2015 USA Passat into a new Caddy 2K chassis.
Haven't worked on this project in a while, got back to it tonight. Biggest headache is not being able to communicate with a J400 module; I'm starting to suspect that the 5K0937087AE H+ BCM from the PQ35 NMS simply can't communicate with it. I tested the J400 on another car with a older 3C8937049E and the motor and module functioned perfectly.
Scan after manually clearning:
Scan prior to manually clearing each Module. I guess something wasn't happy clearing that many codes..?
Saturday,02,June,2018,22:00:37:42907
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: XXXXXXX License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 55 56 75
77 BF
VIN: XXXXXX Mileage: 20km-12miles
2E-Media Player 3 -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
BF-Slid. Door Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 K HW: 06K 907 425 C
Component: Simos18.2 H13 8104
Revision: --H13---
Coding: 001A0012242400170000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906071K 001006
ROD: EV_ECM18TFS02006K906071AC.rod
VCID: B3265BC81A9273DC6A-80E6
19795 - EVAP System Leak Detection Pump Heater Control Circuit
P240A 00 [039] - Open Circuit
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:58
Engine speed: 0.00 /min
Coolant temperature: 34 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.972 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 18.359375 %
FUP_H_SAE: 15010.0 kPa
19798 - Control Circuit for EVAP Vent Control
P0447 00 [039] - Open Circuit
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:58
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
19791 - EVAP Leak Detection Pump Control Circuit
P2400 00 [039] - Malfunction
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:58
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
17178 - Databus
U1123 00 [039] - Received Error Message
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:55
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 09G-927-749-V1.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 109 2784
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW41.rod
VCID: B83C6CE403F490845F-80EC
22920 - Implausible Data Received from Parking Brake Control Module
U0417 00 [171] - -
Reset counter: 36
Mileage: 29 km
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Engine torque: 0 Nm
Transmission fluid temperature: 25 °C
Accelerator position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492500FBA31103E892210041A1100012
VCID: 8444C81407BC046483-80D0
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:19
Count: 2
Count: 12
Count: 4096
Count: 16390
Count: 42496
Count: 512
Fault Status: 01100101
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:15
Count: 2
Count: 12
Count: 4096
Count: 291
Count: 42496
Count: 512
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: F5A2A5D054662DEC84-80A0
9471253 - Temperature Sensor for Footwell Vent
B1085 15 [009] - Open or Short to Plus
Reset counter: 27
Date: 2018.03.09
Time: 03:18:43
9471509 - Temperature Sensor for Driver Side Vent in Dashboard
B1086 15 [009] - Open or Short to Plus
Reset counter: 27
Date: 2018.03.09
Time: 03:18:43
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 67
9472533 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Reset counter: 67
Date: 2018.04.04
Time: 00:31:26
B10AB F0 [009] - Too Low
Reset counter: 27
Date: 2018.03.09
Time: 03:18:44
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: 81200418802B080101080001060009004104A000408018207F8400000C70
VCID: F8BCACE44B7450849F-80AC
00897 - Windshield Washer Pump (V5)
Fault Status: 01101100
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:27
Voltage: 12.00 V
