Friday,01,June,2018,17:01:51:09178
-- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
Version: 18.2.0.3 (x64) HEX-V2 : 0.4411.4
Mileage: 220310km-136894mi Repair Order: 03 w/ trans
Chassis Type: 8T0
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
Mileage: 220310km-136894miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: Malfunction 0010
Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 G HW: 8T0 907 560
Component: 4.2l V8/4V H10 0008
Revision: 76H10---
Coding: 01140009180F0120
Shop #: 93204 999 83903
VCID: 3E25C295B0758857404-806A
10 Faults Found:
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
006418 - Pressure Sensor for Brake Boost (G294)
P1912 - 001 - Short to Plus
Fault Status: 01100001
Temperature: 21.0°C
Temperature: 26.0°C
Absolute Pres.: 940.0 mbar
Voltage: 12.954 V
000400 - Fuel Pressure Sensor (G247)
P0190 - 001 - Circuit Malfunction
Temperature: 21.0°C
Temperature: 26.0°C
Voltage: 12.827 V
001796 - Clutch Switch (F36)
P0704 - 004 - Implausible Signal
Temperature: 21.0°C
Temperature: 26.0°C
Voltage: 12.954 V
000112 - Sensor for Ambient Air Temperature (G17)
P0070 - 001 - Malfunction
Mileage: 220314 km
Date: 2009.04.28
Time: 16:56:09
Temperature: 21.0°C
Temperature: 27.0°C
Voltage: 13.081 V
004200 - Intake Air Switch-Over Valve (N335)
P1068 - 004 - Open Circuit
Mileage: 220314 km
Date: 2009.04.28
Time: 17:15:50
RPM: 119 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 27.0°C
Voltage: 12.192 V
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Mileage: 220314 km
Date: 2009.04.28
Time: 17:15:50
RPM: 119 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 27.0°C
Voltage: 12.192 V
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Mileage: 220314 km
Date: 2009.04.28
Time: 17:15:50
RPM: 119 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 27.0°C
Voltage: 12.192 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction
Mileage: 220314 km
Date: 2009.04.28
Time: 17:15:50
RPM: 119 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 27.0°C
Voltage: 12.192 V
001153 - Coolant Fan Control Circuit 2
P0481 - 004 - Electrical Malfunction
Mileage: 220314 km
Date: 2009.04.28
Time: 17:15:50
RPM: 119 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 27.0°C
Voltage: 12.192 V
Address 03: Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0010
Coding: 150D10
Shop #: 02391 823 56573
VCID: 7AAD0E85ECDD64773CC-802E
12 Faults Found:
02214 - Tire Pressure Warning
Reset counter: 99
Mileage: 219357 km
Date: 2017.08.20
Time: 11:43:35
Hex Value: 0x4400
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1CA8
Hex Value: 0x00FF
Reset counter: 131
Mileage: 220314 km
Date: 2017.09.05
Time: 12:11:53
Hex Value: 0x00C0
Hex Value: 0x0806
Hex Value: 0x1203
Hex Value: 0x0373
Hex Value: 0x00FF
013 - Check Memory
Fault Status: 01101101
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:32:02
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0032
Hex Value: 0x0296
Hex Value: 0x00FF
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x002B
Hex Value: 0xB99D
Hex Value: 0x00FF
Fault Frequency: 29
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0027
Hex Value: 0x859D
Hex Value: 0x00FF
013 - Check Memory
Fault Frequency: 31
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:23
Hex Value: 0x0000
Hex Value: 0x2282
Hex Value: 0x0038
Hex Value: 0x339C
Hex Value: 0x00FF
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:32:02
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0032
Hex Value: 0x0296
Hex Value: 0x00FF
Reset counter: 131
Hex Value: 0x0000
Hex Value: 0x2280
Hex Value: 0x0038
Hex Value: 0x66A4
Hex Value: 0x00FF
013 - Check Memory - Intermittent
Fault Status: 00101101
Reset counter: 131
Hex Value: 0x0000
Hex Value: 0x2280
Hex Value: 0x001C
Hex Value: 0x23A3
Hex Value: 0x00FF
Fault Status: 00100101
Reset counter: 131
Hex Value: 0x0000
Hex Value: 0x2280
Hex Value: 0x001C
Hex Value: 0x2AA4
Hex Value: 0x00FF
Reset counter: 131
Hex Value: 0x0000
Hex Value: 0x2280
Hex Value: 0x0038
Hex Value: 0x1BA3
Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent - MIL ON
Fault Status: 10100000
Reset counter: 131
Hex Value: 0x0000
Hex Value: 0x2280
Hex Value: 0x0014
Hex Value: 0x13A3
Hex Value: 0x00FF
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DF HW: 8K0 907 064 DF
Component: BCM2 1.1 H02 0321
Coding: 090100
Shop #: 02399 823 56573
VCID: 77AB17B1DFCF791F432-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000034446013
