Trouble logging into vcds mobile
67sattelite
C?ID=214052
I can't seem to log into vcds mobile on my phone or laptop. It says I have the wrong username. I'm pretty sure I set it up the same as I set it up for this forum. Please help, I only use this stuff when I need it which is not very often so I may tend to forget exactly how to use it. Also I can't get vcds to work, it says that I need a firmware update.
Where exactly does it ask for a username? ;)
jakematic
NC USA
C?ID=129085
I think you mean VCDS-Cloud - that's the only place a username is required.
In the Options -> Test screen on VCDS it will show you the IP address of the HEX-NET.
Plug that into a browser (or use the app), while in infrastructure mode, login to VCDS Mobile, and update the firmware under Options -> Check for Updates.
67sattelite
C?ID=214052
I can't seem to get my laptop to come up on anything but the vcds 14.8.1 but then tells me that I need a firmware update. My phone thru the app comes up but then tells me I have the wrong username.
67sattelite
C?ID=214052
Thank you, I'll try when I get a chance.
BRMTDI
C?ID=247677
Ok so I try to use my device today it days I need a firmware update...
Trouble is it can only be done through vcds mobile, trouble with that is the default password of password does not work....?
Can anyone help, I need to reset my car, and have some cars to work on tomorrow and I have a device that technically is un usable.
Did you change the password?
Check that your device/browser isn't auto-CAPITALIZING the first letter of your password.
If that isn't it, reset the password. Power up the HEX-NET, press and hold the button for 15 seconds. It should produce a very short beep when you release it.
FL C6.5 Avant
C?ID=224391
Hey bud. Sorry to hear. I'm having issues with this latest update as well being unique to thr mobile interface (ser thread on update error) so I feel your pain. I don't have a whole lot to suggest other than did your default password somehow get changed?
Hopefully a super mod will see both of our issues and be able to get us up and running again......
BRMTDI
C?ID=247677
Will try that..hopefully I have some luck with it
