ECM swap
james_flowers
C?ID=318004
Trying to find out how to get coding & perform an ECU swap on a 2013 PASSAT CC. The original ECU is toast. Also wondering if a used ECU is an option. Could really use some assistance.
iichel
Eindhoven, NB, NL
C?ID=284912
If it's the engine control module, you'll need to marry it with the cluster and the keys. Or defeat immo completely.
Guys like Jetta97 or Jack@EuropeanParts could help out with this.
james_flowers
C?ID=318004
Thanks, and yes I am talking about the engine control module.
NostraJackAss
Indeed I can help swap identity data, even from dead units with forensic tools I built here....
What part number?
Post a scan of what you can talk to ........
james_flowers
C?ID=318004
What part number?
06J 907 309 B
Monday,04,June,2018,15:00:24:13821
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: FMK AUTOMOTIVE
VIN: WVWBN7AN2DE515894   License Plate: LE6642
Mileage: 186050km-115606mi   Repair Order: 00541
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56
          62 65 72
VIN: WVWBN7AN2DE515894   Mileage: 186050km-115606miles
01-Engine -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3505
   Revision: 05551213    Serial number: 00001205142762
   Shop #: WSC 05311 000 00000
   VCID: 25022FDCECD4FB6C74-8070
11 Faults Found:
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 176
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:45
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU
                    Fault Frequency: 0
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:46
01196 - Engine-Transmission Data Bus
                    Fault Frequency: 126
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:46
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:52
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:52
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
17204 - Message from selector lever; emergency operation
            P0820 - 000 -
                    Reset counter: 8
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:13
00511 - Selector Lever (E313)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 0
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:13
            014 - Defective
                    Fault Frequency: 0
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:13
00653 - Selector Lever/Auto Trans Plausibility
                    Fault Frequency: 0
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:15
28775 - No Communication with Gear Selector Module
            U0103 - 004 -
                    Reset counter: 0
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:18
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V484 0024
   Revision: --H07---    Serial number: 00000005807679
   Coding: 0004495
   VCID: 71AA0B8C689CE7CCD8-8024
                    Fault Frequency: 165
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:47
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.00 V
                    Bin. Bits: 00011111
                    Count: 220
                    Hex Value: 0x0000
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:16
                    Hex Value: 0x0000
                    Voltage: 6.75 V
                    Bin. Bits: 00011111
                    Count: 115
                    Hex Value: 0x0000
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 218
                    Hex Value: 0x0000
                    Fault Status: 01101000
                    Fault Frequency: 90
                    Reset counter: 132
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 236
                    Hex Value: 0x0000
            014 - Defective
                    Reset counter: 132
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:43:57
                    Hex Value: 0x0000
                    Voltage: 9.50 V
                    Bin. Bits: 00011101
                    Count: 246
                    Hex Value: 0x0000
            014 - Defective
                    Reset counter: 132
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:43:57
                    Hex Value: 0x0000
                    Voltage: 9.50 V
                    Bin. Bits: 00011101
                    Count: 250
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0202
   Revision: 00001K01
   Coding: 0010001008
   Shop #: WSC 00015 115 00000
   VCID: 7CB42AB8F7DE9AA47B-8028
          U1111 00 [009] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 42
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:10:04
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
   Shop #: WSC 05311 000 08193
   VCID: 41CA9B4CD8BC374C68-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 070512  010 0604
   Serial number: 070512
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M05D22h18m45s36S4
   Coding: 0280DD
9 Faults Found:
                    Fault Frequency: 98
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:07
                    Voltage: 8.00 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Voltage: 12.85 V
                    Fault Frequency: 89
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:35:19
                    Voltage: 11.10 V
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:05
                    Voltage: 7.15 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Voltage: 12.90 V
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:45
