Programming folding mirror using remote ( car key )
Diver
C?ID=290183
Hello can you help me out with this problem, previous it was possible with older versions of VCDS to program the folding mirror so they work by pushing the lock button on the remote ( car key ) but now I can`t find it anymore, are there chances in the program, ore is it renamed. below the old way.
1.Select [42-Door Elec, Driver]
2.Klik [Security Access - 16]
3.enter security code "04354" and click op "Do it!"
4.Back in the previous menu , click [Adaptation -10]
5.Selectthe next channel: (9)-System_Parameter_0-System Parameter Byte8 ( it should be a bit at the bottom )
6.now you See the value is 90. You have 2 options : 1.95 – on remote keep lock button pressed to fold mirrors and unfold with motor on.
2.99 - Keep lock button pressed to fold mirror, and unfold by opening the door.
7.Klik op "Do it!" than "Yes"
8.than you get the massage code accepted click ok
9.Now you are done...
Here my adaption map.
;SW:3C0-959-701-A   HW:3C0-959-793-A ---  Door Elect, Driver --- SA: 04354
;Component:TUER-SG FT    002 0329, Coding:0011FF
;EV_DCU42BroseDriveSide,A03004,EV_DCU42BroseDriveSide_VW32.rod
;Thursday,31,May,2018,17:39:08:35994
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 26427CA5596B97747D-8072
ENG106031-ENG103506-ECU ID2 PartNumber HW SW-Byte 1,1 ,22
ENG106031-ENG99970-ECU ID2 PartNumber HW SW-Byte 10,G ,22
ENG106031-ENG103845-ECU ID2 PartNumber HW SW-Byte 11,  ,22
ENG106031-ENG103008-ECU ID2 PartNumber HW SW-Byte 12,0 ,22
ENG106031-ENG100040-ECU ID2 PartNumber HW SW-Byte 13,0 ,22
ENG106031-ENG101630-ECU ID2 PartNumber HW SW-Byte 14,1 ,22
ENG106031-ENG99906-ECU ID2 PartNumber HW SW-Byte 15,C ,22
ENG106031-ENG99415-ECU ID2 PartNumber HW SW-Byte 16,  ,22
ENG106031-ENG101004-ECU ID2 PartNumber HW SW-Byte 17,  ,22
ENG106031-ENG100194-ECU ID2 PartNumber HW SW-Byte 18,  ,22
ENG106031-ENG102302-ECU ID2 PartNumber HW SW-Byte 19,  ,22
ENG106031-ENG100432-ECU ID2 PartNumber HW SW-Byte 2,K ,22
ENG106031-ENG102337-ECU ID2 PartNumber HW SW-Byte 20,  ,22
ENG106031-ENG100802-ECU ID2 PartNumber HW SW-Byte 21,  ,22
ENG106031-ENG101604-ECU ID2 PartNumber HW SW-Byte 22,  ,22
ENG106031-ENG103171-ECU ID2 PartNumber HW SW-Byte 3,0 ,22
ENG106031-ENG99780-ECU ID2 PartNumber HW SW-Byte 4,9 ,22
ENG106031-ENG101635-ECU ID2 PartNumber HW SW-Byte 5,5 ,22
ENG106031-ENG100290-ECU ID2 PartNumber HW SW-Byte 6,9 ,22
ENG106031-ENG101242-ECU ID2 PartNumber HW SW-Byte 7,7 ,22
ENG106031-ENG101974-ECU ID2 PartNumber HW SW-Byte 8,9 ,22
ENG106031-ENG100834-ECU ID2 PartNumber HW SW-Byte 9,5 ,22
ENG106032-ENG103506-ECU ID2 PartNumber VW SW ID-Byte 1,1 ,20
ENG106032-ENG99970-ECU ID2 PartNumber VW SW ID-Byte 10,P ,20
ENG106032-ENG103845-ECU ID2 PartNumber VW SW ID-Byte 11,  ,20
ENG106032-ENG103008-ECU ID2 PartNumber VW SW ID-Byte 12,L ,20
ENG106032-ENG100040-ECU ID2 PartNumber VW SW ID-Byte 13,1 ,20
ENG106032-ENG101630-ECU ID2 PartNumber VW SW ID-Byte 14,5 ,20
ENG106032-ENG99906-ECU ID2 PartNumber VW SW ID-Byte 15,9 ,20
ENG106032-ENG99415-ECU ID2 PartNumber VW SW ID-Byte 16,± ,20
ENG106032-ENG101004-ECU ID2 PartNumber VW SW ID-Byte 17,1 ,20
ENG106032-ENG100194-ECU ID2 PartNumber VW SW ID-Byte 18,1 ,20
ENG106032-ENG102302-ECU ID2 PartNumber VW SW ID-Byte 19,4 ,20
ENG106032-ENG100432-ECU ID2 PartNumber VW SW ID-Byte 2,K ,20
ENG106032-ENG102337-ECU ID2 PartNumber VW SW ID-Byte 20,8 ,20
ENG106032-ENG103171-ECU ID2 PartNumber VW SW ID-Byte 3,0 ,20
