hey guys,
so far loving VCDS, never used a scan tool in my life before this. got my mk4 diagnosed and fixed after months of annoying symptoms and its already paid for itself. but now onto the mk5, ive posted an auto scan below, all errors have been fixed/ or never returned, but the ones in Address 16: steering wheel.
only recently purchased the car and its not running how its supposed to, i have alot of weird things going on, and as soon as its down at my mechanics it magically runs perfectly (which is starting to get really annoying)
my question is, what symptoms would i be experiencing with the fault codes in address 16
i have 4 issues with the car at the moment which i dont know/think are related the only one that could possibly be is while accelerating, the car will just stop pulling as if ive let go of the pedal (as if the cars lost power), for a split second and then power and pull is regained
again please excuse my ignorance, just a female who loves her golfs and wants them fixed
Thanks in advanced
Friday,19,September,2014,18:32:04:47635
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ1KZ8U019938 License Plate:
Mileage: 72350km-44956mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 77
VIN: WVWZZZ1KZ8U Mileage: 72350km/44956miles
77-Telephone -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
Component: R4 2.0l PPD1.2 G 1155
Revision: --H52--- Serial number: VWX7Z0GD3NE03Q
Coding: 0000072
Shop #: WSC 00046 412 00000
VCID: 6BD5E0684A3FE3465EF-803E
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
VCID: 73E5F808120F3B8696F-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CP HW: 1K0 907 044 CP
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
VCID: 77FDCC18067757A6AA7-8022
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007970854
Coding: E5890F2700041500471400001400000000087F075C000100000000000000
VCID: 71E9F20068130996643-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 250108 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 211207 046 0204
Coding: 00208933
Shop #: WSC 00046
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1R3FJS
Coding: 0012624
VCID: 3D711E3064CBBDF6B0B-8068
Subsystem 1 - Serial number: 6332MSME2A5273549
Subsystem 2 - Serial number: 6342MSME2A551837D
Subsystem 3 - Serial number: 6352QSME484E7A17W
Subsystem 4 - Serial number: 6362QSME424244536
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0100
Coding: 0002022
VCID: 810922C0D8B39916143-80D4
Component: E0221 002 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GD3NE03Q
Coding: 0003103
Shop #: WSC 30067 959 127766
VCID: 2C5723748FB1247E175-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B3007DB
Coding: E9807F0E0006020003
Shop #: WSC 30134 959 45725
VCID: 306F3704A399409E2BD-8065
Reset counter: 86
Mileage: 71397 km
Time: 15:38:45
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 39790A2070E381D69C3-806C
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 3663011C41FD6EAE711-8063
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D0484056008DF0380FC00
VCID: 830528C8C2AF8B0606F-80D6
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000948
Shop #: WSC 00046 000 00000
VCID: 3A7B152C75E58ACE959-806F
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 052 0208
Revision: 00000001 Serial number: VWZ1Z3L1613679
Coding: 01000400020001
Shop #: WSC 00788 648 00255
VCID: 2345C848226FEB06A6F-8076
Reset counter: 86
Mileage: 71397 km
Time: 15:38:45
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 387F0F244BE998DE63D-806D
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D512E70B4AB2D7600B-8078
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 B HW: 5K0 035 730 B
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669813684
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 2447CB542F61EC3EDF5-8071
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 46
Mileage: 71397 km
Time: 15:29:17
Thanks in advanced
