URGENT help me please in Audi A6
mo_ferwana
Palestine Gaza
C?ID=11756
Hi all
I have got Audi A6, the problem is sometimes the electricity from the cluter going to be OFF and no more electricity and try to make ignition on but nothing of the light will be on and there is no ignition on in the car ,, when I remove the battery cable and attatch it again everything come back and the car has the ability to ignition on and start the car , PS : without removing the battery cable the car dosnt ignition on and there is no more lights in the cluster ,,
Tank you all
here is the Autoscan :
Sunday,12,October,2014,15:57:22:25282
VCDS Version: 14.8.1.0
Data version: 20140905
Dealer/Shop Name: Ferwana Workshop Bros.
Workshop Code: 123 12345 023456
VIN: WAUZZZ4F55N117161   License Plate: XXXXXXXX
Mileage: 58650km-36443mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
          62 72 77
VIN: WAUZZZ4F55N117161   Mileage: 58650km-36443miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 4F0 910 559 E    HW: 4F0 907 559
   Component: 3.0L V6/5V      G   0030
   Revision: --H01---    Serial number:
   Coding: 0011582
   Shop #: WSC 02325 785 00200
   VCID: 2C5D60F28F69F55A55-8079
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
16486 - Mass Air Flow Sensor (G70)
            P0102 - 002 - Signal too Low - MIL ON
Readiness: 0010 1101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F1 910 155 C    HW: 01J 927 156 HT
   Component: V30 01J 3.0l 5V RdW 0020
   Revision: 00000012    Serial number: 00000002071898
   Coding: 0000001
   Shop #: WSC 04940 001 00001
   VCID: 234F8BCEE2B73A22E4-8076
006231 - Load Signal
               P1857 - 000 - Error Message from ECU
                    Mileage: 55972 km
                    Date: 2005.02.04
                    Time: 03:32:10
                    RPM: 896 /min
                    RPM: 70 /min
                    (no units): 2.0
                    Torque: 26.0 Nm
                    Temperature: 71.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 1010 0 1
005953 - Clutch Pressure Adaptation
               P1741 - 000 - Limit Reached - Intermittent
                    Mileage: 58642 km
                    Date: 2005.02.03
                    Time: 13:22:16
                    RPM: 1280 /min
                    RPM: 500 /min
                    (no units): 6.0
                    Torque: 106.0 Nm
                    Temperature: 62.0°C
                    T.B. Angle: 18.8°
                    Bin. Bits: 1010 0 0
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H03 0090
   Coding: 0021338
18265 - Load Signal
                    Reset counter: 195
                    Mileage: 58659 km
                    Date: 2005.02.01
                    Time: 14:36:13
                    Hex Value: 0x0000
                    Hex Value: 0x6282
                    Hex Value: 0x0028
                    Hex Value: 0x01A4
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0160
   Revision: 27100401    Serial number: 10600300154884
   Coding: 0000003
   Shop #: WSC 02323 785 00200
   VCID: 63CFCBCEA2377A22A4-8036
   Subsystem 1 - Part No: 4F0 910 131 A
   Component: FBSAUDIC6 EZS   H44 0070
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H39 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4F0 910 730 K    HW: 4F0 035 729 D
   Component: MMI Cockpit     H35 0130
   Revision: C51100DE    Serial number: AUZ6Z3E47F13M1
   Coding: 0000001
   VCID: 295399E6809BE072AE-807C
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000138932
   Subsystem 3 - Serial number: 0111.04.050000000100010759ے
   Subsystem 4 - Serial number: 010759ے
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 195
                    Mileage: 58659 km
                    Date: 2005.02.01
                    Time: 14:36:32
                    Bin. Bits:      010
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 F
   Component: KLIMABETAETIGUNGH04 0150
   Revision: 00000025    Serial number: 00000000132436
   Coding: 0008198
   Shop #: WSC 02327 785 00200
   VCID: 5BBFF32E9A4742E2EC-800E
                    Reset counter: 195
                    Mileage: 58659 km
                    Date: 2005.02.01
                    Time: 14:35:28
   Part No SW: 4F0 910 279 B    HW: 4F0 907 279 B
   Component: ILM Fahrer      H14 0080
   Coding: 0000101
   Shop #: WSC 02335 785 00200
   VCID: 28559CE29B91D97AB1-807D
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
Address 0E: Media Player 1        Labels: Redir Fail!