                    Voltage: 11.25 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Voltage: 12.20 V
                    Fault Status: 00101001
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:49:57
                        Term 15 Off
                    Voltage: 11.70 V
03678 - Coordinator for Start-Stop Operation
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:47
                    Voltage: 11.30 V
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__713 VW10 HI   2118
   Revision: 24017000    Serial number: 003LDPAE5KF/
   Coding: 0012595
   VCID: 4ED0B070D9E2D834E5-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 000000000084R8
   Subsystem 3 - Serial number: 0025.04.120000300000630065ÿ†63
   Subsystem 4 - Serial number: 630065ÿ†6332MTS612791352 ÿ†63
   Subsystem 5 - Serial number: 91352 ÿ†6342MTS640881362 ÿ†63
   Subsystem 6 - Serial number: 81362 ÿ†6351HTS6H97S3BKJ ÿ†63
   Subsystem 7 - Serial number: S3BKJ ÿ†6361HTS6PNAQ3BKJ ÿ†63
   Subsystem 8 - Serial number: Q3BKJ ÿ†63727TS6HUH12BKJ ÿ†63
   Subsystem 9 - Serial number: 12BKJ ÿ†63827TS6D4T12BKJ ÿ
   Subsystem 10 - Serial number: 12BKJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 41
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:20
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Fault Frequency: 12
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:19
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120602300254
   Coding: 098A270000
   VCID: 6B9619E482B00D1CE2-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:05
114433 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
                    Reset counter: 172
136194 - Supply voltage
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.25
                    Time: 13:44:26
617742 - Selector Lever Park Position Lock Switch
          B1162 07 [008] - Mechanical Failure
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 22:19:38
   Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
   Component: KOMBI         H05 0705
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 2C14DAF8473ECA24AB-8078
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 00:12:51
          [Supply voltage too low]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
   Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
   Component: J533  Gateway H41 1632
   Revision:   H41       Serial number: 240512F1000974
   Coding: 469006
   Shop #: WSC 05314 000 00000
   VCID: 6FAE0DF4BEA8F13CCE-803A
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:46
                    Fault Status: 00110100
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:15:41
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:06
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   VCID: 373EF594467879FCD6-8062
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:33
   Revision: A1001003    Serial number: 7662551749
   Coding: 020000
   VCID: 291A23EC40CCDF0C50-807C
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:04
                    Reset counter: 172
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4238493
   Coding: 0400040104000F000001100A
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 25022FDC24D4FB6C74-8070
   Component: NAR_V3_(0037)  0037
1048578 - Supply voltage
          [supply voltage lower limit exceeded]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:10:34
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [restriction due to undervoltage]
                    Fault Frequency: 17
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:22
1048634 - Antenna 2 for radio
          B111A 13 [008] - Open Circuit
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 06:55:39
1048663 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [CAN TO instrument cluster]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0551
   Revision: 12110009    Serial number: 0005069979
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   VCID: 6D9217FCBCA4032CFC-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002946209
   Coding: 010490
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
68102 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN Kombi]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
131329 - Rear Door Control Module
          B11ED F0 [008] - Supply Voltage too Low
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:05
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 132
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 00:01:05
132866 - Switch for Rear Central Locking
          B122E 29 [008] - Signal Implausible
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.25
                    Time: 13:48:16
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.302 1101
   Revision: 1AH03735    Serial number: 00121460462801
   Coding: 0000258
   VCID: 3D32E7BC644453AC0C-8068
9 Faults Found:
                    Fault Status: 11100100
                    Fault Frequency: 106
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:45
                    RPM: 1500 /min
                    (no units): 7.0
                    Voltage: 11.20 V
                    Fault Frequency: 43
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:08:37
                    Voltage: 0.80 V
                    Voltage: 10.30 V
                    Voltage: 4.40 V
                        Not Occup.
                        Not Occup.