ENG106032-ENG99780-ECU ID2 PartNumber VW SW ID-Byte 4,9 ,20
ENG106032-ENG101635-ECU ID2 PartNumber VW SW ID-Byte 5,5 ,20
ENG106032-ENG100290-ECU ID2 PartNumber VW SW ID-Byte 6,9 ,20
ENG106032-ENG101242-ECU ID2 PartNumber VW SW ID-Byte 7,7 ,20
ENG106032-ENG101974-ECU ID2 PartNumber VW SW ID-Byte 8,0 ,20
ENG106032-ENG100834-ECU ID2 PartNumber VW SW ID-Byte 9,3 ,20
ENG106033-ENG103506-ECU ID3 HW ID VW-Byte 1,0 ,3
ENG106033-ENG100432-ECU ID3 HW ID VW-Byte 2,0 ,3
ENG106033-ENG103171-ECU ID3 HW ID VW-Byte 3,5 ,3
ENG106034-ECU ID4 VW Tester ID,00 00 00 00 14 BF B1 31 31 34 ,10
ENG108997-ENG103506-Software Version Number-Byte 1,± ,4
ENG108997-ENG100432-Software Version Number-Byte 2,1 ,4
ENG108997-ENG103171-Software Version Number-Byte 3,1 ,4
ENG108997-ENG99780-Software Version Number-Byte 4,4 ,4
ENG108998-ENG103506-Software Version Number(Front)-Byte 1,0 ,4
ENG108998-ENG100432-Software Version Number(Front)-Byte 2,3 ,4
ENG108998-ENG103171-Software Version Number(Front)-Byte 3,2 ,4
ENG108998-ENG99780-Software Version Number(Front)-Byte 4,9 ,4
ENG109228-System Data Part 1 (rear),00 04 01 59 A9 00 ,6
ENG109230-System Data Part 10 (rear),30 30 31 30 30 30 31 36 32 36 31 ,11
ENG109232-System Data Part 11 (rear),00 ,1
ENG109234-System Data Part 12 (rear),3F ,1
ENG109236-System Data Part 13 (rear),7E 40 00 ,3
ENG109238-System Data Part 2 (rear),00 00 00 00 10 84 00 00 ,8
ENG109240-System Data Part 3 (rear),00 01 00 01 02 00 05 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109242-System Data Part 4 (rear),00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109244-System Data Part 5 (rear),00 00 00 0B 00 03 3D 00 00 FF FF 7E 40 00 ,14
ENG109246-System Data Part 6 (rear),01 10 09 C2 ,4
ENG109248-System Data Part 7 (rear),06 10 17 62 61 97 36 24 01 05 FE 00 00 00 00 00 ,16
ENG109250-System Data Part 8 (rear),05 57 35 2E 98 40 64 25 79 03 03 02 00 00 00 00 ,16
ENG109252-System Data Part 9 (rear),30 30 30 30 30 30 30 30 37 35 30 34 30 32 42 52 46 30 30 31 31 37 31 30 30 36 31 31 ,28
ENG109253-System Data Part1,00 00 01 0C 16 02 00 00 00 01 00 11 00 0F D9 00 00 58 89 00 02 02 04 04 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8F 12 12 12 00 02 01 00 00 00 ,56
ENG109254-System Data Part2,00 00 00 00 00 00 65 92 74 7D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 30 30 30 30 30 37 35 30 34 30 32 00 00 07 07 07 07 07 07 07 07 07 07 07 07 07 00 00 06 00 00 06 02 02 06 06 05 05 07 07 07 02 05 06 01 06 07 04 07 07 03 03 05 06 07 05 07 07 00 07 04 02 01 01 03 05 04 07 07 07 07 03 07 07 00 02 01 00 00 00 00 01 01 00 00 00 00 01 02 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 03 00 00 00 00 00 01 00 00 01 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 ,216
ENG109255-System Data Part3,FF FF 08 5E 03 02 DD E5 00 46 26 D9 5E FF FF 08 CD 01 02 89 61 00 42 36 D1 39 FF FF 08 B1 01 02 42 CC 00 3E 55 12 B4 FF FF 08 C1 04 02 22 86 00 3C FA A4 B0 FF FF 08 C1 08 02 22 86 00 3C FA A5 0A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 0A 00 84 AC 22 E0 FE 00 00 00 00 00 00 00 00 A5 FF ,174
ENG109256-System Data Part4,10 09 17 04 14 91 84 32 01 01 00 00 00 00 42 52 46 2D 30 30 31 31 37 2E 30 39 2E 31 30 30 30 30 31 30 34 31 34 31 32 31 30 31 30 30 35 54 55 45 52 2D 53 47 20 46 54 20 20 20 30 30 30 31 35 33 30 35 35 30 ,68
ENG109257-System Data Part5,03 31 3D 42 98 83 30 00 05 06 00 00 00 00 00 00 00 00 00 00 ,20