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:27
Voltage: 12.00 V
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD017DHN
Coding: 00004832
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: F1AA91C0200E01CC58-80A4
Serial number: 3572MSME4E2F2D48ZZZC
Serial number: 3582MSME4A312D48ZZZ$
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME796E0A30ZZZ
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME1567702FZZZ
17 Faults Found:
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
B1006 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9437979 - Igniter 2 for Passenger's Airbag
B1003 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9445937 - Seat occupied recognition control module
B1022 31 [137] - No Signal
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:43
9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140603200150
Coding: 089A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: F9BAA9E0787E498CE0-80AC
Component: E221__MFL-YVJ H07 0023
Coding: E30000
617742 - Selector Lever Park Position Lock Switch
B1162 07 [009] - Mechanical Failure
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:48
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 F HW: 561 920 970 F
Component: KOMBI H04 0811
Coding: 230A00
Shop #: WSC 27461 001 104857
VCID: 9D729D708C16D5ACAC-80C8
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Leuchtweitenregelung: keine Kommunikation]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:57
13654544 - Databus
[Steuergerät für Telefon keine Kommunikation]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:57
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 07091403000360
Coding: 468000
VCID: 804CC40413A41844A7-80D4
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:02
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:06
03272 - Control Module for Audio Interface
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:06
03605 - Control Module Auomatic Sliding Door, Rear Right
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:02
Address 1C: Position Sensing
Component: IMMO H04 0811
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EA9886AC0DD8F21419-80BE
Address 2E: Media Player 3
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008855618
Coding: 0404B5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: DBF6D368D2829B9C92-808E
65538 - Local Data Bus
U10BA 00 [009] - No Communication
[Front Timeout LIN Sub bus]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:19:44
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:19:44
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 211 3501
Revision: 00H22000
VCID: B93A69E0F0FE898CA0-80EC
Fault Status: 11100101
Date: 2018.03.05
Time: 00:11:47
Battery Volts: 12.1 V
DD
Temperature: 24.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Reset counter: 67
Voltage: 12.63 V
DD
Temperature: 23.0°C
Fault Status: 00101101
Fault Frequency: 14
Reset counter: 76
Mileage: 27 km
Date: 2018.05.05
Time: 09:54:49
Voltage: 14.38 V
DU
Temperature: 12.0°C
RPM: 1741 /min
Speed: 17.0 km/h
Speed: 17.0 km/h
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 00000000
VCID: EFAE97B83E3A173C4E-80BA
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008877502
Coding: 0404B4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: DCF4D074D78C9CA49B-8088
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:21:14
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:21:14
Address 55: Headlight Range
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3191183
Coding: 01000400040007
Shop #: WSC 00066 000 00000
VCID: E386EB88E2F2A35CDA-80B6
15 Faults Found:
01704 - Terminal 58 (Dimming)
Reset counter: 67
