2015 Jetta Hybrid only has 2nd gear
atikovi
C?ID=115538
Just picked up this car with the 7-speed DSG transmission. It has 157,000 miles and only has second gear plus reverse. Wrench symbol flashing in display. First is of full scan followed by scan after deleting codes, then scan of just the trans. Does P1604 Internal Control Module Output Driver IC Error point to a bad circuit board in the Mechatronics? With the other codes, am I looking at just replacing the Mechatronics unit?
Tuesday,17,April,2018,15:21:49:53717
VCDS Version: 18.2.0.3 (x64)
VIN: 3VW637AJ1FM310596 License Plate:
Mileage: 254050km-157859mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 2E 37 3C 42 44 46 47
4F 51 52 55 56 61 62 72 75 77 8C
VIN: 3VW637AJ1FM310596 Mileage: 254050km-157859miles
Address 01: Engine (J623-CNLA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 K HW: 04E 907 309 AM
Component: 1.4l TFSI hy H10 7993
Revision: X2H10---
Coding: 00250012442401000000
Shop #: WSC 00066 790 00185
ASAM Dataset: EV_ECM14TFS01104E906023K 002004
ROD: EV_ECM14TFS01104E906023K.rod
VCID: 28550E9C5322CE0470-807C
CAN Converter 01:
10341 - Please Check Fault Codes in Transmission Control Module
U1026 00 [047] - -
Mileage: 254000 km
Date: 2018.04.10
Time: 10:43:13
Engine speed: 849.50 /min
Normed load value: 12.2 %
Coolant temperature: 71 °C
Intake air temperature: 36 °C
Voltage terminal 30: 14.960 V
Median injection timing: 0.871 ms
Engine operating condition: Idling
Readiness: 0000 0100
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0CG 300 045 H HW: 0AM 927 769 H
Component: GSG DSG AG7 431 6304
Revision: 00043014 Serial number: CU501406065515
Shop #: WSC 02069 000 90108
VCID: 2E59F884B9C69034BA-807A
8 Faults Found:
005636 - Internal Control Module
P1604 - 000 - Output Driver IC Error - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 254000 km
Date: 2018.04.10
Time: 10:43:13
006079 - Hydraulic Pump
P17BF - 000 - Play Protection - Intermittent
Reset counter: 10
Mileage: 254000 km
Date: 2018.04.10
Time: 11:07:19
P17BF - 001 - Play Protection - Intermittent
Reset counter: 10
Mileage: 254000 km
Date: 2018.04.10
Time: 11:07:19
002113 - Transmission Fluid Pressure Sensor/Switch 1
P0841 - 000 - Implausible Signal - Intermittent - MIL ON
Fault Frequency: 11
Mileage: 254001 km
Date: 2018.04.10
Time: 12:40:54
006300 - Function Restriction due to Insufficient Pressure Build-Up
P189C - 000 - - Intermittent
Reset counter: 9
Mileage: 254001 km
Date: 2018.04.11
Time: 15:02:10
Fault Frequency: 11
Mileage: 254001 km
Date: 2018.04.10
Time: 12:40:54
006293 - Functional Restriction due to Pressure Drop
P1895 - 000 - - Intermittent
Reset counter: 5
Mileage: 254003 km
Date: 2018.04.17
Time: 12:23:02
001870 - Unable to Engage Gear 6 -or- Synchronization Gear 6 aborted
P074E - 000 - - Intermittent
Mileage: 254048 km
Date: 2018.04.17
Time: 13:52:24
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492300FA851002ED921F0044A118F01A
Shop #: WSC 00066 000 00000
VCID: 040D7A2C87CACA643C-8050
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0356421066
Coding: 030C0C
Shop #: WSC 00066 000 00190
VCID: 3777DDE08E9C51FCE9-8062
Part No SW: 1K8 907 044 J HW: 1K8 907 044 J
Component: Climatronic H05 0102
Revision: 00001K01
Coding: 0010419002
Shop #: WSC 00066 000 00324
ASAM Dataset: EV_ACClimaBHBVW361Hybri 001001
ROD: EV_ACClimaBHBVW361Hybri.rod
VCID: 3669D0E48996A8F4F2-8062
Air Conditioning Compressor:
Subsystem 1 - Part No SW: 5C0 820 803 F HW: 5C0 820 803 F
Component: J842 eKK H03 0001
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator stuck