            000 -  -  - Intermittent
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.17
                    Time: 12:17:28
                    Voltage: 4.60 V
                    Voltage: 9.30 V
                    Voltage: 9.30 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.17
                    Time: 12:17:60
                    Voltage: 2.30 V
                    Voltage: 8.00 V
                    Voltage: 8.00 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.17
                    Time: 12:17:60
                    Voltage: 4.00 V
                    Voltage: 7.90 V
                    Voltage: 8.00 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:52
                    RPM: 1500 /min
                    (no units): 7.0
                    Voltage: 12.80 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    RPM: 1500 /min
                    (no units): 7.0
                    Voltage: 12.10 V
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 172
                    (no units): 2.0
                    Voltage: 12.10 V
00003 - Control Module
                    Fault Status: 00101100
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 00:06:53
                        Term 15 Off
                    (no units): 11.0
                    Voltage: 12.70 V
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1B910F8001862E521204141FF08A0F0E105801
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:05
                    Fault Status: 00100001
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 00:02:07
   Part No SW: 7N0 907 532     HW: 7N0 907 530 G
   Component: EZE_2         H41 1632
   Coding: 00000008
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0551
   Revision: 14110009    Serial number: 0005063854
   Coding: 0004B6
   VCID: 6E9010F0B1A2F834C5-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002943374
   Coding: 010490
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 172
          U1111 00 [008] - -
          [Front CAN Kombi]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:05
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.25
                    Time: 13:48:16
   Revision:   H19       Serial number: 00000000241767
   Coding: 0022156
   VCID: 3620F890417280F4CD-8062
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:05
                    Voltage: 7.00 V
                    Count: 48
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 00110010
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:11:42
                    Voltage: 6.70 V
                    Count: 50
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 164
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:18:45
                    Voltage: 9.60 V
                    Count: 71
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 373EF5948E7879FCD6-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
13893888 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
          [Funktionseinschraenkung durch Ueberspannung]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 01:44:11
          U1400 00 [008] - -
          [Funktionseinschraenkung durch Unterspannung]
                    Reset counter: 172
13705474 - Databus
          [Timeout mLW_1]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 00:12:50
13705475 - Databus
          U1121 00 [137] - Missing Message
          [Timeout mMotor_1]
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
13705477 - Databus
          [Timoout mKombi_3]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
13705483 - Databus
          [Timeout mLSM]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 00:12:51
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000128623
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 3522FF9C94748BECC4-8060
12652544 - Supply voltage
          [Versorgungsspannung unterer Grenzwert unterschritten]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 22:07:49
12656662 - Databus
          [CAN Signal Kl15 fehlende Botschaft]
12656664 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Kombiinstrument keine CAN Kommunikation]
End----------(Elapsed Time: 01:46, VBatt start/end: 13.8V/14.0V)-----------
