0778 2006 Audi A6 vant Quattro 3.2
porschetech
C?ID=135483
I have retrofitted an heated steering wheel to my A6. I also changed the clock spring or steering angle sensor (G85) and combination switch with attached module. The module was already coded for the HSW and values for it register in MB's. I cannot, however, calibrate my steering angle sensor. My ABS control module appears to be coded and was not disturbed during the changeover. I have followed the instructions in the WIKI, to no avail. When I get to the place I am supposed to click on "on off start", segments are all reed and 3 & 4 say not available. I am attaching a scan for you. Any help will be appreciated.
Thanks,
Kurt
Friday,10,October,2014,17:10:10:52331
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: WAUKG74F06N018485   License Plate: BNT-1949
Mileage: 182100km-113151mi   Repair Order: 10/10/14A6
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 34 36 37 42 46 47 4F
          52 53 55 56 61 62 65 67 6D 72 76 77
VIN: WAUKG74F06N018485   Mileage: 182100km/113151miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0040
   Revision: --H15---    Serial number:
   Coding: 010D0106190F0520
   Shop #: WSC 98765 666 36911
   VCID: 2E5915CDB9DB2E6E391-807B
009220 - EVAP Leak Detection Pump Sense Circuit
               P2404 - 006 - Implausible Signal - Intermittent
                    Reset counter: 32
                    Mileage: 181999 km
                    Date: 2014.10.01
                    Time: 16:06:42
                    RPM: 1056 /min
                    Mass Air / Rev.: 98.1 mg/str
                    Temperature: 66.0°C
                        Idle
                    Voltage: 14.08 V
                    Speed: 33.0 km/h
005672 - Powertrain Data Bus
               P1628 - 009 - Missing Message from Steering Angle Sensor
                    Mileage: 182105 km
                    Date: 2014.10.10
                    Time: 15:27:41
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 87.0°C
                        Engine Off
                    Voltage: 12.44 V
               P1653 - 008 -
                    Mileage: 182105 km
                    Date: 2014.10.10
                    Time: 15:27:41
                    RPM: 672 /min
                    Mass Air / Rev.: 114.5 mg/str
                    Temperature: 87.0°C
                        Idle
                    Load: 18.0 %
   Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4025867
   Coding: 0000002
   Shop #: WSC 02335 785 00200
   VCID: 31630EB1A8E53196243-8064
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    (no units): 30.0
                    (no units): 24.0
                    Temperature: 55.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0016799
   VCID: 2D5B12C1B4DD557600B-8078
                    Reset counter: 234
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x001E
                    Hex Value: 0x4394
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0170
   Revision: 17040501    Serial number: 10600300135994
   Coding: 0000143
   Shop #: WSC 07109 444 65458
   VCID: E3CF34F92299530666F-80B6
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 KSG   H26 0080
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 731 B    HW: 4E0 035 729
   Component: Interfacebox    H43 1190
   Revision: 00000000    Serial number: 360DI057523065
   Coding: 0000003
   VCID: 2143FEF1F8058116B43-8074
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000143989
   Subsystem 3 - Serial number: 0120.04.050000000100010106ÿ
   Subsystem 4 - Serial number: 010106ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0150
   Revision: 00000026    Serial number: 00000030016936
   Coding: 0524582
   VCID: DBBF0C191AE96BC62EF-808E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   VCID: E6C92DEDD1AB262E811-80B3
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7158818
   VCID: 1B3FCC19DA69ABC66EF-804E
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No: 4E0 910 593 E
   VCID: 2953E6D180354956EC3-FFFF
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH29 0310
   Revision: 10H29000    Serial number: 00359D08CE4P
   Coding: 0013622
   Shop #: WSC 40233 444 83861
   VCID: 2649EDED912B662EC11-8073
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME084866531
   Subsystem 3 - Serial number: 6342CSME095138491
   Subsystem 4 - Serial number: 6351HSME07085324$
   Subsystem 5 - Serial number: 6361HSME07001029U
   Subsystem 6 - Serial number: 6371VSME071B5D21N
   Subsystem 7 - Serial number: 6381VSME066F0A6B