ENG109258-System Data Part6,FF FE 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 01 00 01 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 ,38
ENG109259-System Data Part7,00 ,1
ENG109260-System Data Part8,3F ,1
ENG109263-System Parameter Part16,FF 11 00 01 81 C8 F6 30 39 16 06 17 00 00 ,14
ENG109264-System Parameter Part-17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 2A 0A 08 03 79 2A 0A 3D 00 19 00 00 00 00 00 00 00 00 00 00 00 C2 42 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
ENG109265-System Parameters Part 1 (rear),74 9E 0F 34 00 05 6F 50 ,8
ENG109266-System Parameters Part 10 (rear),00 ,1
ENG109267-System Parameters Part 2 (rear),0C A8 0E 56 53 65 00 00 06 08 10 1E 50 96 3F 48 84 00 5A 3F 01 FF 58 44 ,24
ENG109268-System Parameters Part 3 (rear),3E 28 64 50 3E 3E 3E 3E 8A 92 B2 99 07 07 07 87 FB 84 65 34 00 44 28 46 ,24
ENG109269-System Parameters Part 4 (rear),07 B7 82 C1 73 46 10 27 3C 85 14 2B 0D 20 08 0C ,16
ENG109270-System Parameters Part 5 (rear),87 51 12 1B 37 83 A4 7D 0C 13 C5 18 B4 22 19 FF ,16
ENG109271-System Parameters Part 6 (rear),00 19 19 3E 42 71 77 BB BC FF 00 5A 6B CA D6 FF 00 2D 33 66 CC FF DF 77 6B 5E C6 1E 03 64 83 02 51 50 1F 7F 7D 00 ,38
ENG109272-System Parameters Part 7 (rear),0E 46 20 20 20 0D 03 02 02 0D 0D 5A 34 32 03 22 05 02 ,18
ENG109273-System Parameters Part 8 (rear),03 00 00 D0 ,4
ENG109274-System Parameters Part 9 (rear),B6 E5 A4 3F B7 E5 08 E0 0F 0A E0 0C 9E E6 06 A1 D0 26 0D A6 94 9E E7 07 A6 FF B7 B6 B7 B7 10 B8 81 9D 9D 9D 9D 81 D0 1C ,40
ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 ,16
ENG109280-System_Parameter_1,E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 ,16
ENG109281-System_Parameter_10,1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 ,16
ENG109282-System_Parameter_11,75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 ,16
ENG109283-System_Parameter_12,00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 ,16
ENG109284-System_Parameter_13,00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F ,16
ENG109285-System_Parameter_14,74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 ,16
ENG109286-System_Parameter_15,00 00 ,2
ENG109287-System_Parameter_2,18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 ,16
ENG109288-System_Parameter_3,46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 ,16
ENG109289-System_Parameter_4,00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 ,16
ENG109290-System_Parameter_5,0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 ,16
ENG109291-System_Parameter_6,D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 ,16
ENG109292-System_Parameter_7,10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 ,16
ENG109293-System_Parameter_8,0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 ,16
ENG109294-System_Parameter_9,00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 ,16
ENG109297-System-Parameter Block,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110034-VW-Identification,30 30 31 31 30 33 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 30 31 41 20 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 39 33 41 20 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 4A 33 38 36 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 33 32 39 45 56 5F 44 43 55 34 32 42 72 6F 73 65 44 72 69 76 65 53 69 64 65 00 00 00 00 41 30 33 30 30 34 01 81 C8 F6 30 39 16 06 17 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110126-MAS00478-Window_Lifter_Position-Reserved,00 ,8
