LOST ABS MK60EC1 coding
Fredrick Awuor
Kenya
C?ID=309834
hello,can anyone help with this abs coding,the new owner does not have a previous repair history apart from the engine ECU being taken out of car and swapped with another one to see if some unexplained faults could go away,I have tried some codes in another thread on mk60 here but not successful so far,I can see that VIN in ECU and IMMO advanced ID match,however theres a fault of immo not being adapted,[i do not know whether immo was bench flashed] i cleared it,it has not come back,but will check if it resurfaces tomorrow,any insights will be greatly appreciated,below are
the autoscans
Friday,25,May,2018,07:13:09:48669
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZ9U009952   License Plate: CF933Y
Mileage: 114580km-71196mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9U009952   Mileage: 114580km-71196miles
03-ABS Brakes -- Status: Not registered 0011
Address 01: Engine        Labels: 03C-906-032-BLG.lbl
   Part No SW: 03C 906 032 AK    HW: 03C 906 032 C
   Component: MED17.5.1       G   6457
   Revision: 96H07---    Serial number: VWX7Z0H63N881O
   Coding: 0000075
   Shop #: WSC 43127 000 1048576
   VCID: 6696BF75B46C2CE7EBB-8032
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 114571 km
                    Time: 01:15:21
                    RPM: 1766 /min
                    Load: 29.4 %
                    Temperature: 87.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 13.589 V
   Part No SW: 02E 300 051 F    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1803
   Revision: 04843012    Serial number: 00000807060297
   Shop #: WSC 44551 111 44551
   VCID: 1676CFB5C48C7C67BBB-8042
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Frequency: 255
                    Mileage: 114466 km
18261 - Powertrain Data Bus
            P1853 - 000 - Implausible Message from ABS Controller - Intermittent
                    Mileage: 114466 km
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00046 412 00000
   VCID: 75B4E839F5CAD77F521-8020
            000 -  -  - Intermittent
                    Reset counter: 30
                    Mileage: 114467 km
                    Count: 7
                    Count: 512
                    Count: 294
                    Count: 48390
            000 -  -
                    Reset counter: 245
                    Mileage: 114466 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 195
                    Count: 48640
                    Count: 57344
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 245
                    Mileage: 114466 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 100
                    Count: 48640
                    Count: 57344
00150 - Plausibility Brake Booster System
            000 -  -
                    Reset counter: 245
                    Mileage: 114466 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 398
                    Count: 48640
                    Count: 57344
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 245
                    Mileage: 114466 km
                    Count: 7
                    Count: 4608
                    Count: 104
                    Count: 48152
                    Count: 65280
01312 - Powertrain Data Bus
            014 - Defective
                    Reset counter: 248
                    Mileage: 114466 km
                    Count: 7
                    Count: 14
                    Count: 8704
                    Count: 161
                    Count: 48384
                    Count: 57600
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6C82CD5DAA8016B7BDF-8038
   Revision: 00H54000    Serial number: 00000008680100
   Coding: 038F0F2700041500471400001400000000097F075C000100000000000000
   VCID: 33301621B73E894FBC5-8066
   Component: Wischer 030908 020  0501
   Coding: 00049109
   Shop #: WSC 00046
                    Fault Status: 01101100
                    Reset counter: 248
                    Mileage: 114466 km
                    Voltage: 13.55 V
   Component: 15 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0BFBUE
   Coding: 0012597
   Subsystem 1 - Serial number: 6332MSME3D51026DE
   Subsystem 2 - Serial number: 6342MSME3B3571248
   Subsystem 3 - Serial number: 6352QSME69623159I
   Subsystem 4 - Serial number: 6362QSME73472C71L
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           752 0101
   Coding: 0012142
   VCID: 045285FDA210FEF755F-8050
   Part No SW: 1K0 920 864 G    HW: 1K0 920 864 G
   Revision: V0002000    Serial number: VWX7Z0H63N881O
   Coding: 0007503
   Shop #: WSC 50942 000 942208
   VCID: 303A192D4628B257C17-8064
                    Reset counter: 31
                    Mileage: 114549 km
                    Time: 00:00:05
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 080608F2001714