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV H36 0042
Serial number: 0209000046095011
013 - Check Memory
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
02241 - Engine Control Module; Immobilizer Data not Adapted
Reset counter: 91
Mileage: 220314 km
Date: 2009.05.01
Time: 23:19:45
02811 - Control Module for Electronic Steering Column Lock (J764)
Reset counter: 131
Mileage: 220314 km
Date: 2009.05.05
Time: 19:34:14
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 131
Mileage: 220314 km
Date: 2009.05.05
Time: 22:20:11
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0160
Revision: A1000000 Serial number: 01010720090991
Coding: 64002000
VCID: 7DA70599FDF3534F19E-8028
8 Faults Found:
Fault Status: 01101000
Reset counter: 91
00457 - Control Module for Network (J519)
013 - Check Memory
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:31:59
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:31:59
Temperature: 15.0°C
03220 - Stop Valve for Coolant for Climatronic (N422)
Fault Status: 00101001
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:19
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:19
006 - Short to Plus
Fault Status: 01100110
Reset counter: 91
Mileage: 220314 km
Date: 2009.05.01
Time: 23:19:45
Voltage: 12.70 V
Voltage: 12.90 V
Voltage: 13.00 V
Voltage: 13.00 V
Bin. Bits: 00000000
Time: 0.00 s
Count: 1
Reset counter: 131
Reset counter: 131
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000297025
Coding: 690000B1063C00010000080300007F5F0F14520802000001000000
Shop #: 08180 444 68462
VCID: 3C21C89DA6699A476E0-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 260609 H06 0070
Serial number: SWF09060260410
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - H08 0090
Serial number: 00000000002506090800
9 Faults Found:
03351 - Bulb for DRL and Marker Light; Left
Fault Status: 01101100
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:31:00
03354 - Bulb for DRL and Marker Light; Right
Reset counter: 91
Mileage: 219028 km
Date: 2017.08.15
Time: 21:15:00
Reset counter: 91
Mileage: 220314 km
Date: 2017.10.07
Time: 15:19:00
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.28
Time: 00:11:00
Reset counter: 87
Mileage: 220204 km
Date: 2017.09.01
Time: 20:39:00
Reset counter: 87
Mileage: 220204 km
Date: 2017.09.01
Time: 20:39:00
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:31:00
Reset counter: 91
Mileage: 219028 km
Date: 2017.08.15
Time: 21:15:00
00910 - Indicator Lamp for Emergency Flashers (K6)
Reset counter: 91
Mileage: 1048574 km
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Serial number: 003EGD0264ET
Coding: 303836354230303030304A55304C384B3053
Shop #: 02145 785 00200
Dataset: EV_AirbaECUVWAUDI010 003010
VCID: 42DDB665C40DECB724C-8016
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900004FL4
Serial number: 6334MSME4903092CC
Serial number: 6344MSME49636B47O
Serial number: 6352QSME20313434/
Serial number: 6362QSME7E311C20I
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 220314 km
Date: 2009.04.30
Time: 20:31:56
9444115 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 220314 km
Date: 2009.04.30
Time: 20:31:56
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 220314 km
Date: 2009.05.05
Time: 22:26:32
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
[High Speed CAN Communication Bus no signal/communication]
Reset counter: 131
9482752 - Seat Occupied Recognition
B10B2 00 [008] - Function Restriction due to Missing Message(s)
[Bladder Mat: functional restriction because of missing message]
Reset counter: 131
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IFT0004U
Coding: 000014
VCID: 3D27C599BD73934F59E-8068
Component: E221 - MFL H02 0003
Reset counter: 131
Reset counter: 131
(no units): 44.0
Text: 2C8BFFFFFFFF00C0FF
RPM: 0
Raw, Index/Key Err.: 255 255 000
Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
Component: KOMBIINSTR. H19 0253
Revision: 00100000 Serial number: BWX33GR69
Coding: 8B1209000300D705020000
VCID: 313FE9A9712B672FCD6-8064
Fault Frequency: 82
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:13
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:13:51
00438 - Fuel Supply Sensor 2 (G169)
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:13:51
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0101
Revision: GB500049 Serial number: 4900G096208416
