Changing climatronic on e-Golf to remember last setting
flyboy320
Canada
C?ID=152178
There is an issue with the climatronic on the e-Golf. It will not remember the last setting so when you get back in the car it resets to a default of 72F / 22C. There is a tech tip for the 2015 and 2016 e-Golf and I'm trying to implement this on my new 2018 e-Golf. The tech tip is TT 87-15-02. There is a user on MyVWeGolf who said it got it to work on his 2017, but I cannot get it to work on mine. I cannot get the value to change from inactive to active, in my case the first time I try to change the value I get an error saying "value out of range", and the second time saying "the value was rejected by the controller and it will probably fail" (or something to that effect).
Looking for any insight as how I might set this value on my e-Golf?
Here is a log from a scan I did just after I got it home from the dealer. The only change I made prior to the scan is I changed the setting to remember both driver and passenger electric seat heater setting. I was able to change the setting, but it did not work. After I get back in the car where I previously had the seat heat on, it is set to off, so it's not remembering the last setting. I have since set it back to the way it was.
Saturday,14,April,2018,09:09:34:19795
VCDS Version: 18.2.0.3
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: WVWPR7AU3JW909878   License Plate:
Mileage: 108km-67mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 4B 51 52 5F
          8C A5 BD C0 C5 C6
VIN: WVWPR7AU3JW909878   Mileage: 108km-67miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: Malfunction 0010
Address 01: Engine (J623-EAZA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 F    HW: 0EA 907 309 A
   Component: E-Vehicle     H24 4238
   Revision: WMH24---
   Coding: 000D0016006400003000
   ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
   ROD: EV_VCU00XXX0110EA906016F_004.rod
   VCID: 3245C4D9656232D4DE-8066
   Part No SW: 5Q0 614 517 DB    HW: 5Q0 614 517 AH
   Component: ESC           H62 0856
   Revision: 00000000    Serial number: 60078000000101
   Coding: 01FA40A12C202175857F0207A1CB2980023484A14085943238915058C2E203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 74C902C1DFF67CE40C-8020
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0470501508
   Coding: 032C0C
   VCID: 3C59EAE1B726F4A404-8068
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002220020011001050500020010102B
   VCID: 08314631B37E680450-805C
   Air quality sensor:
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001803900229
   ROD: EV_BCMCONTI.rod
   VCID: 062D4809B96A7E7422-8052
   Component: WWS    180113  043 0551
   Serial number:         180119102247
   Component: RLHS  047 0105
   Serial number: S4Y18M02D14H08M34S43
   Coding: 00A8DD
   Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0452
   Serial number: 000308417617296
   Coding: 2271167811
   ASAM Dataset: EV_EPHVA2CAU3700000 009038
   VCID: 5285A45905A212D4FE-8006
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 7D0000C159FFC728949C810580400600000000000000000000
1236 - Databus
                    Reset counter: 43
                    Mileage: 96 km
                    Date: 2018.04.13
                    Time: 10:27:35
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 14.7 V
                    Velocity_vehicle_reference: 7.11 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.30 m/s²
   Serial number: 003GCR09PSC3
   Coding: 8CCCFC00002000005000001AC20800000065
   VCID: 47B3850DFEE0A77C99-8012
   Occupant Detection:
   Serial number: IBH000000000008H3VK$
   Coding: 303139
   Subsystem 2 - Part No SW: -----------    HW: 480 001 002 18
   Serial number: 35700000000C3755CB2T
   Subsystem 3 - Part No SW: -----------    HW: 480 001 002 18
   Serial number: 35800000000B6555CB2U
   Subsystem 4 - Part No SW: -----------    HW: 480 400 902 18
   Serial number: 35100019D291EE450566
   Subsystem 5 - Part No SW: -----------    HW: 480 400 902 18
   Serial number: 3520001BF28DB2A2048B
   Subsystem 6 - Part No SW: -----------    HW: 480 400 802 18
   Serial number: 35500019D2909F02D2EG
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 802 18
   Component: FrontSensor_P  000 6149
   Serial number: 35600019D2909F035565
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 04021808490139
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 09374335A874110C4F-805C
   Part No SW: 5G1 920 795 A    HW: 5G1 920 795 A
   Component: KOMBI         408 3195
   Coding: 0BB4701A6F8888090288690B5701002080000000
   VCID: 2E7DD0A9715A1634BA-807A
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 04011810800014
   Coding: 0201001704F81000FB001212081D00000001070100070000000300000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 3957F3F5B814C18C1F-806C