   Coding: E5817F060002020003
   Shop #: WSC 00046 412 12345
   VCID: 35342839B94A977F921-8060
                    Fault Frequency: 46
                    Reset counter: 247
                    Mileage: 114466 km
                    Time: 11:18:22
            000 -  -
                    Mileage: 114466 km
                    Time: 11:18:22
   Component: IMMO            VDD 1212
02241 - Engine Control Module; Immobilizer Data not Adapted
                    Mileage: 114466 km
                    Time: 11:18:20
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1210
   Coding: 0000694
   VCID: 392C24099552731F769-806C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A0E0B4560F4C8870F3-807E
                    Fault Frequency: 140
                    Reset counter: 43
                    Mileage: 114580 km
                    Time: 10:45:18
                    Voltage: 14.00 V
                        DU
                    Temperature: 38.0°C
                    RPM: 1235 /min
                    Speed: 47.0 km/h
                    Speed: 47.0 km/h
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 809002005103087F2D0484056008DF03E0FCA0
   VCID: 71BCDC298DA2FB5F8E9-8024
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000950
   VCID: 3A2E3B05905478077F3-806E
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B2D53DF2B0CE7765F-8020
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   VCID: 382A210DAE586A17897-806C
00098 - Rear Left Central Locking (Safe) Motor (V163)
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:14, VBatt start/end: 13.8V/13.8V)-----------
Friday,25,May,2018,15:06:28:48669
VIN: WVWZZZ1KZ9U009952   License Plate: CF935Y
Control Module Part Number: 1K0 920 864 G
  Component and/or Version: IMMO            VDD 1212
           Software Coding:
            Work Shop Code: WSC 00000
Advanced Identification
     Identification: VDD-024
     Revision: V0002000
     Date: 08.07.08
     Test stand number: 7702
     Manufacturer number: 0428
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 00000 000 00000
     Flash Date: --.--.--
Software
     DKBI339
     Y012
     Z0012
Misc.
     Hardware number: 1K0 920 864 G
     Lot Number: 000
     Type Lock: 0000
Car Info
     Chassis Number: WVWZZZ1KZ9U009952
VCDS Info:
iichel
Eindhoven, NB, NL
C?ID=284912
you'll need to care of that immo error, i'm not sure what VCDS can do for you
I made a code with the assumption
Golf MK5/6
1K chassis
RHD
1.4 TSI 170hp
000000000000000000000000000000000000 empty code
163B600D092400FD68F0066090B000803000 iichel 1
133B600D092400FDC8F0066090B000803000 iichel 2
Fredrick Awuor
Kenya
C?ID=309834
Golf MK5/6
1K chassis
RHD
1.4 TSI 170hp
thanks iichel,Im thinking immo was deleted,but unsure,I will try the codes tomorrow and report back
Fredrick Awuor
Kenya
C?ID=309834
UNFORTUNATELY i get request out of range error on both codes,so still hunting
Fredrick Awuor
Kenya
C?ID=309834
Hello Luo,
I am living in Mombasa Kenya. too.
Try this: 133b600d09220003c81406e9901b00c1b108
Hello,thanks I'll sure contact you when I come to Mombasa,I'm based in Industrial area ,Nairobi,I will try tomorrow and post back
Fredrick Awuor
Kenya
C?ID=309834
I'd probably make it something like 133B600d092400FDC8F0066090B000C1B108 just to accomodate the VIN
Hello,thanks iichel I'll try this as well and get back you,thanks for your continued support
Fredrick Awuor
Kenya
C?ID=309834
Still no luck,ABS module has refused to accept these codes, request out of range error is what I get
Donibcsi
Hungary
C?ID=28126
Try this: 133b600d09220003c81406e9901b0081b108
Donibcsi
Hungary
C?ID=28126
I repaired a lots cars in Nairobi around industrial area. My num. is 0717054477. Whatsapp too
iichel
Eindhoven, NB, NL
C?ID=284912
I'm sure help is always appreciated here. No exceptions.
But you'll need to keep in mind, for these ABS units, there are many variables stored in the coding.
Byte 0 and 3 contain the chassis info
Byte 1 and 4 the selling region
Byte 2 the brake disc diameter
Byte 7, 9, 11, 13 and 15 contain VIN digits
Byte 8, 10, 12, 14 and 16 contain the inverse of other bytes.
Other bytes relate to ESP/ESC, Diff locks, TPMS, HHC, ACC, TPMS etc etc
In the basis, taking a very similar car as a reference is a very good idea, however modifying certain bytes is an even better idea.
In one of my previous posts, I took your reference coding and substituted the VIN bytes for the appropriate ones, but still it's rejected.
Some of my tricks:
- Check coding length (newer modules have a longer coding)
- Find similar cars and modify coding step by step. Start with VIN bytes.
- Try and adapt codes, one step at a time.
- Make your own tools. Ross Tech doesn't provide a long code helper for these ABS units and I think that's a wise decision.