NostraJackAss
Yup got it.......
x
Vehicle Identification No.WVWBN7AN2DE515894
ModelPassat CC
CC
Date of production14.06.2012
Year2013
Sales type3584L6
Engine CodeCCTA
Transmission CodePBG
x
[TABLE="class: vinInfoTable"]
[TR]
[TH]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0DJ[/TD]
[TD]Vehicle class differentiation -350-[/TD]
[/TR]
[TR]
[TH]drive-off assistance[/TH]
[TD="class: prCode"]UG1[/TD]
[TD]Hill hold control[/TD]
[/TR]
[TR]
[TH]Emission standard[/TH]
[TD="class: prCode"]7GB[/TD]
[TD]Emission standard ULEV 2[/TD]
[/TR]
[TR]
[TH]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH]airbag[/TH]
[TD="class: prCode"]4UB[/TD]
[TD]Airbag for NAR[/TD]
[/TR]
[TR]
[TH]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E4[/TD]
[TD]Activated carbon canister (ORVR)
and siphoning device for fueling[/TD]
[/TR]
[TR]
[TH]Tray areas package[/TH]
[TD="class: prCode"]QE0[/TD]
[TD]Without tray areas package/box[/TD]
[/TR]
[TR]
[TH]Aerials[/TH]
[TD="class: prCode"]8ZH[/TD]
[TD]Antenna for AM/FM reception, "diversity"[/TD]
[/TR]
[TR]
[TH]Exterior mirror setting[/TH]
[TD="class: prCode"]6XC[/TD]
[TD]Exterior mirrors: power-adjustable[/TD]
[/TR]
[TR]
[TH]Follow-on warranty[/TH]
[TD="class: prCode"]EA0[/TD]
[TD]Without subsequent warranty[/TD]
[/TR]
[TR]
[TH]Left exterior mirror[/TH]
[TD="class: prCode"]5SH[/TD]
[TD]Left exterior mirror, flat (US)[/TD]
[/TR]
[TR]
[TH]Right exterior mirror[/TH]
[TD="class: prCode"]5RR[/TD]
[TD]Right exterior mirror, convex (US)[/TD]
[/TR]
[TR]
[TH]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH]Equipment levels[/TH]
[TD="class: prCode"]A8F[/TD]
[TD]Sports equipment[/TD]
[/TR]
[TR]
[TH]Brake type in rear[/TH]
[TD="class: prCode"]1KW[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[TD="class: prCode"]J0L[/TD]
[TD]Battery 340 A (70 Ah)[/TD]
[/TR]
[TR]
[TH]Brake type, front[/TH]
[TD="class: prCode"]1ZG[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH]Beverage holders[/TH]
[TD="class: prCode"]4M9[/TD]
[TD]Beverage holders[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0D[/TD]
[TD]Assembly kit, USA corresponding vehicle
version (not California), various parts[/TD]
[/TR]
[TR]
[TH]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH]Heated washer nozzles[/TH]
[TD="class: prCode"]9T0[/TD]
[TD]Without heated washer nozzles[/TD]
[/TR]
[TR]
[TH]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH]"Charism"[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH]Chrome package[/TH]
[TD="class: prCode"]QJ1[/TD]
[TD]Chrome package[/TD]
[/TR]
[TR]
[TH]General operating permit, alterations[/TH]
[TD="class: prCode"]C11[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]roof without cut out[/TD]
[/TR]
[TR]
[TH]Suspension system in rear[/TH]
[TD="class: prCode"]UA4[/TD]
[TD]Rear shock absorption, base version[/TD]
[/TR]
[TR]
[TH]Suspension system in front[/TH]
[TD="class: prCode"]G60[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH]Differential lock[/TH]
[TD="class: prCode"]1Y0[/TD]
[TD]without differential lock[/TD]
[/TR]
[TR]
[TH]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X2[/TD]
[TD]Load-through hatch[/TD]
[/TR]
[TR]
[TH]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G1[/TD]
[TD]Insert for the filling up of unleaded
fuel[/TD]
[/TR]
[TR]
[TH]Installation differentiation for components[/TH]
[TD="class: prCode"]0ES[/TD]
[TD]Installation differentiation for
transmission DQ250
-- vehicle components --[/TD]
[/TR]
[TR]
[TH]Theft protection system[/TH]
[TD="class: prCode"]7AG[/TD]
[TD]Electronic immobilizer
with anti-theft alarm system (for USA)[/TD]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]5MN[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH]Scuff plates[/TH]
[TD="class: prCode"]7M1[/TD]
[TD]Scuff plates in door apertures with
metal inserts[/TD]
[/TR]
[TR]
[TH]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH]Electric interface for external use[/TH]
[TD="class: prCode"]UF8[/TD]
[TD]Electric interface for external use[/TD]
[/TR]
[TR]
[TH]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH]Pedestrian protection[/TH]
[TD="class: prCode"]VL0[/TD]
[TD]Standard pedestrian protection measures[/TD]