   Subsystem 1 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29170002564560127451
   Coding: 34FFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 8162526704
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460013516
   Coding: 06720100321A00010002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004.rod
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861230118154454
   Revision: 00000000    Serial number: 18000039633005
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449C2C19F763CE4CC-8060
   Component: HRE_Master    H12 0080
   Serial number: 0468916317
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D5FE7E5AC3CFDAC33-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0469208477
   Coding: 020111
   Serial number: 201217ELK13082
   Coding: 003E13208000040000000000
   VCID: 43AB911DCAD88B5C45-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000019154673
   Coding: 111000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: D3020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73CB01DDDAF87BDC15-8026
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 5QE 907 080 K    HW: 5QE 907 080 K
   Component: LE Gen 3.3H16 2052
   Revision: 00H16000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM10030115QE907080K 001008
   ROD: EV_DMCM10030115QE907080K.rod
   VCID: 4EBDB029119A7634DA-801A
   Serial number: 120118EAC12342
   VCID: 42A59419D5C282544E-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000019199712
   Coding: 091000
   Part No SW: 5NA 035 047 B    HW: 5NA 035 047
   Component: MU-H-NS-US    H54 1126
   Serial number: A852A0JB001486
   Coding: 02738002FF00000051220001001828009F0105F401200405DE
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJV0106186
   Subsystem 2 - Part No SW: V03 959 803 SR    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Compact Disc Database:
   Component: Gracenote2  --- 3011
Address 8C: Hybrid Battery
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 20011812K21732
   Coding: 000307000000020100222354C150490084000E200120
   ROD: EV_MFKBoschMQBB_VW27.rod
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:* None
   Part No SW: 5QE 915 022 AP    HW: 12E 915 022 H
   Component: LMSG          H20 1096
   Serial number: 01148074970422
   Coding: 4A4914040400
   ASAM Dataset: EV_HVChargManagVWMQB 003004
   ROD: EV_HVChargManagVWMQB.rod
   VCID: 0F036D2DD6103F3C91-805A
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN180350400000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
   VCID: 4BBBB93DE288431CBD-801E
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 5GE 907 458 C    HW: 5GE 907 458
   Component: TME-Min       H06 0203
   Serial number: 0064769
   Coding: 02
   ASAM Dataset: EV_ThermContrVISAU49X 001021
   ROD: EV_ThermContrVISAU49X_VW37.rod
   VCID: 45AF8F05C4ECB56C6B-8010
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR180243003810000133
   Air Conditioning Compressor Sub:
   Subsystem 3 - Part No SW: 5QE 816 803 A    HW: 5QE 816 803 A
   Component: J842 eKK  H03 0009
   Refrigerant Pressure And Temperature Sender 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Refrigerant Pressure And Temperature Sender 3:
   Subsystem 5 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G827 pT-Sens3  H11 0010
   Refrigerant Pressure And Temperature Sender 4:
   Subsystem 6 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G828 pT-Sens4  H11 0010
   Refrigerant Pressure And Temperature Sender 5:
   Subsystem 7 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G829 pT-Sens5  H11 0010
   Refrigerant Expansion Valve 1:
   Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000120293565
   Refrigerant Expansion Valve 2:
   Subsystem 9 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000120293568
   Refrigerant Expansion Valve 3:
   Subsystem 10 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N638 EV3_KaMi  H12 0102
   Serial number: 00000000000120293511
   Refrigerant Shut Off Valve 1:
   Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: V424 AV1_KaMi  H12 0102
   Serial number: 00000000000140292785
   Refrigerant Shut Off Valve 4:
   Subsystem 12 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000140292787
   Refrigerant Shut Off Valve 5:
   Subsystem 13 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000140290909
37024 - A/C Compressor
          U103B 00 [044] - No Communication
                    Mileage: 108 km
                    Date: 2018.04.13
                    Time: 22:33:11
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H59 1560
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 05:41)--------------------------
seacycle
C?ID=212304
Having gotten a bit of time to assemble screen shots today, I’ll follow up with more detail.
