- Dec 28, 2016
- 579
- 409
- Amsterdam
- C?ID=295586
I'm usually in the habit of asking stuff that results in a 'not possible' answer, but here it goes;
On certain golf 7's (pre-facelift), it seems to be possible to change the ASR/ESP button behavior through changing a bit in the ABS module. Stock seems to be ASR off (short press) and ESP sport (long press). It can be recoded to ASR off/ESP off (which seems to be stock on a Golf R?), ESP sport/ESP off and probably a dozen other styles.
Anyway, this involves changing Byte 29 in de ABS controller (last byte). I was having a look at my ABS controller as I'm getting pretty fed up with the overactive ESP (as inn: I'd like to turn it off and have some fun every now and then. I've got the power to match anyway). Unfortunately, the ABS controller in my car seems to have 46 bytes, and byte 29 has hex value 'AA' (where golf 7’s have 09). Not something I'm going to touch.
Does anyone have an idea if this is possible, more in-depth knowledge of the coding of these modules and/or a Golf 7 R facelift autoscan?
ABS module:
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62057000001070
Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB8625088C2AA4200002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 77BE26B1CE6DD1FD84-8022
Autoscan:
ABS module:
Autoscan:
Sunday,04,February,2018,03:55:42:41109
VCDS Version: 18.1.0.2 (x64) HEX-NET CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WVGZZZ5NZJW123456 License Plate:
Mileage: 17976km-11169mi Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
42 44 47 4B 52 5F 65 69 6C 6D 75 82 A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZJW123456 Mileage: 17976km-11169miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA) Labels:. 03N-906-026-CUA.clb
Part No SW: 03N 906 026 D HW: 03N 907 309
Component: R4 2.0l BTD X24 3680
Revision: A1X24---
Coding: 01250032047605083000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20BTD01103N906026D 004005
ROD: EV_ECM20BTD011.rod
VCID: 2C14C9DD47ABA22539-8078
Readiness: 1110 1011
Part No SW: 0DL 300 011 M HW: 0GC 927 711 G
Component: GSG DQ500 H06 2001
Revision: 00H06V07
VCID: 3228D7A5658FF4D573-8066
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0451329535
Coding: 132C2C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E30F395A1D720B587-806A
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98226912
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0022
Serial number: Y0006QGM20164
Coding: 001000020000050081C281808181000000008181000000F400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide_VW37.rod
VCID: 3C34F99DB7CB32A5A9-8068
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000B00605887
Coding: 0002012420241001110510420010112A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 4AD8AF45ED1F9C152B-801E
Subsystem 2 - Part No SW: 3G0 907 049 E HW: 3G0 907 049 E
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
[PTC-Reduzierung durch MSG]
Reset counter: 200
Mileage: 17976 km
Date: 2018.02.04
Time: 03:53:28
Voltage terminal 30: 14.2 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 2
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001721700533
ROD: EV_BCMBOSCH_018.rod
VCID: 095A5049A899D70DE2-805C
Subsystem 1 - Part No SW: 5NB 955 119 HW: 5NB 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 170630 033 0372
Serial number: 00000001706280300593
Component: RLHS 042 0105
Serial number: S8Y17M08D14H01M31S46
Coding: 00A8EE
Serial number: 000000000ZY1718333XN
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223971734394
Part No SW: 3Q0 919 298 B HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0029
Serial number: 001607177478001
Coding: 0A31667A51
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000.rod
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 320167CB5CFF8728749C8145804087
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 12071741350391
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 383CE58D83F31E854D-806C
Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK
Component: AirbagVW21 005 0336
Serial number: 003VXR33ZYC9
Coding: 98FCC0C00C8000005C5400CF004800000065
VCID: 0A586F45AD9FDC15EB-805E
Belt Pretensioner left:
Serial number: 5NB857705C0216R00777
Coding: 80000D
Belt Pretensioner right:
Serial number: 5NB857706C0217R00515
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 808 17
Serial number: 35700000000B2B19A62O
Subsystem 4 - Part No SW: ----------- HW: 480 000 808 17
Serial number: 35800000000156842728
Subsystem 5 - Part No SW: ----------- HW: 480 400 208 17
Serial number: 3510001BB260B4F1B4BB
Subsystem 6 - Part No SW: ----------- HW: 480 402 807 17
Serial number: 3520001A524CDB11F48B
