Software Version Management
GXCars
C?ID=248011
I'm trying to rid my car of the software version management code after changing the MIB unit because audi will not touch the car until I've got everything sorted, I've got into the confirmation of installation change in the adaptations in the 5f unit and I get a value of 8A F6 (space between the 8A and F6) I cant find anywhere to calculate the new code does anyone have any ideas ?
I've also noticed a release of Swap functions in the basic settings - can someone tell me what it does as I think it may be related to my failed cruise installation (seperate thread on that..)
Thanks in advance
Ian
South Molton, UK
This worked for me:
[B]VCDS CODING[/B]
[LIST=1]
[*]5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change'
[*] Note your current coding
[*]Start Windows calculator and set it to 'Programming mode' and select 'HEX' option
[*]Calculation: (current coding) XOR C9D2
[*]Change the adaptation channel to the new (just calculated) code
[*]VCDS main screen, 'Auto-Scan'
[*]Check for fault codes (generated by the update) and clear them (software version, interrupted communication, etc.)
[*]Note that VCDS shows your code on the adaptation channel with a space ('xx xx' format).You have to remove the space before you calculate your new code. At the point you enter your new (calculated) code, insert the space again.
[/LIST]
[COLOR=#000000][FONT=&quot]
[/FONT][/COLOR]
[COLOR=#000000][FONT=&quot]EXAMPLE (don't use these values):[/FONT][/COLOR]
[LIST]
[*][FONT=Symbol][/FONT]'1A 1A' (original coding of the adaptation channel)
[*][FONT=Symbol][/FONT]1A1A XOR C9D2 equals D3C8
[*][FONT=Symbol][/FONT]Enter it as 'D3 C8' (with space) on the adaptation channel
[*][FONT=Symbol][/FONT]If your original code starts with zero(s) just remove them before calculating (if it's 0AFB for example calculate with AFB)
[/LIST]
[FONT=&quot]
[/FONT]
GXCars
C?ID=248011
Thanks - Just tried it and I'm getting 4324 - doesnt look right to me - but maybe it is, I just dont want to enter something wrong,
Any chance you could verify for me
Thanks in advance
South Molton, UK
Thanks in advance
I get the same value of 43 24 using your 8A F6.
GXCars
C?ID=248011
Brilliant - just recoded it and the error is gone - I'm really grateful :)
AMBSC
Brazil
C?ID=233374
Just did a SW update in my 5F control unit, coming from train "MHI2_ER_AUG22_P4212" (version 1177) to "MHI2_ER_AUG22_P5092" (version 1329), using the red (engineer) menu in MMI.
Got the same "1555 - checking software version management" fault, did the HEX procedures, and it seems the fault is gone.
But after the update, I also got a "1552 - Expanded Bus Activity Active" fault, that is still there. Did a quick research and found that the SVM fault is related to SW update via engineer menu, but couldn't find the relation between SW update and the "expanded bus active" fault. What could be wrong? Here's the log:
Cheers
Thursday,17,January,2019,11:12:44:30049
VCDS Version: 18.9.0.2 (x64)
VIN: WAUAGCFY2J2216711   License Plate:
Mileage: 805km-500mi   Repair Order:
Chassis Type  FY-AU49 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 36 42 44 46 47 52 5F 6C 6D 74
          81 82 8B A5 A9 BB BC CA
VIN: WAUAGCFY2J2216711   Mileage: 805km-500miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
   Part No SW: 80A 907 559 B    HW: 06M 907 309 D
   Component: V6 3.0l TFSI  H22 0005
   Revision: B2H22000
   Coding: 2A2A00322366050B34180000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS01180A907559B 001005
   ROD: EV_ECM30TFS01180A907559B.rod
   VCID: 2E54877B7162243A77-807A
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 69DE3467880C830262-803C
   Part No SW: 80A 907 379 K    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0775
   Coding: 1CAA14BE30A30A9C91A55892087E52A2E5B5C238280C50891A104A45A7AD43
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 377AA21F8E38E5F224-8062
   Part No SW: 80A 820 043 J    HW: 80A 820 043 J
   Component: Klima Zone 3  H60 0210
   Coding: 6608098C5544010D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 244065532FAE9E6A91-8070
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002325326
   Serial number: BF30DE1900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501343E17900CD050C51199C2F0CF9130B71090000000000000000600016810A4501AB22B606
   VCID: 010E0CC7907C6B42DA-8054
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 180608  040 0570
   Serial number: 00000001805202210071
   Coding: 5FC7F7
   Serial number: 21471476X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 13 06 2018  81640362
   Serial number: GX1CE111061823810052
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 AB    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00006636
   Coding: 010101
   Electrically Adjustable Steering Column:
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA131960000048021807
   Coding: 0A0700
   Cup Holder With Heater And Cooling Element:
   Subsystem 7 - Part No SW: 80A 864 981 B    HW: 80A 864 981 B
   Component: Q5 THERMO CUP  H07 0020
   Serial number: 0009806910
   Subsystem 8 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000105864007
   Part No SW: 80A 907 561     HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3472E7E358FFEC06747860A4
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 65C638576414A76246-8030
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    051 0605
   Serial number: 003WBM05E6BI
   Coding: AACCF00000800000980000FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3E74B73BA102D4BAE7-806A
   Subsystem 1 - Part No SW: -----------    HW: 480 000 705 18
   Serial number: 357000000006877CDE2+
   Subsystem 2 - Part No SW: -----------    HW: 480 000 705 18
   Serial number: 358000000004EB510D2N