   Coding: 0000001
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 C    HW: 4F0 959 655 B
   Component: 32 AIRBAG AUDI8RH29 0230
   Revision: 06H29000    Serial number: 0037LD06FRX$
   Coding: 0013106
   VCID: 27579FDE968FD602B8-8072
   Subsystem 1 - Serial number: 6332CSME096C5E04B
   Subsystem 2 - Serial number: 6342CSME094A44474
   Subsystem 3 - Serial number: 6351HSME07075E5DI
   Subsystem 4 - Serial number: 6361HSME07160414Y
   Subsystem 5 - Serial number: 6371VSME067A5C43U
   Subsystem 6 - Serial number: 6381VSME067A173AS
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksنulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026050920114
   Coding: 0002021
   VCID: 66C9D2DA51050F0A43-8033
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 900 M
   Component: KOMBIINSTR. M73 H10 0630
   Revision: 00900000    Serial number: 4R412UD45
   Coding: 0258143
   VCID: 1E39BA3AC9D517CACB-804B
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 12008054048132
   Coding: 6CFE53C41B1104
                    Reset counter: 195
                    Mileage: 58659 km
                    Date: 2005.02.01
                    Time: 14:36:12
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 C    HW: 4F0 959 793 C
   Component: TSG FA          H11 0040
   Coding: 0000005
   VCID: 2A5166EA859DEB6AA7-807F
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H15 0100
   Revision: 01000015    Serial number: 01003398900000
   Coding: 0263301
   Shop #: WSC 00999 444 64523
10 Faults Found:
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 195
                    Mileage: 57504 km
                    Date: 2005.02.15
                    Time: 00:44:22
02739 - Bulb for Tail/Brake Light; Right
                    Fault Frequency: 209
                    Reset counter: 195
                    Mileage: 58654 km
                    Date: 2005.02.01
                    Time: 12:50:45
                    Reset counter: 195
                    Mileage: 15159 km
                    Date: 2005.02.01
                    Time: 12:17:51
02736 - Bulb for Tail/Fog Light; Left
                    Reset counter: 195
                    Mileage: 55349 km
                    Date: 2005.02.02
                    Time: 15:27:33
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 195
                    Mileage: 55458 km
                    Date: 2005.02.11
                    Time: 16:27:06
02738 - Bulb for Tail/Brake Light; Left
                    Reset counter: 195
                    Mileage: 55548 km
                    Date: 2005.02.04
                    Time: 06:43:54
                    Reset counter: 195
                    Mileage: 55549 km
                    Date: 2005.02.04
                    Time: 06:44:21
02740 - Bulb for Tail Light 2; Left
                    Reset counter: 195
                    Mileage: 55549 km
                    Date: 2005.02.04
                    Time: 06:50:15
01699 - Motor for Central Locking; Hatch/Trunk (V53)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 195
                    Mileage: 52562 km
                    Date: 2005.02.07
                    Time: 13:43:25
                    Reset counter: 194
                    Mileage: 52951 km
                    Date: 2005.02.17
                    Time: 12:07:57
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4F0 910 223 B    HW: 4F0 035 223
   Component: Amp.-ASK        H09 0270
   Revision: 19S00001    Serial number: 00704050081200
   Coding: 0000004
   VCID: 1D3BBD36C4D30CD2D2-8048
                    Reset counter: 195
                    Mileage: 58659 km
                    Date: 2005.02.01
                    Time: 14:35:22
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000083326
   Coding: 0001014
   VCID: 5EB9FA3A895557CA8B-800B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 792 C    HW: 4F0 959 792 C
   Component: TSG BF          H11 0040
   Coding: 0000522
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0004031
   Shop #: WSC 02334 785 00200
   VCID: 5DBBFD3684534CD292-8008
Address 56: Radio        Labels: Redir Fail!