ENG110126-ENG102781-Window_Lifter_Position-Data 1,0.25 ,8
ENG110126-ENG102143-Window_Lifter_Position-Data 2,8789.5 ,8
ENG110126-ENG103757-Window_Lifter_Position-Data 3,00 ,8
ENG110126-ENG101787-Window_Lifter_Position-Data 4,01 ,8
Elapsed Time: 00:39
And a scan of my car.
Thursday,31,May,2018,17:46:11:35994
VCDS Version: 18.2.1.2 (x64)
VIN: WVWZZZ3CZ7E100568   License Plate: 31-05-2018
Mileage: 207540km-128959mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 56 62 69 6C
          72 77
VIN: WVWZZZ3CZ7E100568   Mileage: 207540km-128959miles
   Part No SW: 06F 906 056 GN    HW: 06F 906 056 EK
   Component: MED9.5.10       G00 0184
   Revision: 69H03---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 05311 000 00000
   VCID: 7BF47DD13A69FA9C72-802E
006480 - Radiator Fan (V7)
               P1950 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 48
                    Mileage: 205677 km
                    Date: 2018.04.17
                    Time: 16:48:29
                    RPM: 680 /min
                    Load: 41.9 %
                    Speed: 1.0 km/h
                    Temperature: 93.0°C
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0668044179
   Coding: 0013710
   Shop #: WSC 09436 000 1048576
   VCID: 2F6C9981BE91D63C8E-807A
   Part No SW: 3AA 907 044 BA    HW: 3AA 907 044 BA
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0618004A02
   VCID: 70EE5AFDAB2F89C4D7-8024
9484402 - Motor for Indirect Ventilation Flap
          B10B8 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 231
                    Mileage: 204394 km
                    Date: 2018.03.19
                    Time: 20:20:14
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 126
                    Mileage: 204394 km
                    Date: 2018.03.19
                    Time: 18:59:24
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 126
                    Mileage: 204394 km
                    Date: 2018.03.19
                    Time: 18:59:24
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [008] - Open or Short to Plus
                    Reset counter: 162
                    Mileage: 207480 km
                    Date: 2018.05.30
                    Time: 18:52:09
   Revision: 00H54000    Serial number: 00000008504106
   Coding: E58C0FA510000000C0000F000F0000008019FF4B6410210C000000000000
   VCID: 336495F152B9F2DCEA-8066
   Subsystem 1 - Part No: 3C1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer VW461   012 0503
   Coding: 00063445
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     091006 014  1201
   Coding: 00471077
   Shop #: WSC 12345
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35831413600938
   Coding: 310003
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 336495F19AB9F2DCEA-8066
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 03 AIRBAG VW8   031 2522
   Revision: 11031000    Serial number: 003B1PLSDHB1
   Coding: 0012339
   VCID: 306E9AFDA3AFC9C497-8064
   Subsystem 1 - Serial number: 6332MSME1228235C
   Subsystem 2 - Serial number: 6342MSME13370E2C
   Subsystem 3 - Serial number: 6351HTS66HB0HON6
   Subsystem 4 - Serial number: 6361HTS6S4CSD4N6
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C9953507P
   Coding: 0000312
   VCID: 2E528485B99BDF3485-807A
   Part No SW: 3C0 920 870 T    HW: 3C0 920 870 T
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 02129 003 1048576
   VCID: 346696ED57B7F5E4F3-8060