Date: 2018.03.05
Time: 00:11:47
00856 - Radio Antenna
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Fault Status: 00101011
Reset counter: 67
Date: 2018.03.05
Time: 00:17:58
Reset counter: 36
Date: 2018.03.05
Time: 00:17:58
00877 - Treble Speaker Rear Right (R16)
Reset counter: 36
Date: 2018.03.05
Time: 00:17:58
Reset counter: 67
Date: 2018.03.05
Time: 00:18:00
Reset counter: 36
Date: 2018.03.05
Time: 00:18:00
Reset counter: 36
Date: 2018.03.05
Time: 00:18:00
Reset counter: 69
Date: 2018.03.09
Time: 04:03:04
02633 - Antenna for Satellite Tuner
Reset counter: 27
Date: 2018.04.03
Time: 01:17:31
Reset counter: 67
Reset counter: 27
Reset counter: 27
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140528
Coding: 02140102C21612107F1606C00000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 9464F8547FDC94E413-80C0
10 Faults Found:
12670208 - Databus
[CAN TO instrument cluster]
Reset counter: 67
0022 - Databus
[CAN TO radio]
Reset counter: 67
Date: 2018.04.03
Time: 01:17:55
0037 - Databus
[CAN TO Telephone ECU]
Fault Frequency: 102
Reset counter: 36
13635840 - Supply voltage
[supply voltage lower limit exceeded]
Reset counter: 69
Date: 2018.03.05
Time: 05:00:25
U1400 00 [008] - -
[restriction due to undervoltage]
Fault Frequency: 9
Reset counter: 76
Date: 2018.03.05
Time: 04:55:57
9455635 - Microphone 1
B129B 13 [009] - Open Circuit
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
9457171 - Audio signal output 1
B14F1 13 [009] - Open Circuit
Reset counter: 27
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
[roofline module open load]
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
9458451 - Cellular Antenna
B1053 13 [009] - Open Circuit
[GSM antenna open load]
Reset counter: 0
2566 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS antenna open load]
Reset counter: 0
Address 77: Telephone
Address BF: Slid. Door Rear Right
End----------(Elapsed Time: 01:21, VBatt start/end: 12.0V/12.0V)-----------
Saturday,02,June,2018,21:39:08:42907
VIN: Removedxxxxxxxxxx License Plate:
77 BF
VIN: Removedxxxxxxxxxx Mileage: 20km-12miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Sporadic communication error 1000
75-Telematics -- Status: Malfunction 1010
Revision: --H13---
14 Faults Found:
P240A 00 [175] - Open Circuit
Date: 2018.03.05
Time: 00:11:49
Coolant temperature: 20 °C
Intake air temperature: 23 °C
T_AST_SAE: 0 s
MAP_MES_SAE: 101 kPa
FUP_H_SAE: 630.0 kPa
P0447 00 [175] - Open Circuit
Date: 2018.03.05
Time: 00:11:49
T_AST_SAE: 0 s
P2400 00 [175] - Malfunction
Date: 2018.03.05
Time: 00:11:49
T_AST_SAE: 0 s
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [040] - Malfunction / Open Circuit
Date: 2018.04.03
Time: 01:05:53
Coolant temperature: 18 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.289 V
Unlearning counter according OBD: 32
T_AST_SAE: 0 s
MAP_MES_SAE: 102 kPa
VLS_DOWN_SAE[1]: 1.275 V
15219 - Accelerator Position Sensor (G79)
P2122 00 [032] - Signal too Low
Coolant temperature: 21 °C
Intake air temperature: 25 °C
Voltage terminal 30: 12.597 V
Unlearning counter according OBD: 31
T_AST_SAE: 0 s
FAC_TPS_1_SAE: 25.000000 %
FUP_H_SAE: 640.0 kPa
15221 - Accelerator Position Sensor 2 (G185)
P2127 00 [032] - Signal too Low
T_AST_SAE: 0 s
17178 - Databus
U1123 00 [047] - Received Error Message
Fault Frequency: 141
Date: 2018.03.05
Time: 00:11:47
15186 - Park/Neutral Switch Input Circuit
P0851 00 [104] - Short to Ground
Date: 2018.04.08
Time: 09:20:54
Engine speed: 1004.75 /min
Normed load value: 11.8 %
Coolant temperature: 48 °C
Intake air temperature: 19 °C
Voltage terminal 30: 14.375 V
Engine: operating status: IS
STATE_LS_SAE[1]: CL
T_AST_SAE: 103 s
