Golf 7 window regulator
mohamed
Egypt
C?ID=211960
Could you help me with the procedures of basic setting of the windows
Monday,07,May,2018,10:06:28:22511
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4411.4
VIN: WVWZZZAUZFP053591   License Plate: GOLF 7 WINDOW
Mileage: 95420km-59291mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP053591   Mileage: 95420km-59291miles
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 M    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H10 7864
   Revision: WAH10---
   Coding: 01250012230400082000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM14TFS01104E906016M 002011
   ROD: EV_ECM14TFS01104E906016M.rod
   VCID: 2C14C094475CD82494-8078
   Part No SW: 0CW 300 047 E    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5202
   Revision: 00043014    Serial number: CU501411095594
   Shop #: WSC 00028 028 00067
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 3D32FDD0AC2641AC33-8068
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63254000000282
   Coding: 01FA6AA12425116F077C060941C42980562488E0608294B300200038C202
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   Shop #: WSC 00028 028 00206
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 3C34F0D4B73C48A404-8068
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011431700451
   Coding: 00001842C041005B4BE44000000403001000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DB23DD0ECA681AC73-8028
   Component: WWS    141102  043 0551
   Serial number:         141112094416
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0DBZ3R
   Shop #: WSC 00028 028 00058
   VCID: 41CA8120D0DE254C57-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 911 14
   Serial number: 35767000000DA86C7110
   Subsystem 2 - Part No SW: -----------    HW: 480 001 911 14
   Serial number: 3586700000067B6C711.
   Subsystem 3 - Part No SW: -----------    HW: 480 401 811 14
   Serial number: 3516502A7188FC14E1CT
   Subsystem 4 - Part No SW: -----------    HW: 480 401 811 14
   Serial number: 3526502C51860BC151DC
   Subsystem 5 - Part No SW: -----------    HW: 480 401 811 14
   Serial number: 35565029B188FC12B24O
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141121400798
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FCE87D8A62A53BC21-806A
   Part No SW: 5G1 920 740     HW: 5G1 920 740
   Component: KOMBI         204 4270
   Coding: 07E519082380000800083E001400000000000000
   VCID: 63866BA86A02575C65-8036
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 14111410803538
   Coding: 0101000820085700EF0000081C0F00000001050000000000000000000000
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 71AA11E0A0FEF5CCE7-8024
   Subsystem 2 - Part No SW: 5G0 959 442 H    HW: 5G0 959 442 H  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140002402600084451
   Coding: 24FFFF
   Serial number: 25091402091133
   Coding: 003B0220D000048000001000
   VCID: 42C88E2CD5D83E544E-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007188416
                    Reset counter: 131
                    Mileage: 95420 km
                    Date: 2018.05.07
                    Time: 06:52:26
65593 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
                    Reset counter: 131
                    Mileage: 95420 km
                    Date: 2018.05.07
                    Time: 06:54:27
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43C68B28CAC2375C45-8016
   Serial number: 28091406071116
   Coding: 003B0020DC00048000801000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007236287
   Coding: 090000
                    Reset counter: 131
                    Mileage: 95420 km
                    Date: 2018.05.07
                    Time: 06:53:34
                    Reset counter: 131
                    Mileage: 95420 km
                    Date: 2018.05.07
                    Time: 06:54:27
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      041 0421
   Serial number: V1C02111142568
   Coding: 02730000FF00000011110001001800001F0100840100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 271E3FB85EBAFB7C79-8072
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9PS205DBB
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung]
                    Reset counter: 130
                    Mileage: 95415 km
                    Date: 2018.05.07
                    Time: 05:34:18
                    Voltage terminal 30: 12.4 V
End----------(Elapsed Time: 01:13, VBatt start/end: 12.6V/12.7V)-----------
First, fix switch or wiring for switch that is causing: "Switch for Central Locking - Signal Implausible" DTC.
To get rid of "Motor for Window Regulator - Missing Calibration / Basic Setting":
  • Run window all the way down by holding switch in the down position
  • When window reaches bottom, continue to hold switch in down position for 2 full seconds, then release, and press again for 2 more seconds.
  • Run window all the way up by holding switch in the up position.
  • When window reaches top, continue to hold switch in up position for 2 full seconds, then release, and press again for 2 more seconds.
You may need to repeat this once or twice, and you need to do it for each window that has the above fault.
khaledabdulaziz
Israel
C?ID=394371
I just had this situation and it worked perfectly
thanks Uwe
