U1121 00 [008] - Missing Message from Address 46: Central Conv. (J393) on a A5 2018
o33err
C?ID=317589
While I wait for Audi to look at my car for another error relating to the Auto Transmission that has occurred only once, I notice that there is another error that keeps coming back and is raised quite often. What might that be about?
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Full Auto Scan attached.
Monday,11,June,2018,17:45:59:60553
VCDS Version: 18.5.2.0 (x64)  HEX-V2 CB: 0.4422.4
Data version: 20180518 DS291.0
VIN: WAUZZZF57JA102862   License Plate:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 3C 42 44 46 52 5F 6C 6D
          81 A5 BB BC CF D6 D7
VIN: WAUZZZF57JA102862   Mileage: 681km-423miles
Address 01: Engine (J623-CVNA)       Labels: None
   Part No SW: 04E 906 022 B    HW: 04E 907 309 R
   Component: R4 1.4l TFS   H22 4032
   Revision: 44H22000
   Coding: 022500324324150834380000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM14TFS01104E906022B 002002
   ROD: EV_ECM14TFS011_AU49.rod
   VCID: 1E66D6AE30391D67947-804A
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 8W2 927 155 AD    HW: 0CJ 927 156
   Component: 0CK 14TFSIRdW H05 0002
   Revision: --H05---    Serial number: 0000000610
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 035087DABB9BD08F9B9-8056
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180085001448
20829 - Gear Selector 2
          P187B 00 [096] - Engagement not successful
                    Mileage: 490 km
                    Date: 2018.06.08
                    Time: 21:35:51
                    Engine speed: 929 /min
                    Driving position: d
                    Transmission fluid temperature: 33 °C
                    Voltage terminal 30: 12.9 V
                    Engine torque: 0 Nm
                    selected gear: 1
                    Ctrl. mod.: operating condition: regular operation
                    Auxiliary pump for transmission: requesting function: Fill hydraulic press. accum.
                    Auxiliary hydraulic pump for transmission oil: current: 5 A
                    Oil pressure reservoir: pressure: 16.5 bar
                    Pressure of clutch 1: actual value: 2.9 bar
                    Pressure of clutch 2: actual value: 0.0 bar
                    Clutch status: Creeping
                    Unlearning counter according OBD: 28
                    Occurrence_counter_over_length_of_life: 1
                    Gear selector dist. sensor 2: position: -6.2 mm
                    Sol. valve 2: act. current: 47.7 mA
                    Pressure control valve 3: act. current: 1317.0 mA
                    Pressure control valve 3: spec. current: 1315.2 mA
                    Gear R: calibrated end position: -9.46 mm
                    Gear 2: calibrated end position: 9.63 mm
                    Gear_selector_2_state: Einlegen (Pos)
   Part No SW: 8W0 907 379 Q    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0775
   Coding: 04AA049A10A20A9811A64897007F5292F5B5DA202008508812004A49AFAD5B
   Shop #: WSC 06334 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 53F0779A0B7B800F6B9-8006
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0210
   Coding: 140800095544040D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D244C6FE1517B7E23-8010
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002293268
   Serial number: A951112900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143E11800CD050551181BAC80F9130B3108000000000000000060001A810A4501A222B70A
   VCID: 025E82DEA481D98790F-8056
   Subsystem 1 - Part No SW: 8W6 955 119 A    HW: 8W6 955 119 A
   Component: 494 RL 180215  036 0471
   Serial number: 00000001802130304554
   Coding: 5FC7F7
   Serial number: 21309223X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 30 01 2018  01281684
   Serial number: GX1CE124011823810285
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00753578
   Subsystem 6 - Part No SW: 8W0 925 301 BF    HW: 8W0 925 301 BF
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2817000311607005
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00EWT7B
   Coding: AAFCF0C00C800000585400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4CC26CE6D645DFF72A3-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705F0087S01535
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706G0088S00598
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 060 304 18
   Serial number: 3577Y00C529200B3D35Z
   Subsystem 4 - Part No SW: -----------    HW: 442 060 304 18
   Serial number: 3587Y00C92674B22015W
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 003 18
   Serial number: 3517700AF29B22B430FL
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 103 18
   Serial number: 35277009D2AD016400FB
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 003 18
   Serial number: 3557500AF2A9BCA4F3FC
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 003 18
   Serial number: 3567500AF2A9BCA6A2D7
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 903 18
   Serial number: 2307500A129C70D432F9
   Subsystem 10 - Part No SW: -----------    HW: 442 430 404 18
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00C32730691136
   Subsystem 11 - Part No SW: -----------    HW: 442 430 404 18
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00C32730692E056
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B6EE0EF849F527AC7-8022
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0373