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H12 0040
   Coding: 0012241
   Shop #: WSC 02311 785 00200
   VCID: E5CB2AE12CAD2D3688B-80B0
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H15 0630
   Revision: 01000000    Serial number: 4PY52RW45
   Coding: 2161263
   Shop #: WSC 07109 444 999999
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 1200805428809A
   Coding: ECFE7BCD1B7906
   Shop #: WSC 07109 444 52498
   VCID: 2757E0E996217F26FA7-8072
                    Reset counter: 234
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
Address 34: Level Control        Labels: None
   Part No SW: 4F0 910 553     HW: 4F0 907 553
   Component: J197 LUFTFEDER  H15 0040
   Serial number: 006280004517
   Coding: 0000210
   VCID: E1C33EF138854116743-80B4
                    Reset counter: 234
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    Fault Status: 11101101
                    Reset counter: 234
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H44 1100
   Revision: 00000000    Serial number: 378DR057521094
   VCID: 387533954B9FE0DE63D-806D
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00-00000
   Coding: 0052971
   VCID: 2953E6D180354956EC3-807C
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H18 0130
   Revision: 01300018    Serial number: 01004042370000
   Coding: 7764669
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
   Component: DSP-High C6     H09 0140
   Revision: PROD_01     Serial number: 00000000782185
   Coding: 0000126
   VCID: 1C3DCF05DF67ACFE675-8049
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000000614
   Coding: 0002114
   VCID: DEB9050D09FB7EEE491-808B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00-00000
   Coding: 0052971
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: DDBB020104FD65F650B-8088
Address 55: Xenon Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000017
   Shop #: WSC 02331 785 00200
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H02 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
                    Fault Status: 11100100
                    Reset counter: 234
                    Mileage: 182104 km
                    Date: 2014.10.10
                    Time: 17:05:45
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394EX057543394
   Coding: 0000002
   VCID: 234FF4F9E2199306A6F-8076
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000028101
   Shop #: WSC 00477 384 00291
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  1504220025
   Coding: 344630393135313035452056413031353034323230303235
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0052778
   VCID: E9D326D1C0B50956AC3-80BC
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000900004252
   Coding: 0062221
   Shop #: WSC 07109 444 54528
   VCID: E0C53BF5338F481E7BD-80B5
   Part No SW: 4E0 910 754 J    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0600
   Revision: 00000000    Serial number: 00000503290361
   Shop #: WSC 12336 024 394758
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 B
   Component: ValeoHeckdeckel H14 0280
   Revision: --H14001    Serial number: E5030000B
   Shop #: WSC 23250 431 715754
   VCID: ECDD5FC5CF471C7ED75-80B9
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: KK09.05.05--H14001001A0047ÿ
   Subsystem 4 - Serial number: 1A0047ÿ
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0052778
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 00000000000000
   Coding: 0201216
   Part No SW: 4F0 910 336 B    HW: 4E0 862 335
   Component: Handyvorb2      H10 0440
   Revision: 00000000    Serial number: 00000007521090
   Coding: 0010900
   VCID: 2241F1FDFD039A0EAD9-8077
Whenever a steering angle sensor calibration doesn't work as expected, the first thing to check is the actual readings from the steering angle sensor. In that ABS module, look at MVB 005.1 and tell us what you see there with the steering wheel centered and the front wheels pointed straight ahead. Also verify that the readings change in a plausible manner when you turn the steering wheel both to the left of center and the right of center.
porschetech
C?ID=135483
Uwe,
MVB 005 shows 1) 0.0
2) fluctuates between -0.14 and 0.10 rapidly
3) .65 BAR to .98BAR fluctuating rapidly
4)0.00 to 0.19 fluctuating rapidly
There is no change with any of the MVB #'s while turning the steering wheel.
In basic settings: 1 2 3 4
MVB's 001, all red, showing: ERROR (GROUP #) NOT AVAILABLE
mvb 003 RED SHOWING: ERROR ( GROUP #) SYSTEM TEST ENABLED NOT AVAILABLE
I have attached a scan from this afternoon.
I hope this is helpful.
