Passat B6 - EBP acting up after battery died
MichaelEr
C?ID=144500
Hi,
My battery has died some time ago and after jump starting my car I am seeing issues with the EBP.
The symptoms are as follows:
  • Orange blinking crossed out parking brake MIL
  • AutoHold won't work
  • EBP won't disengage when hitting the gas pedal, it just keeps holding
(Could be other stuff that I am not aware of?)
(I am also not sure of the ABS coding, since I heard that it's usually gets lost when the battery is disconnected)
Below is the auto scan that I have captured after driving around (in order to clear the ESP and steering wheel MILs).
Sunday,05,October,2014,19:56:27:20180
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ3CZ8P028785   License Plate: 95-231-62
Mileage: 116920km-72650mi   Repair Order: AfterBatteryDied
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8P028785   Mileage: 116920km/72650miles
   Part No SW: 06F 906 056 GP    HW: 06F 906 056 EK
   Component: MED9.5.10       G00 0459
   Revision: 69H04---    Serial number: VWZCZ000000000
   Coding: 0000075
   Shop #: WSC 00028 028 00001
   VCID: 7DF1281E24BFBAF6F0B-8028
000819 - Knock Sensor 2 (G66)
               P0333 - 001 - Signal too High - Intermittent
                    Fault Status: 00100001
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    Temperature: 215.0∞C
005120 - EGR Valve (N18)
               P1400 - 002 - Electrical Malfunction - Intermittent
                    RPM: 2600 /min
                    Load: 63.5 %
                    Speed: 107.0 km/h
                    Temperature: 82.0∞C
001299 - Incorrect Immobilizer Key
               P0513 - 008 -  - Intermittent
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal - Intermittent
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09G 927 750 S    HW: 09G 927 750 S
   Component: AQ 250 6F           0746
   Revision: 00H69000    Serial number:
   Coding: 0000072
   VCID: 418994EE18C71E16D43-8014
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000775757014
   Coding: 0000384
   VCID: 1F4D3296CEF308E6827-804A
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 BT    HW: 3C0 907 044 BT
   Component: ClimatronicPQ46 122 0707
   Revision: 00122021    Serial number: 00000000000000
   VCID: 74E70D3A17F5FBBE8F5-8021
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000005010638
   Coding: 00840F0700041A00470A00000F000000000959435C000100000000000000
   VCID: 6FED02567ED3D866727-803A
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 110607 003  0205
   Coding: 00046997
   Shop #: WSC 00028
                    Reset counter: 43
                    Mileage: 116865 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.30 V
                    Reset counter: 43
                    Mileage: 116865 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 7.90 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 43
                    Mileage: 116865 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.90 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1PDLBQG+
   Coding: 0012354
   VCID: 306FC12AA36D879E2BD-8065
   Subsystem 1 - Serial number: 6332MSME1476271F
   Subsystem 2 - Serial number: 6342MSME1B747E23
   Subsystem 3 - Serial number: 6351HTS6D3KSE217
   Subsystem 4 - Serial number: 6361HTS6D3KO2L76
   Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
   Component: Lenks‰ulenmodul 006 0010
   Revision: 00006000    Serial number: 3C5953507BE
   Coding: 0001013
   VCID: 3365CE26527BBC8656F-8066
   Part No SW: 3C0 920 860 M    HW: 3C0 920 860 M
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00008 730 21870
   VCID: 2C57D55A8F45E37E175-8079
                    Fault Frequency: 8
                    Reset counter: 43
                    Mileage: 116857 km
                    Time: 01:47:37
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P07627018F
   Coding: FD807F060002021002
   VCID: 23453E66E29B2C06A6F-8076
                    Reset counter: 227
                    Mileage: 115401 km
                    Time: 13:10:34
01304 - Radio
                    Fault Frequency: 83
                    Reset counter: 44
                    Mileage: 115401 km
                    Time: 13:15:00
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 3979FC0E701746D69C3-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
02835 - Communications between Steering Column Lock and Convenience System
                    Reset counter: 43
                    Mileage: 116857 km
                    Time: 00:31:48
02861 - Electronic Steering Column Lock Check Sum Error
                    Reset counter: 43
                    Mileage: 116857 km
                    Time: 03:30:22