[/TR]
[TR]
[TH]Headlight activation[/TH]
[TD="class: prCode"]8K9[/TD]
[TD]Daytime headlights with automatic headlight control
and coming home function[/TD]
[/TR]
[TR]
[TH]Parking brake[/TH]
[TD="class: prCode"]UH1[/TD]
[TD]Parking brake[/TD]
[/TR]
[TR]
[TH]Vehicle tracing system[/TH]
[TD="class: prCode"]7G0[/TD]
[TD]Without preparation for VTS (Vehicle Tracing System)[/TD]
[/TR]
[TR]
[TH]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH]Transmission types/gearshift mechanisms[/TH]
[TD="class: prCode"]0G7[/TD]
[TD]tiptronic[/TD]
[/TR]
[TR]
[TH]Weight category rear axle[/TH]
[TD="class: prCode"]0YB[/TD]
[TD]Weight range 2
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH]Weight category front axle[/TH]
[TD="class: prCode"]L10[/TD]
[TD]Suspension range 10
[/TR]
[TR]
[TH]Base engine[/TH]
[TD="class: prCode"]TQ2[/TD]
[TD]4-cyl. petrol engine 2.0 l assembly 06J.B[/TD]
[/TR]
[TR]
[TH]Tie down straps/net/pocket[/TH]
[TD="class: prCode"]6M0[/TD]
[TD]Without tie down straps/net/pocket[/TD]
[/TR]
[TR]
[TH]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH]Transmission specifications[/TH]
[TD="class: prCode"]G1A[/TD]
[TD]6-speed automatic transmission[/TD]
[/TR]
[TR]
[TH]Cruise control system and speed limiter[/TH]
[TD="class: prCode"]6Y2[/TD]
[TD]Speed limiter[/TD]
[/TR]
[TR]
[TH]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH]Molded headliner[/TH]
[TD="class: prCode"]6NC[/TD]
[TD]Molded headliner[/TD]
[/TR]
[TR]
[TH]Rear seats[/TH]
[TD="class: prCode"]3NJ[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AK[/TD]
[TD]Climatronic with impact pressure
control, CFC-free[/TD]
[/TR]
[TR]
[TH]Headlamps[/TH]
[TD="class: prCode"]8IM[/TD]
[TD]Gas discharge headlights with
dynamic bending light[/TD]
[/TR]
[TR]
[TH]Customized installation[/TH]
[TD="class: prCode"]FC1[/TD]
[TD]Customized installation[/TD]
[/TR]
[TR]
[TH]Interior light in footwell[/TH]
[TD="class: prCode"]6T0[/TD]
[TD]Without interior light in footwell[/TD]
[/TR]
[TR]
[TH]Instrument clusters[/TH]
[TD="class: prCode"]U5C[/TD]
[TD]Instrument cluster, mph speedometer
- USA -[/TD]
[/TR]
[TR]
[TH]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L6[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming[/TD]
[/TR]
[TR]
[TH]headphone connection, rear[/TH]
[TD="class: prCode"]8MA[/TD]
[TD]no headphone connection in rear[/TD]
[/TR]
[TR]
[TH]Body style[/TH]
[TD="class: prCode"]K8C[/TD]
[TD]Coupe[/TD]
[/TR]
[TR]
[TH]Camera/distance sensor[/TH]
[TD="class: prCode"]QK0[/TD]
[TD]Without camera without distance sensor
(driver assistance system)[/TD]
[/TR]
[TR]
[TH]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SE[/TD]
[TD]Flat needle-punched trunk floor covering[/TD]
[/TR]
[TR]
[TH]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH]Climatic zones[/TH]
[TD="class: prCode"]0Y4[/TD]
[TD]Cold and tropical climatic zones (US)[/TD]
[/TR]
[TR]
[TH]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH]Seat ventilation/massage seat[/TH]
[TD="class: prCode"]4D0[/TD]
[TD]Without seat ventilation/massage seat[/TD]
[/TR]
[TR]
[TH]headrest for seat, rear[/TH]
[TD="class: prCode"]3Q9[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH]Head restraints[/TH]
[TD="class: prCode"]5ZG[/TD]
[TD]Head restraints for front seats (NAR)
(x-adjustment)[/TD]
[/TR]
[TR]
[TH]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH]Fuel systems[/TH]
[TD="class: prCode"]1A2[/TD]
[TD]Fuel system for SI engine with direct
injection (FSI)[/TD]
[/TR]
[TR]
[TH]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH]Camera systems/accident sensors[/TH]
[TD="class: prCode"]KA0[/TD]
[TD]without camera systems/environment sensors[/TD]
[/TR]
[TR]
[TH]Radiator grille[/TH]
[TD="class: prCode"]6KJ[/TD]
[TD]Radiator grille with chrome-plated strip[/TD]
[/TR]
[TR]
[TH]Rear license plate bracket[/TH]
[TD="class: prCode"]6P0[/TD]
[TD]Without rear license plate carrier[/TD]
[/TR]
[TR]
[TH]Front license plate bracket[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]License plate bracket front (small, NAR)[/TD]
[/TR]
[TR]
[TH]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K4[/TD]
[TD]Full body cover (shape-adapted system)
with additional transport protection
