09 Passat 2.0 Car won't start
ivagp
C?ID=95551
Customer States car would not start had the car towed to a local shop. Local shop check the battery it was fine. They went to start the car and the car started when they scanned it it would not communicate. They told the customer it's probably going to not start again. Now it's at my shop it starts but we have no communication DLC pins 1 and 16 have 12.5 volts. pins 6 and 14 have 2.5 volts. Here is the VIN number wvwjk73c19p021764
What does VCDS says when you do [Options] -> [Test] when connected to this car?
ivagp
C?ID=95551
I'll check again in the morning but I believe it was communicating okay with that portion of it. I think I've scanned the car before and I posted it on this website.
ivagp
C?ID=95551
Can testing k1 ok k2 ok
ivagp
C?ID=95551
thanks to Peter @ Rosstech for walking me thru i or we were able to pull a scan and here it is. due to testing with out battery charger is the reason for low volts.
Tuesday,17,April,2018,09:55:26:13440
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: ivagp
VIN: WVWJK73C19P021764   License Plate: JOEY
Mileage: 139230km-86513mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 53 56 62 65
          72 77
VIN: WVWJK73C19P021764   Mileage: 139230km-86513miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
77-Telephone -- Status: Not registered 0011
Address 01: Engine
Unable to communicate with address 01,
and "Force K on engine" is activated.
   Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
   Component: AQ 250 6F           1391
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00028 028 00001
   VCID: 8542F83FCC15266CAB-80D0
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785898014
   Coding: 0000376
   VCID: AB166E870A31301C1D-80FE
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:11
                    Speed: 3.0 km/h
                    Hex Value: 0x0004
                    Voltage: 8.50 V
                    Bin. Bits: 00011110
                    Count: 112
                    Hex Value: 0x0000
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: F8BC81CB8BE74B84A0-80AC
   Revision: 00H54000    Serial number: 00000005874614
   Coding: 15848F0340041A00470000000F00000000285D435C000100000000000000
   VCID: B32676E7D20168DC55-80E6
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 210508 003  0205
   Coding: 00046997
   Shop #: WSC 00028
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.12
                    Time: 07:28:00
                    Voltage: 13.80 V
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 11:02:00
                    Voltage: 8.40 V
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__01F VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPCGDJXC
   Coding: 0012614
   VCID: FAB89BC3B5EB5994D6-80AE
   Subsystem 1 - Part No: 3C0 959 339 D
   Component: BF-Gewichtsens. 001 0002
   Subsystem 2 - Serial number: 00000000001BQM
   Subsystem 3 - Serial number: 0024.05.080000100000630046ÿ†63
   Subsystem 4 - Serial number: 630046ÿ†6333FTS650091948 ÿ†63
   Subsystem 5 - Serial number: 91948 ÿ†6343FTS648931928 ÿ†63
   Subsystem 6 - Serial number: 31928 ÿ†6353ETS62T03UVNH ÿ†63
   Subsystem 7 - Serial number: 3UVNH ÿ†6363ETS60103UVNH ÿ†63
   Subsystem 8 - Serial number: 3UVNH ÿ†6374CTS6TCBMSVNH ÿ†63
   Subsystem 9 - Serial number: MSVNH ÿ†6384CTS61BAMSVNP ÿ
   Subsystem 10 - Serial number: MSVNP ÿ
                    Reset counter: 47
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:15:52
03551 - Functional Restriction of Seat Occupied Recognition
            000 -  -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 32
                    Reset counter: 47
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:15:52
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AR
   Coding: 0001111
   VCID: ED92A09FF4A5FE2C43-80B8
   Part No SW: 3C0 920 972 A    HW: 3C0 920 972 A
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007205
   VCID: A40485BB67EFFF64DC-80F0
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 11:07:46
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:06
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.12
                    Time: 07:47:25
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P08714064F
   Coding: FD807F074002121002
   VCID: A6009FB311D30D74C2-80F2
            000 -  -
                    Reset counter: 20
                    Mileage: 120144 km
                    Date: 2017.07.05
                    Time: 09:25:41
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:45:17
01304 - Radio
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:45:17
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 22503 444 103841
   VCID: F3A6B6E7928128DC95-80A6
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 16
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:28:31
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667022012
   VCID: A50298BFACD5066CCB-80F0
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:52:42
01304 - Radio
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:44:25
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:47:19
   Part No SW: 3C0 035 684     HW: 3C0 035 684
   Component: RNS-MID       H17 0210
   Revision: AB001001    Serial number: VWZ6Z7H8218084
   Coding: 040004000400000200
   VCID: E08CC9ABF377A344F8-80B4
02633 - Antenna for Satellite Tuner
                    Fault Status: 00101011
                    Reset counter: 47
                    Mileage: 139224 km
                    Date: 2018.04.16
                    Time: 12:38:05
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:58
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:52:29
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000023688714
   Coding: 0001205
   VCID: EFAEBA97FEA90C3C71-80BA
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:48:59
                    Fault Status: 01100101
                    Reset counter: 9
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:37:09
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0401
   Revision: 1AH02234    Serial number: 00081340050002
   Coding: 0000258
   VCID: B6204FF3C1737DF472-80E2
01288 - Terminal 30; Steering Assist
                    Fault Priority: 9
                    Reset counter: 48
                    (no units): 2.0
                    Voltage: 11.00 V
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:33
                    Voltage: 0.10 V
                    Voltage: 8.40 V
                    Voltage: 0.80 V
                        Not Occup.