   Coding: 0000001
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000017866
   Shop #: WSC 00000 384 00290
   Subsystem 1 - Part No: 4F0 915 105 B
   Component: von MLA  0504120881
   Coding: 34463039313531303542204D4C4130353034313230383831
02254 - Interface to Generator
                    Reset counter: 195
                    Mileage: 58659 km
                    Date: 2005.02.01
                    Time: 14:36:05
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 A    HW: 4F0 959 795 A
   Component: TSG HL          H11 0030
   Coding: 0000002
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 A    HW: 4F0 959 794 A
   Component: TSG HR          H11 0030
   Coding: 0000002
   Part No SW: 4E0 910 336 D    HW: 4E0 862 335
   Component: Handyvorb2      H11 0320
   Revision: 00000000    Serial number: 00000007502822
   Coding: 0020990
End-------------------------(Elapsed Time: 02:15)--------------------------
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
Thanks for your fast reply,,,,
so what should I do to solve this problem ?
jakematic
NC USA
C?ID=129085
CP can only be removed by a dealership with a connection to the mothership in Ingolstadt
You'll have to book in to a main dealer and have them remove it.
They may require proof of ownership of the modules as this is a theft deterrent mechanism.
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
but what is a CP ? I am not so proffi..sorry
Regards
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
sorry,, CP means Component Protection sorry Sir
I already have VVDI abritus v.2.7.7 and it is 3-9-2014 updated, chines clone, but it is so good in programming ,
can it solve the problem ?
jakematic
NC USA
C?ID=129085
I don't know about that product at all, and clones makes me nervous.
It would be completely at your risk and might break something.
I already have VVDI abritus v.2.7.7 and it is 3-9-2014 updated, chines clone, but it is so good in programming.
You will not get help with ANY cloned products here.
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
Sorry UWE,, I will not use it any more ,and I knew that it is dangerous,, sorry again,and Iam so pleased by joining this amazing group,,
and about Jake's question ,, I dont know really and I have asked the customer wether he have been replaced any part he said that he bought the car whithout any knowdlege about its history,,
I am wondering also about its Information screen ( for radio and Navigation ) sometimes it is light on for 1 min then going OFF light
any Idea Boss (Jack and UWE )
Regards
jakematic
NC USA
C?ID=129085
Regards
That's a side effect of the CP.
You'll also notice it if you try to play music - it will cut out every 2 second like a skip on a record.
Ouch...
Exact reason I always tell people to let me use VCDS to check a car they might buy - sort of an electronic pre-purchase inspection :D
OK, car with unknown history -- I guess I'm not surprised. ;)
Please set time and date in car correctly, then go to every control module that has a fault code and clear the fault codes. Yes, one by one, in each control module please. Then cycle ignition and do another auto-scan. I think we should see what faults come back with (current time/date stamps) after you have done this.
mo_ferwana
Palestine Gaza
C?ID=11756
Hi all
Today I went to Audi dealer and explain to him, he shown me his understanding and programmed the car ONLINE and remove all the CP , and then he told me that the car needs to replace the back signals lamps and to repair the Alternator ( it lost data bus signal,according to him ) now I am trying to repair what does he advice me to fix,,,
Do you all think SO ? advice me friends ,,please
Regards
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Can you post another Auto-Scan now that CP have been removed? That way we can see what faults are still present.
In your last scan, it seemed like all of the lamps on the rear of the car were showing faults. Did it have accident damage to the rear? That seems like a lot of bulbs to be burnt out. I'm wondering about blown fuses, physical damage to wiring, or ground (earth) problems.
Jason
