- Jun 14, 2017
- 24
- 14
- Netherlands
- C?ID=315283
Hi,
im trying to deactivate the crashmode of the steering assist (module 44) on a brand new Seat Ibiza 6F. Car was crashed and repaired, i only need to fix the steering assist so i can do calibration.
I tried the same procedure as EPS_TRW_Alow (but with different security access: 19249).
I tried it with Odis, VCP and VCDS but all the systems say "pre conditions not met". What are those conditions?
Wednesday,13,June,2018,16:25:27:55204
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: VSSZZZKJZJRxxxxx License Plate: SEAT6F
Mileage: 1372km-852mi Repair Order:
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 44 47 55 5F CA
VIN: VSSZZZKJZJRxxxxx Mileage: 1372km-852miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHZJ) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 BQ HW: 04C 907 309 AT
Component: R3 1.0l TFS H21 5155
Revision: WXH21---
Coding: 01190032234405081000
Shop #: WSC 00049 770 00137
ASAM Dataset: EV_ECM10TFS01104C906026BQ 002001
ROD: EV_ECM10TFS01104C906026BF.rod
VCID: 71BE24EB912460CF8E9-8024
CAN Converter 01:
21472 - Databus
U1122 00 [039] - Implausible Message
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:49
Engine speed: 0.00 /min
Coolant temperature: 59 °C
Intake air temperature: 27 °C
Voltage terminal 30: 11.897 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 7
Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 0
Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 1
Cruise control system: temporary deactivation-Bits 0-7: 255
Cruise control switch actuation-Bits 0-7: 49
Cruise control switch actuation-Bits 0-7: 129
17165 - Databus
U1123 00 [039] - Received Error Message
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:49
U0428 00 [039] - -
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:49
Outside air temperature: 21 °C
Absolute intake pressure: 101 kPa abs
Engine torque: 0.0 Nm
Fuel: tank fill level: 5.0 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Engine operating condition: Idling
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 2Q0 614 517 AA HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0222
Serial number: 08506823180106
Coding: 510D4C5735428AB532FDAC1E24DF42A649124D26224A242444541254452442659248B26444522424222A482AA249D6427D926B42BE
Shop #: WSC 00049 770 00140
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0.rod
VCID: 6D86389B8D1C842FAA1-8038
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:56
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0466522578
Coding: 112E0E0603
Shop #: WSC 00049 770 00020
VCID: 3E24CFD790FACFB743B-806A
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 6F0 907 044 A HW: 6F0 907 044 A
Component: Climatronic H03 0401
Coding: 0100000108000100110008000240010D0000000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004017
ROD: EV_ACClimaBHBMQBA0.rod
VCID: 251600BB156C7C6F221-8070
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 090 HW: 2Q0 937 090
Component: BCM A0 Std+ H97 0915
Serial number: 07001801500442
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_104_VW27.rod
VCID: 6FBA22938710763F98D-803A
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S7Y18M01D17H15M04S18
Coding: 00194D
Drivers Door Control Module:
Subsystem 2 - Part No SW: 2Q1 959 881 B HW: 2Q1 959 881 B
Component: FHSG_DRV 001 0001
Serial number: 00000000000018215488
Coding: 13000F
Subsystem 3 - Part No SW: 2Q1 959 882 D HW: 2Q1 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000018299897
Coding: 09000F
Subsystem 4 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY173381ZKD
Serial number: 00000000000039711994
Subsystem 6 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000018665854
Subsystem 7 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000018331723
Coding: 190000
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418618016
Coding: 0471151001
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 4BC29603D3486A1FD45-801E
13679372 - Databus
[Steuergerät für Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:17:01
13637426 - Databus
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:17:01
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 2A00608140FF8728749C8145604085
7 Faults Found:
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:58
Voltage terminal 15: 11.7 V
Control Module temperature: 43 °C
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:18:15
Control Module temperature: 45 °C
2062 - Databus
[FAULT_MAINSWITCH_FAIL]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:58
1116 - Databus
[FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:58
Voltage terminal 15: 11.8 V
Longitudinal_acceleration_vehicle_reference: -0.06 m/s²
2052 - Databus
[FAULT_ALP_STEERINGWHEEL_FAIL]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:58
2049 - Databus
[FAULT_ALP_DT_STEERING_WHEEL_FAIL]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:58
2127 - Databus
[FAULT_OP_FAIL]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:58
Address 14: Susp. Elect. (J250) Labels:. 6C0-907-359.clb