Excel is a handy tool if you want to modify hexadecimal code and offers some user-friendly interface.
Or you could make yourself a LBL file for the LCode2.
Donibcsi
Hungary
C?ID=28126
I know exactly, and I generated the coding by software but the problem I do not know the engine ID. If someone can telling me the ID I will be generate coding very easy
iichel
Eindhoven, NB, NL
C?ID=284912
It's a BMY 1.4 TSI engine
Gone But Not Forgotten
FYI:
Coding tables may specify PC of an engine code for displacement, but often the OEM isn't setting them to the actual value in the tables....... :banghead:
iichel
Eindhoven, NB, NL
C?ID=284912
FYI:
Yes, can confirm. My 75hp TDI was coded as if it were a 2.0 140hp TDI with 6-speed gearbox.
Hence why observations of auto-scans abroad show such consistency or inconsistency.............that is why I cry like a little bitch about always a scan being posted, the more scan comparisons to make a pattern....... the better!
Science and a hypothesis!
images
iichel
Eindhoven, NB, NL
C?ID=284912
Yep when I first started 'cracking' MK60EC1 codes, about a year ago, even less, I noted these inconsistencies as well and it took me quite a while to see it's not 'by design' but simply badly coded. It threw off my scripts quite badly and they couldn't make a lot of sense of it because they were programmed with 'Ordnung muss sein' in mind. This was not the case.
But it also indicates that it probably doesn't matter that much. You'll still get away with it... and the code will accepted.
Yup and I recall someone being nameless, trying to imply & run their mouth about this too & to others about me being dangerous in the name of safety and that I shouldn't give out long codes to the collective & gave me a scolding but than again, this person was charging people for long coding for profit & further to be done while deliberately convoluted the adaption process in public view and I to date never have......... ;)
Things will be full circle soon........
images
Nothing is more upsetting to me than the non release of required repair information or to hide behind a specification to abuse the release of said repair information & that everyone should for a fair price be entitled too.
I have first hand knowledge and a bone to pick on this subject and I indeed fight for it for everyone!
The CEL/MIL being illuminated by ABS past a ABS MIL qualifies such an event!
https://ecfr.io//Title-40/sp40.21.86.a
(15) Availability of manufacturer-specific scan tools. (i) By July 1, 2013, manufacturers shall make available for sale to the persons specified in paragraph (j)(3)(i) of this section their own manufacturer-specific diagnostic tools at a fair and reasonable cost. These tools shall also be made available in a timely fashion either through the manufacturer Web site or through a manufacturer-designated intermediary. Upon Administrator approval, manufacturers will not be required to make available manufacturer-specific tools with reconfiguration capabilities if they can demonstrate to the satisfaction of the Administrator that these tools are not essential to the completion of an emissions-related repair, such as recalibration. As a condition of purchase, manufacturers may request that the purchaser take all necessary training offered by the engine manufacturer. Any required training materials and classes must comply with the following:
(A) Similar training must be required by the engine manufacturer for the use of the same tool by its franchised dealerships or authorized service networks;
(B) The training must be substantially similar to such training in terms of material covered and the length of training;
(C) The training must be made available within six months after a tool request has been made;
(D) The training must be made available at a fair and reasonable price.
(ii) Manufacturers shall ship purchased tools in a timely manner after a request and training, if any, has been completed. Any required training materials and classes must be made available at a fair and reasonable price. Manufacturers who develop different versions of one or more of their diagnostic tools that are used in whole or in part for emission-related diagnosis and repair shall also insure that all emission-related diagnosis and repair information is available for sale to the aftermarket at a fair and reasonable cost. Factors for determining fair and reasonable cost include, but are not limited to:
(A) The net cost to the manufacturer's franchised dealerships or authorized service network for similar tools obtained from manufacturers, less any discounts, rebates, or other incentive programs;
(B) The cost to the manufacturer for preparing and distributing the tools, excluding any research and development costs;
(C) The price charged by other manufacturers of similar sizes for similar tools;
(D) The capabilities and functionality of the manufacturer tool;
(E) The means by which the tools are distributed;
(F) Inflation;
(G) The ability of aftermarket technicians and shops to afford the tools.
Manufacturers shall provide technical support to aftermarket service providers for the tools described in this section, either themselves or through a third-party of their choice.