MAP_MES_SAE: 52 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
FAC_TPS_1_SAE: 14.453125 %
FUP_H_SAE: 8200.0 kPa
26384 - Databus
U1123 00 [109] - Received Error Message
Date: 2018.04.18
Time: 19:36:04
Engine speed: 1246.00 /min
Normed load value: 21.2 %
Vehicle speed: 16 km/h
Coolant temperature: 64 °C
Voltage terminal 30: 14.160 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 246 s
MAP_MES_SAE: 48 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.992 V
FAC_TPS_1_SAE: 13.281250 %
FUP_H_SAE: 15070.0 kPa
19868 - No Communication with Instrument Cluster
U0155 00 [032] - -
Coolant temperature: 22 °C
Voltage terminal 30: 12.480 V
ECU_STATE: ENG_STOP
Engine oil temperature: 21.0 °C
Time since engine start: 0.0 s
T_ES: 2880 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: operated
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: operated
Cruise control switch actuation-Large increment: not activated
STATE_ERR_ABC_PRED: 0
21322 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Fault Frequency: 14
Date: 2018.04.18
Time: 19:36:03
Engine speed: 1221.00 /min
Normed load value: 26.3 %
Vehicle speed: 14 km/h
Voltage terminal 30: 14.179 V
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 49.0 °C
Time since engine start: 246.6 s
T_ES: 0 min
21323 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Fault Frequency: 14
Date: 2018.04.18
Time: 19:36:03
T_ES: 0 min
23130 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Fault Frequency: 14
Date: 2018.04.18
Time: 19:36:03
Engine speed: 1214.00 /min
Voltage terminal 30: 14.101 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 245 s
MAP_MES_SAE: 57 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.973 V
FAC_TPS_1_SAE: 15.234375 %
FUP_H_SAE: 12970.0 kPa
23131 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Fault Frequency: 14
Date: 2018.04.18
Time: 19:36:03
STATE_LS_SAE[1]: CL
T_AST_SAE: 245 s
MAP_MES_SAE: 57 kPa
Readiness: 0010 0101
Coding: 000348
7 Faults Found:
U0417 00 [171] - -
Fault Frequency: 20
Reset counter: 27
Engine torque: 0 Nm
Transmission fluid temperature: 22 °C
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
22616 - No Communication with Instrument Cluster
U0155 00 [040] - -
Reset counter: 27
Engine torque: 0 Nm
Transmission fluid temperature: 24 °C
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
22617 - No Communication with Instrument Cluster
U0155 00 [040] - -
Reset counter: 27
Engine torque: 0 Nm
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
22618 - No Communication with Instrument Cluster
U0155 00 [040] - -
Reset counter: 27
Engine torque: 0 Nm
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
22988 - Implausible Data Received from Engine Control Module
U0401 00 [032] - -
Reset counter: 27
Engine torque: 0 Nm
Accelerator position: 101.6 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
22970 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Fault Frequency: 14
Reset counter: 27
Engine speed: 1250.0 /min
Transmission input speed: 970 /min
Transmission output speed: 384 /min
Engine torque: 748 Nm
Transmission fluid temperature: 28 °C
Accelerator position: 23.2 %
Clutch_C1: closed
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: closed
Clutch_B2: Open
22971 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Fault Frequency: 14
Reset counter: 27
Transmission output speed: 385 /min
Clutch_C1: closed
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: closed
Clutch_B2: Open
Revision: 00H46001
9 Faults Found:
Reset counter: 67
Count: 2
Count: 12
Count: 20480
Count: 8208
Count: 43264
Count: 768
03391 - Coding Not Possible
Reset counter: 67
Count: 2
Count: 12
Count: 20480
Count: 8254
Count: 44288
Count: 1023