                        Not Occup.
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 8
                    Mileage: 139231 km
                    Date: 2018.04.16
                    Time: 15:57:29
                    Hex Value: 0x5301
                    Hex Value: 0x4301
                    Hex Value: 0x1B01
                    Hex Value: 0x5601
                    Hex Value: 0x4601
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13910F8001862E521004141FF08A0F0E085801
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:48:19
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000038388717
   Coding: 0001204
   VCID: F0ACB9EBE39713C468-80A4
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:00
                    Fault Status: 00100101
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:37:09
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000077350
   Coding: 0000057
   VCID: A81C918B1BC71B04F0-80FC
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:47
                    Voltage: 8.00 V
                    Count: 50
                    Speed: 6.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 47
                    Mileage: 139224 km
                    Date: 2018.04.16
                    Time: 12:38:05
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:58
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:52:29
   Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388   TUER-SG HL   0308
   Revision: 42004101    Serial number: 00000000518302
   Coding: 0001168
   VCID: F2A8B3E3ED9B21D49E-80A6
01813 - Supply Voltage for Door Controller; Rear Left (J388)
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:04
   Coding: 0100101
00667 - Ambient Temperature Signal
                    Reset counter: 47
00625 - Vehicle Speed Signal
                    Fault Frequency: 149
                    Reset counter: 47
                    Mileage: 139231 km
   Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389   TUER-SG HR   0308
   Revision: 42004101    Serial number: 00000000478550
   Coding: 0001168
No Faults Found
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 051 730 D    HW: 1K8 051 730 D
   Component: Telefon       H03 6900
   Revision: 00003000    Serial number: 00000A09617478
   Coding: 402120
   Shop #: WSC 22503 444 103858
   VCID: A81C918BDBC71B04F0-80FC
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:38:59
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:54:08
01304 - Radio
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:44:25
End----------(Elapsed Time: 02:52, VBatt start/end: 13.7V/13.7V)-----------
Santos
Address 01: Engine
Uncheck "force K on engine" in the options screen.
ivagp
C?ID=95551
Ok how about can initiation
ivagp
C?ID=95551
here is a scan from earlier this year.
Thursday,25,January,2018,12:59:21:13440
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4407.4
Data version: 20171130 DS276.6
VIN: WVWJK73C19P021764   License Plate: PASSAT
Mileage: 132120km-82095mi   Repair Order:
          72 77
VIN: WVWJK73C19P021764   Mileage: 132120km-82095miles
77-Telephone -- Status: Not registered 0001
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3319
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   VCID: EFAEBA97FEA90C3EF8-80BA
Readiness: 0110 0101
   Coding: 0000840
   VCID: 8542F83FCC15266E22-80D0
   Coding: 0000376
   VCID: AB166E870A31301E94-80FE
   VCID: F8BC81CB8BE74B8629-80AC
   VCID: B32676E7D20168DEDC-80E6
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 0012614
   VCID: FAB89BC3B5EB59965F-80AE
                    Reset counter: 29
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:15:52
                    Fault Frequency: 20
                    Reset counter: 29
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:15:52
   Coding: 0001111
   VCID: ED92A09FF4A5FE2ECA-80B8
   Coding: 0007205
   VCID: A40485BB67EFFF6655-80F0
   VCID: A6009FB311D30D764B-80F2
            000 -  -
                    Reset counter: 20
                    Mileage: 120144 km
                    Date: 2017.07.05
                    Time: 09:25:41
   VCID: F3A6B6E7928128DE1C-80A6
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 00101110
                    Reset counter: 143
                    Mileage: 131038 km
                    Date: 2018.01.18
                    Time: 13:36:15
   VCID: A50298BFACD5066E42-80F0
   VCID: E08CC9ABF377A34671-80B4
                    Fault Frequency: 21
                    Reset counter: 154
                    Mileage: 126496 km
                    Date: 2017.10.30
                    Time: 04:04:26
   Coding: 0001205
   Coding: 0000258
   VCID: B6204FF3C1737DF6FB-80E2
   Coding: 0001204
   VCID: F0ACB9EBE39713C6E1-80A4
   Coding: 0000057
   VCID: A81C918B1BC71B0679-80FC
                    Reset counter: 245
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:18:03
                    Voltage: 8.00 V
                    Count: 50
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 21
                    Reset counter: 154
                    Mileage: 126496 km
                    Date: 2017.10.30
                    Time: 04:04:26
   Coding: 0001168
   VCID: F2A8B3E3ED9B21D617-80A6
   Coding: 0100101
   Coding: 0001168
   Coding: 402120
   VCID: A81C918BDBC71B0679-80FC
End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.1V)-----------
ivagp
C?ID=95551
here is the latest scan after letting it idle for a while seems like more are working.