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 43
                    Mileage: 116857 km
                    Time: 01:47:52
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000528878710
   Coding: 0000181
   VCID: 3B75E6067A2B74C68EF-806E
                    Fault Status: 00100101
                    Reset counter: 43
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.133 H08 1901
   VCID: 3561F03E5C0FA2B678B-8060
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 11910A0001864E763004941570084F0B6078A0
                    Reset counter: 43
                    Mileage: 116857 km
                    Time: 01:49:19
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000538778706
   Coding: 0000180
   VCID: 3C77E51A7F2573FE875-8069
                    Reset counter: 44
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000088334
   Coding: 0010000
   Shop #: WSC 00098 730 93473
   VCID: 29592C4E80B7F656EC3-807C
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 2
                    Mileage: 116857 km
                    Voltage: 11.20 V
                    Count: 43
                    Hex Value: 0x12C1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 3
                    Voltage: 8.00 V
                    Count: 50
                    Hex Value: 0x0841
                    Hex Value: 0x0088
                    Hex Value: 0x1010
03190 - Incorrect Vehicle Type
                    Reset counter: 43
                    Mileage: 116857 km
                    Voltage: 11.20 V
                    Count: 98
                    Hex Value: 0x12C1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Reset counter: 2
                    Mileage: 116857 km
                    Voltage: 11.20 V
                    Count: 100
                    Hex Value: 0x12C1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1118
   Revision: 11006001    Serial number: 00000002032881
   Coding: 0000144
   VCID: 3D71E81E643F7AF6B0B-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1118
   Revision: 11006001    Serial number: 00000002005656
   Coding: 0000144
   VCID: 3E73EF12693961EEA91-806B
(I have had this issue in the past and never got to fix it, since there were no DTC saved, but this time there are - so I really want to sort that out)
Thanks a lot!
AIB Wolfgang
Coding: 0010000
Hello again,
please perform the correct coding of EPB and then start the basic settings. After that, you can clear the faultcodes.
Wolfgang
MichaelEr
C?ID=144500
Hey!
It works!!!
I am not getting any MILs and all the functions work as they should!
Thanks a lot!
Details below:
I have coded the module with the code:
0000057 = Parking Brake with Auto-Hold (Rest of World / PR-UH2)
(Taken from: http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Parking_Brake)
and performed all the basic settings that are outlined on that page.
This indeed cleared the DTCs but the MIL was still on and AutoHold wasn't working.
I have then went to the next page:
http://wiki.ross-tech.com/wiki/inde..._.26_Yaw_Rate_Sensor_.28G200.2FG202.2FG251.29
and performed only the:
Lateral/Longitudinal Acceleration & Yaw Rate Sensor (G200/G202/G251) Basic Settings
This has removed the MIL and the AutoHold system started to work!
That's basically it!
Below is a new auto scan (just before the ABS basic settings, and right after the EBP basic settings, after clearing DTCs using the AutoScan window)
Thursday,09,October,2014,11:33:49:20180
Mileage: 116970km-72681mi   Repair Order: AfterBS_AfterClearDTCs
VIN: WVWZZZ3CZ8P028785   Mileage: 116970km/72681miles
   Coding: 0000075
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    RPM: 2600 /min
                    Load: 63.5 %
                    Speed: 107.0 km/h
                    Temperature: 82.0∞C
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
   Coding: 0000072
   Coding: 0000384
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 0012354
   Coding: 0001013
   Coding: 0007105
                    Reset counter: 6
                    Mileage: 116971 km
                    Time: 11:30:00
   Coding: 0000181
   Coding: 0000180
   Coding: 0000057
   Coding: 0000144
   Coding: 0000144
What's weird is that there were no DTCs saved in neither the ABS module nor the EBP module.
(I have assumed that the issue is with the G251 sensor since I saw that code active in the SUPP codes section - 01279).
So my question is, what exactly is the SUPP codes section? and should I pay any attention to active codes there?
In addition,
since I don't have any MILs on, can I assume that all the braking systems work fine (e.g.: ABS/ESP/etc.)?
Thanks a lot for the help guys!
and here is a photo of the AutoHold light working!