measures[/TD]
[/TR]
[TR]
[TH]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH]Rear cargo area[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH]Country codes[/TH]
[TD="class: prCode"]FE0[/TD]
[TD]Without country code (no DVD player in
vehicle)[/TD]
[/TR]
[TR]
[TH]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH]Reading lamp[/TH]
[TD="class: prCode"]8S7[/TD]
[TD]2 reading lights in front[/TD]
[/TR]
[TR]
[TH]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH]Backrest release[/TH]
[TD="class: prCode"]3H0[/TD]
[TD]Without backrest release for front seats[/TD]
[/TR]
[TR]
[TH]Light control systems[/TH]
[TD="class: prCode"]8G0[/TD]
[TD]Without Light Assist[/TD]
[/TR]
[TR]
[TH]Load edge protection[/TH]
[TD="class: prCode"]2P1[/TD]
[TD]Plastic loading edge protection[/TD]
[/TR]
[TR]
[TH]Lumbar support[/TH]
[TD="class: prCode"]7P1[/TD]
[TD]Power adjustable lumbar support in front
seats[/TD]
[/TR]
[TR]
[TH]steering wheels[/TH]
[TD="class: prCode"]2PP[/TD]
[TD]Leather-wrapped multi-function steering
wheel[/TD]
[/TR]
[TR]
[TH]Driving on the left/on the right[/TH]
[TD="class: prCode"]AV2[/TD]
[TD]Driving on the right (NAR)[/TD]
[/TR]
[TR]
[TH]Speaker installation[/TH]
[TD="class: prCode"]8RM[/TD]
[TD]8 speakers (passive)[/TD]
[/TR]
[TR]
[TH]Headlight range control[/TH]
[TD="class: prCode"]8Q5[/TD]
[TD]Dynamic headlight range control,
with cornering light (AFS 1)[/TD]
[/TR]
[TR]
[TH]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Front center armrest[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q5[/TD]
[TD]Multi-function display with control[/TD]
[/TR]
[TR]
[TH]center console[/TH]
[TD="class: prCode"]3I6[/TD]
[TD]center console[/TD]
[/TR]
[TR]
[TH]Driver alert system[/TH]
[TD="class: prCode"]EM0[/TD]
[TD]Without driver alert system[/TD]
[/TR]
[TR]
[TH]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH]Engine specifications[/TH]
[TD="class: prCode"]D2L[/TD]
[TD]4-cylinder SI engine 2.0 l/147 kW (16V)
turbo FSI, homogeneous
base engine: T59/T61/TQ2/TU2/TD6/TN6/TL5[/TD]
[/TR]
[TR]
[TH]Left vanity mirror[/TH]
[TD="class: prCode"]4SH[/TD]
[TD]Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable[/TD]
[/TR]
[TR]
[TH]Right vanity mirror[/TH]
[TD="class: prCode"]4TH[/TD]
[TD]Vanity mirror, right, illuminated, with
extractable[/TD]
[/TR]
[TR]
[TH]Navigation device[/TH]
[TD="class: prCode"]7T8[/TD]
[TD]Navigation system "RNS315" NAR[/TD]
[/TR]
[TR]
[TH]rear fog lamp[/TH]
[TD="class: prCode"]8TA[/TD]
[TD]witout rear fog lamp[/TD]
[/TR]
[TR]
[TH]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WH[/TD]
[TD]Front fog lamp and cornering lamp[/TD]
[/TR]
[TR]
[TH]Upgrading measures[/TH]
[TD="class: prCode"]GP1[/TD]
[TD]Vehicles with special upgrade measures[/TD]
[/TR]
[TR]
[TH]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]CL4[/TD]
[TD]Alloy wheels 8J x 18[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[TD="class: prCode"]8AY[/TD]
[TD]Radio navigation system[/TD]
[/TR]
[TR]
[TH]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JF[/TD]
[TD]Non-smoking package (NAR)[/TD]
[/TR]
[TR]
[TH]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K3[/TD]
[TD]Tire pressure monitoring system 433 MHz
High[/TD]
[/TR]
[TR]
[TH]tire[/TH]
[TD="class: prCode"]H04[/TD]
[TD]All-weather tires 235/40 R 18 95H (NAR)
(polymer coating)[/TD]
[/TR]
[TR]
[TH]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G1[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH]Restraint systems, front[/TH]
[TD="class: prCode"]4QQ[/TD]
[TD]3-point seat belts in front with
pretensioner and height adjustment,
US label[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]W75[/TD]
[TD]CC 2.0T SPORT PLUS USA[/TD]
[/TR]
[TR]
[TH]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SL[/TD]
[TD]Taillight assemblies with diodes (LED)
(for NAR)[/TD]
[/TR]
[TR]
[TH]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH]Service indicator[/TH]
[TD="class: prCode"]QI7[/TD]
[TD]Service indicator ( 10000 miles )[/TD]
[/TR]
[TR]
[TH]Front seat, left[/TH]
[TD="class: prCode"]3TF[/TD]
[TD]Front left comfort seat[/TD]
[/TR]
[TR]
[TH]Front seat, right[/TH]
[TD="class: prCode"]3SF[/TD]
[TD]Comfort seat, front right[/TD]