Tuesday,17,April,2018,10:52:30:13440
          72 77
37-Navigation -- Status: Malfunction 1010
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 30.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 9.144 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 9.017 V
001393 - Brake Switch (F)
               P0571 - 000 - Implausible Signal
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 139233 km
                    Date: 2018.04.16
                    Time: 17:27:29
                    RPM: 760 /min
                    Load: 20.8 %
                    Temperature: 96.0°C
                    Temperature: 60.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.954 V
   Coding: 0000840
   Coding: 0000376
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:11
                    Speed: 3.0 km/h
                    Hex Value: 0x0004
                    Voltage: 8.50 V
                    Bin. Bits: 00011110
                    Count: 112
                    Hex Value: 0x0000
   Coding: 00046997
   Shop #: WSC 00028
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.12
                    Time: 07:28:00
                    Voltage: 13.80 V
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 11:02:00
                    Voltage: 8.40 V
   Coding: 0012614
                    Reset counter: 47
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:15:52
                    Fault Frequency: 32
                    Reset counter: 47
                    Mileage: 128283 km
                    Date: 2017.11.23
                    Time: 00:15:52
   Coding: 0001111
   Coding: 0007205
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 11:07:46
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:06
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.12
                    Time: 07:47:25
            000 -  -
                    Reset counter: 20
                    Mileage: 120144 km
                    Date: 2017.07.05
                    Time: 09:25:41
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:45:17
01304 - Radio
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:45:17
                    Fault Frequency: 16
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:28:31
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:52:42
01304 - Radio
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:44:25
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:47:19
                    Reset counter: 47
                    Mileage: 139224 km
                    Date: 2018.04.16
                    Time: 12:38:05
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:58
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:52:29
   Coding: 0001205
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:48:59
                    Reset counter: 9
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:37:09
   Coding: 0000258
                    Fault Priority: 9
                    Reset counter: 48
                    (no units): 2.0
                    Voltage: 11.00 V
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:33
                    Voltage: 0.10 V
                    Voltage: 8.40 V
                    Voltage: 0.80 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 8
                    Mileage: 139231 km
                    Date: 2018.04.16
                    Time: 15:57:29
                    Hex Value: 0x5301
                    Hex Value: 0x4301
                    Hex Value: 0x1B01
                    Hex Value: 0x5601
                    Hex Value: 0x4601
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:48:19
   Coding: 0001204
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:00
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:37:09
   Coding: 0000057
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:47
                    Voltage: 8.00 V
                    Count: 50
                    Speed: 6.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 47
                    Mileage: 139224 km
                    Date: 2018.04.16
                    Time: 12:38:05
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:53:58
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:52:29
   Coding: 0001168
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:04
   Coding: 0100101
                    Reset counter: 47
                    Reset counter: 47
                    Mileage: 139231 km
   Coding: 0001168
01814 - Supply Voltage for Door Controller; Rear Right (J389)
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:49:14
   Coding: 402120
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:38:59
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.10
                    Time: 10:54:08
01304 - Radio
                    Reset counter: 47
                    Mileage: 139231 km
                    Date: 2018.04.11
                    Time: 13:44:25
End----------(Elapsed Time: 02:20, VBatt start/end: 13.4V/13.4V)-----------
ivagp
C?ID=95551
Battery is being charged and will be tested.
ivagp
C?ID=95551
after charging battery tested good its a group 48 and sticker on it says July 2017. here is another scan, of course the car starts and acts fine. the only other info i got out of the customer is that when the problem occurred the first time when he pushed the key down the light on the interment panel where flickering on and off. and when they towed it to the shop even the thier jumper on it would not start till the next day when it started on its own
Wednesday,18,April,2018,13:21:00:13440
          72 77
                    Mileage: 139233 km
                    Date: 2018.04.16
                    Time: 17:47:14
                    RPM: 760 /min
                    Load: 20.0 %
                    Temperature: 96.0°C
                    Temperature: 63.0°C
                    Voltage: 12.954 V
   Coding: 0000840
   Coding: 0000376
   Coding: 00046997
   Shop #: WSC 00028
No Faults Found
   Coding: 0012614
   Coding: 0001111
   Coding: 0007205
            000 -  -
                    Reset counter: 9
                    Mileage: 139233 km
                    Date: 2018.04.16
                    Time: 17:45:36
   Coding: 0001205
                    Reset counter: 9
                    Mileage: 139233 km
                    Date: 2018.04.16
                    Time: 17:45:31
   Coding: 0000258
No Faults Found
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Coding: 0001204
   Subsystem 1 - Part No: 1K0 959 702 AC
No Faults Found
   Coding: 0000057
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
   Coding: 402120
End----------(Elapsed Time: 03:16, VBatt start/end: 13.8V/13.8V)-----------
