0FE01D36E810F245-802E
16 Faults Found:
0789 - Control Head for Level Conrtol System
          C10D4 31 [009] - No Signal
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.12.22
                    Time: 20:24:48
                    Default: 00
                    Default: 77
                    Default: 00
0465 - Air Control Valve for Valve Body of Level Control System
          C10D1 13 [137] - Open Circuit
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0481 - Valve for Pressure Accumulator for Level Control System
          C10D0 13 [137] - Open Circuit
                    Fault Priority: 13
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0497 - Bleed Valve for Ride-Height
          C103B 13 [137] - Open Circuit
                    Fault Priority: 13
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0353 - Valve for Air-Spring Front Right
          C103D 13 [137] - Open Circuit
                    Fault Priority: 13
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0369 - Valve for Air-Spring Rear Left
          C103E 13 [137] - Open Circuit
                    Fault Priority: 8
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0385 - Valve for Air-Spring Rear Right
          C103F 13 [137] - Open Circuit
                    Fault Priority: 8
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0304 - Valve for Damping Adjustment Rear Left
          C1042 11 [137] - Short to Ground
                    Fault Priority: 8
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0600 - Pressure Sensor for Ride-Height
          C1031 14 [137] - Open or Short to Ground
                    Fault Priority: 12
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 00:00:60
                    Default: 00
                    Default: 77
                    Default: 00
0337 - Valve for Air-Spring Front Left
          C103C 13 [137] - Open Circuit
                    Fault Priority: 9
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.00
                    Time: 01:24:60
                    Default: 00
                    Default: 77
                    Default: 00
12656644 - Databus
          [CAN-Timeoutfehler Getriebesteuerung]
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.12
                    Time: 00:12:59
                    Default: 00
                    Default: 77
                    Default: 00
0515 - Relay for Ride-Height Compressor
          C1038 01 [008] - Electrical Failure
                    Fault Frequency: 57
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.12
                    Time: 09:56:58
                    Default: 00
                    Default: 77
                    Default: 00
12656642 - Databus
          [CAN-Timeoutfehler Motorsteuerung]
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.12
                    Time: 10:08:59
                    Default: 00
                    Default: 77
                    Default: 00
12656788 - Databus
          [CAN-Signalfehler BCM vorne]
                    Fault Frequency: 57
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.12
                    Time: 10:12:57
                    Default: 00
                    Default: 77
                    Default: 00
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
          C10DA 13 [009] - Open Circuit
                    Fault Frequency: 57
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.12
                    Time: 10:32:56
                    Default: 00
                    Default: 77
                    Default: 00
12656773 - Databus
          [CAN-Signalfehler PSM]
                    Fault Frequency: 17
                    Reset counter: 0
                    Mileage: 427008 km
                    Date: 2054.08.12
                    Time: 27:32:59
                    Default: 00
                    Default: 77
                    Default: 00
   Revision: 00002001    Serial number: 0371598045
   Coding: 011B1620A8B9108083200624010000000000000000000000000000000000
12 Faults Found:
                    Fault Frequency: 68
                    Reset counter: 16
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 20:08:58
02739 - Bulb for Tail/Brake Light; Right
                    Fault Status: 11101100
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:38:21
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:52:25
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
02738 - Bulb for Tail/Brake Light; Left
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:12:39
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:32:15
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:03:14
                    Fault Frequency: 13
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:49
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:02
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:04
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000154340336
   Coding: 011D0620D001451005080000
   VCID: 48CA51CDD2B81A97F97-801C
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 14:10:45
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:04
            000 -  -  - Intermittent
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 18:55:17
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:51
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:03:08
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1561000814
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 36362F35A8CC9C679BB-8062
   Slave 3:
10 Faults Found:
12652545 - Supply voltage
          [Excess voltage]
                    Reset counter: 56
                    Voltage: 19.6 V
0037 - Control Module for Electronic Parking Brake
          C10E2 53 [008] - Deactivated
                    Reset counter: 56
                    Voltage: 11.6 V
12652544 - Supply voltage
          [Insuff. voltage]
                    Fault Frequency: 17
                    Reset counter: 57
                    Mileage: 22148 km
                    Voltage: 0.0 V
0038 - Databus
          [Steuergerät PSM - Notbremsung nicht verfügbar]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:34:33
                    Voltage: 11.2 V
12656644 - Databus
          [CAN-Timeout Getriebe]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:34:33
                    Voltage: 11.2 V
12656770 - Databus
          [CAN-Signalfehler Getriebe]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:34:19
                    Voltage: 11.2 V
12656773 - Databus
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:34:19
                    Voltage: 11.2 V
12656659 - Databus
          [CAN-Timeout Türsteuergerät Fahrer]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:20
                    Voltage: 12.0 V
12656642 - Databus
          [CAN-Timeout Motorsteuergerät]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 01:34:33
                    Voltage: 11.6 V
12656790 - Databus
          [CAN-Signalfehler Kombiinstrument]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:48
                    Voltage: 12.0 V
   Component: AFS-ECU       H01 0110
   Coding: 01A602000B000200
   ROD: EV_HeadlRegulAFSMQBMLB_VW51.rod
   VCID: 3FD84A1187F65D2F48D-806A
9 Faults Found:
5276144 - Power Output Module for Left Headlamp
          C1081 F0 [009] - Not Coded
                    Reset counter: 17
5276400 - Power Output Module for Right Headlamp
          C1082 F0 [009] - Not Coded
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:22
5275926 - Power Output Module for Left Headlamp
          C1081 16 [008] - Voltage Too Low
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:05:59
5276209 - Power Output Module for Right Headlamp
          C1082 31 [008] - No Signal
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:24
5276182 - Power Output Module for Right Headlamp
          C1082 16 [008] - Voltage Too Low
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:10:19
13771011 - Databus
          [Motor_03 Datenbus fehlende Botschaft]
                    Fault Frequency: 102
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 11:29:11
13705478 - Databus
          [RLS_01 Datenbus fehlende Botschaft]
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:20
13679104 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:20
13705985 - Databus
          [Fehlerwert im Signal ESP_HL_Radgeschw]
                    Fault Frequency: 41
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:20
Address 56: Radio
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000154222462
   Coding: 011804200001251005080000
                    Reset counter: 57
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:03:57
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8JA50696
   Coding: 0020001
   VCID: 37282231A346656F80D-8062
01327 - Control Module for Parking Aid (J446)
                    Fault Frequency: 34
                    Reset counter: 56
                    Mileage: 22149 km
                    Date: 2016.11.10
                    Time: 23:37:50
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 14:10:53
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 56
                    Mileage: 22148 km
                        Term 15 Off
                        Reverse OFF
                    Count: 3
02203 - Audio / Video Input 1
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:01:17
                        Reverse OFF
                    Count: 3
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 162501744
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
0014 - Supply voltage
          [Versorgungsspannung dauerhaft zu niedrig]
                    Reset counter: 56
                    Mileage: 22148 km
                    Date: 2016.11.11
                    Time: 14:06:31
                    Voltage terminal 30: 8.66 V
0013 - Supply voltage
          [Versorgungsspannung dauerhaft zu hoch]
                    Reset counter: 56
                    Mileage: 22148 km
                    Voltage terminal 30: 0.84 V
0048 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 17
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 00:00:39
                    Voltage terminal 30: 11.86 V
0011 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Mileage: 22148 km
                    Date: 2016.11.13
                    Time: 18:55:52
                    Voltage terminal 30: 8.07 V
0059 - Pinch Protection Strip 2
          B11DC 13 [137] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 17
                    Voltage terminal 30: 11.97 V
Address 72: Door, Rear Right
End----(Elapsed Time: 01:42, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
That's definitely not an NAR model.
See the 'Z' in position 9?
WVGZZZ7PZGD003385
That's not allowed in modern NAR models; they must have a valid check-digit in that position.
In addition, you'll not see the 'ZZZ' in positions 4-6 on NAR models either.
Fredrick Awuor
Kenya
C?ID=309834
WVGZZZ7PZGD003385
thanks for the swift reply UWE