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3690P10C141166
   Coding: F9A07F46404602002002
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 43674 001 1048576
   VCID: 3978A7D970D5088C20-806C
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
                    Reset counter: 139
                    Mileage: 206910 km
                    Date: 2018.05.18
                    Time: 14:41:53
02827 - Wake-Up request via ESP
                    Reset counter: 139
                    Mileage: 206910 km
                    Date: 2018.05.18
                    Time: 14:41:54
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 F
   Component: RNS-MID       H06 5269
   Revision: AB001001    Serial number: VWZ6Z7L7135074
   Coding: 02010400010000200000
   VCID: 3B74BDD1BAE93A9C32-806E
   Component: EU West V15  8515
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0329
   Revision: 12101005    Serial number: 0001530550
   Coding: 0011FF
   ROD: EV_DCU42BroseDriveSide_VW32.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388__TSG-HL  005 1114
   Serial number: 00000000750402
   Coding: 0000D0
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.133 H07 1806
   Shop #: WSC 02069 000 90108
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051030E76300294157008CF0B607C00
   Part No SW: 3C0 959 702 A    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0329
   Revision: 14101005    Serial number: 0001436895
   Coding: 0011FE
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 275C71A15E618E7C46-8072
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389__TSG-HR  005 1114
   Serial number: 00000000748883
   Coding: 0000D0
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 G    HW: 3C0 907 801 G
   Component: EPB  VD8HC005   013 0005
   Revision:   013
   Coding: 0000012
   VCID: 26427CA5916B97747D-8072
02844 - Lamp for Automatic Parking Function
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 126
                    Mileage: 206264 km
                    Date: 2018.04.30
                    Time: 17:20:08
                    Voltage: 10.46 V
                    Count: 64
Address 69: Trailer        Labels: 1K0-907-383-V1.clb
   Part No SW: 1K0 907 383     HW: 1K0 907 383
   Component: ANHAENGERELEKTR 003 0020
   Coding: 0000001
   VCID: 6ADA489545F3731499-803E
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J810528
   Coding: 0031007
   VCID: 5FCC29418EB106BC7E-800A
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 B    HW: 5N0 035 730 B
   Component: J412                8502
   Revision: 00015000    Serial number: 0000B7A090504
   Coding: 0020041
   VCID: 275C71A196618E7C46-8072
01524 - Antenna for Telephone
                    Fault Status: 00101011
                    Reset counter: 135
                    Mileage: 206716 km
                    Date: 2018.05.15
                    Time: 16:54:38
End-------------------------(Elapsed Time: 03:28)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
I have :
ENG109297-ENG100496-System-Parameter Block-Bytes 1-20,7F BE 0F 34 00 0D C3 51 90 F2 07 E4 E4 62 00 28 E4 00 4C 00
You have:
Diver
C?ID=290183
You need to look at code
This is sorted per an email and a conversation here http://forum.vwpassat.nl/index.php?...-combinatie-met-laatste-versie-vcds/?p=811710
Using a current version of VCDS you should be able to make that modification to Byte 8 in Adp channel ENG109279 -or- ENG109297.
