Starting problem A4 2009 3.0 tdi Quattro
Tompanys
Pirate
Sweden
Thanks for letting me join.
I have a problem with my A4 3.0tdi I won't start or it is very close but stalls, it will run if i spray brake clean in to airbox.
Look at this two videos and say what you think,
as you see in one of the film it says that esp fault and parking brake fault and it set fault code on sens]or g28 crankshaft but I have change it.
Tompanys
Pirate
Sweden
Ok I will do that tomorrow, isn't anyone have any idea?
The strangest thing if I crank it I get fuel pressure but when I try to jumpstart it with another car pulling I don't get any fuel pressure from the hpfp?
Viking
C?ID=151455
A full autoscan is required even to make a guess. Knowing how your car is configured is the basic starting point here.
Tompanys
Pirate
Sweden
One more thing the fault codes esp, parking brake and crankshaft sensor G28 are only setting when the the rpm is a round 800Rpm and higher but I still have rpm signal to rev gauge.
A full autoscan is coming tomorrow night.
Thanks from Sweden.
Tompanys
Pirate
Sweden
[b]Auto-Scan Removed.  Data from a clone/pirate copy of VCDS is not welcome here.[/b]
