9w7 and steering controls question (2010 Touareg)
ZimZimmma
Canada
C?ID=319353
so I have retrofitted an RNS510 and its working perfectly. My 2010 Touareg had the 9w3 Bluetooth module which I also upgraded to the 9w7
everything seems to be working fine except the steering controls don't work with the 9w7.
I have heard that the steering wheel control module might need the software upgraded for it to work with the 9w7..can VCDS do this?
or is there some other area I should be focusing on?
here is the module info:
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 G
Component: J527 3601
Coding: 0010211
Shop #: WSC 31414 790 00001
VCID: 43D3B1A6A7D1DBCF068-8016
any help is greatly appreciated
thank you
VCDS cannot do control module software updates.
Here's a 2009 T'Reg with a factory RNS510:
   Part No: 7L6 953 549 F
   Coding: 0010011
It looks to have the same version 3601 software in it.
Here's the BT module from it (also factory):
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 A    HW: 1Z0 035 729 A
   Component: FSE_2P8x        H34 0150
   Revision: 00000000    Serial number: 00000005016720
   Coding: 0012077
   VCID: 36689BA03835
Please post an Auto-Scan from yours for context.
ZimZimmma
Canada
C?ID=319353
Tuesday,12,June,2018,21:09:18:16445
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
VIN:   License Plate:
Mileage: 176300km-109547mi   Repair Order:
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 22 36 37 46 47 55 56 68 69
          6D 6E 76 77
VIN:  Mileage: 176300km-109547miles
37-Navigation -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
68-Wiper Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: Sporadic communication error 1000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
   Component: 3.0TDI EDC17G004AG  0090
   Revision: 33H02---    Serial number: VWX3Z0J2911891
   Coding: 0421002A590F0968
   VCID: 3C21CA5ADA7FA4376E0-5160
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 LD    HW: 09D 927 750 LD
   Component: AL 750 6A           1667
   Revision: 00H89000    Serial number:
   Coding: 0004984
   VCID: 7BA309469FF1630F27A-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0004354
   VCID: 46D5A8B294B3EEE7084-5184
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22072    Serial number: VWX3Z0J2911891
   Coding: 0000232
   VCID: 313FEB6E0D6D595FCD6-8064
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AL
   Component: CLIMAtronic R/L     4537
   Coding: 0003030
   VCID: 7AAD0C42909B5A073CC-802E
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2004
   Revision: -0004---    Serial number: --------------
   Coding: 230008002F00BC000000000000000000
   VCID: 00597EAAF64700D7728-8054
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655 A    HW: 7L0 959 655 A
   Component: J234__0B VW8T       0270
   Revision: 92013027    Serial number: 003C6001FTK0
   Coding: 0012354
   VCID: 3B23C946DF21A30F67A-806E
   Coding: 0010211
   VCID: 43D3B1A6A7D1DBCF2FA-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 876 B    HW: 7L6 920 876 B
   Component: J285 KOMBI-INST.    9833
   Revision: KHH05V44
   Coding: 0007301
   Shop #: WSC 39254 002 104857
   VCID: 3B23C946DF61A30F67A-806E
                    Reset counter: 199
                    Mileage: 165666 km
                    Date: 2018.01.17
                    Time: 21:11:23
                    Fault Frequency: 95
                    Reset counter: 238
                    Mileage: 165807 km
                    Date: 2018.01.21
                    Time: 17:53:54
01304 - Radio
                    Fault Frequency: 8
                    Reset counter: 219
                    Mileage: 174923 km
                    Date: 2018.05.17
                    Time: 18:57:23
                    Fault Frequency: 8
                    Reset counter: 219
                    Mileage: 174923 km
                    Date: 2018.05.17
                    Time: 18:57:23
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 144
                    Mileage: 174923 km
                    Date: 2018.05.17
                    Time: 19:31:54
                    Reset counter: 238
                    Mileage: 175053 km
                    Date: 2018.05.22
                    Time: 19:16:54
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 876 B
   Component: J533  GW-K-CAN TP20 9833
   Coding: 77E2EF9BCB066002
   VCID: 70B92E6AC6A71057828-8024
7 Faults Found:
                    Reset counter: 199
                    Mileage: 165666 km
                    Date: 2018.01.17
                    Time: 21:11:23
                    Fault Frequency: 95
                    Reset counter: 238
                    Mileage: 165807 km
                    Date: 2018.01.21
                    Time: 17:53:54
02786 - Module 2 for Hatch / Trunk Lid (J756)
                    Reset counter: 203