For the purpose of adding clarity for anyone using older instructions with one of our latest VCDS Release/Beta versions, this is an example from another vehicle that we had Adpmaps from:
1) VCDS Version: Release 17.8.0 (x64) Data version: 20170721 - DS276.2:
  • ENG109279-ENG99426-System_Parameter_0-System Parameter Byte8,95 ,16
  • ENG109297-ENG100496-System-Parameter Block-Bytes 1-20,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 ,242
2) VCDS Version: Beta 17.10.0 (x64) Data version: 20171026 - DS283.3:
  • ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 ,16
  • ENG109297-System-Parameter Block,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
In this exact case "7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28" was present in the older VCDS version under channel ENG109297-ENG100496 but the same values are available in two channels (ENG109279 -and- ENG109297) using the current version.
golfi_vend
Tartu, Estonia
C?ID=195131
Seems like my info is outdated.
Need to update my personal wiki. :)
ghost
C?ID=139898
Unfortunately that didn't work on 2013 Tiguan with Power Folding Mirrors from factory and gen4 modules. Changed mentioned bytes from 90 to 95 and still no joy
golfi_vend
Tartu, Estonia
C?ID=195131
Comfort closing enabled?
TBAx
C?ID=287144
Since you have a RHD car, the aforementioned tweak does not apply to your car. I'll provide instructions in exchange for an adaption channel map of your module 42. ;)
ghost
C?ID=139898
Sure mate. Inbox me if you can please
Regards
TBAx
C?ID=287144
ghost
C?ID=139898
Here you go:
SW:5N0-959-701-G   HW:3C0-959-793-C ---  Door Elect, Driver
;Component:TUER-SG FT    002 0504, Coding:0212BE
;EV_TSGFPQ35BRFVW46X,A04001,EV_TSGFPQ35BRFVW46X_VW36.rod
;Friday,08,January,2021,13:48:32:40917
;VCDS Version: Release 20.12.0  Data version: 20201124 DS322.0
;VCID: 393ACFFAB8C6474C04-806C
ENG106031-ENG103506-ECU ID2 PartNumber HW SW-Byte 1,3 ,22
ENG106031-ENG99970-ECU ID2 PartNumber HW SW-Byte 10,C ,22
ENG106031-ENG103008-ECU ID2 PartNumber HW SW-Byte 12,  ,22
ENG106031-ENG100040-ECU ID2 PartNumber HW SW-Byte 13,  ,22
ENG106031-ENG101630-ECU ID2 PartNumber HW SW-Byte 14,  ,22
ENG106031-ENG99906-ECU ID2 PartNumber HW SW-Byte 15,  ,22
ENG106031-ENG99415-ECU ID2 PartNumber HW SW-Byte 16,1 ,22
ENG106031-ENG101004-ECU ID2 PartNumber HW SW-Byte 17,6 ,22
ENG106031-ENG100194-ECU ID2 PartNumber HW SW-Byte 18,2 ,22
ENG106031-ENG100432-ECU ID2 PartNumber HW SW-Byte 2,C ,22
ENG106032-ENG103506-ECU ID2 PartNumber VW SW ID-Byte 1,5 ,20
ENG106032-ENG99970-ECU ID2 PartNumber VW SW ID-Byte 10,F ,20
ENG106032-ENG103008-ECU ID2 PartNumber VW SW ID-Byte 12,R ,20
ENG106032-ENG101630-ECU ID2 PartNumber VW SW ID-Byte 14,6 ,20
ENG106032-ENG99906-ECU ID2 PartNumber VW SW ID-Byte 15,1 ,20
ENG106032-ENG101004-ECU ID2 PartNumber VW SW ID-Byte 17,5 ,20