(16) Changing content of manufacturer-specific scan tools. Manufacturers who opt to remove non-emissions related content from their manufacturer-specific scan tools and sell them to the persons specified in paragraph (j)(3)(i) of this section shall adjust the cost of the tool accordingly lower to reflect the decreased value of the scan tool. All emissions-related content that remains in the manufacturer-specific tool shall be identical to the information that is contained in the complete version of the manufacturer-specific tool. Any manufacturer who wishes to implement this option must request approval from the Administrator prior to the introduction of the tool into commerce.
(17) Reference materials. Manufacturers shall conform with the following industry standards. These documents are incorporated by reference in §86.1. Anyone may inspect copies at the U.S. EPA or at the National Archives and Records Administration (NARA). For information on the availability of this material at U.S. EPA, NARA, or the standard making bodies directly, refer to §86.1.
(i) SAE J1939-71, Revised January 2008. For providing a means for the application processes to access the OSI environment, manufacturers shall comply with this industry standard.
(ii) SAE J1939-73, Revised September 2006. For identification and scaling information necessary to interpret and understand data available through Diagnostic Message 8, manufacturers shall comply with this industry standard. In the alternate, manufacturers may comply with Service/Mode $06 pursuant to SAE J1979, Revised May 2007. These recommended practices describe the implementation of diagnostic test modes for emissions related test data. Manufacturers shall comply with either SAE J1939-73 or SAE J1979 beginning with Model Year 2013.
(iii) SAE J1939-81, Revised May 2003. For management of source addresses and the association of those address with an actual function and with the detection and reporting of network realized errors, manufacturers shall comply with this industry standard.
(iv) SAE J2403, Revised August 2007. For Web-based delivery of service information, manufacturers shall comply with this industry standard which standardizes various terms, abbreviations, and acronyms associated with on-board diagnostics. Manufacturers shall comply with SAE J2403 beginning with the Model Year 2013.
(v) TMC RP 1210B, Revised June 2007. For pass-thru reprogramming capabilities, manufacturers shall comply with Technology and Maintenance Council's (TMC) Recommended Practice TMC RP 1210B. In the alternate, manufacturers may comply with SAE J2534-1, Revised December 2004. These recommended practices provide technical specifications and information that manufacturers must supply to equipment and tool companies to develop aftermarket pass-thru reprogramming tools. Manufacturers shall comply with either TMC RP 1210B or SAE J2534-1 beginning with Model Year 2013.
(18) Reporting requirements. Performance reports that adequately demonstrate that each manufacturers website meets the information requirements outlined in paragraphs (j)(6)(i) through (j)(6)(vi) of this section shall be submitted to the Administrator annually or upon request by the Administrator. These reports shall indicate the performance and effectiveness of the websites by using commonly used Internet statistics (e.g., successful requests, frequency of use, number of subscriptions purchased, etc.). Manufacturers shall provide to the Administrator reports on an annual basis within 30 days of the end of the calendar year. These annual reports shall be submitted to the Administrator electronically utilizing non-proprietary software in the format as agreed to by the Administrator and the manufacturers.
(19) Prohibited acts, liability and remedies. (i) It is a prohibited act for any person to fail to promptly provide or cause a failure to promptly provide information as required by this paragraph (j), or to otherwise fail to comply or cause a failure to comply with any provision of this subsection.
(ii) Any person who fails or causes the failure to comply with any provision of this paragraph (j) is liable for a violation of that provision. A corporation is presumed liable for any violations of this subpart that are committed by any of its subsidiaries, affiliates or parents that are substantially owned by it or substantially under its control.
(iii) Any person who violates a provision of this paragraph (j) shall be subject to a civil penalty of not more than $ 31,500 per day for each violation. This maximum penalty is shown for calendar year 2002. Maximum penalty limits for later years may be set higher based on the Consumer Price Index, as specified in 40 CFR part 19. In addition, such person shall be liable for all other remedies set forth in Title II of the Clean Air Act, remedies pertaining to provisions of Title II of the Clean Air Act, or other applicable provisions of law.
(iv) Manufacturers will not have any emissions warranty, in-use compliance, defect reporting or recall liability for service on a heavy-duty engine that is not undertaken by the manufacturer, for any damage caused by their own tools in the hands of independent service providers, or for the use and misuse of third party tools.
[74 FR 8408, Feb. 24, 2009, as amended at 75 FR 22978, Apr. 30, 2010; 79 FR 23689, Apr. 28, 2014]
OP: LUO
or
If anyone sees auto-scans of this abstract please post or point to 0x01,0x02,0x03 with same or similar hardware and 1K VIN BASE.