87-15-02TT is straight forward:
1. 08- Air Conditioning
2. Guided Functions
3. Calibration
4. Adaptation Channel-5 Switching-on behavior
5. Select option “2 - activated” (Other options are “1 - not activated”, and “3 -corresponds coding”)
While the TT only cites 2015-2016 models, 2017 owners have reported elsewhere that dealers have applied the fix to 2017 instances as well. Though it isn’t completely certain whether or not they are using 87-15-02TT as written on a 2017, I haven’t found anything newer on on the topic in erwin.
The VCDS process described in http://www.myvwegolf.com/forum/viewtopic.php?f=12&t=1128 suggests an error will pop up on the first attempt of changing to “activated”, but the controller will accept the request on the second.
My experience on a 2017 starts here:
On pressing “Do It!” I get:
Press “Yes”, I get a “Request out of range”:
Going through the process a second time is the same, except instead of “Request out of range” I get:
Followed by a “Request Sequence Error”
I'm fairly low on the VCDS learning curve, so have no real idea what is going on there.
For reference, the “out-of-box” adaptation mapping for my 2017 SEL + DAP:
;SW:5GE-907-044-AN   HW:5GE-907-044-AN ---  Auto HVAC
;Component:Climatronic   H04 1702, Coding:0002220020011001050500021211102B
;EV_ACClimaBHBVW37X,006145,EV_ACClimaBHBVW37X_006_VW37.rod
;Friday,27,April,2018,19:29:14:41186
;VCDS Version: Release 18.2.0 (x64)  Data version: 20180212 DS287.0
;VCID: 885CEF8533935904D0-80DC
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01493-Air quality sensor sensitivity,Maximum ,1
IDE01503-Runtime for compressor run-in basic setting,120 s,1
IDE01536-Post-heating of parking heater,10 min,1
IDE03176-Duration of compressor run in,0 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06097-Target temperature of A/C - heater function via remote control,22.0 ºC,1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06546-Interior target temperature for production routines,22 ºC,1
IDE06593-Recirculation air for production routines,No effect ,1
IDE07108-Climate modes,activated ,1
IDE07301-Remote start function: activation of seat heating,Seat heater front ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.,4 ºC,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15 ºC,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 ºC,1
IDE07307-Remote start function: activation stage of seat heating,2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,2 ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00000000 00000000  ,2
IDE80008-Analysis 8,not active ,1
MAS05739-CO2 compressor on-time reduction,Matching coding ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS07251-Cut-in behavior,not activated ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,12 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG130577-Knockout_timer_activation,not activated ,1
Elapsed Time: 00:13
Terminology footnote: On a German language forum, I found MAS07251 described as “Einschaltverhalten”, which Google Translate says is “Switch-on behavior”, which is also the terminology 87-15-02TT, uses. Curious about the origin of “cut-in behavior” in VCDS.
That's VAG's own translation. They will set people to do translation who are not native English speakers and who may be lacking appropriate context for the strings being translated as well. When we see stuff like that, the question is: Should we improve it, or should we leave it the same as it would be in the factory tool?
