MKIV 2003 Jetta 1.8t AWP - N249 Code Question - P1287
rbb1485
C?ID=325014
Hi All,
So over the weekend, I pulled off one heck of a procedure on my 2003 jetta with 207,xxx miles! It consisted of replacing a cracked exhaust manifold, leaking flex joint on downpipe, and the original K03s turbo with a K04-001 with only 30,xxx miles on it.
After about ~12 hours, I had pulled off success! Bled my coolant system, and everything looked good, i was so happy!
Car ran well, no CEL came up, no boost issues, or anything of the sort. Sadly, I did not perform an auto-scan immediately prior to starting the procedure =( Last time I did an autoscan was on 4/2/18 and I did not have this code.
Anyway, after completing and driving for a day or 2, I ran an autoscan and I get P1287 - Boost Pressure Control Valve (N249) Open Circuit.
Entire autoscan is here:
Tuesday,05,June,2018,13:05:47:53404
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: 3VWSE69M03M161580   License Plate: BR49BL
Mileage: 332620km-206680mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWSE69M03M161580   Mileage: 332620km-206680miles
Address 01: Engine        Labels: 06A-906-032-AWP.lbl
   Part No: 06A 906 032 LP
   Component: 1.8L R4/5VT     G   0007
   Coding: 07500
   Shop #: WSC 12857
   VCID: 77AB16EA06D04D7F40D-5160
   3VWSE69M03M161580     VWZ7Z0C6698338
17695 - Boost Pressure Control Valve (N249)
            P1287 - 35-00 - Open Circuit
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 3431E1E652266667A5F-5184
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0001
   Coding: 12340
   Shop #: WSC 00066
   VCID: 270B06AA96F01DFF10D-513C
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00066
   VCID: 2F3BEE8ABE0045BFD8D-5184
   Part No: 1J0 920 906 J
   Component: KOMBI+WEGFAHRSP VDO V65
   Coding: 07232
   Shop #: WSC 08080
   VCID: 2F3BEE8ABE0045BFD8D-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B92DF663BE1A47817-513C
            49-00 - No Communications
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 00066
   VCID: 372BD6EA46508D7F80D-4B1E
   Component: 1H Tõrsteuer.FS KLO 0009
   Component: 1H Tõrsteuer.BF KLO 0009
   Component: 1H Tõrsteuer.HL KLO 0009
   Subsystem 4 - Part No: Steuerger
   Component: t HR    antwortet nicht
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 E
   Component: RADIO 3CP          0004
   Coding: 04031
   Shop #: WSC 00066
   VCID: 221D17BEFDD2F8D7473-513C
End----------(Elapsed Time: 05:00, VBatt start/end: 12.1V/12.1V)-----------
I first thought I had forgotten to put back the N249 electrical plug i removed on back of intake manifold plate, but checked that and it is indeed plugged in. Also, checked function of my DV (forge 007) and it holds vacuum OK. So my question is, how can I test using Vag-com the functionality of the N249 valve, prior to shelling out $ for a new one?? Or is there something else I should be looking at?
Thank you all!
Jef
HQ
Thanks for posting an Auto-Scan! :thumbs:
Vehicle Identification No. 3VWSE69M03M161580
Model Jetta GLS
JEM
Date of production 28.03.2003
Year 2003
Sales type 9M25N4
Engine Code AWP
Transmission Code EHA
An "open circuit" is some sort of electrical path issue.
  • Unplug the N249 and ohm test it, it should be 20 to 35 Ω (at approx. 20° C).
  • With the engine at idle, do you have battery power to /1 (yellow/black) at the N249?
  • /2 (grey/green) goes to ECM T121/105, is that wire to factory design?
You can also play around with Output Testing for fun and games:
http://www.ross-tech.com/vcds/tour/out_test.php
NostraJackAss
JPPSG!
http://forums.ross-tech.com/forumdisplay.php?9-Car-Repair-Support
You were in here recently, please verify the N249 is plugged into the correct harness connector and not the SAI noid or that left undone.
Please clear codes re-post the scan right after doing so, then do output tests with VCDS to see what is clicking and is for correct component to be initiated.
In addition to Jef's advice, a noid light can also be used to verify if the tracks to the two control solenoids are functional for wiring.
rbb1485
C?ID=325014
JPPSG!
I will confirm N249 is plugged in correctly tonight, and then perform Jef's ohm test as well, and report back !
Thanks All
rbb1485
C?ID=325014
Just to update everyone, I found the /2 (grey/green) wire broken at the connector, was able to remove the terminal from connector, re-solder, and cleared the code, has not come back yet! Thanks for your help
