Sticky Free to a Good Home -- Bentley Repair Manual DVDs
Sticky
We have some old Bentley repair manual DVDs still in our storeroom. We stopped selling these some years ago when Bentley refused to update them to make them compatible with newer versions of Windows, which generated too many customer complaints.
They work best under XP, and I've heard they will work OK on XP in a VM.
Since we're giving them away for free, I don't make any promises and obviously won't provide any support.
These only cover NAR models. If you're a verified user here in the US and you're you want one, let me know via PM.
Here's what we have:
A4: VW R32 - 04 -- qty 1
B4: Audi 90 - 93-95 -- qty 3
B4: VW Passat - 95-97 -- qty 10 9 8
B5: VW Passat - 98-05 -- qty 1
B6: VW Passat - 06-09 -- qty 5 4 3 2 1
C5: Audi A6/S6 - 98-05 -- qty 1
NB: New Beetle - 98-09 -- qty 1
7L: VW Touareg - 04-09 -- qty 2 1
D3: Audi A8/A8L/S8 - 04-09 -- qty 5 4 3 2 1
D2: Audi A8/S8 - 97-03 -- qty 3 2 1
atomizer
C?ID=325670
yes, that is correct addr... I am having difficulty with private mess and learning about this ,that is why I came back here to say yes, THANK YOU
Johnson Motorwerks
C?ID=245616
Interested in the B4 Passat disc if you still have one.
Never saw a DM on the B4 CD.
Neither did I. Again, you need to PM me. In the new forum software we're running now, a PM is called a "Conversation".
B4: VW Passat - 95-97 should sill be available.
Johnson Motorwerks
C?ID=245616
Gotcha
My Apologize, I did receive a conversation MSG from you on this but it was a direct quote of what I had earlier posted so wasn't trying to guess at what that meant.
FutureRacer24
Colorado, USA
C?ID=221959
B4: Audi 90 - 93-95 -- qty 2
Hi Uwe,
I would be interested in a B4 disc as may B4 is requiring more maintenance at 370K+ milesage.
Also, I have a 2012 Touareg with 1232k on it and the Adblue 1000 mile countdown started. I stopped soon and tops for the Adblue with a name brand ADblue.
The countdown continued quickly.... in 350 miles the 1000 mile countdown went to 0.
But it hit 7 miles from my stop and I shutdown the engine after it was garaged.
It naturally would not restart. I pulled the Adblue tack which was full on Platinum Adblue, sealed of any openings to wire connectors and hoses and cleaned the take and pump.
I found little Adblue in the system, I removed and cleaned the injector which had crystalization but I count see that if had been working. I blew out the line which had very little amounts of Adblue in it and resealed it at both ends. All wire connectors were clean...
Do you have an Idea as to whether the pump, level detector or doubtfully the heater is bad? I'm in Florida for neck surgery so I need the vehicle....
How do I reset the computer to get it started after the right repair? I do have my Ross Tech diagnostic reader with me.... No codes.
Thanks!
John in Florida getting a neck transplant (#6 surgery)