Part No SW: 6C0 907 359 HW: 6C0 907 359
Component: DAEMPFUNGS-SG H04 0007
Serial number: 27111702000249
Coding: 81
ASAM Dataset: EV_SwitcDampeContiTemic 001004
ROD: EV_SwitcDampeContiTemic.rod
VCID: 6A8C3387BCF29317CF3-803E
Address 15: Airbags (J234) Labels:* None
Part No SW: 5QF 959 655 L HW: 5QF 959 655 L
Component: Airbag VW22 006 0520
Revision: -------- Serial number: 003XNPEY3ES5
Coding: 88CCC0C000000000585400CF000C00000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
ROD: EV_AirbaVW22TS6VW48X.rod
VCID: 5F9A525377B0E6BF28D-800A
Subsystem 1 - Part No SW: ----------- HW: 454 001 001 18
Serial number: 357000000000FBD0CB2-
Subsystem 2 - Part No SW: ----------- HW: 454 001 001 18
Serial number: 35800000000520FCCB2W
Subsystem 3 - Part No SW: ----------- HW: 454 801 101 18
Serial number: 351000FA803130000006
Subsystem 4 - Part No SW: ----------- HW: 454 800 501 18
Serial number: 352005C29D512000000G
Subsystem 5 - Part No SW: ----------- HW: 454 801 412 17
Component: FrontSensor_D 307 0189
Serial number: 3550018AFA812000000P
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:57
Part No SW: 5Q0 953 569 A HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: -------- Serial number: 20180301500093
Coding: 6E10
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C20C5DF86E6DDA76DF-8068
226843 - Turn Signal Switch
B1144 13 [009] - Open Circuit
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:17:00
Ubat 30 Voltage: 12.00 V
Ignition State: On
Terminal 15: 11.20 V
A/D #1: 97.65 %
A/D #2: 35.69 %
A/D #3: 0.00 %
B1149 13 [009] - Open Circuit
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:17:00
Ignition State: On
A/D #1: 97.65 %
A/D #2: 50.59 %
A/D #3: 0.00 %
229235 - Switch for ADR Distance Selection
B1155 07 [009] - Mechanical Failure
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:17:00
Ignition State: On
A/D #1: 65.49 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 6F0 920 740 HW: 6F0 920 740
Component: KOMBI 206 0450
Coding: 04A401103D800008018862011000000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001020
ROD: EV_DashBoardVDDMQBA0_SE27.rod
VCID: 629C5BA744C2CB57073-8036
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007323347
Coding: 030100046F085700E9000258880F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_SE27.rod
VCID: 3828D9CFB2DEF187897-806C
Subsystem 2 - Part No SW: 5F0 959 537 E HW: 5F0 959 537 E
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G0212121217
Coding: 002000
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 1003BA2F
8526363 - Unknown Error Code
B189C F0 [009] - Unknown Error Elaboration
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:57
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 2Q0 905 861 HW: 2Q0 905 861
Component: ELV-MQBB H06 0020
Serial number: 17000252591005
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0.rod
VCID: 70B821EF9A2E69C7817-8024
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q1 909 144 J HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 610 6030
Serial number: 0317585CB4J0202
Coding: 00000000000000010101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
VCID: 392EDCCB89D4E88F769-806C
15788544 - Crash Shut-Down Activated
P1609 00 [137] - -
[DEM_FRONT_CRASH_FAULT]
Mileage: 1372 km
Date: 2018.06.13
Time: 15:21:48
Engine speed: 959 /min
Terminal 15 status: On
Voltage terminal 30: 13.68 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 215 °C
Steering assistance: engine output: 100 %
Engine angle: 65535 °
Electric motor speed: 45535 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.0 Nm
Part No SW: 5Q6 035 456 HW: 5Q6 035 456
Component: KonzernAmp 8K H01 2426
Revision: -------- Serial number: A1117A00040379
Coding: 0202000000AAAA00000000000000
ASAM Dataset: EV_AMPCAN8C1PASE 001015
ROD: EV_AMPCAN8C1PASE_VW27.rod
VCID: 73B22EE3EB3852DF7C5-8026
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0070
Coding: 078A000001200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DEB42BE104B04F3E9-8014
13705992 - Databus
[Fehlerwert im Signal LWI_Lenkradwinkel]
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:21:24
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 858 B HW: 5QA 035 858 B
Component: MU-S-ND-ER H41 0468
Serial number: SEZAZ2U0227551
Coding: 047200010000000011110103008808232F0101D401200500C6
ASAM Dataset: EV_MUStd4CTSAT 001001
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 46D4A737C82A97770BB-8012
Subsystem 1 - Part No SW: 6F0 919 605 A HW: 6F0 919 605 A
Component: ABT_Std-2_Nav H50 8130
Serial number: SEZ6ZHV0164009
Subsystem 2 - Part No SW: 6P0 919 866 AB HW: -----------
Component: ECE1 2018 --- 0915
0008 - Connection between Antenna Amp 2 for Radio and Antenna
B1273 13 [009] - Open Circuit
Reset counter: 111
Mileage: 1372 km
Date: 2018.06.13
Time: 15:16:56
Voltage terminal 30: 11.8 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 408040527001
ROD: EV_SunRoofCONTIAU736.rod
VCID: 3B22C6C383E8DA9F645-806E
End----------(Elapsed Time: 01:30, VBatt start/end: 14.4V/14.4V)-----------