Kurt
VCDS Version: Release 12.12.3 (x64)
Tuesday,14,October,2014,14:46:33:52331
VIN: WAUKG74F06N018485   Mileage: 182300km/113275miles
                    Mileage: 181999 km
                    Date: 2014.10.01
                    Time: 16:06:42
                    RPM: 1856 /min
                    Mass Air / Rev.: 250.7 mg/str
                    Temperature: 79.5°C
                        Part Throttle
                    Voltage: 14.08 V
                    Speed: 91.0 km/h
                    Fault Frequency: 34
                    Mileage: 182105 km
                    Date: 2014.10.10
                    Time: 15:27:41
                    RPM: 1216 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Temperature: 84.0°C
                        Idle
                    Voltage: 11.63 V
               P1653 - 008 -
                    Fault Status: 01101000
                    Fault Frequency: 35
                    Mileage: 182105 km
                    Date: 2014.10.10
                    Time: 15:27:41
                    RPM: 1024 /min
                    Temperature: 84.0°C
                        Idle
                    Load: 11.4 %
012410 - Air Intake System
               P307A - 009 - Flow too Low - Intermittent
                    Reset counter: 33
                    Mileage: 182156 km
                    Date: 2014.10.11
                    Time: 16:37:39
                    RPM: 672 /min
                    Mass Air / Rev.: 119.9 mg/str
                    Temperature: 85.5°C
                        Idle
                    Voltage: 13.97 V
000104 - MAP/MAF <-> Throttle Position Correlation
               P0068 - 007 -  - Intermittent
                    Fault Status: 00000010
                    Reset counter: 32
                    Mileage: 182156 km
                    Date: 2014.10.11
                    Time: 16:37:39
                    RPM: 672 /min
                    Temperature: 85.5°C
                        Idle
                    Voltage: 13.87 V
                    Bin. Bits: 00000010
   Coding: 0000002
               U0126 - 000 -
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    (no units): 30.0
                    (no units): 24.0
                    Temperature: 55.0°C
                    T.B. Angle: 0.0°
   Coding: 0016799
                    Reset counter: 245
                    Mileage: 182309 km
                    Date: 2014.10.14
                    Time: 14:38:43
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x001E
                    Hex Value: 0x4397
                    Hex Value: 0x00FF
01486 - System Function Test Activated
                    Fault Frequency: 29
                    Reset counter: 245
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:24:06
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0021
                    Hex Value: 0x4199
                    Hex Value: 0x00FF
   Coding: 0000143
   Coding: 0000003
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 49
                    Reset counter: 39
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:25:01
02244 - Button in Control Head is Stuck
                    Reset counter: 24
                    Mileage: 182197 km
                    Date: 2014.10.12
                    Time: 16:53:00
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      001
   Coding: 0524582
00797 - Sunlight Photo Sensor (G107)
                    Fault Status: 00101001
                    Fault Frequency: 19
                    Reset counter: 30
                    Mileage: 182120 km
                    Date: 2014.10.10
                    Time: 18:40:22
   Coding: 0013123
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 593 E    HW: 4E0 035 593 A
   Component: SDAR
   Serial number: AUZ4Z7D20
                    Reset counter: 234
                    Mileage: 182107 km
                    Raw, Form. N/A: 000 000 075
                    Raw, Form. N/A: 000 000 000
   Coding: 0013622
   Coding: 0012242
   Coding: 2161263
                    Reset counter: 234
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    Fault Frequency: 14
                    Reset counter: 28
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 18:27:40
                    Reset counter: 25
                    Mileage: 182249 km
                    Date: 2014.10.13
                    Time: 14:11:49
   Coding: 0000210
                    Fault Frequency: 30
                    Reset counter: 245
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    Fault Frequency: 33
                    Reset counter: 245
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
   Coding: 0082954
   Revision: 00-00000
   Coding: 0052971
   Coding: 7764669
   Coding: 0000126
   Coding: 0002114
   Revision: 00-00000
   Coding: 0052971
   Revision: C63C0030
   Coding: 0005022
   Coding: 0000017
                    Fault Frequency: 28
                    Reset counter: 245
                    Mileage: 182104 km
                    Date: 2014.10.10
                    Time: 17:05:45
   Coding: 0000002
   Coding: 0052778
   Coding: 0062221
   Coding: 0052778
   Coding: 0201216
   Coding: 0010900
golfi_vend
Tartu, Estonia
C?ID=195131
Just a reminder.
