MY VOLKSWAGEN PASSAT WONT GO INTO GEAR
imoebu
Nigeria
C?ID=325141
PLS SEE MY SCAN RESULT BELOW. I CHECKED MEASURING BLOCKS 30 31 AND 32
Friday,30,March,2018,10:30:02:37132
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZ3CZCP015734   License Plate:
Mileage: 74700km-46416mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61 62 72
VIN: WVWZZZ3CZCP015734   Mileage: 74700km-46416miles
01-Engine -- Status: Not registered 0011
02-Auto Trans -- Status: Not registered 0011
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 06J 906 027 B    HW: 06J 907 309 B
   Component: MED17.5.2        04 8317
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404001024070060
   VCID: 2A0DFF1AE0F639970CC-807E
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -  - Intermittent
                    Temperature: 62.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.049 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 62.0°C
                    Temperature: 33.0°C
                    Voltage: 11.049 V
               U1017 - 015 -
                    Fault Status: 01101111
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:34:27
                    Temperature: 62.0°C
                    Temperature: 33.0°C
                    Voltage: 11.176 V
000604 - Fuel Pump Control Module
               P025C - 000 - Short to Ground - Intermittent
                    Temperature: -40.0°C
                    Voltage: 12.319 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:00:27
                    RPM: 1258 /min
                    Load: 25.1 %
                    Temperature: 25.0°C
                    Temperature: 30.0°C
                    Voltage: 14.351 V
Readiness: 1010 0001
   Part No SW: 0AM 300 051 R    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2711
   Revision: 00043014    Serial number: CU501107265644
   Shop #: WSC 00028 028 00001
   VCID: 392FD0561550820F756-806C
006079 - Hydraulic Pump
               P17BF - 000 - Play Protection
                    Reset counter: 10
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:25
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal
                    Reset counter: 10
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:27
006300 - Function Restriction due to Insufficient Pressure Build-Up
               P189C - 000 -
                    Reset counter: 10
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:45
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V4B6 0022
   Revision: --H07---    Serial number: 00000004573842
   Coding: 0131450
   VCID: 6D8734061198EEAFA9E-8038
            000 -  -
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:26
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
            000 -  -
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:26
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000001002
   Shop #: WSC 00028 028 00022
   VCID: 7F5BFE4E47746C3F0B2-802A
Address 09: Cent. Elect.
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PE55JHM
   Coding: 0012337
   VCID: 4CC199824AC207A7DE0-8018
   Subsystem 1 - Serial number: 6332MTS650652071
   Subsystem 2 - Serial number: 6342MTS690322081
   Subsystem 3 - Serial number: 6351HTS6HPK7AAKR
   Subsystem 4 - Serial number: 6361HTS6HJPR8AKJ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20170602200939
   Coding: 7982A00000
   Shop #: WSC 01286 386 08256
   VCID: 025D77BA348601D764C-8056
   Serial number: 70000000000000316582
   Coding: E20000
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2018.03.30
                    Time: 00:07:26
          B1149 13 [009] - Open Circuit
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2018.03.30
                    Time: 00:07:26
1140738 - Steering angle sensor
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2018.03.30
                    Time: 00:07:26
                    UBat: 14.40 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 3AA 920 870 C    HW: 3AA 920 870 C
   Coding: 160F00
   VCID: 323DE77AC4A67157B4C-8066
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 180711F2001885
   Coding: 469007
   VCID: 3829D552225A9B078A8-806C
            000 -  -
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:26
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76B51B6A64CE2D77584-8022
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003312361
   Coding: 0010B7
   VCID: 3537DC6635C8666F91E-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002351948
   Coding: 000090
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 1002
   Revision: 1AH03733    Serial number: 00112160156401
   Coding: 0000258
   VCID: 3C21C9421A62B7276E0-8068
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:25
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:25
                    RPM: 759 /min
                    (no units): 7.0
                    Voltage: 14.30 V
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:25
                    (no units): 7.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 8
                    Fault Status: 11101101
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:27
                    RPM: 769 /min
                    (no units): 7.0