In addition,
The Supported Codes function is explained on this page of our interactive manual but I do not have an explanation for the No fault code found results with an Active fault stored. It is also odd that this EPB module lost its coding ... even if the battery was seriously discharged or faulty. On the other hand however most of the Tech Tips and TPIs recommend a battery disconnect when that system is misbehaving so the most recent low voltage episode could have resolved a conflict?
Providing you do not have any fault codes shown in the scan and the dash warnings are not on (including proper operation of the ESP and EPB buttons) I want to believe it is operating properly at this time.
MichaelEr
C?ID=144500
Thanks for your answer Dana,
I have made another autoscan and checked the supp codes of both the ABS Brakes and the Parking Brake module.
There were no active codes in the supp codes for the Parking Brake module, but there a bunch of them in the ABS Brakes module (although there are no active codes in the autoscan.
Question is, should one be concerned due to these?
Is this normal?
Below is the scan and the screenshot from the ABS Brakes supp. codes window:
Wednesday,19,November,2014,10:09:02:20180
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Mileage: 119350km-74160mi   Repair Order: 19Nov2014
VIN: WVWZZZ3CZ8P028785   Mileage: 119350km-74160miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
   Coding: 0000075
   VCID: 7DF1281E24BFBAC904D-8028
               P1400 - 002 - Electrical Malfunction - MIL ON
                    Fault Status: 11100010
                    RPM: 2600 /min
                    Load: 63.5 %
                    Speed: 107.0 km/h
                    Temperature: 82.0∞C
000105 - Intake Manifold Pressure <-> Ambient Air Pressure
               P0069 - 008 - Incorrect Correlation - Intermittent
                    Fault Frequency: 40
                    Mileage: 118389 km
                    Time: 10:04:42
                    Load: 29.8 %
                    Temperature: 83.0∞C
   Coding: 0000072
   VCID: 418994EE18C71E29205-8014
   Coding: 0000384
   VCID: 1F4D3296CEF308D9761-804A
   VCID: 74E70D3A17F5FB817B3-8021
                    Fault Status: 00110000
                    Fault Frequency: 134
                    Reset counter: 91
                    Mileage: 117084 km
                    Time: 17:36:05
   VCID: 6FED02567ED3D859861-803A
   Coding: 00046997
   Shop #: WSC 00028
                    Reset counter: 79
                    Mileage: 118469 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.50 V
   Coding: 0012354
   VCID: 306FC12AA36D87A1DFB-8065
   Coding: 0001013
   VCID: 3365CE26527BBCB9A29-8066
   Coding: 0007105
   VCID: 2C57D55A8F45E341E33-8079
   VCID: 23453E66E29B2C39529-8076
                    Reset counter: 6
                    Mileage: 116971 km
                    Time: 11:30:00
01304 - Radio
                    Fault Frequency: 184
                    Reset counter: 93
                    Mileage: 116971 km
                    Time: 11:34:47
                    Reset counter: 79
                    Mileage: 118469 km
                    Time: 09:52:19
   VCID: 3979FC0E701746E9685-806C
   Coding: 0000181
   VCID: 3B75E6067A2B74F97A9-806E
   VCID: 3561F03E5C0FA2898CD-8060
   Coding: 0000180
   VCID: 3C77E51A7F2573C1733-8069
   Coding: 0000057
   VCID: 29592C4E80B7F669185-807C
Address 56: Radio
   Coding: 0000144
   VCID: 3D71E81E643F7AC944D-8068
   Coding: 0000144
   VCID: 3E73EF12693961D15D7-806B
End-------------------------(Elapsed Time: 02:12)--------------------------
Thanks a lot!
MichaelEr
C?ID=144500
Clear them...............I think it is not so important.
Sounds good to me, although they don't show up in the regular autoscan, so how would one be able to clear them? (There is no clear button in this window).
Beside the codes in this window, it seems that it's all clear (no lights are on and no codes found in the autoscan).
One thing though,
When I had the autohold issue, I also didn't have any codes in the Parking Brake module, but there was the G251 (01279) code saved in the supp. codes window (which actually gave me the clue for the fix)
Zenerdiode
Newcastle, England
C?ID=24330
Just use the regular 'Clear Codes' button. In some modules - even if no fault codes are stored - pressing Clear Codes does a reset of the module. e.g. In the engine module, clearing codes also resets the Readiness bits and clears the learned adaptive trim values.