Reset counter: 67
Count: 2
Count: 12
Count: 20480
Count: 8211
Count: 44288
Count: 1023
Reset counter: 67
Date: 2018.03.07
Time: 22:46:43
Count: 7
Count: 13
Count: 28672
Count: 128
Count: 26624
Count: 512
Reset counter: 67
Date: 2018.04.07
Time: 00:43:01
Count: 2
Count: 14
Count: 20736
Count: 8269
Count: 44544
Count: 768
Fault Status: 00100011
Reset counter: 27
Date: 2018.04.18
Time: 19:36:03
Count: 2
Count: 4608
Count: 83
Count: 50446
Count: 769
Reset counter: 27
Mileage: 526596 km
Date: 2000.08.01
Time: 16:20:07
Count: 1792
Count: 158
Count: 6912
Count: 67
Count: 320
Count: 1537
Count: 291
Count: 6913
Reset counter: 27
Date: 2018.03.05
Time: 00:11:48
Count: 2
Count: 12
Count: 20480
Count: 16390
Count: 42496
Count: 512
Reset counter: 27
Date: 2018.03.05
Time: 00:11:50
Count: 2
Count: 12
Count: 20480
Count: 291
Count: 42496
Count: 512
Revision: 00009001
Coding: 0000001002
Reset counter: 27
Date: 2018.03.09
Time: 03:18:43
Reset counter: 27
Date: 2018.03.09
Time: 03:18:43
U1111 00 [008] - -
Reset counter: 67
Reset counter: 67
Date: 2018.04.04
Time: 00:31:26
Reset counter: 27
Date: 2018.03.09
Time: 03:18:44
Revision: BL122001
29 Faults Found:
Fault Frequency: 9
Reset counter: 67
Term 15 Off
Voltage: 12.30 V
Fault Frequency: 19
Reset counter: 76
Date: 2018.03.09
Time: 04:50:40
Voltage: 8.15 V
Reset counter: 76
Voltage: 5.40 V
Reset counter: 36
Date: 2018.03.09
Time: 22:13:20
Voltage: 12.05 V
Reset counter: 36
Date: 2018.03.09
Time: 22:13:20
Voltage: 12.05 V
00985 - Right Tail Light (M2)
Fault Status: 00101010
Reset counter: 67
Date: 2018.03.09
Time: 21:03:03
Voltage: 12.30 V
Fault Status: 01101010
Reset counter: 27
Date: 2018.03.09
Time: 21:03:03
Voltage: 12.30 V
Reset counter: 27
Date: 2018.03.09
Time: 21:03:03
Voltage: 12.30 V
Reset counter: 27
Date: 2018.04.07
Time: 00:43:32
Term 15 Off
Voltage: 12.85 V
01259 - Fuel Pump Relay (J17)
Fault Status: 00101001
Reset counter: 67
Term 15 Off
Voltage: 12.30 V
Reset counter: 67
Voltage: 12.45 V
Reset counter: 67
Date: 2018.04.04
Time: 00:29:24
Term 15 Off
Voltage: 11.60 V
Reset counter: 67
Date: 2018.03.09
Time: 22:13:22
Voltage: 12.00 V
Reset counter: 67
Date: 2018.03.09
Time: 22:13:22
Voltage: 12.00 V
01502 - Bulb for Rear Fog; Left (L46)
Reset counter: 27
Date: 2018.03.09
Time: 21:03:01
Voltage: 12.20 V
Reset counter: 27
Date: 2018.03.09
Time: 21:03:32
Voltage: 11.85 V
Reset counter: 27
Date: 2018.03.09
Time: 21:03:01
Voltage: 12.15 V
Reset counter: 67
Date: 2018.03.09
Time: 21:03:01
Voltage: 12.15 V
01800 - Light Switch (E1)
Reset counter: 76
Date: 2018.04.07
Time: 00:01:25
Term 15 Off
Voltage: 13.15 V
Reset counter: 27
Date: 2018.03.09
Time: 21:03:01
Voltage: 12.15 V
Reset counter: 27
Date: 2018.03.09
Time: 21:03:01
Voltage: 12.15 V
Reset counter: 27
Date: 2018.04.09
Time: 02:51:10
Voltage: 11.90 V
Reset counter: 27
Date: 2018.04.09
Time: 02:51:00
Voltage: 11.80 V
Reset counter: 67
Term 15 Off
Voltage: 12.35 V
Reset counter: 67
Term 15 Off
Voltage: 12.30 V
02743 - Bulb for Brake/Turn Signal Light; Right
Reset counter: 67
Date: 2018.04.09
Time: 02:39:48
Voltage: 11.90 V
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 27
Date: 2018.04.09
Time: 02:39:49
Voltage: 11.90 V
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 27
Date: 2018.04.09
Time: 02:39:49
Voltage: 11.95 V
03281 - Signal Lights On from Light Sensor
Reset counter: 27
Term 15 Off
Voltage: 11.90 V
Coding: 00004832
23 Faults Found:
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
Reset counter: 27
Date: 2018.03.05
Time: 00:11:51
9444885 - Driver's seat position sensor
B101E 15 [136] - Open or Short to Plus
Date: 2018.03.05
Time: 00:11:49
Date: 2018.03.05
Time: 00:11:49
[Powersupply lower threshold fall short of]