Reset counter: 158
Mileage: 249793 km
Date: 2017.10.01
Time: 08:00:00
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Reset counter: 157
Mileage: 253523 km
Date: 2017.10.16
Time: 17:29:18
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200A1A912F06D40188088124000D4C0174000845A08DB0E4 842600A043
VCID: 78F51EDCCB029E8420-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 141114 05 54 0403
Coding: 02300A
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 A HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0477
Revision: -------- Serial number: 39391435001850
Coding: 0001194011
Shop #: WSC 00066 000 00121
ASAM Dataset: EV_EPHVA18VW364GP00 001006
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 356BD7E89490A3ECFB-8060
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD04L1X2
Coding: 00005042
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72E12CF4A57EF4D41E-8026
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002BGGF02
Coding: 303146
Serial number: 3572MSME025A3B4BZZZ$
Serial number: 3582MSME58593B4BZZZ7
Serial number: 3516KSME0B597933ZZZ-
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME40757933ZZZS
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6B320832ZZZT
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME4A2C0832ZZZ-
Part No SW: 1K5 953 521 CA HW: 5K0 953 569 AG
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20141114300984
Coding: 0002440008
ROD: EV_SMLSNGVOLWS.rod
VCID: 6ED93884B146D034FA-803A
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 0051518534701809AD1B
Coding: 280000
Part No SW: 5C6 920 984 HW: 5C6 920 984
Component: KOMBI H05 0706
Coding: 281E01
Part No SW: 7N0 907 530 AS HW: 7N0 907 530 AN
Component: J533 Gateway H56 1653
Revision: H56 Serial number: 08021503000502
Coding: 351002
VCID: 0103733898D8DF4C17-8054
00576 - Terminal 15
Reset counter: 167
Mileage: 253988 km
Date: 2018.03.02
Time: 09:19:50
Component: IMMO H05 0706
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD134948DAE3C14A6-803E
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 253988 km
Date: 2018.02.28
Time: 13:27:31
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000007010003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3065E6FC6BF286C4A8-8064
Address 2E: Media Player 3
Part No SW: 5C6 035 274 F HW: 5C6 035 274 F
Component: RNS315-NAR H85 0501
Serial number: VWZAZ2P0635696
Coding: 040900610100060000008000
ROD: EV_RNS315NARV2UDS.rod
VCID: 29530B984828F70C6F-807C
Component: NAR_V7N 0060
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Reset counter: 184
Mileage: 19820 km
Date: 2015.10.07
Time: 01:14:19
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 A HW: 5Q0 907 686 A
Component: HRE_Master H11 0066
Serial number: 0349132652
Coding: 02011102
Shop #: WSC 00066 790 00191
ASAM Dataset: EV_HREntryHella 001024
ROD: EV_HREntryHella_VW27.rod
VCID: 3B7FC1D0B2B4759C0D-806E
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 A HW: 5Q0 907 685 A
Component: HRE_Slave H11 0066
Serial number: 0351399138
Coding: 020111
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0009339559
Coding: 0404BD
VCID: 5BBF615052F4559C2D-800E
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587150105190106
Coding: C00000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
VCID: 3973DBD87088478C1F-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0027537
ROD: EV_AudioVerst10KanalSTT3.rod
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1653
Coding: 01030100
VCID: 6FE72580BE4CD93CF1-803A
Subsystem 1 - Part No: 5K0 959 591 A