Subsystem 7 - Part No SW: ----------- HW: 480 402 907 17
Serial number: 3550001C322EA2B5730%
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 402 907 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001B526D7C0386BB
Subsystem 9 - Part No SW: ----------- HW: 480 402 907 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001B526D7C0475EE
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 402 907 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001B526D7C04615Z
Subsystem 11 - Part No SW: ----------- HW: 480 002 707 17
Serial number: I0M00000000D91C0252+
Subsystem 12 - Part No SW: ----------- HW: 480 002 707 17
Serial number: I0N000000002A1C0252W
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20170802501343
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 73A612A1DA15BDDDB8-8026
Part No SW: 5NA 920 791 B HW: 5NA 920 791 B
Component: KOMBI 407 3193
Coding: 07A400987E8C000801887B0F3401000880000000
VCID: 42C88765D52F4455E3-8016
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 23071710800155
Coding: 0B0500344F017300FB07225E9E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 3326D2A19A95FDDD78-8066
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001574160027313
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 E HW: 5QA 915 181 E
Serial number: 4480423804
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 F HW: 5Q0 907 155 F
Component: U13DCAC H25 0780
Serial number: 0024537
Serial number: HA1-00020.06.17
Coding: 0101
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45C29C79C401736DC6-8010
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000199457001
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA18A9A0098FCD4A-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006QGM20144
Coding: 001000020000150001C281808181000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Revision: --------
Coding: 14C002
VCID: 3A38FF85BDFF0C95BB-806E
Component: TSG FS 020 0041
Serial number: 080717EG809145
Coding: 003F1B20D200048000001000
VCID: 43C68261CA354D5DE8-8016
Part No SW: 5QF 909 144 HW: 5QF 909 144 _
Component: EPS_MQB_ZFLS 506 5572
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 075E5671BE8DA17DF4-8052
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00TYB7
Coding: 1223060001A00A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 6B960AC18225651D70-803E
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 21071710803739
Coding: 000000050100085207104F010A0000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X.rod
VCID: 72A817A5A50FB4D5B3-8026
Component: TSG BFS 020 0041
Serial number: 070717EG609369
Coding: 003F1120DE00048000001000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 022 A HW: 5NA 035 022
Component: MU-H-LND-EU H54 1121
Serial number: A846G0HS006021
Coding: 02730601000000005111010200880A331F0106E401200400DE
VCID: 312AD8A96089CFCD0A-8064
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT2116065
Subsystem 2 - Part No SW: V03 959 800 QR HW: -----------
Component: ECE 2017/2018 --- 0161
Compact Disc Database:
Component: Gracenote2 --- 1016
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000098730
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3424D1BD9F9BFAE561-8060
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0449274529
Coding: 0100000202000000
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG016316
Coding: 01230600A30F200000204814
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
VCID: 393AE089B8F9078DB2-806C
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: 31450492700000
Coding: 0AA8
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0717
Revision: --------
Coding: 02230601EA42380D3F1CBE020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW27.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 5NA 919 608 B HW: 5NA 919 608 B
Component: HeadupDisplay 023 0302
Coding: 574060
ASAM Dataset: EV_HeadUpDisplContiVW481 001015
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 47DE9671FE0D617D34-8012
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 29071712K20584
Coding: 000307060000040100262347C150A90098000E200040
ROD: EV_MFKBoschMQBB_VW27.rod
Component: TSG HFS 020 0041
Serial number: 120717EG908013
Coding: 002A11200101048000001000
Component: TSG HBFS 020 0041
Serial number: 190617EFJ09168
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 208040732602
ROD: EV_SunRoofCONTIAU736.rod
VCID: 3D32F499ACD13BAD9E-8068
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 14C002
VCID: 373EE6B18EED11FD44-8062
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16600B35E92708F57F-8042
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:37, VBatt start/end: 14.4V/14.4V)-----------