[ CODE] autoscan info [/ CODE]
Without spaces.
Does this change when you move the steering wheel? 'Cause if it doesn't, then that would explain why you can't calibrate the sensor. ;)
porschetech
C?ID=135483
Uwe,
The numbers do not change.
OK, and you also have this in the ABS.
Given that
I think you need to back-track your steps and perhaps revert some parts to figure out what's wrong here.
porschetech
C?ID=135483
Uwe,
I have succeeded in gaining steering angle sensor recalabration. Everything works better when I followed the directions properly! This whole deal started as I am trying to add a heated steering wheel to the car. All the hardware has been changed (wheel and associated clock spring). I am trying to change the coding from factory default 0002042 to 0002242 but VCDS shows code not accepted. I'm wondering if I need a security code (as with ABS) in order to recode? Where may I find this code, if that is what I need?
Thanks,
Kurt
What's the exact error you get when the module rejects it?
I don't think a security access code is needed to code the steering column module.
porschetech
C?ID=135483
Uwe,
Just in case my efforts are getting in trouble; here is what I have done.
Start VCDS select 16-steering wheel 07 coding changed 0004042 to 0004242.
Do it Code rejected. Error 31 Request out of range. exit, exit, etc.
Kurt
Have you verified that your steering column module supports a heated steering wheel? It wouldn't surprise me if Audi used a different one for that.
porschetech
C?ID=135483
Uwe,
Well, no I haven't. What I bought is complete from the module to the clock spring. I'm changing one piece at a time! I will swap my wiper stalk with the A8 unit and install all the parts. That should do it. I'll let you know. Thanks for all your help with this. I have certainly learned a lot about my VCDS. By the by, I checked the MVB's for HSW and, in green letters, I saw 'not installed'
Kurt
porschetech
C?ID=135483
Uwe,
I changed the module today and found a new (different) problem. When I tried the SAS alignment/calibration process I get green letters in Basic Settings MVB #001 [ADJ STEERING] [ANGLE SENSOR] [ LOCKED] [N/A]
MVB 005 has red letters and 'not enabled', 'N/A', etc.
You changed which module? Got a scan with the new module installed?
gupsterg
C?ID=146338
Hi Porscetech,
Uwe asked:-
You replied:-
Well, no I haven't
I'd like to inform you after seeing this info in your autoscan log :-
That you will require a differing steering module to support heated steering wheel.
If your going to use A8 module one then you need SW: 4E0 910 549 A HW P/N: 4E0 953 549 B
If your going to use A6 module then you'll need SW: 4F0 910 549 A HW P/N: 4F0 953 549 C
I was going to look at your coding as VCDS log in post 1 have different coding for module 16 than the one in post 3, then in post 8 & 10 you start stating some other differing codings but no point now until you have correct module 16 installed.
All the best
Gup
porschetech
C?ID=135483
Uwe,
Here is a scan from this morning. What a mess! By the way, after changing the steering column, the heated steering wheel works.
Monday,27,October,2014,10:39:45:52331
VIN: WAUKG74F06N018485   Mileage: 182800km/113586miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
0E-Media Player 1 -- Status: Malfunction 0010
               P1602 - 008 - Voltage too Low - Intermittent
                    Fault Status: 00001000
                    Reset counter: 32
                    Temperature: 85.5°C
                        Engine Off
               P1653 - 008 -
                    Fault Frequency: 13
                    Mileage: 182678 km
                    Date: 2014.10.22
                    Time: 15:42:43
                    RPM: 1088 /min
                    Temperature: 73.5°C
                        Idle
                    Load: 11.0 %
                    Mileage: 182731 km
                    Date: 2014.10.24
                    Time: 16:39:14
                    RPM: 1888 /min
                    Mass Air / Rev.: 223.5 mg/str
                    Temperature: 63.0°C
                        Part Throttle
                    Voltage: 13.97 V
                    Speed: 92.0 km/h
                    Fault Frequency: 13
                    Mileage: 182781 km
                    Date: 2014.10.26
                    Time: 13:09:20
                    Temperature: 6.0°C
                        Engine Off
                    Voltage: 11.93 V
   Coding: 0000002
               U0126 - 000 -
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    (no units): 30.0
                    (no units): 24.0
                    Temperature: 55.0°C
                    T.B. Angle: 0.0°
   Coding: 0016799
                    Reset counter: 13
                    Mileage: 182807 km
