Q7 4M - Reverse Camera 'Low Line' Retrofit Doesnt show image when selecting reverse
andyhud
C?ID=32695
Hi Guys
I've just retrofitted a rear camara "low line" (so no Extended CAN) into a 2016 Q7 4M. This is just power/ground/12v trigger then 2 wires from the camera into the back of the MIB2 5F module.
While everything is working, the camera doesn't automatically appear when put in reverse gear. I have to switch the parking sensor button off and on and then the image appears. No errors / DTCS in VCDS. I enabled Low Line camera in 5F Byte 35 / Bit 4 and I've wired in the 12v trigger on the reverse gear
Funny thing is, once you press the parking sensor button on the dash off and on and the video signal displays on the MMI, if you take the car out of reverse and drive forward then put it back into reverse the image then automatically appears as expected. Only the first time after the engine/electrics are off it doesnt.
Any help would be appreciated. I scoured Modules 09/46/5F but to no avail.
Andy
Link to video showing issue: LINK
Thursday,10,May,2018,14:41:50:50897
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4422.4
VIN:    License Plate:
Mileage: 18163km-11285mi   Repair Order:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 42 44 46 50
          52 5F 69 6D 74 81 82 8B A5 AC BB BC CA D6 D7
VIN:    Mileage: 18163km-11285miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3,0TDI EDC17  H46 0005
   Revision: 91H46---
   Coding: 2A2A4032037E050335080000000000000000000000000000
   Shop #: WSC 41360 002 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401 001009
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 66807A9599A11C7482-8032
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H05 1013
   Revision: --H05---
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B36FBE1B2A3719C0D-806E
Address 03: ABS Brakes (J104)       Labels:. 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Coding: 249830B230A50A9DD1A05898187F52AAE6A6D2240C0C508B1A184A5567654B
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K.rod
   VCID: 45C29D19C467376C6B-8010
   Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
   Component: MEM-BFS       008 0031
   Serial number: 00000231708975
   Coding: 003030000000B2410000010101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736.rod
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0093
   Coding: 6618083D5544451102220280800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 679E77919EAB057CB9-8032
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0003
   Serial number: 00000000000001206388
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 9D09C06880PAG0MUFU02
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0266
   Coding: 07501943E17900CD050D57185BBF80F9130331009000000000000000A00016810A45013B125601
   VCID: 0248460595C9C0540E-8056
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160926  043 0893
   Serial number: 89565300401627000410
   Coding: 1BC7F7
   Serial number: 20051979X81A955547A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 04 07 2016  00563031
   Serial number: GX1CE113091611521371
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00234916
   Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000043281
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Coding: 3473FFEA58FFEC0A949880A0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3228D6C565E9B0D4DE-8066
   Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
   Component: Airbag10.44   H01 0103
   Serial number: 003UL0007F2Z
   Coding: AACCF0D80C80000098F650F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005013
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 3D32F5F9ACB77FAC33-8068
   Subsystem 1 - Part No SW: -----------    HW: 442 062 311 16
   Serial number: 3577Y00C7209FF91D3CP
   Subsystem 2 - Part No SW: -----------    HW: 442 062 311 16
   Serial number: 3587Y00AD2093B71F278
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 611 16
   Serial number: 35177000429E291536B3
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 611 16
   Serial number: 35277001029E0847583%
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 811 16
   Serial number: 3557500AB21CC873E30M
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 811 16
   Serial number: 3567500AB21CC872F1DY
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 811 16
   Serial number: 2307500A522355F3D14%
   Subsystem 8 - Part No SW: -----------    HW: 442 421 711 16
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00C52093B72738I
   Subsystem 9 - Part No SW: -----------    HW: 442 421 711 16
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00C52093B73B52K
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 014A490990CFDB4C17-8054
   Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
   Component: FBenRDW       H16 0306
   Coding: 248400D07C80060001A3E9603000600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 2E10C2B571D19434BA-807A
   Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
   Component: Gateway       H30 0309
   Revision: 5C010004    Serial number: 0485C280616C15
   Coding: 03010001000086407F07000000590032D8120007080000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4CD4A83DE70DC624B4-8018
