Audi A3 2016 US to EU
FandaTDI
Czech Republic
C?ID=204559
maybe this topict belongs more to "How to ..." section, but here also ... :)
After visiting a dealer, the car cames to me with problem not functioning remote, so I coded BCM back to US and "relearn" the remote ... The ligts,etc.stays ok, but I am not sure what other things are related to apart of the 315MHz (300-400MHz) is in our country "restricted for public use" ... eventhough when you order a new key at a dealer by the VIN (so "preprogrammed"), you still get 315MHz :rolleyes: :D ... So what´s the "right" way to "converse" it? Do it needs to replace the BCM or if it is just recoded, you can use the 434MHz (or 868 even w/o kessy?) As I understood in accordance of this table: http://wiki.ross-tech.com/wiki/index.php/Immobilizer I assume, that even a new key is N/A (even when I found some basic settings, but won´t take it ... ) , but what about the rest? Probably new fw for 5F even w/o navi? Other problem is that when I select cz language in coding of instrument cluster, it still displays in en (probably due to fw - is it very different from 3G/3GP? I.e. green menu, etc.?) ...
Here are the scans:
Monday,23,April,2018,20:11:12:12188
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
VIN: WAUA7GFF7G1061464   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C BB BC
VIN: WAUA7GFF7G1061464   Mileage: 41294km-25658miles
Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1D00122424000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FCEAFF3A65220BC21-806A
Readiness: 0000 1100
   Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4907
   Revision: 06253104    Serial number: TFK01510140227
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 197A216B18B62E8CFF-804C
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63015000003124
   Coding: 13FF6A9234260A6D017B020681C729C8562C5080408194B4024100548208
   VCID: 79BA01EBF8F6CE8C5F-802C
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000783810
   Coding: 03000014010000000000000000001400
   VCID: 3228F6C76500FDD4DE-8066
   Serial number: B29847D7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061531200076
   Coding: 04141A42C04122F541804004511007000000000000000000000000000000
   Shop #: WSC 12345 444 00001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7F4EEFF3E6D2E0BC61-802A
   Component: WWS371 150808  042 0585
   Serial number:         151029123312
   Coding: 0A47F7
   Serial number: 60886543
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 07 09 2015  00001065
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033981301
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000MVS4D00000
   Coding: 101F00
   Revision: --------    Serial number: 39391530801758
   Coding: 0010150011
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 43C6A303CABA445C45-8016
   Serial number: 003GCR03WAK.
   VCID: 47DEB713FE82687C99-8012
   Belt Pretensioner left:
   Serial number: 34230167A12111540025
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A12111550405
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001E9VSG
   Coding: 303332
   Subsystem 4 - Part No SW: -----------    HW: 480 002 910 15
   Serial number: 35700000000FF3C8371-
   Subsystem 5 - Part No SW: -----------    HW: 480 002 910 15
   Serial number: 35800000000C04C8371K
   Subsystem 6 - Part No SW: -----------    HW: 480 400 311 15
   Serial number: 3510002B71D25F00F11$
   Subsystem 7 - Part No SW: -----------    HW: 480 400 311 15
   Serial number: 3520002B31D25F03027V
   Subsystem 8 - Part No SW: -----------    HW: 480 401 808 15
   Serial number: 3550002A31CB0C04303V
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 808 15
   Serial number: 3560002A51CB0C0483A6
   Part No SW: 8V0 953 521 EP    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 10111508490973
   Coding: A018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0C54483FA764CB2474-8058
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6423
   Coding: 07F519092B8000080800A8001800000000000000
   Shop #: WSC 20745 401 00001
   VCID: 45C2BD1BC48E7A6C6B-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 01111510800611
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 27 10 2015  B0070220
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 120815BHB12065
   Coding: 00100B204000048000000002
   VCID: 41CAA90BD0A6564C57-8014
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   VCID: 44C4A01FCFB443647C-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 130815DHC14678
   Coding: 001003204000048000000002
   VCID: 40CCAC0FDBAC5F4458-8014
   Coding: 011A000101000000
   VCID: 75A20DDBD4EEAAEC3B-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     014 0660
   Serial number: A7A01111150128
   Coding: 01730100FF0A000011110001001A00002F0002440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 393AC1EBB8760E8C1F-806C
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30EDEE
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000018091500040112
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 125
                    Mileage: 41294 km
                    Date: 2018.04.23
                    Time: 19:31:19
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302CFCCF6B0CCFC4A8-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 101015BJ814474
   Coding: 000003204000048000000002
   Serial number: 101015BJ814473
End----------(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V)-----------
With a new VIN "preprogrammed" key from dealer (I´ve tried also the procedure via ignition and door locks simmilar to "relearn" learned remote and even with the learned key more than 10meters it starts and run on the new key - with fault just in instrument cluster - but remote not works ... ) :
Saturday,28,April,2018,11:38:07:12188
VIN: WAUA7GFF7G1061464   Mileage: 41464km-25764miles
   Revision: --H13---
15072 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
                    Mileage: 41464 km
                    Date: 2018.04.28
                    Time: 10:46:19
                    Engine speed: 1142.75 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 73 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 11.972 V
                    FRF_IMMO_SNAPSHOT_BYTE1: 50
                    FRF_IMMO_SNAPSHOT_BYTE2: 50
                    FRF_IMMO_SNAPSHOT_BYTE3: 153
                    FRF_IMMO_SNAPSHOT_BYTE4: 11
                    FRF_IMMO_SNAPSHOT_BYTE5: 16
                    FRF_IMMO_SNAPSHOT_BYTE6: 0
                    Engine: operating status: IS
Readiness: 0000 0100
21197 - Transmission Control Unit
          P1701 00 [008] - Locked
                    Mileage: 41464 km
                    Date: 2018.04.28
                    Time: 10:46:19
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 101F00
   Coding: 0010150011
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303332
   Coding: A018
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 41464 km
                    Date: 2018.04.28
                    Time: 10:46:19
   Coding: 0102
                    Reset counter: 125
                    Mileage: 41294 km
                    Date: 2018.04.23
                    Time: 19:31:19
End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
Any ideas? And what is the right fw for EU and this 5F? (still the same/similar in green menu?) Thanks
This car does not seem to be broken. Moving to Tweaks.
FandaTDI
Czech Republic
C?ID=204559
Ok, thanks. The car was a little bit broken, but that is not the issue now (interesting is e.g. after repair and refilling th A/C it was necessary to run basic settings for first run of a compressor to make the compressor work ... It was obvious, that it some time not works because it was a little "stale"/smelly ... just for info that in case of newer cars you need a diag for almost everything ;-) ...)
FandaTDI
Czech Republic
C?ID=204559
Hi again, little "update" ... The car is in use, still not fully "EUropied" :D , still little smelly (also after ozone,etc. and mainly with A/C off) :D and still with US Instr.cluster, but with "plate" under speed needle swaped from 860E cluster (will add some photos) and now the main problem is different numbers spacing(even when showing km/h l/100km values...), so "meantime" is in progress solution for fully "EU conversion", but the question is, if it can be changed in the cluster in the car. Reflash to diff. sw or...? Thanks