Coding: 00C303
VCID: 50F98C2D1AE10E27A28-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19082A05110609
Fault Frequency: 37
Reset counter: 131
Mileage: 220314 km
Date: 2017.09.29
Time: 16:20:18
Bin. Bits: 10011
Voltage: 11.60 V
Count: 6
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Bin. Bits: 00000
Voltage: 13.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Fault Frequency: 25
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Bin. Bits: 00000
Voltage: 13.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
01312 - Powertrain Data Bus
Fault Frequency: 61
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Bin. Bits: 00000
Voltage: 13.00 V
Count: 7
Bin. Bits: 10000
Reset counter: 131
Mileage: 220314 km
Date: 2009.05.02
Time: 00:08:26
Bin. Bits: 00000
Voltage: 13.30 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
01304 - Radio
Reset counter: 131
Mileage: 220314 km
Date: 2009.05.05
Time: 22:12:08
Bin. Bits: 10000
Voltage: 13.10 V
Count: 12
Bin. Bits: 10000
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: FA H11 0306
Revision: Serial number: 0000008999560
Coding: 011C03204000410001
VCID: 45D7AD79D5A3DB8F01E-8010
Reset counter: 131
Reset counter: 131
Reset counter: 131
Reset counter: 131
Reset counter: 131
Revision: 00002001 Serial number: 0119131169
Coding: 0106023A007A000400B0010000000000
Component: BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS039 H06 0041
10 Faults Found:
02616 - Fuel Tank Cap; Unlock
Fault Status: 01101001
Reset counter: 22
Mileage: 218339 km
Date: 2017.08.07
Time: 12:37:14
02615 - Fuel Tank Cap; Lock
Reset counter: 23
Mileage: 218369 km
Date: 2017.08.07
Time: 13:04:11
03305 - Wire for Engine Start Request
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
013 - Check Memory
Fault Frequency: 147
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:39
Reset counter: 131
Mileage: 220314 km
Date: 2009.05.02
Time: 00:08:30
Reset counter: 131
Mileage: 220314 km
Date: 2009.05.05
Time: 22:27:22
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:14:14
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:14:14
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:14:14
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010101
VCID: 74B120BDCEB91207660-8020
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: BF H11 0306
Revision: Serial number: 0000009013006
VCID: 44D1B07DDE99E287160-8010
Reset counter: 131
Reset counter: 131
Reset counter: 131
Reset counter: 131
Reset counter: 131
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000402919
Shop #: 00000 000 00000
VCID: 3431E0BD8E395207A60-8060
7 Faults Found:
Reset counter: 131
Voltage: 13.10 V
Count: 68
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 131
Voltage: 13.10 V
Count: 67
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 00101011
Fault Frequency: 23
Reset counter: 91
Mileage: 220314 km
Date: 2009.05.01
Time: 23:50:33
Voltage: 14.20 V
Count: 38
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
03182 - Clutch Position Sensor (G476)
Fault Status: 01101010
Reset counter: 91
Mileage: 220314 km
Date: 2009.05.01
Time: 23:19:46
Voltage: 13.00 V
Count: 51
Hex Value: 0x02F3
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
Voltage: 12.60 V
Count: 66
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:21
Voltage: 12.60 V
Count: 64
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
013 - Check Memory - MIL ON
Fault Status: 11101101
Reset counter: 91
Mileage: 220314 km
Date: 2009.04.30
Time: 20:32:02
Voltage: 12.00 V
Count: 80
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H03 0351
Revision: 00000005 Serial number: AUZ5Z6I1240320
Coding: 05020000010105004119070000
VCID: 46D5AA75E8A5D097084-8012
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Reset counter: 22
Mileage: 218339 km
Date: 2017.08.07
Time: 11:58:26
03138 - Input AUX IN
Reset counter: 22
Mileage: 218339 km
Date: 2017.08.07
Time: 11:58:35
Reset counter: 131
Mileage: 220314 km
Date: 2009.04.28
Time: 00:06:24
02259 - Information Display and Control Head (Front) (J685)
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: HL H10 0306
Revision: Serial number: 0000101439676
Coding: 010C03204000210001
VCID: 42DDB665C48DECB724C-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: HR H10 0306
Revision: Serial number: 0000101439673
End----------(Elapsed Time: 01:28, VBatt start/end: 13.2V/12.8V)-----------
