- Feb 26, 2014
- 104
- 122
- Budapest, Hungary
- C?ID=59799
Hi,
A friend of mine has a 8R chassis Q5, Modelyear 2010, and he wants to replace the headligts on his car, to a newer, MY2013 Q5 headlights.
The only problem is, that as the MY2010 Q5 has a separate Address 55 for the AFL functions, the MY2013 Q5 has this function integrated into Address 09 - BCM.
So far, he replaced the headlights, 09-BCM (J519), and the CAN Gateway (J533). Also been to the dealership, programmed the component protection, but they were unable to help him any further.
They told him, that this is cannot be done officially, because of the ODIS / SVM always complaining this BCM is not belongs to the selected VIN / Modelyear.
Here is the autoscan done with VCDS:
My question is the following:
Is there any special procedure on how to code the power output stages?
In VCDS, the headlight slaves are cannot be coded directly.
We figured out, that the basic settings of the headlight should be performed in Channel 11, but all we see here is "Wait...... ", then the "Not available" message comes up.
Could you look into this?
Thanks in advance!
Steve
Wednesday,12,March,2014,16:31:40:21752
VCDS Version: 14.2.2.2
Data version: 20140307
VIN: WAUZZZ8RX9A004484 License Plate: Q5_MY2010
Mileage: 105820km-65753mi Repair Order:
Chassis Type: 8R (8R0)
Scan: 01 02 03 05 08 09 0E 10 13 14 15 16 17 19 1B 20 42 46 52 53
56 5F 62 69 6C 6D 72
VIN: WAUZZZ8RX9A004484 Mileage: 105820km/65753miles
0E-Media Player 1 -- Status: Malfunction 0010
1B-Active Steering -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CCWA) Labels: 059-907-401-CAP.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0008
Revision: 15H01---
Coding: 0121002C240F0A20
Shop #: WSC 00870 233 00000
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 397386B3B80D6AFC8A-806C
4814 - System Voltage
P0562 00 [032] - Too Low
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:35
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 AD HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H04 0002
Revision: --H04--- Serial number: 0000000007
Shop #: WSC 00870 233 179043
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 7DFB52A3ECA596DCE6-8028
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 C HW: 8R0 907 379 C
Component: ESP8 quattro H06 0230
Coding: 0FFD00
Shop #: WSC 00023 123 00848
VCID: 4085EB57D3D73B34CD-8015
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AQ HW: 8K0 907 064 AQ
Component: BCM2 1.1 H80 0145
Coding: 050500
Shop #: WSC 06335 000 00000
VCID: 7F07A8ABEEA984CCF4-802A
Subsystem 1 - Part No SW: 8T0 959 754 K HW: 8T0 959 754 K
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:50:09
Fault Status: 00101101
Reset counter: 44
Mileage: 105782 km
Date: 2014.03.12
Time: 09:30:02
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:06:36
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:53
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0102.10.080100
Coding: 36110000
VCID: 72E1719FADFBD9A48B-8027
01230 - Left Footwell Vent Temperature Sensor (G261)
Fault Status: 00101010
Reset counter: 42
Mileage: 105782 km
Date: 2014.03.12
Time: 02:06:32
Temperature: 19.0°C
Voltage: 12.40 V
Reset counter: 42
Mileage: 105782 km
Date: 2014.03.12
Time: 02:11:13
Temperature: 19.0°C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DL HW: 8K0 907 063 DL
Component: BCM1 1.0 H16 0103
Revision: 10016001 Serial number: 00000671563402
Coding: 26081015863CAF311F01000300001D0D0F9CE74802010141000000000000070200040000000000
VCID: 7CFD5FA7FFBF9FD4D1-8029
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 080924 H10 0041
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0080
Subsystem 4 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
7 Faults Found:
Fault Status: 01100101
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:43:23
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:43:23
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:43:23
03679 - Switch for Night-Vision System
Fault Status: 01101000
Reset counter: 4
Mileage: 105782 km
Date: 2014.03.12
Time: 02:44:22
03735 - Switch for Head-Up Display
Reset counter: 4
Mileage: 105782 km
Date: 2014.03.12
Time: 02:44:22
01800 - Light Switch (E1)
Reset counter: 44
Mileage: 105782 km
Date: 2014.03.12
Time: 08:20:27
03280 - Switch Position of Light-Switch Knob
Reset counter: 44
Mileage: 105782 km
Date: 2014.03.12
Time: 08:32:14
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H47 0050
Revision: 00000011
VCID: 21434ED3389D123CA2-8074
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:34
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52830827609168
Coding: 310105
VCID: 3B7F9CBBBA3158EC98-806E
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:39
Temperature: 34.0°C
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:06:49
Temperature: 34.0°C
00457 - Control Module for Network (J519)
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:06:21
Temperature: 77.0°C
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 HW: 8R0 907 561
Component: ACC2 H01 0020
Coding: 0079B9
Shop #: WSC 38143 000 1048576
VCID: F6E9CD8F4193458427-80A3
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 A HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0051
Revision: 00000000 Serial number: 30090807910002
Coding: 070181
Shop #: WSC 32310 133 80747
VCID: 387583B78B0773F475-806D