Try setting up new WSC, Importer, and Equipment number values on the Options screen in VCDS:
The importer number for Canada is 999. These don't have any functional effect on anything, but the module may not like the fact that we're trying to put back the same values it already has (which might be factory defaults). After you change the values on that screen, click [Save], then exit and restart VCDS before you try the Adaptation again.
turbocharged
C?ID=334886
Has this worked on your car?
turbocharged
C?ID=334886
FYI, I tried yesterday with exact above instructions and was unable to make it work. Can we try anything else? Many thanks!
Erlingni
Norway
C?ID=83371
I have the exact same problem on my MY2018 e-golf. As well as everyone else with VCDS and the facelift model, according to forums.
I have tried with two different WSC, Importer, and Equipment number combinations that I know are both valid: one used for preparation of new cars before delivery (software update etc.), and one used by an authorized local dealer.
Dealers are now able to change this with their own tools on the very same facelift cars, so clearly there must be a bug here, either in VCDS or in the module itself.
Edit; Using latest VCDS software version 18.2.1 and HEX-NET interface with latest firmware installed.
Another possibility is that nobody presently understands what the dealers' tool is actually doing when it changes this.
bojangles
London ON, Canada
C?ID=216260
Same issue here... waiting patiently for Ross tech to respond
If we knew what the "magic trick" was, we would happily tell you guys. Unfortunately, the e-Golf is not sold in Pennsylvania, nor is it likely to have a customer bring one to us to play with because they don't have sufficient range to make it here. ;)
TBAx
DE
C?ID=287144
Could it be, that the change simply has to changed in another diagnostic session?
There are a number of possibilities and that would certainly be one of them.
Erlingni
Norway
C?ID=83371
I have made an appointment with my local dealer in about three weeks from now, to get this changed permanently.
I will check if the relevant diagnostic session (Auto HVAC -Cut-in behavior) has been changed or not afterwards, and report back here.
Erlingni
Norway
C?ID=83371
So this is the result after my visit to the dealer:
They have now somehow managed to change the adaption in "Cut-in behavior" to "Matching coding".
Last temperature settings are now remembered.
I still struggle to understand why we are not able to change this particular adoption with VCDS ourselves.
Edit; I just compared the new scan to an old one. Nothing else changed. Coding is the same, shop# is the same and the module software has not been updated.
South Molton, UK
My guess would be that either they changed an adaptation channel(s), or changed the parameterisation (more likely IMHO).
bojangles
London ON, Canada
C?ID=216260
I just played around for a while and no luck with adaptation change here ...
what can I do to collaborate with Ross-Tech and figure this out?
Bruce
bojangles
London ON, Canada
C?ID=216260
At the dealer now in Canada, they cannot change the “cut in behaviour “
They will open a ticket with VW Canada tech help
More later
Ps the tech is opening a help ticket for this - in Canada there is not a tech ticket 87-15-02TT so he will ask about that
Also they will ask about my FM radio reception that has gotten worse over the last year
AND he found one of my two horns are dead... so that is on order
It’s good to have progress- but without a pleasant nudge on these this I am sure I’d be going home with a “normal vehicle function” report card
TBAx
DE
C?ID=287144
Dear everyone,
changing the described adaption channel "MAS07251-Cut-in behaviour" ("MAS07251-Einschaltverhalten") is possible through VCDS. I can confirm this changes the HVAC to remember the last setting.
All needed is a switch to the engineering session (4F) prior to changing the value.
I've created a small label file, which can be placed in the Labels\User directory, which will allow the SA "S12345" to switch to the developer/engineering session.
You can grab it here: https://ufile.io/xg7k1z0i (available 30 days).
(If any of this is unwanted by Uwe and the RT team, please feel free to edit this post)
Maybe RT puts something like this in a future label revision. Wish you all a merry christmas.
flyboy320
Canada
C?ID=152178
Dear everyone,
Can you explain how you did this? I tried doing as you said and put your file in the User directory (overwrote the existing one), and did the following;
- choose module 8 (auto HVAC)
- Go to adaptions
- choose "cut-in behaviour"
- select active AND check soft reset
- press ok
I get the same errors as in my original post in this thread.