Coding: 0000075
Revision: 00H35001
Coding: 134B000C09220003C81400E9901B00000000 VIN STRIP RHD
Coding: 133B600D09220003C81406E9901B0081B000 RHD stripped attributes
Coding: 133B600D09220003C81406E9901B0081B108 Don
Coding: 133B600D09220003C81406E9901B00C1B108 Don
Coding: 133B600D092400FDC8F0066090B000C1B108 iichel
Yes HH
Vehicle Identification No.WVWZZZ1KZ9U009952
ModelGolf 1,4
GOLF
Date of production26.09.2008
Year2009
Sales type1K1BT3
Engine CodeBLG
Transmission CodeKPY
Axle drive6A
EquipmentRS
x
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HAVehicle class differentiation -1K0-
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG4Hill hold assist + comfort driving assist
Emission standard0GGEmission standard EU4
Trailer hitch1D0without trailer towing
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E1Activated carbon canister
Aerials8ZKAntenna for AM/FM reception, "diversity" (for Japan)
Exterior mirror setting6XQExterior mirrors with memory feature, power-folding/adjustable, separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8Gsport-comfort version
Brake type in rear1KEDisc brakes in rear
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZDDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0LComponent parts set, complying with vehicle type for Japan, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ASElectronic stability control (ESC)
Owner's manuals0VAWithout owner's manual
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A1CD changer preparation
"Charism"2H0Without "drive select"
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC24Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JCRear shock absorption for sports version
Suspension system in frontG07Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7AAElectronic immobilizer
Inserts5MNDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FVSouth Africa manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
FußhebelwerkVF0Standard pedal cluster
Headlight activation8K0Without special driving light switching
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GGAlternator 110 A
Weight category rear axle0YBWeight range 2 installation control only, no requirement forecast
Weight category front axleL58Suspension range 58 installation control only, no requirement forecast
Base engineTF04-cyl. petrol engine 1.4 l assembly 03C.H (ALU)
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U1Folding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG1A6-speed automatic transmission
Brackets3P1Bracket for first aid kit and warning triangle
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8JXTwin headlamps for driving on the left (gas discharge) w/ integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5EInstrument cluster, km/h speedometer Japan
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Cassette and CD storage unit4W0without cassette / CD tray
coolbox1W2Glove compartment cooling system
child safety4H3Manual child lock
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y2Tropical zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
headrest for seat, rear3T2Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank treatment2LDFuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A5Petrol injector fuel system (FSI)
Body measures5C0Without special body measures
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Rear license plate bracket6P4Rear license plate carrier (Japan)
Front license plate bracket6W4License plate bracket fr (small, Japan)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0RRight-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2PBLeather-wrapped steering wheel with tiptronic
Speaker installation8RW10 speakers (passive)
Headlight range control8Q3Dynamic headlight range control (self-adjusting while driving)
Center armrest6E3Front center armrest
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q1Multi-function display/trip computer
Engine cooling8Z6Hot country
Engine specificationsD4P4-cylinder petrol engine 1.4 L/125 KW (16 V) Twin turbo with compressor and turbocharger Basic engine is: TF0
Left vanity mirror4SFLeft vanity mirror illuminated, with cover and pocket, extractable
Right vanity mirror4TFVanity mirror, right, illuminated, with cover and pocket, extractable
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WDIntegrated front fog light
Upgrading measuresGP0Vehicles w/o special upgrade measures
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCX8Alloy wheels 7J x 17
Radios8AMRadio for Japan
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K0Without tyre pressure monitor
tireH6LTires 225/45 R17 91W
Tire suppliersV0GMICHELIN tires
Spare wheel/breakdown kit1G6Space-saving spare wheel
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
PH2Air conditioning Climatronic
PXRXenon light (right-hand drive)
W4B4-door incl. power windows rear
Side airbag4X4Side airbag in front and rear with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SLLabels in Japanese
Locking mechanism for boot lid/cover rear4E0Tailgate/trunk lid unlocking from outside
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Nameplates for sales nameQD1Nameplates for sales name
Seat belt check9P1Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN0ESeat trim covers in woven fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety head restraint system3K0w/o safety head restraint system
Side lights7R3Side turn signal lights (white)
Horns8Y1Two-tone horn
Side and rear windows4KFheat protective glass for door, side and rear windows, darkened from b-pillar
Protective side molding4B2Body-colored protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JQSports bumpers
Rear stabilizer0BERear stabilizer
Front stabilizer bar0AEFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UCSports version
Headlamp washer system8X1Headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0NWNameplate set "TSI"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB29Type approval Japan
Carrier frequency for remote control5D3Carrier frequency 315 MHz with reduced transmitting power
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EJSpecial identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