                    Mileage: 175462 km
                    Date: 2018.05.29
                    Time: 07:18:28
01304 - Radio
                    Fault Frequency: 8
                    Reset counter: 219
                    Mileage: 174923 km
                    Date: 2018.05.17
                    Time: 18:57:23
                    Fault Frequency: 8
                    Reset counter: 219
                    Mileage: 174923 km
                    Date: 2018.05.17
                    Time: 18:57:23
                    Reset counter: 144
                    Mileage: 174923 km
                    Date: 2018.05.17
                    Time: 19:31:54
                    Reset counter: 238
                    Mileage: 175053 km
                    Date: 2018.05.22
                    Time: 19:16:54
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1439802T1EHZ02
   VCID: 46D5A8B294A3EEE7084-8012
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 015F7BAEFD1D09DF7D6-5160
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77AB1576A3D9476F432-5184
   Part No SW: 7L6 035 684 D    HW: 7L6 035 684 B
   Component: RNS-MID       H01 1142
   Revision: AB001001    Serial number: VWZ6Z7J9071168
   Coding: 060100020100002500
   Shop #: WSC 10085 003 1048576
   VCID: 372BD576EF49876F832-8062
00857 - CD Changer Unit (R41)
                    Fault Frequency: 143
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:19
00856 - Radio Antenna
                    Fault Status: 00101011
                    Fault Frequency: 22
                    Reset counter: 226
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:29
                    Fault Frequency: 66
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:29
02633 - Antenna for Satellite Tuner
                    Fault Frequency: 66
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:29
            000 -  -
                    Fault Frequency: 37
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.07
                    Time: 07:11:52
01523 - Microphone for Telephone (R38)
                    Fault Frequency: 36
                    Reset counter: 199
                    Mileage: 175993 km
                    Date: 2018.06.06
                    Time: 21:45:28
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   VCID: 40D9BEAAB697C0D7328-4B1E
   Subsystem 1 - Part No: 7L0 959 701 N
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 N
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
   Part No SW: 7L6 035 456 B    HW: 7L6 035 456 B
   Component: 08K Audioverst.     0008
   Revision: 00006000    Serial number: 00000008156215
   VCID: 323DE462082B6247B4C-8066
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0143
   Coding: 1290435
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000019
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:19
                    Fault Frequency: 22
                    Reset counter: 226
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:29
                    Fault Frequency: 66
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:29
                    Fault Frequency: 66
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.06
                    Time: 21:45:29
            000 -  -
                    Fault Frequency: 37
                    Reset counter: 199
                    Mileage: 175992 km
                    Date: 2018.06.07
                    Time: 07:11:52
                    Fault Frequency: 36
                    Reset counter: 199
                    Mileage: 175993 km
                    Date: 2018.06.06
                    Time: 21:45:28
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392FD34ED55D911F756-806C
   Component: RLS     130210 054  0403
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A008002    Serial number: 00000126144967
   Coding: 0016386
   VCID: 3FDBBD56CB39BF2F4B2-806A
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
   Component: J605  HECKKLAPPE    1310
   Revision: --H05---    Serial number: --------051983
   Coding: 0122110
   VCID: 3A2DCC42D01B9A077CC-806E
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
   Component: J702  Dachdisplay   0401
   Revision: 1030006S    Serial number: 00000000155342
   VCID: 79AF134E95DD511F356-802C
   Part No: 7L0 919 283 F
   Component: 0L Einparkhilfe     1108
   VCID: 392FD34ED51D911F756-806C
ZimZimmma
Canada
C?ID=319353
still have not been able to get the steering wheel controls to work with the 9w7.
From the steering wheel i can control the volume and change stations but thats it.
But if i put the 9w3 back in, steering wheel controls work with the BT module, put the 9w7 in and they dont work.
I cannot use the voice control button (star) and the phone button doesn't do anything.
i also cannot get VCDS to find the 9w7 in Address 77: Telephone
anyone have ideas? im at a loss.