[/TR]
[TR]
[TH]Seat belt check[/TH]
[TD="class: prCode"]9P7[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact in buckle[/TD]
[/TR]
[TR]
[TH]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZD[/TD]
[TD]3-point seat belts, outer rear with US
label[/TD]
[/TR]
[TR]
[TH]seat covers[/TH]
[TD="class: prCode"]N2Q[/TD]
[TD]Seat trim covers in leatherette[/TD]
[/TR]
[TR]
[TH]Seat adjustment[/TH]
[TD="class: prCode"]3L5[/TD]
[TD]Both front seats power-adjustable[/TD]
[/TR]
[TR]
[TH]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH]Side lights[/TH]
[TD="class: prCode"]8F1[/TD]
[TD]Side-marker lamps[/TD]
[/TR]
[TR]
[TH]Start-stop system/regenerative braking[/TH]
[TD="class: prCode"]7L3[/TD]
[TD]Without start/stop system without
regenerative braking[/TD]
[/TR]
[TR]
[TH]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH]Control number (no PR family)[/TH]
[TD="class: prCode"]SX8[/TD]
[TD]Model update, week 22[/TD]
[/TR]
[TR]
[TH]Audio-response system/voice control[/TH]
[TD="class: prCode"]QH0[/TD]
[TD]without voice control[/TD]
[/TR]
[TR]
[TH]Lane change assist/lane keeping system[/TH]
[TD="class: prCode"]7Y0[/TD]
[TD]no lane change assistant[/TD]
[/TR]
[TR]
[TH]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH]Protective side molding[/TH]
[TD="class: prCode"]4B4[/TD]
[TD]Protective side molding[/TD]
[/TR]
[TR]
[TH]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH]power outlet[/TH]
[TD="class: prCode"]7B3[/TD]
[TD]12-volt socket(s)[/TD]
[/TR]
[TR]
[TH]Bumper[/TH]
[TD="class: prCode"]2JC[/TD]
[TD]Comfort bumpers[/TD]
[/TR]
[TR]
[TH]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N3[/TD]
[TD]intermittent windscreen wiper with rain sensor[/TD]
[/TR]
[TR]
[TH]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH]Nameplate set[/TH]
[TD="class: prCode"]0PW[/TD]
[TD]Nameplate set "CC"[/TD]
[/TR]
[TR]
[TH]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5Hz[/TD]
[/TR]
[TR]
[TH]Door and lid locking system[/TH]
[TD="class: prCode"]4K0[/TD]
[TD]Central locking w/ radio remote control
and interior controls[/TD]
[/TR]
[TR]
[TH]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]BU1[/TD]
[TD]Legal requirements for USA 1
States without CARB requirement[/TD]
[/TR]
[TR]
[TH]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH]Transit coating[/TH]
[TD="class: prCode"]NT0[/TD]
[TD]Transit coating (type 1)[/TD]
[/TR]
[TR]
[TH]Door and side trim panels[/TH]
[TD="class: prCode"]3LJ[/TD]
[TD]Door and side trim panel in foam film,
insert in leatherette[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QU4[/TD]
[TD]Satellite radio reception NAR
integrated in device[/TD]
[/TR]
[TR]
[TH]Assembly parts for engine (drive bearing)[/TH]
[TD="class: prCode"]1VG[/TD]
[TD]Assembly part for 4-cyl. engine[/TD]
[/TR]
[TR]
[TH]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH]Identification plates[/TH]
[TD="class: prCode"]1EB[/TD]
[TD]without identification plate[/TD]
[/TR]
[TR]
[TH]Delivery equipment[/TH]
[TD="class: prCode"]2A8[/TD]
[TD]Delivery equipment, water border[/TD]
[/TR]
[TR]
[TH]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH]Telephone / telematics[/TH]
[TD="class: prCode"]9ZS[/TD]
[TD]Preparation for UHV-internal telephone
with voice control[/TD]
[/TR]
[TR]
[TH]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH]LongLife Service Regime[/TH]
[TD="class: prCode"]QG0[/TD]
[TD]without service interval extension[/TD]
[/TR]
[TR]
[TH]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH]Second battery/battery installation[/TH]
[TD="class: prCode"]8FA[/TD]
[TD]without 2nd battery[/TD]
[/TR]
[TR]
[TH]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH]Decorative trims[/TH]
[TD="class: prCode"]4ZN[/TD]
[TD]Bright decorative trims[/TD]
[/TR]
[TR]
[TH]Additional child seat anchors[/TH]
[TD="class: prCode"]3B3[/TD]
[TD]Child seat anchors[/TD]
[/TR]
[TR]
[TH]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[TR]
[TH]Clocks[/TH]
[TD="class: prCode"]UP0[/TD]
[TD]Analog clock[/TD]
[/TR]
[/TABLE]
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Best will be if you put used ECU in car and see if is going to connect to VCDS , maybe you have different problem .