Reset counter: 42
Mileage: 105782 km
Date: 2014.03.12
Time: 01:57:46
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
Component: AirbagVW-AU10 H02 0310
Serial number: 003E8D0240NO
Coding: 30343131313030303030554A304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 001001
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 438FE45BCAC1202CD0-8016
Serial number: 6334MSME40330730-
Serial number: 6344MSME422262440
Serial number: 6352QSME471018020
Serial number: 6362QSME480E003CJ
Serial number: 63732SME32171D16X
Crash sensor for front airbag; passenger side:
Serial number: 63832SME29103320K
13635840 - Supply voltage
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 14:40:38
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HJ20006J
Coding: 00001F
VCID: 3E7995AFA9234DC4BF-806B
Component: E221 - MFL H02 0003
Reset counter: 44
Mileage: 105782 km
Date: 2014.03.12
Time: 09:29:57
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 J HW: 8R0 920 930 J
Component: KOMBIINSTR. H07 0224
Revision: 00100000 Serial number: 9EW55W9A8
Coding: 0F0E220037000008000000
Shop #: WSC 00813 823 12356
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z13C1906AE
Coding: 80C303FF00
VCID: 4C9DCF67EF9FEF5421-8019
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0100
03175 - Invalid Data Set
Reset counter: 4
Mileage: 105823 km
Date: 2014.03.12
Time: 15:46:01
Bin. Bits: 00000
Voltage: 12.60 V
Count: 7
Bin. Bits: 00001001 00000000
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 42
Mileage: 105782 km
Date: 2014.03.12
Time: 05:00:01
Reset counter: 43
Mileage: 105782 km
Date: 2014.03.12
Time: 08:00:36
Bin. Bits: 00000
Voltage: 12.30 V
Count: 7
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 C HW: 8K0 907 144 C
Component: DYNAMIKLENK. H06 0500
Revision: 50001003 Serial number: --------------
Coding: 020000
Shop #: WSC 06334 000 00000
VCID: 2F67B8EB7E49B44C24-807A
Reset counter: 42
Mileage: 105782 km
Date: 2014.03.12
Time: 01:57:44
Count: 55
Count: 1
Hex Value: 0x0274
Hex Value: 0x7409
Hex Value: 0xFFFF
Hex Value: 0x250C
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 C HW: 8K0 857 511 A
Component: FLA H04 0003
Revision: AA001002
Coding: 02012064747464545425363E
VCID: 3163BE93687DA2BC32-8064
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:43
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000007704663
Coding: 011D12205000440004
VCID: 4183EE53D8DD323CC2-8014
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:50
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0114790816
Coding: 013A0E2020393495052005
Shop #: WSC 06342 000 00000
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 4 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Reset counter: 44
Mileage: 105782 km
Date: 2014.03.12
Time: 09:30:02
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Fault Status: 00101011
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 13:48:15
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000007700382
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000238232
Part No SW: 4F0 035 056 K HW: 4F0 035 056
Component: Radio U STD H43 0074
Revision: AB001007 Serial number: 342JV087515380
Coding: 010003020100000001
VCID: 285553F75BA7E374E5-807D
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 01:04:40
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 K HW: 8T1 035 666
Component: H-BN-EU H60 0167
Revision: -------- Serial number: 321JV087533176
Coding: 010100060305A9EF25000F0E000000030001
VCID: 4281E15FDDDB2924DB-8017
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Reset counter: 42
Mileage: 105782 km
Date: 2014.03.12
Time: 02:28:21
Bin. Bits: 00000100 00000000
Reset counter: 43
Mileage: 105782 km
Date: 2014.03.12
Time: 01:04:40
01043 - Control Module; Incorrect Software Version
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 01:04:39
Bin. Bits: 00000000 10000000
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000007827244
Coding: 010C12204000240004
VCID: 438FE45BC2C1202CD0-8016
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:07:40
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: Anhaenger H07 0100
Revision: 1G001001 Serial number: 00000137350694
Coding: 0109080000000000
Shop #: WSC 25397 000 00000
VCID: 356B8A839C158E9C6E-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J89A025
Coding: 1031010
VCID: F3EFF49B92E150AC00-80A6
03006 - Back-up Camera System not calibrated
Reset counter: 2
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:06:53
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 A HW: 8R0 827 851
Component: J605 Master H24 0240
Revision: -------- Serial number: 8R0827851
VCID: 3A7199BFB50B61E483-806F
Subsystem 1 - Part No SW: 8R0 827 852 A HW: 8R0 827 852
Component: J756 Slave H24 0240
16347 - Control Module - EEPROM Error
014 - Defective
Fault Status: 01101110
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 01:04:38
Reset counter: 43
Mileage: 105803 km
Date: 2014.03.12
Time: 15:08:03
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000007826444
End ---------------------------------------------------------------------
Thanks in advance!
Steve
Coding: 01DD13
Coding: 024D25
H05 0012
H05 0012
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:43:23
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:43:23
Reset counter: 2
Mileage: 105782 km
Date: 2014.03.12
Time: 02:43:23