   Subsystem 3 - Part No SW: -----------    HW: 480 030 405 18
   Serial number: 351001C0C7BB11016D43
   Subsystem 4 - Part No SW: -----------    HW: 480 030 505 18
   Serial number: 352001C10B0945A0BC88
   Subsystem 5 - Part No SW: -----------    HW: 480 030 305 18
   Serial number: 355001C0C73AF640AAEV
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 030 305 18
   Serial number: 356001C0C73AF2407EFU
   Central Sensor XY:
   Subsystem 7 - Part No SW: -----------    HW: 480 021 804 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C929635C1928Z
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 CH    HW: 80A 907 129 CH
   Component: Lenks.Modul   H02 0005
   VCID: 70E85903ABD672CA25-8024
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H19 0377
   Coding: 048D96C43C9400081AA3E9401000400000000000
   VCID: 4382C6CFCAE0B95288-8016
   Part No SW: 4M4 907 468 F    HW: 4M4 907 468 E
   Component: Gateway       H22 0123
   Revision: 7L010001    Serial number: 01G7L013618610
   Coding: 03010001000006405407000000590032F89A0000100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 003111
   VCID: 3D76B037AC04CFA2FE-8068
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0004
   Serial number: 20180628131716 00534
   Serial number: 8300445900
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 11A14818400973
   Coding: 00581B000000B0010000010101010000000000000000000000000000000000
   VCID: 76E46F1BC9B25CFAFF-8022
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1RFG004EA
   Coding: 005D8A015E00040000011002
   VCID: 081811E3B3465A0A9D-805C
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000690634
   Coding: B0112101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 346095139F4E0EEA01-8060
Address 46: Central Conv.
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAJTK02RDUA
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 193E44A718ECD38232-804C
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1RF900T3Y
   Coding: 005D8A015E00040000011000
   VCID: 071A12DFBE58557294-8052
   Part No SW: 8W5 035 039 C    HW: 8W5 035 039
   Component: MU-P-LN-RW    034 1329
   Serial number: A801F0J9402993
   Coding: 012456030000000013220002001A00102F001AE401700100DE
   VCID: 3B72BE2FB210C192C0-806E
   Subsystem 1 - Part No SW: V03 959 802 DG    HW: -----------
   Component: ROW 2018/2019  --- 0071
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9JBL04YWW
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 11051800000000000529
   Compact Disc Database:
   Component: Gracenote2  --- 4012
          U1104 00 [009] - -
                    Reset counter: 15
                    Mileage: 805 km
                    Date: 2019.01.17
                    Time: 11:04:08
                    Voltage terminal 30: 11.4 V
   Component: RVC Compact   H12 0250
   Coding: 0224060102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 3362960F9A4009D218-8066
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5
   Coding: 0730
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 4898D1E3F3C69A0A5D-801C
Address 74: Chassis Control
   Part No SW: 80B 713 041 M    HW: 80B 713 041 M
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20180608000060
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 275A725F5E987572B4-8072
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 80A 919 617     HW: 80A 919 617
   Component: HeadUpDisplay H13 1640
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736.rod
   VCID: 6ADC4B6B8D0A881A6B-803E
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 63C2264F6A20D952A8-8036
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H16 0050
   Coding: 0404020600000402022023A4CD000000B0000020C020
   ROD: EV_BVSMLBevKOSTAAU736.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Serial number: 180329200420
   VCID: 68D831639306BA0A7D-803C
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1RFL00EBA
   Coding: 000D88000000040000001000
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 0A1C2BEBAD4A281A8B-805E
   Component: TSG HBFS001 0737
   Serial number: CLSM1RFL00E85
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:32)--------------------------
AMBSC
Brazil
C?ID=233374
And here's the previous log, before the SW update (changed SW version from B to C, and VCID - maps where updated days before):
Monday,17,December,2018,22:06:15:30049
Mileage: 116km-72mi   Repair Order:
VIN: WAUAGCFY2J2216711   Mileage: 116km-72miles
   Revision: B2H22000
Readiness: 0010 0001
   Revision: --H05---
   Coding: 100000
196896 - Temperature Sensor for Rear Upper Body Vent
          B1451 01 [009] - Electrical Failure
                    Reset counter: 0
                    Mileage: 45 km
                    Date: 2018.12.13
                    Time: 14:20:50
                    Voltage terminal 30: 13.18 V
                    Outside air temperature: 28.50 °C
   Coding: 07501143E17900CD050C51199C2F0CF9130B71090000000000000000600016810A4501AB22B606
   Coding: 5FC7F7
   Coding: 02006E
   Coding: 010101
   Coding: 0A0700
   Central Sensor XY:
   Coding: 048D96C43C9000081AA3E9401000000000000000
   Part No SW: 8W5 035 039 B    HW: 8W5 035 039
   Component: MU-P-LN-RW    034 1177
   VCID: 3A7CBB2BBD2AF89ADB-806E
   Subsystem 1 - Part No SW: V03 959 801 PT    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Coding: 0730
   Coding: 4E01C0
   Coding: 0404020600000402022023A4CD000000A0000020C020
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:39)--------------------------
Address 08: DTCs cleared
Address 09,8W0 907 063 CF,channel IDE03782-Switch-off speed for parking assist,adapted from,5 ,to,20 ,
Address 17,8W5 920 790 D,recoded (Long Coding),from,048D96C43C9000081AA3E9401000000000000000,to,148D96C43C9000081AA3E9401000000000000000,(02391/785/00200),