ENG106032-ENG100194-ECU ID2 PartNumber VW SW ID-Byte 18,0 ,20
ENG106032-ENG100432-ECU ID2 PartNumber VW SW ID-Byte 2,N ,20
ENG106032-ENG102337-ECU ID2 PartNumber VW SW ID-Byte 20,9 ,20
ENG106032-ENG100834-ECU ID2 PartNumber VW SW ID-Byte 9,4 ,20
ENG106033-ENG103171-ECU ID3 HW ID VW-Byte 3,9 ,3
ENG106034-ECU ID4 VW Tester ID,20 20 20 20 20 20 20 20 20 20 ,10
ENG108997-ENG100432-Software Version Number-Byte 2,5 ,4
ENG108997-ENG103171-Software Version Number-Byte 3,0 ,4
ENG108998-ENG100432-Software Version Number(Front)-Byte 2,5 ,4
ENG108998-ENG103171-Software Version Number(Front)-Byte 3,0 ,4
ENG108998-ENG99780-Software Version Number(Front)-Byte 4,4 ,4
ENG109228-System Data Part 1 (rear),00 00 01 A4 89 00 ,6
ENG109230-System Data Part 10 (rear),30 30 31 30 30 30 31 32 34 39 37 ,11
ENG109234-System Data Part 12 (rear),2F ,1
ENG109236-System Data Part 13 (rear),2C 10 00 ,3
ENG111562-System Data Part 14 (rear),5A ,1
ENG109238-System Data Part 2 (rear),00 00 00 0C 0B 2F 00 00 ,8
ENG109240-System Data Part 3 (rear),07 07 07 07 07 07 07 00 07 07 07 07 00 00 00 00 07 07 07 07 00 00 00 00 ,24
ENG109242-System Data Part 4 (rear),00 00 01 03 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109244-System Data Part 5 (rear),00 00 00 00 00 03 25 00 00 B3 84 2C 10 00 ,14
ENG109246-System Data Part 6 (rear),00 10 29 C1 ,4
ENG109248-System Data Part 7 (rear),13 04 26 24 97 C1 26 97 01 01 FE 00 00 00 00 00 ,16
ENG109250-System Data Part 8 (rear),3A B4 42 D0 C0 33 87 25 80 04 08 00 00 00 00 00 ,16
ENG109252-System Data Part 9 (rear),30 30 30 30 30 30 30 37 39 30 32 31 31 36 42 52 46 30 30 31 32 36 30 34 31 33 31 31 ,28
ENG109253-System Data Part1,00 00 00 0C 09 16 00 00 00 01 00 04 00 13 A3 00 00 BE 63 00 01 16 04 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8F 12 12 12 00 03 01 00 00 00 ,56
ENG109254-System Data Part2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 30 30 30 30 37 39 30 32 31 31 36 0D 07 07 07 07 07 07 07 01 07 07 07 01 07 00 00 01 03 01 00 07 07 06 02 01 02 00 02 01 00 00 00 03 00 00 00 00 01 01 00 00 00 00 03 01 00 00 00 05 07 03 06 00 06 07 01 04 07 00 03 03 06 04 07 07 07 00 00 00 00 01 02 00 00 00 00 00 00 00 00 00 01 01 00 01 00 01 05 00 00 03 00 03 00 00 06 00 00 00 02 00 01 05 00 00 00 00 00 00 00 00 00 07 07 00 03 00 01 00 02 01 07 07 01 02 04 07 00 00 00 00 00 00 05 02 00 07 02 03 07 07 03 07 07 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 ,216
ENG109255-System Data Part3,FF FF 08 72 01 01 95 D4 01 23 9E C1 36 FF FF 08 28 01 00 00 00 00 03 80 02 07 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 7A C4 84 8C 02 E1 FF 00 00 00 00 00 00 00 00 A5 FF ,174
ENG109256-System Data Part4,13 04 24 18 26 91 84 32 01 10 00 00 00 00 42 52 46 2D 30 30 31 32 34 2E 30 34 2E 31 33 30 30 30 31 31 38 32 36 31 32 31 31 30 30 30 39 54 55 45 52 2D 53 47 20 46 54 20 20 20 30 30 30 36 39 30 33 35 39 38 ,68