Component: J245 PS41.402 H02 0003
Serial number: 0000FST0002KQ2E00000
Coding: 180000
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5C0 907 080 F HW: 5C0 907 080 E
Component: VW361H0108020 H02 0541
Revision: 00H02000 Serial number: 00000000000000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM04510115C0907080F 001023
ROD: EV_DMCM04510115C0907080F.rod
VCID: 264900A45936D87442-8072
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0009361947
Coding: 0404BC
VCID: 5CBD624C57FA52A424-8008
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586150113190100
Coding: C00000
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 081200010B000200
Shop #: WSC 01383 790 50316
Subsystem 1 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
5276435 - Stationary Cornering Lamp Left
C1083 13 [009] - Open Circuit
Reset counter: 225
Mileage: 182987 km
Date: 2017.02.09
Time: 20:30:58
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1653
Coding: 16667100
VCID: 71E323F8A878CFCCE7-8024
Subsystem 1 - Part No SW: 1S0 915 181 A HW: 1S0 915 181 A
Component: J367-BDM H08 0181
Serial number: 51185B35102181490139
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140533
Coding: 02637102C24232107F1606000000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 142D4A6CFFAA5AE4AC-8040
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666939739
Coding: 0A100300A0010110
ROD: EV_UHVUMI.rod
VCID: 3261ECF465FEB4D4DE-8066
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5C6 915 182 C HW: 5C6 915 182 C
Component: BECM H11 0820
Serial number: 288 SYES623C31
ASAM Dataset: EV_BECM06020115C6915182 005024
ROD: EV_BECM06020115C6915182.rod
VCID: 2B5FF19042D4E51C9D-807E
End-------------------------(Elapsed Time: 04:41)--------------------------
Revision: X2H10---
CAN Converter 01:
U1026 00 [039] - -
Mileage: 254057 km
Date: 2018.04.17
Time: 15:23:58
Engine speed: 0.00 /min
Coolant temperature: 68 °C
Intake air temperature: 51 °C
Voltage terminal 30: 11.473 V
Median injection timing: 0.000 ms
Readiness: 1110 1101
Mileage: 254057 km
Date: 2018.04.17
Time: 15:23:58
Revision: 00H46001
Coding: 030C0C
Revision: 00001K01
Coding: 0010419002
Revision: BL122001
Coding: 02300A
Coding: 0001194011
Coding: 00005042
Coding: 303146
Coding: 0002440008
Coding: 280000
Coding: 281E01
Coding: 351002
Coding: 000007
Reset counter: 138
Mileage: 254057 km
Date: 2018.04.17
Time: 15:23:57
Coding: 02011102
Coding: 020111
Coding: 0404BD
Slave Driver:
Coding: C00000
Revision: 00H22000
9463827 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 138
Mileage: 254057 km
Date: 2018.04.17
Time: 15:23:59
Coding: 01030100
Coding: 180000
Coding: 0404BC
Slave Passenger:
Coding: C00000
Coding: 16667100
ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 04:33)--------------------------
Tuesday,17,April,2018,17:30:58:53717
Control Module Part Number: 0CG 300 045 H HW: 0AM 927 769 H
Component and/or Version: GSG DSG AG7 431 6304
Software Coding: 0000020
Work Shop Code: WSC 02069 000 90108
VCID: 2E59F884BAC69034BA-5120
Reset counter: 9
Mileage: 254057 km
Date: 2018.04.17
Time: 17:22:33
Reset counter: 9
Mileage: 254057 km
Date: 2018.04.17
Time: 17:22:33
Mileage: 254057 km
Date: 2018.04.17
Time: 17:22:33
Reset counter: 9
Mileage: 254058 km
Date: 2018.04.17
Time: 17:25:15
Golftwincharged
Guyana
C?ID=320847
Did you fix this problem?
atikovi
C?ID=115538
Yes I did.
Golftwincharged
Guyana
C?ID=320847
what was the remedy for this? thanks much
atikovi
C?ID=115538
Replaced the Mechatronic.
elkm36a
C?ID=5916
Where did you find this part?
atikovi
C?ID=115538
VW dealer.