Reset counter: 69
Date: 2018.03.05
Time: 05:01:20
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
[Lost Comminication with Immobilizer]
Reset counter: 67
B10B4 00 [008] - Function Restriction due to Undervoltage
Fault Frequency: 8
Reset counter: 69
Date: 2018.03.05
Time: 05:00:36
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Fault Frequency: 58
Reset counter: 36
Date: 2018.03.05
Time: 04:58:06
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Reset counter: 67
Coding: 089A140000
Coding: E30000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 67
Date: 2018.03.07
Time: 22:48:04
136194 - Supply voltage
Reset counter: 76
Date: 2018.03.09
Time: 04:03:13
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Reset counter: 67
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 00:06:49
Coding: 230A00
U1111 00 [009] - -
Reset counter: 30
Mileage: 3 km
Date: 2018.04.24
Time: 11:15:48
[Supply voltage too low]
Reset counter: 69
Date: 2018.04.07
Time: 23:43:11
13654544 - Databus
Fault Frequency: 131
Reset counter: 36
Date: 2018.04.07
Time: 00:00:26
Coding: 468000
10 Faults Found:
Reset counter: 30
Mileage: 3 km
Date: 2018.04.24
Time: 11:15:48
Fault Status: 00110100
Reset counter: 67
Reset counter: 67
Reset counter: 67
Date: 2018.04.04
Time: 00:29:22
01302 - Control Module for Telematic (J499)
Reset counter: 67
Date: 2018.04.18
Time: 18:26:04
01304 - Radio
Reset counter: 67
Date: 2018.04.03
Time: 01:17:56
Reset counter: 27
Reset counter: 69
Mileage: 1 km
Date: 2018.04.23
Time: 19:34:35
Reset counter: 27
Reset counter: 27
Date: 2018.03.09
Time: 04:22:33
Coding: 0404B5
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 36
Date: 2018.03.05
Time: 00:11:47
67074 - Motors for Central Locking
B122B 01 [009] - Electrical Failure
Reset counter: 27
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 74
Date: 2018.03.09
Time: 00:59:32
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 27
Date: 2018.03.07
Time: 22:51:19
65793 - Supply voltage
[Front DCU undervoltage]
Reset counter: 67
Date: 2018.03.09
Time: 04:03:06
Revision: 00H22000
Date: 2018.03.05
Time: 00:11:47
DD
Temperature: 24.0°C
Count: 3
SteerAng n.Init
Reset counter: 67
Voltage: 12.63 V
DD
Temperature: 23.0°C
Fault Frequency: 14
Reset counter: 76
Mileage: 27 km
Date: 2018.05.05
Time: 09:54:49
Voltage: 14.38 V
DU
Temperature: 12.0°C
RPM: 1741 /min
Speed: 17.0 km/h
Speed: 17.0 km/h
Coding: 00000000
Coding: 0404B4
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 36
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Fault Frequency: 23
Reset counter: 74
Reset counter: 27
Date: 2018.03.07
Time: 22:51:19
Reset counter: 67
Date: 2018.03.09
Time: 04:03:08
15 Faults Found:
Reset counter: 67
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 67
Date: 2018.03.05
Time: 00:17:58
Reset counter: 36
Date: 2018.03.05
Time: 00:17:58
Reset counter: 36
Date: 2018.03.05
Time: 00:17:58
Reset counter: 67
Date: 2018.03.05
Time: 00:18:00
Reset counter: 36
Date: 2018.03.05
Time: 00:18:00
Reset counter: 36
Date: 2018.03.05
Time: 00:18:00
Reset counter: 69
Date: 2018.03.09
Time: 04:03:04
Reset counter: 27
Date: 2018.04.03
Time: 01:17:31
Reset counter: 67
Reset counter: 27
Reset counter: 27
10 Faults Found:
12670208 - Databus
Reset counter: 67
0022 - Databus
[CAN TO radio]
Reset counter: 67
Date: 2018.04.03
Time: 01:17:55
0037 - Databus
Reset counter: 36
Reset counter: 69
Date: 2018.03.05
Time: 05:00:25
U1400 00 [008] - -
Fault Frequency: 9
Reset counter: 76
Date: 2018.03.05
Time: 04:55:57
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 0
2566 - GPS Antenna
Reset counter: 0
End----------(Elapsed Time: 01:58, VBatt start/end: 12.1V/12.1V)-----------
