Changing climatronic on e-Golf to remember last setting
   #21
South Molton, UK
Can you explain how you did this? I tried doing as you said and put your file in the User directory (overwrote the existing one), and did the following;
- choose module 8 (auto HVAC)
- Go to adaptions
- choose "cut-in behaviour"
- select active AND check soft reset
- press ok
I get the same errors as in my original post in this thread.
It sounds like you missed out the most important step:
All needed is a switch to the engineering session (4F) prior to changing the value.
   #22
flyboy320
Canada
C?ID=152178
I'm sure I'm missing something simple, but I can't figure out what it is.
I'm using a Micro-Can cable and the latest version of the software. When I enter module 8 and select security access and enter the code S12345 I get an error saying the value should be a 5 digit number. If I enter 12345 it gives an error something along the lines of not supported.
   #23
TBAx
DE
C?ID=287144
Something went wrong with the label file, if you didn't get the balloon tip with the S12345 login. Can you post an Auto-Scan excerpt of the HVAC module (08)?
   #24
flyboy320
Canada
C?ID=152178
That's correct, I do not get a balloon tip.
Is this the scan you need?
Part No SW: 5GE 907 044 AN HW: 5GE 907 044 AN
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 0002220020011001050500020010102B
VCID: 08314631B37E680450-805C
Air quality sensor:
TBAx
DE
C?ID=287144
Yup, that is correct. But it doesn't seem to use the correct label:
This should be User\5G0-907-044.clb
Can you please double check, that you have the file from my previous post in your C:\Ross-Tech\VCDS\Labels\User directory (assuming you installed it to the default path).
   #26
flyboy320
Canada
C?ID=152178
Yes I have the file you posted earlier and it's in the user folder, and called 5G0-907-044.clb
   #27
flyboy320
Canada
C?ID=152178
I have just done a re-scan and it now shows the Labels as "* None". I did the previous scan I posted above about a month ago;
Address 08: Auto HVAC (J255) Labels:* None
Revision: 00001K01
Coding: 0002220020011001050500420010102B
VCID: 08314631B37E680FEF-805C
Air quality sensor:
flyboy320
Canada
C?ID=152178
A scan shows Labels as "* None", anything else I can try, or is the clb file incorrect?