And on your question for used ECU,
Yes it can be program but not with VCDS.
james_flowers
C?ID=318004
Used ECU Responds fine. Just need to correctly code and program unit and immobilizer.
NostraJackAss
James.......
I can do it ....just need your credentials to ID you and car ownership or if doing Immo defeat, data transfer, just cost is insured freight and a donation of your choosing for being a VCDS forum member to welcome you.
I don't need to see the old ecu talk either........
Send me old ecu and used one.
No dual identities permitted.
Best,
Jack
james_flowers
C?ID=318004
Thanks Jack. I need to know what you will charge as for this for a customer of mine, not for me personally.
NostraJackAss
Normally I get $350 + 50 USD standard freight to observe each controller I touch, plus apply that observation fee toward a service.
In this case my offer is 50 USD to cover freight + a donation you see fit.
This is my good deed offer for the day extended.
Do as you wish.......
https://europeanpartsemporium.com/contact/
Jetta 97
C?ID=81680
James.......
Best,
Jack
Jack, IF is MCU dead , no way to get info form it , like water damage or etc. I run few times in this problem.
This is 2013 model, should be UDS protocol , so Immo defeat is out of the question.
NostraJackAss
OP just an FYI:
The controller you submitted supplied by your customer or prior customers repair shop & to be used as replacement, is tampered & for a CBFA not a CCTA with different SMOG tier.
Marin
ECU is not UDS.
UDS and TP 2.0 or MED17 ECU's can indeed have the Immo removed.
Just because an ECU doesn't communicate with VCDS & via normal diagnostic methods, doesn't mean an MCU is dead.
I look forward to proving that & other ubiquitous inaccurate statements you have made in the past, indeed are wrong.
NostraJackAss
Very good!
[h=2]VINCheck® Results[/h]VIN: WVWBN7AN2DE515894
[h=3]VINCheck® Theft Record[/h]VIN: WVWBN7AN2DE515894 has not been identified as a vehicle listed in the VINCheck® Theft Records.
VINCheck® is updated regularly as additional information is reported.
[HR][/HR][h=3]VINCheck® Total Loss Record[/h]VIN: WVWBN7AN2DE515894 has not been identified as a vehicle listed in the VINCheck® Salvage Records.
NostraJackAss
And than there is reality! :rolleyes:
Address 01: Engine
Control Module Part Number: 06J 906 027 FE
Component and/or Version: MED17.5.2 TFSI 2 06 5369
Software Coding: 0404010A1C070160
Work Shop Code: WSC 03738
Advanced Identification
Identification: BPG-810
Revision: P3H07---
Date: 27.08.12
Manufacturer number: 1586
Test stand number: 1324
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 452326 152 78387
Flash Date: 00.00.00
Software
A0101
M13E00
Misc.
Hardware number: 06J 907 309 A
Car Info
Chassis Number: WVWBN7AN2DE515894
Engine code: CCT
VCDS Info:
Labels: None
Readiness: No script available
Adaptation Channel 091:
Stored value 1
N/A
N/A
N/A
N/A
Jetta 97
C?ID=81680
Jack, read my post again ,
I said "IF MCU IS DEAD ",
I never said it is not possible to read data form ECU if can not communicate with VCDS.
NostraJackAss
Marin,
MCU is almost never dead, that is what a programmer & external after being de-soldered is for.
Plus you said Immo defeat can't be done again and indeed it can.
NostraJackAss
I spoke with James today & to verify that this is indeed solved and when he has time he will tell the story.
Immobilizer defeat Successful Marin!
NostraJackASS Has Spoken!
rhinopower
C?ID=58979
Well done Jack, love reading success stories like this, very talented
james_flowers
C?ID=318004
Ok, finally taking time out to finish this post. Jack is awesome! He was able to supply me with a functional control unit that had the immobilizer disabled. Best part is that it was all done legitimately, and by the book. Three months later, and everything is all well.
Thanks again Jack!