                    Voltage: 14.20 V
03375 - Steering Motor
            003 - Mechanical Failure - MIL ON
                    Fault Status: 11100011
                    Reset counter: 84
                    Mileage: 73598 km
                    Date: 2012.01.08
                    Time: 19:43:19
                    (no units): 7.0
                        OK
                    (no units): 9
   Component:    KSG PQ47 ELV 043 0634
   Coding: 00910A0002860E763004941570084F0B607801
   Component: EZE_2         H40 1620
   Coding: 00000008
   VCID: 6FBB2E0E17941CBF9B2-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003321874
   Coding: 0010B6
   VCID: 3635DB6A28CE6D77984-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002355979
   Coding: 000090
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2018.03.30
                    Time: 00:07:26
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000122502
   Coding: 0022157
   VCID: 3537DC663948666F91E-8060
                    Fault Status: 01101101
                    Reset counter: 182
                    Mileage: 74701 km
                    Date: 2012.08.20
                    Time: 00:07:27
                    Voltage: 14.40 V
                    Count: 104
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  032 0079
   Revision: 01000001    Serial number: VWZ1Z2L3142520
   Coding: 05000400040010
   VCID: 72BD277A04A6315774C-8026
   Component: Batt.regelung H40 1620
   Coding: 03220858
   VCID: 71BF287601A00A4F8D6-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900216624
End----(Elapsed Time: 01:23, VBatt start/end: 14.0V/14.1V. VIgn 0.0V)------
imoebu
Nigeria
C?ID=325141
HOW DO I ADD PICTURES
alesypalsy
HC843859 (2nd hand?)
Hi, IS there any way you could tell me what the measuring blocks were for this as I have just fitted a new accumulator on my dsg megatronics and yet I am still not getting enough pressure for the pump to stop, my pressure before was 30-40 and now I am getting up to 45-55 but it just won't get up to 60 or 70 where I believe it needs to be so the pump is running constantly and the fault is still there,
I am wondering if it is possible that I have air lock in the system? I first refilled the hydraulic fluid through the breather cap, then I read that causes air locks , so I drained it, removed the starter motor and refilled from correct point, now I am scratching my head wondering why it not getting enough pressure still
My car mk6 1.6 TDI 2011 DSG , 139,000 miles,
any advice many thanks
Golftwincharged
Guyana
C?ID=320847
This is the DSG 7 0AM dry clutch, many mech unit issues relating pressure, this unit needs to maintain between 40 - 60 bars to fully functional and working, air lock can be a problem , also the accumulator plate is a main reason for a low pressure issue would replace this, i would recommend you uninstall the mech unit change the plate , bench refill it with exactly one litre hydraulic fluid, and installed correctly and this will fix your problem.
alesypalsy
Thank you for helpful reply!,, I today stripped the megatronic unit down and found the o-ring had been squashed when I installed the new part!,, I am 99.9% sure this is my problem, I shall try to find some where I can buy a o-ring to fit this tomorrow, otherwise I will have to await one in post,
I got the Kinergo housing and accumulator repair and when I installed the housing I had squashed the o-ring ! silly move by myself but at least I now have the cause.
thanks again
Golftwincharged
Guyana
C?ID=320847
hope that is the issue, please keep us posted with the results, thanks!!
alesypalsy
Hi guys and girls, I am awaiting delivery of a mk 7 DSG golf 2014 , 1.6 Tdi , I brought it from the auctions and know it has gearbox problem, Will not engage gears,
So I listened to the car with ignition switched on and could hear the hydraulic pump in the Mechatronics unit permanently running which led me to believe it maybe just a case of new accumulator kit (fingers crossed) that may sort the problem,
I shall post up a scan in next couple of days as soon as I receive the car!
My question is I cannot seem to find the Ross tech instructions for setting the Mechatronic unit into removal mode ? I would like to print it off to be ready if I need to remove the unit.
Is there also instructions to after its been reinstalled to turn the removal mode off?
I am hoping I am lucky and can in fact do the repair while still attached to the car but I am not sure until I see it as this is a MK7 and the last one I done was MK6
Please any links to the 7 speed DSG removal of megatronics, and also instructions on resetting and coding would be most appreciated.
This car shall be my family daily car, and I am looking forward to it arriving! Fingers crossed for me that I can repair myself!!!
South Molton, UK
Once you have posted the Auto-Scan it will be a lot easier for people to point you in the right direction.
alesypalsy
Hi petrol Dave, yes completely understand , I do not yet have the car so cannot scan it, I just wanted to swat up on the relevant information that I was asking for,
I have searched google and cannot seem to find the links
