Car threw massive code last night with accompanying symptoms.
Came off on the off ramp to rest area for the usual and when it came to idle this engine code came up. Car never gets beat, travels 250 miles in each direction all highway and some local upstate roads.
Too tired to get upset, went to take care of businesss came back started and drove away. All gone. Could this be a one off? Pretty sure the guys at my Audi are gonna tell me there's nothing wrong after keeping it for 3 days. Last 2013 A4 threw a misfire on on a bridge at rush hour, dicey, never did it again. Never had a car with such an issue with such low miles. Son in Holland says they send different models to NA market? Hasn't even had first service, did my own oil and tires.
Saturday,26,May,2018,16:57:34:30397
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WAURNAF48HN070849 License Plate:
Mileage: 9823km-6103mi Repair Order:
Chassis Type: F4-AU49 (8W6)
Scan: 01 03 08 09 15 16 17 19 22 29 2B 36 39 3C 42 44 46 47 52 5F
6C 82 A5 BB BC CA CF D6 D7
VIN: WAURNAF48HN070849 Mileage: 9823km-6103miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels: None
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 0A5900320326010E34280000000000000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: 48DC83CAF3C54604AF-801C
15074 - Cylinder Disabling
P130A 00 [096] - -
Mileage: 9683 km
Date: 2018.05.25
Time: 22:03:45
Engine speed: 2715.50 /min
Normed load value: 7.1 %
Vehicle speed: 44 km/h
Coolant temperature: 101 ∞C
Intake air temperature: 36 ∞C
Voltage terminal 30: 12.792 V
FAC_TPS_1_SAE: 15.234375 %
FUP_H_SAE: 6330.0 kPa
MAP_MES_SAE: 32 kPa
Engine: operating status: PL
TAA: 21.500 ∞C
T_AST_SAE: 2683 s
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.148 V
15131 - Cylinder 3
P0303 00 [100] - Misfire Detected
Mileage: 9683 km
Date: 2018.05.25
Time: 22:03:45
Engine speed: 2739.75 /min
Normed load value: 9.4 %
Vehicle speed: 45 km/h
Voltage terminal 30: 12.773 V
FAC_TPS_1_SAE: 14.453125 %
FUP_H_SAE: 6310.0 kPa
MAP_MES_SAE: 30 kPa
TAA: 21.500 ∞C
T_AST_SAE: 2682 s
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.499 V
15128 - Cylinder 2
P0302 00 [100] - Misfire Detected
Mileage: 9683 km
Date: 2018.05.25
Time: 22:03:45
MAP_MES_SAE: 30 kPa
TAA: 21.500 ∞C
T_AST_SAE: 2682 s
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 9683 km
Date: 2018.05.25
Time: 22:03:45
MAP_MES_SAE: 30 kPa
TAA: 21.500 ∞C
T_AST_SAE: 2682 s
23126 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Mileage: 8210 km
Date: 2018.05.05
Time: 06:07:14
Engine speed: 2278.00 /min
Normed load value: 25.9 %
Vehicle speed: 115 km/h
Coolant temperature: 98 ∞C
Voltage terminal 30: 12.753 V
Unlearning counter according OBD: 30
IGA_IGC_SAE: 18.5 ∞
FTL_SAE: 74.90196201 %
selected gear: 6th gear
Fuel level: 44 l
Tank fill level diagnostic reference value: 31.0 l
T_AST_SAE: 2818 s
Fuel consumption per driving cycle: 6.20 l/100km
Address 03: ABS Brakes (J104) Labels:. 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Coding: 18AA409920A90A9611A6409520865292E6419E180204508802044A49678279
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 49DA86CEE8CFBF0CB0-801C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0205
Coding: 140805085544010D10000100880000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44C497FACFED626443-8010
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001485181
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 5C58C1A880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
131078 - Reference Voltage
B10AD 16 [009] - Voltage Too Low
Reset counter: 47
Mileage: 6310 km
Date: 2018.01.13
Time: 12:29:20
Voltage terminal 30: 14.26 V
Outside air temperature: 5.50 ∞C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363E0081CCD05155119188C98BB110B3D08000000000000000020001A010A690122025709
VCID: 024851E29579AC5431-8056
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 170310 043 0813
Serial number: 89435300301706909208
Coding: 5BC7F7
Serial number: 20386410X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 04 07 2016 00701226
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z02GE02
Coding: 350000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170405153619 00893
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE110021723311081
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CJ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00337720
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000017453006
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0104
Serial number: 003UQ000V9FS
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 4DD2B2DE1CA7A32C9C-8018
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0116R00996
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0116R00253
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J1700071VUH0U
Subsystem 4 - Part No SW: ----------- HW: 442 060 604 17
Serial number: 3577Y00AD21781A3020R
