2018 VW Amarok DC Highline Extreme (2H), 3.0L V6 TDi 165kW, DDXC - (South Africa)
DJMAXIZA
South Africa, Johannesburg
C?ID=200764
This is the very initial scan on the Amarok, selecting all addresses to be scanned. This scan was done with HEX+CAN USB interface, where all consequent work was done with HEX-NET when received earlier this year.
Scan done after Trailer Control Module (address 69) was fitted, but not yet coded, other than being added to the CAN Gateway.
As Engine and most other control units are on the UDS protocol, I cannot draw engine channel maps, other than the CSV's it created upon a Debug 02 scan.
Saturday,23,December,2017,14:49:22:08083
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
VIN: WV1ZZZ2HZJA011164   License Plate: TBD
Mileage: 120km-74mi   Repair Order: 2017-12-23
Chassis Type: 2H-VN81 (XX - All Addresses)
Scan: 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14
          15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28
          29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C
          3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50
          51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64
          65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78
          79 7A 7B 7C 7D 7E 7F 80 81 82 83 84 85 86 87 88 89 8A 8B 8C
          8D 8E 8F 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0
          A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 B1 B2 B3
          B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 C2 C3 C4 C5
          C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 D4 D5 D6 D7
          D8 D9 DA DB DC DD DE DF E0 E1 E2 E3 E4 E5 E6 E7 E8 E9
          EA EB EC ED EE EF F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB
          FC FD FE FF
VIN: WV1ZZZ2HZJA011164   Mileage: 120km-74miles
Address 01: Engine (J623-DDXC)       Labels: None
   Part No SW: 2H6 907 311 B    HW: 059 907 309 J
   Component: 3.0l V6 TDI   H21 0001
   Revision: 9AH21---
   Coding: 012A4132232608020001
   Shop #: WSC 00059 790 00056
   ASAM Dataset: EV_ECM30TDI0112H6907311B 001002
   ROD: EV_ECM30TDI0112H6907311B.rod
   VCID: 275D03D45EF28712AE8-8072
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 2H0 927 158 J    HW: 0DR 325 025 C
   Component: 2H0 30 TDIRdW H22 1003
   Revision: --H22---
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211.rod
   VCID: 3467E4989F24FC8A1BA-8060
   Part No SW: 2H6 907 379 A    HW: 2H6 907 379
   Component: ESC           H06 0310
   Revision: 00000000    Serial number: 61887000000232
   Coding: 207368B64995B69604A316A992546D85390000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
   ROD: EV_Brake1ESCCONTIVN817GP_008.rod
   Serial number: 24061713470647
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF306B0E1E8E6DABDE-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
   Component: ClimatronicT5 H04 0613
   Revision: 00001K05
   Coding: 0000000402
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN81.rod
   VCID: 26430ED059F89E1A95E-8072
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.CLB
   Part No SW: 7E0 937 089 B    HW: 7E0 937 089 B
   Component: BCM PQ25 MMI4 H82 0752
   Revision: BB082001    Serial number: 58217189170111
   Coding: 3C0002380CA1140013380E3164CB86D4B280654F60CE7160310000030803
   VCID: 326BE2806D30F2BA096-8066
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 030717 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 802 EJ    HW: 6R0 959 802 EJ  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2322
   Serial number: 13102844170613031920
   Subsystem 3 - Part No SW: 6R0 959 801 EF    HW: 6R0 959 801 EF  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2322
   Serial number: 13202847170627193416
   Subsystem 4 - Part No: 5C0 951 171
   Subsystem 5 - Part No: 5C0 951 171
   Subsystem 6 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170001675810047257
   Coding: A5FFFF
   Subsystem 7 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
   Component: J388__TSG_HL  022 1323
   Serial number: 13102709170713092001
   Subsystem 8 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
   Component: J389__TSG_HR  022 1323
   Serial number: 13102708170707001926
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231717203575
   Coding: 30810E
   Shop #: WSC 00059 790 00011
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71E92D8CA0B689A230C-8024
   Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
   Component: VW10Airbag01T H08 0018
   Revision: --------    Serial number: 003V1004LLSN
   Coding: 000000000000000000000000000000003154
   VCID: 3B75CFA4B27A33F2DA0-806E
   Serial number: 3495RRB400M59NFOE9UQ
   Serial number: 3505RRB401E59L4II8EM
   Serial number: 3555YRB400I59JH2NA4T
   Serial number: 3565YRB400K59JH6F8T8
   Part No SW: 2H6 920 883     HW: 2H6 920 883
   Component: KOMBI         H09 1109
   Coding: 131E000300
   VCID: 6ED336F0B188965A2DE-803A
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.CLB
   Part No SW: 7E0 909 901     HW: 7E0 937 089 B
   Component: GW-K-CAN TP20 H82 0752
   Revision: BB082001
   Coding: 742303
   VCID: 68DF40E89B6C486A672-803C
   Component: IMMO          H09 1109
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB3AE08D607A7A716-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771 B    HW: 2H0 927 771
   Component: Quersperre    H04 0018
   Revision: 11001001    Serial number: 4DG 11.07.17 00
   ASAM Dataset: EV_QuersUDSAAMVN817 002001
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 2D51F1FC7C0EAD42544-8078
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0449
   Serial number: VWZAZ2T5276334
   Coding: 06180709BE00000011110001000918001F0100D60020010047
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 244714D82FC46C0A8BA-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BF    HW: -----------
   Component: MRM2 2017/18  --- 0821
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.CLB
   Part No SW: 7E0 907 534     HW: 7E0 937 089 B
   Component: Batt.regelung H82 0752
   Coding: E10008AF
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.CLB
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000441972527
   Coding: 0100000100000000
   VCID: 306FE888633CC0AA7F2-8064
Address 76: Park Assist (J446)       Labels:| 7E0-919-475.clb
   Coding: 30810E
End---------------------(Elapsed Time: 43:04, Deb=2)-----------------------
Jeromeo
Australia
C?ID=335683
Hi
is your instrument cluster White or full color?
thank you.
