Security Access Error "7F" whilst attempting to calibrate back up camera Audi A3 8V
Hi, my name is Andy and I've been using VCDS on several different cars over the years originally with a HEX-CAN lead and have recently bought a later HEX-V2 lead from Gendan.
Anyway, I've come a bit unstuck with a backup / reversing camera retrofit on a 2017 Audi A3 8V.
The camera install has gone perfect and it's all coded and working perfectly (this is my own personal car) however I'm left with a single fault code for the camera calibration.
I've attempted to follow the calibration guide on the forums here but I can't get past the security access.
When I enter the code "22351" in Module 6C "Back-up cam" and click Do it!, I get the error message "Controller refused to send a seed! Error 7F:Service not supported in active session".
Now, I've tried several times with and without the engine running. Tried MMI resets etc.. Can't seem to get past this.
Does anyone know what exactly that error message is telling me and the normal cause?
I've popped up a few screenshots below and attached a scan. The databus fault message in the scan below is cleared, just the calibration message remains
Any ideas welcome and thanks for the forums.
Wednesday,30,May,2018,15:55:08:23725
VCDS Version: 18.2.1.2 (x64)
VIN: WAUZZZ8V2HA060110 License Plate:
Address 6C: Back-up Cam. Labels: 5Q0-980-556.clb
Control Module Part Number: 5Q0 980 556 B HW: 5Q0 980 556 B
Component and/or Version: RVC Compact H12 0231
Software Coding: 0273000100012003400040
Work Shop Code: WSC 86562 184 84156
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009 (AU37)
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
VCID: 3979F61CB8053F8C20-806C
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 208
Mileage: 33910 km
Date: 2018.05.30
Time: 15:52:37
passive
Thursday,31,May,2018,10:22:54:23725
Software Coding: 0273000182012201400040
Advanced Identification/FAZIT
Identification: PS9-001
Date: 24.11.17
Manufacturer number: 0906
Test stand number: 3692
Flash Status
Programming Attempts(application): 1/0/0
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Date: 12.09.20
Flash Tool Code(data): 12345 123 12345
Misc.
Hardware number: 5Q0 980 556 B
Workshop System Name: J772
Equipment/PR Code: 0000000000000000
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset Revision: 006009
VCDS Info:
Tuesday,05,June,2018,20:23:52:61867
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VCID: 392FD1DA79D6887F769-806C
B2010 00 [009] - -
Reset counter: 221
Mileage: 34360 km
Date: 2018.06.05
Time: 20:21:24
passive
13705478 - Databus
[message Parkhilfe_01 not received]
Reset counter: 221
Mileage: 34360 km
Date: 2018.06.05
Time: 20:21:25
passive