Subsystem 5 - Part No SW: ----------- HW: 442 060 604 17
Serial number: 3587Y00B921303C5338V
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 903 17
Serial number: 3517700C52220D22706X
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 903 17
Serial number: 3527700C52220D2180F0
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 904 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A722BF490E2ET
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 904 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A722BF492329G
Part No SW: 4M0 907 129 GB HW: 4M0 907 129 GB
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76A03D32C9B180F40D-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 C HW: 8W5 920 890 C
Component: FBenUSA H17 0313
Coding: 08E65191A888CF050223E9601800000008000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 43C694E6CAE3655C7A-8016
16777024 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
[BCME_0x23 communication error bap_error_timeout heartbeat]
Reset counter: 82
Mileage: 5880 km
Date: 2017.11.04
Time: 11:20:50
Part No SW: 8W6 907 468 D HW: 8W6 907 468 D
Component: Gateway H30 0308
Revision: 5B010004 Serial number: 0485B004317427
Coding: 03010001000006402907000000590010CC280007000000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4BD6BCC6E2B3AD1C82-801E
Subsystem 1 - Part No SW: 8W0 951 523 E HW: 8W0 951 523 E
Component: J453 MFL H04 0002
Serial number: 20170418202617 01335
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8524973604
Address 22: AWD (J492) Labels:* None
Part No SW: 8W0 927 755 HW: 0CJ 927 749
Component: B9_ML4_N_SD4 H01 0004
Serial number: 1626517574
Coding: 31000000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78BC330AC3A5F6841F-802C
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000065359013
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 3228C1226559DCD4E1-8066
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000252271452
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMDriveSideCONTIAU736.rod
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 3620FD328931C0F4CD-8062
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0057
Serial number: 0000253581510
Coding: 005D1B205E001080000100B2
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 40CC9BEADBF57E4467-8014
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41CA9EEED0FF774C68-8014
Part No SW: 8W0 907 064 CC HW: 8W0 907 064 C
Component: BCM2 MLBevo 018 0344
Coding: 012C00004F900080650FA0002E01000233024000010027500F0400000B04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7F4ED816E68BC1BC5E-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1708233GE
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000069306346
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0904
Serial number: >1082556
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA01Q5JA
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0057
Serial number: 0000252390411
Coding: 005D1B205E001080000100B0
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 3FCE9816A60B01BC1E-806A
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 HW: 8W5 035 880
Component: MU-P-LNS-US 033 0918
Serial number: A798D0HB026733
Coding: 019401020000000053220002041A00102F0002E501700904FE
VCID: 7CB42F1AF79DDAA47B-8028
Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
Component: NAR 2017 --- 0057
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0160
Serial number: TPO00117031700820148
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 R HW: 8W0 919 614 R
Component: ControlUnit_H H30 0206
Serial number: APVAK115021700040317
Compact Disc Database:
Component: Gracenote2 --- 3011
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG015644
Coding: 029401029A0FA10008404004
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: 3424C73A9F4DD2E4F3-8060
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W5 919 617 B HW: 8W5 919 617 B
Component: HeadUpDisplay H18 1640
Coding: 2A01E0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 47DE80F6FEDB497CA6-8012
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 C HW: 8W0 907 217 C
Component: BVS H16 0050
Coding: 0404090100000203022023A2A40000FC00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: 3C34EF1AB71D1AA43B-8068
Part No SW: 4M0 959 795 E HW: 4M0 959 795 C
Component: TSG HFS 009 0057
Serial number: 0000252233424
Coding: 000D1B2000001080400000A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 42C891E2D5F96C5471-8016
Component: TSG HBFS 009 0057
Serial number: 0000252894430
ROD: EV_DCU2RearPasseMAXHCONT.rod
Part No SW: 4M0 907 594 A HW: 4M0 907 594
Component: SAD_STG_1 012 0003
Coding: 208000049100
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
VCID: 3326C4269A43D5DCEA-8066
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16601DB2E9F120F4ED-8042
Component: LED1R H09 0003
End----------(Elapsed Time: 02:05, VBatt start/end: 12.1V/12.1V)-----------