   Coding: 25A440D6289806000120E9601000000000000000
   VCID: 43D047DAFB1B108FDB9-8016
   Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
   Component: Gateway       H43 0123
   Revision: 7A000002    Serial number: 0287A529218405
   Coding: 03010001000086402607000000590012CC180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   ROD: EV_GatewCONTIAU736.rod
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180403024243 20301
   Serial number: 7670497204
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77A8E30AFF438C2FB71-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000103976016
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323E121E54A1A90740F-8066
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 4E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 36362E0EB8C9B5276C7-8062
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0129
   Serial number: 0000314838229
   Coding: 001DCA6250010080000014B2
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09880380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DE42DEE4011987D0F-8016
   Part No SW: 8W0 907 064 EB    HW: 8W0 907 064 DB
   Component: BCM2 MLBevo   025 0387
   Coding: 013500002FB100406309A0000600080231020010804B06502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 005A88D6AA8DCB9786B-8054
   Ignition key:
   Subsystem 1 - Part No SW: 4M0 959 754 T    HW: 4M0 959 754 T
   Component: ID-Geber  H40 0105
   Serial number: 3618000057134003
   Serial number: 000000000ZY1805710LF
   Serial number: 00000000000010243443
65896 - Databus
                    Fault Frequency: 174
                    Reset counter: 82
                    Mileage: 269 km
                    Date: 2018.06.01
                    Time: 20:54:50
                    Supply voltages-Supply voltage: Terminal 30: 12.541 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.541 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.514 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000314997015
   Coding: 001DCA225C010080000014B0
   ROD: EV_DCU2PasseSideMAXHCONT.rod
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035 B    HW: 8W5 035 035
   Component: MU-P-LND-EU   034 1177
   Serial number: A829D0JB063599
   Coding: 01940301FF0A000053111101000A00332F000DE701700100DE
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00131101700820387
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK113031800040373
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG064006
   Coding: 02940301BE0FA10008404084
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
   VCID: 35342902A5CFBE3F65D-8060
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31874554200000
   Coding: 0610
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 48CA50F6C23D33D70EB-801C
   Part No SW: 8W2 713 041 G    HW: 8W2 713 041 J
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18040346686746
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 382A2036B2DD43577EB-806C
   Part No SW: 8W6 907 217 A    HW: 8W6 907 217 A
   Component: BVS           H16 0050
   Coding: 0404090300000401024023A2C50000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736.rod
   VCID: 40DA48D6EA0D0B97C6B-8014
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0129
   Serial number: 0000315434372
   Coding: 000DC82200010080000010A0
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 45D459C2F52F2EBFF5D-8010
   Component: TSG HBFS      005 0129
   Serial number: 0000315434715
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 4E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 3330171AABBBA00F4B9-8066
   VCID: 1768C38ADF036C2F571-8042
End----------(Elapsed Time: 01:52, VBatt start/end: 12.3V/12.2V)-----------
46 is is complaing that it's not receiving some message that it expects from 08.
Have you made any changes to 46 or 08? If not, then only Audi and their suppliers would have the answer.
o33err
C?ID=317589
Absolutely no changes made. The car is exactly as it came from the factory. This error has been on the car since I got it. And keeps coming back each time I clear it. Now that I am not planning to clear it again, what do I tell Audi, so that they look into this for me.
Good question!
If the fault was in the HVAC, I'd give them some complaint about unexpected temperature fluctuations or something like that. But I'm really not sure what kind of complaint to to conjure up that would make them investigate that fault in 46.
TBH, if it were my car, a spurious "missing message" fault code is not something that would upset me very much if there were no functional problems associated with it.
o33err
C?ID=317589
All the scans for 2018 A5/S5 cars I have seen to date appear to have this error. So clearly it's a non essential message that is missing, and it's causing no perceived issue.
o33err
C?ID=317589
Does anyone have any explanation for this error on new cars?
o33err
C?ID=317589
Any clue, what might be causing this error?
A software bug in one of the modules? Possibly a timing problem, such has too short a wait for the other module to wake/boot up before reporting it MIA?
One problem with people getting scan tools is that it can make them all OCD about having a car that's free of fault codes, which may never happen on some modern cars. Going as far back as model year 2000, there was a note in the repair manual for the then-current Passat about a fault code in the CAN gateway module that was to be ignored.