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20161206021922 00210
   Serial number: 0984792304
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0092
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3522EDD99487A7ECFB-8060
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77BE27D1CE0B95FC29-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000327363002
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   Component: MEM-FS        008 0031
   Serial number: 00000231697872
   Coding: 002832000000B2410000010101010000110000313100000000000000000000
   Shop #: WSC 48154 001 104857
   ROD: EV_SCMDriveSideCONTIAU736.rod
   Part No SW: 4M0 959 593 E    HW: 4M0 959 593 C
   Component: TSG FS        005 0057
   Serial number: 0000231660075
   Coding: 001D9A005E01000000003082
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 3E30F2F5A1B164B42A-806A
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000487018
   Coding: B0040101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 3424D0DD9FFDBEE4CC-8060
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0344
   Coding: 01351E002F9100406309A0006600580203000000004706502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 004C4C0D9BC5D24418-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY163140KQU
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000067942770
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000232754210
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736.rod
   Part No SW: 4M0 959 592 E    HW: 4M0 959 592 C
   Component: TSG BFS       005 0057
   Serial number: 0000233427196
   Coding: 001D9A005C01000000003080
   ROD: EV_DCU2PasseSideMAXHCONT.rod
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035     HW: 4M1 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A641L0GB007363
   Coding: 01370601FF0A000053111101000A00332F001BF7017001009E
   VCID: 62886685758960546E-8036
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9GJ403D5G
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 11011700000000000315
   Compact Disc Database:
   Component: Gracenote2  --- 1015
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0214
   Revision: 9A001003    Serial number: 0389212548
   Coding: 0110000202010000
   VCID: 3326D3C19AF3B9DCD5-8066
   Trailer Articulation Angle Sensor:
   Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
   Component: G820 KNWINSEN  H18 0019
   Serial number: 26377
136203 - Supply Voltage
          P1757 00 [009] - Open Circuit
                    Reset counter: 29
                    Mileage: 18163 km
                    Date: 2018.05.10
                    Time: 14:38:54
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31105654300000
   Coding: 0090
   VCID: 48DC942DF3752A0490-801C
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 G    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H34 1213
   Serial number: 1712160205
   Coding: 98505848F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130099908
   Coding: 303030
   Part No SW: 4M2 713 041 F    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20161123000279
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 291A31A9483FF30C6F-807C
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H28 1603
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736_AU49.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 302CDCCD6BE582C4A8-8064
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Coding: 0407030600000402024023A5AD0000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736.rod
   VCID: 2F2EDFB176DB9D3CB1-807A
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0005
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 4M0 959 595 E    HW: 4M0 959 595 C
   Component: TSG HFS       005 0057
   Serial number: 0000232236371
   Coding: 000D98000001000000003080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 40CC8C0DDB45124458-8014
   Component: TSG HBFS      005 0057
   Serial number: 0000232236617
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 5A8000053602
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3A38FEE5BD99489416-806E
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16600A55E9414CF4D2-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:17, VBatt start/end: 12.1V/12.1V)-----------
myounus
Northwest UK
C?ID=321059
Hi Andy
From what you describe it sounds like the camera is either wired incorrectly or it needs a software update. Was the camera a genuine part? Did you follow the wiring diagram as per ELSA?
m87a
Bosnia and Herzegovina
C?ID=156900
from your explanation it seems that parking sensors doesn't know that it has camera connected. I believe that your sensors are connected to 09 central electronic (correct me if I'm wrong) so probably some coding or adaptation channel that needs to be changed to display camera instead of sensors.
andyhud
C?ID=32695
Hi Myonus.
Yep, all genuine parts used and wired in as per Erwin/Elsa. I never figured if it could be changed and after speaking to a few others around the world it seems like it was "just the way"
@m87a - It could well be, but as I have no access to the vehicle now I can't really check but I can look at another Q7 in 09 and see what is what. Thanks
Andy
