Tiguan 2011 engine coding
mohamed
Egypt
C?ID=211960
Hi,
this car read fault 4746 magnetic clutch
i have changed the magentic clutch , and test the circuit diagram , and nothing change , when i checked the coding of the engine control unit , i fount in byte 4 , that the car with not a electric pump and this pump of this car should be electrical ,
Could you tell me if this code of ECU is right or not ?
note : i have cleared the fault at the moment of taking the auto-scan
Tuesday,05,June,2018,11:54:40:22511
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4411.4
VIN: WVGZZZ5NZCW516545   License Plate: DESKTOP
Mileage: 74020km-45993mi   Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 52 53 56 62 72
VIN: WVGZZZ5NZCW516545   Mileage: 74020km-45993miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAVD)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 DC    HW: 03C 907 309 J
   Component: 1.4l R4/4V TS H04 1686
   Revision: LGH04---    Serial number: 00000000000000
   Coding: 00190012002600000000
   Shop #: WSC 44131 002 1048576
   ASAM Dataset: EV_ECM14TSI01103C906027DC 001005
   ROD: EV_ECM14TSI01103C906027DC.rod
   VCID: E582F5B0E436A96C0B-80B0
Readiness: 1110 0101
   Part No SW: 5N0 614 109 AH    HW: 5N0 614 109 AH
   Component: J104   C6 450M VDE4 0003
   Revision: --H07---    Serial number: 00000004603480
   Coding: 0005390
   VCID: F1AA91E0E8FE75CC67-80A4
                    Reset counter: 2
                    Mileage: 73871 km
                    Date: 2012.10.21
                    Time: 22:08:36
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 220
                    Hex Value: 0x0000
02214 - Tire Pressure Warning
                    Reset counter: 10
                    Mileage: 74000 km
                    Date: 2012.10.25
                    Time: 13:31:30
                    Speed: 38.0 km/h
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0000001002
   VCID: 804CC4241B546C4498-80D4
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0048
   Revision: BC011001
   Coding: 40180A3B80251AC0400800C0100081E44B010088524D8D60648040000040
   VCID: BB3673C83A32CF9C8D-80EE
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 280711 03  32  0010
   Coding: 009795
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 226
                    Mileage: 74023 km
                    Date: 2012.10.26
                    Time: 00:00:05
                        Term 15 Off
                    Voltage: 12.60 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261123501472
   Coding: 148003
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: C4C408344FCCB064FC-8090
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__206 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PGS6HH3
   Coding: 0012342
   VCID: CCD42014AF9C782434-8098
   Subsystem 1 - Serial number: 6332MTS613682151
   Subsystem 2 - Serial number: 6342MTS604352151
   Subsystem 3 - Serial number: 6351HTS6S0SDAAKJ
   Subsystem 4 - Serial number: 6361HTS6QV9EAAKJ
   Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20110818300752
   Coding: 1182140000
   VCID: F1AA91E020FE75CC67-80A4
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5N0 920 872 B    HW: 5N0 920 872 B
   Coding: 111F01
   VCID: B12A51E0E07E35CC27-80E4
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 250711F2000130
   Coding: 356002
   VCID: B52265F01C1619EC7B-80E0
                    Fault Status: 00110100
                    Reset counter: 1
                    Mileage: 73871 km
                    Date: 2012.10.21
                    Time: 22:08:37
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: CDD22D105486712C23-8098
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA98868C0D28861426-80BE
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2111
   Coding: 0000188
   VCID: B62062FCC11012F472-80E2
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.285 1002
   Revision: 1AH03835    Serial number: 00112250258801
   Coding: 0000258
   VCID: BC3470D4FF3CC8A484-80E8
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 12
                    (no units): 2.0
                    Voltage: 12.50 V
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Coding: 0000188
   VCID: B73E6FF8C61AEBFC69-80E2
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000160728
   Coding: 0026157
   Shop #: WSC 54569 001 1048576
   VCID: B52265F0DC1619EC7B-80E0
                    Reset counter: 1
                    Mileage: 73871 km
                    Date: 2012.10.21
                    Time: 22:08:36
                    Voltage: 12.40 V
                    Count: 71
                    Hex Value: 0x1273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 1
                    Mileage: 73871 km
                    Date: 2012.10.21
                    Time: 22:08:37
                    Voltage: 12.20 V
                    Count: 61
                    Hex Value: 0x1273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  052 0208
   Revision: 00000001    Serial number: VWZ1Z3L1614145
   Coding: 0500040004000C
   VCID: A306ABA8A282975CA5-80F6
   Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
   Component: Tuer-SG         007 2102
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: B83C6CC4CB04E48460-80EC
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Coding: 0000144
   VCID: B93A69C0F00EFD8C9F-80EC
End----------(Elapsed Time: 01:18, VBatt start/end: 12.5V/12.5V)-----------
Jef
HQ
mohamed
Egypt
C?ID=211960
okay could you tell me another code to try it , as there is no other option , as i have changed the wiring diagram , magnetic clutch and the last option is the ECU , i want to try other code before i change the ECU