                    Date: 2014.10.27
                    Time: 10:18:22
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x001E
                    Hex Value: 0x4392
                    Hex Value: 0x00FF
                    Fault Frequency: 8
                    Reset counter: 13
                    Mileage: 182781 km
                    Date: 2014.10.26
                    Time: 13:29:52
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0021
                    Hex Value: 0x419D
                    Hex Value: 0x00FF
   Coding: 0000143
00956 - Key 2
                    Fault Status: 00110010
                    Reset counter: 38
                    Mileage: 182545 km
                    Date: 2014.10.20
                    Time: 12:18:17
   Coding: 0000003
                    Fault Frequency: 193
                    Reset counter: 39
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:25:01
                    Reset counter: 29
                    Mileage: 182197 km
                    Date: 2014.10.12
                    Time: 16:53:00
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      001
   Coding: 0524582
                    Fault Frequency: 56
                    Reset counter: 53
                    Mileage: 182120 km
                    Date: 2014.10.10
                    Time: 18:40:22
   Coding: 0013123
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
                    Reset counter: 32
                    Mileage: 182382 km
                    Date: 2014.10.15
                    Time: 15:10:54
   Component: SDAR
   Coding: 0013622
   Coding: 0002242
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 52
                    Mileage: 182536 km
                    Date: 2014.10.19
                    Time: 14:27:43
   Coding: 2161263
                    Reset counter: 18
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    Fault Frequency: 42
                    Reset counter: 53
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 18:27:40
                    Reset counter: 25
                    Mileage: 182249 km
                    Date: 2014.10.13
                    Time: 14:11:49
                    Reset counter: 36
                    Mileage: 182536 km
                    Date: 2014.10.19
                    Time: 14:43:01
   Coding: 0000210
                    Fault Frequency: 61
                    Reset counter: 13
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
                    Fault Frequency: 80
                    Reset counter: 13
                    Mileage: 182107 km
                    Date: 2014.10.10
                    Time: 17:05:43
   Coding: 0082954
02927 - DVD Read Error
                    Fault Frequency: 8
                    Reset counter: 44
                    Mileage: 182486 km
                    Date: 2014.10.17
                    Time: 11:12:00
                    Hex Value: 0x5447
                    Hex Value: 0x9E98
                    Hex Value: 0x0401
                    Hex Value: 0x0000
   Revision: 00-00000
   Coding: 0052971
   Coding: 7764669
                    Reset counter: 36
                    Mileage: 182536 km
                    Date: 2014.10.19
                    Time: 14:43:04
   Coding: 0000126
   Coding: 0002114
   Revision: 00-00000
   Coding: 0052971
   Revision: C63C0030
   Coding: 0005022
   Coding: 0000017
                    Fault Frequency: 58
                    Reset counter: 13
                    Mileage: 182104 km
                    Date: 2014.10.10
                    Time: 17:05:45
   Coding: 0000002
   Coding: 0052778
   Coding: 0062221
   Coding: 0052778
   Coding: 0201216
   Coding: 0010900
Kurt
gupsterg
C?ID=146338
Coding: 0002242
EPC data showed that module doesn't support heated steering wheel :confused:
But good news! :D and a round of applause for your perseverance! :cool:
porschetech
C?ID=135483
0778
The scan you are referring to is from before I changed the module and clock spring out of my A6 using a good used clock spring and module and heated steering wheel from an A8.
Please look at the scan from this morning an verify that all the A8 parts on the car now will work OK together. I have heat, but I can't calibrate the steering wheel sensor.
Kurt
gupsterg
C?ID=146338
The data I've posted in post 17 is from your new scan in post 16.
porschetech
C?ID=135483
Gup,
I don't know what is going on with the scan data. I now have the "B" clock spring and the "B" module (4E0) from an '05 A8 along with the SW with heat/switch, etc. The heat works fine after installing the "B" module but the SAS is "locked" and I cannot adjust it. I was able to do steering centering before I installed the HSW "B" module?
At this point, I really need to know how to unlock the SAS for calibration? Any ideas?
Kurt