ENG109257-System Data Part5,3A AD 42 01 C1 03 81 00 01 00 00 00 00 00 00 00 00 00 00 00 ,20
ENG109263-System Parameter Part16,BE 12 02 00 06 40 16 05 4D 0D 05 1D 00 00 ,14
ENG109264-System Parameter Part-17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
ENG109265-System Parameters Part 1 (rear),7F BE 4F 34 00 04 C3 51 ,8
ENG109267-System Parameters Part 2 (rear),0C 58 0A 5A 40 7A 00 00 04 06 0C 16 37 BC 3F 1F 48 00 5A 2F 02 35 29 44 ,24
ENG109268-System Parameters Part 3 (rear),4B 37 64 64 46 3C 3C 3E 8A 92 B2 99 8C 88 88 88 FB 84 65 34 00 44 28 00 ,24
ENG109269-System Parameters Part 4 (rear),04 94 5A 96 73 0D 08 27 3C 85 14 2B 0D 20 10 0C ,16
ENG109270-System Parameters Part 5 (rear),87 51 12 1B 37 83 F4 7D 06 3F C5 18 B4 22 19 0F ,16
ENG109271-System Parameters Part 6 (rear),00 19 19 3E 42 71 77 BB BC FF 00 5A 6B CA D6 FF 00 2D 33 66 CC FF DF 77 6B 5E C6 1E 03 64 83 02 51 00 1F 7F FD 00 ,38
ENG109272-System Parameters Part 7 (rear),0E 56 20 20 20 0D 03 0D 02 0D 0D 5A 34 32 03 22 05 82 ,18
ENG109273-System Parameters Part 8 (rear),03 00 00 90 ,4
ENG109274-System Parameters Part 9 (rear),00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40
ENG109279-System_Parameter_0,7F BE 0F 34 00 0C C3 51 90 F2 07 E4 84 62 00 28 ,16
ENG109280-System_Parameter_1,E4 00 4C 00 0F 75 0A 87 69 96 00 00 05 08 0A 0C ,16
ENG109287-System_Parameter_2,0D 44 3F 62 9E 00 6E 3F 02 60 29 44 78 3C 64 4F ,16
ENG109288-System_Parameter_3,41 41 41 41 8A 88 99 93 8F 86 86 8A FD 72 B5 34 ,16
ENG109289-System_Parameter_4,00 53 50 19 07 9E 64 61 73 19 08 27 3C 86 14 28 ,16
ENG109297-System-Parameter Block,7F BE 0F 34 00 0C C3 51 90 F2 07 E4 84 62 00 28 E4 00 4C 00 0F 75 0A 87 69 96 00 00 05 08 0A 0C 0D 44 3F 62 9E 00 6E 3F 02 60 29 44 78 3C 64 4F 41 41 41 41 8A 88 99 93 8F 86 86 8A FD 72 B5 34 00 53 50 19 07 9E 64 61 73 19 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110034-VW-Identification,30 30 31 33 30 35 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 35 4E 30 39 35 39 37 30 31 47 20 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 39 33 43 20 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 4A 33 38 36 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 35 30 34 45 56 5F 54 53 47 46 50 51 33 35 42 52 46 56 57 34 36 58 00 00 00 00 00 00 00 41 30 34 30 30 31 00 00 00 00 00 00 00 01 01 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110126-ENG102781-Window_Lifter_Position-Data 1,0.75 ,8
ENG110126-ENG102143-Window_Lifter_Position-Data 2,3156.5 ,8
TBAx
C?ID=287144
You have this adaption channel:
adaption channelcurrent value
ENG109285-System_Parameter_1474 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00
replace E0 with E5 (= open with ignition) or E9 (= open with driver door).
ghost
C?ID=139898
Thanks a lot sir :)
