Brake lights and Horn on with Terminal 15 off - no-go in Jetta Mk. VI?
JTK Awesome
C?ID=301999
I found these bits in Central Electronics on our 2012 Beetle Base and 2015 Passat SEL as well as my Jetta (2017 SEL). For the Beetle and Passat, it was as simple as checking the associated bits in VCDS and done.
Not so in the Jetta Mk. VI. Whether I have these bits checked or not, I cannot activate my horn or brake lights with the ignition off.
Are there additional settings buried in some other controller?
NitrousOxide
Jamaica
C?ID=269481
It seems as though you may need another module to be installed which may have some sort of relay included to make it work.
iichel
Eindhoven, NB, NL
C?ID=284912
Autoscan would be nice
MotorEldia
Morocco
C?ID=374242
Up, reviving the topic. I can't get my horn to honk with the ignition turned off. 2016 Jetta.
Autoscan :
Sunday,21,July,2019,21:53:34:44035
VIN: 3VW3A7AJ6GM******   License Plate: *******
Mileage: 3470km-2156mi   Repair Order: 2 Telematics OK and Edits
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 04 05 08 09 15 17 19 25 2B 44 47 5F 75
VIN: 3VW3A7AJ6GM******   Mileage: 3470km-2156miles
Address 01: Engine (J623-DELA)       Labels: None
   Part No SW: 04L 906 016 MC    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4450
   Revision: 8AH20---
   Coding: 01190012042410095000
   Shop #: WSC 20200 993 00000
   ASAM Dataset: EV_ECM20TDI01104L906016MC 004002
   ROD: EV_ECM20TDI01104L906016MC.rod
   VCID: 76B5E6E9E84DFD87E05-8022
   Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
   Component: ESP MK60EC1   H46 0174
   Revision: 00H46001
   Coding: A14B400C492300FC850F02E7921C004221100012
   Shop #: WSC 00066 000 00000
   VCID: 74B1DCE1FEB1EF97DE1-8020
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0368374703
   Coding: 030C0C
   Shop #: WSC 00066 000 00018
   VCID: 372B2BEDAFC7448F3B3-8062
   Part No SW: 1K8 907 044 Q    HW: 1K8 907 044 Q
   Component: Climatronic   H05 0304
   Revision: 00001K03
   Coding: 0050019002
   Shop #: WSC 00066 000 00318
   VCID: 3D2739C58DFB6EDFE1F-8068
   Part No SW: 7E0 937 189     HW: 7E0 937 189
   Component: BCM PQ25 MMI3 H80 0733
   Revision: BA080001    Serial number: 18003183150699
   Coding: 72994FBF48AB0F00093926807EE896C52D86700E60842130B0A0500B2844
   Shop #: WSC 18930 003 104857
   VCID: 71BFD5F581A3DABF357-8024
   Component: RLS 270515 05  54  0403
   Coding: 06300A
   Subsystem 2 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585150618081238
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584150612144508
   Coding: 820000
   Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST0009097P00000
   Coding: 180000
   Subsystem 5 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Serial number: 1701510224300841AD1B
   Coding: 280000
   Subsystem 6 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587150620190552
   Coding: 800000
   Subsystem 7 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586150619145341
   Coding: 800000
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM0077R/
   Coding: 8CCCF000000000005000001AC20800000065
   Shop #: WSC 55286 001 1048576
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW32.rod
   VCID: 6393AFBD4BDF782FB7B-8036
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH00000000000328SCD
   Coding: 303146
   Subsystem 2 - Part No SW: -----------    HW: 480 000 505 15
   Serial number: 357000000008F255241E
   Subsystem 3 - Part No SW: -----------    HW: 480 000 505 15
   Serial number: 35800000000CB155241E
   Subsystem 4 - Part No SW: -----------    HW: 480 021 305 15
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001C519BDF22B44D
   Subsystem 5 - Part No SW: -----------    HW: 480 021 305 15
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001BB19BDF2553FQ
   Subsystem 6 - Part No SW: -----------    HW: 480 020 605 15
   Component: FrontSensor_D  000 0189
   Serial number: 3550001AD19BDF23730F
   Subsystem 7 - Part No SW: -----------    HW: 480 020 605 15
   Component: FrontSensor_P  000 0189
   Serial number: 3560001AD19BDF21B2BS
   Part No SW: 5C6 920 955     HW: 5C6 920 955
   Component: KOMBI         H04 1007
   Coding: 170A010000
   Shop #: WSC 36656 002 1048576
   VCID: 6C81C481A6013757061-8038
   Part No SW: 7E0 909 901     HW: 7E0 937 189
   Component: GW-K-CAN TP20 H80 0733
   Revision: BA080001
   Coding: 102203
   VCID: 6889B891B2791B77629-803C
   Component: IMMO          H04 1007
   Coding: 000007
   Shop #: WSC 00066 790 00318
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC299ACF5296774D-803E
   Revision: 00000000    Serial number: 15000125678002
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 303910F14AA993B77A9-8064
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F2DD5955352FFCD7-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0058171
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 2809F8917279DB77A29-807C
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H21 0241
   Serial number: VWZAZ2R0260771
   Coding: 02630102AA00000051110003001808001F0100D400200105CE
   Shop #: WSC 62743 001 104857
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 629DAAB954C57127BCD-8036
   Subsystem 1 - Part No SW: 5NA 919 866 N    HW: -----------
   Component: MRM3 2019/20  --- 1115
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140539
   Coding: 02630102C04232007F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 1471BC61DEF14F977E1-8040
End----------(Elapsed Time: 01:31, VBatt start/end: 12.3V/12.3V)-----------
NitrousOxide
Jamaica
C?ID=269481
I feel this is a CECM limitation which simply can't be "coded in". I suspect you would have to do an "old-school" wiring with an additional relay to get this working like any other non-VAG vehicle. I'm in the same boat as you are
MotorEldia
Morocco
C?ID=374242
I mean...the wiring is probably to be done with the steering wheel. Since the acoustic signal (honking) while locking the doors is working, the alarm is working, the panic thingy is working, all without ignition on. So I'm pretty sure it's not about the honk itself.
NitrousOxide
Jamaica
C?ID=269481
I have gone through all 255 adaptation channels and the long coding labels for MY car, and have concluded that it isn't possible for my car.
My suggestion to you is to fire up your trusty soldering iron, and brush upon your good-old-fashioned electrical skills, as I foresee some good old hard-wiring of the horn with an analog relay to fix the issue.
What you are saying above is plausible, but the option isn't listed for that module (whether coding or adaptation channel). Otherwise, you would have to fool the CECM into staying ON all the time (draining your battery).
MotorEldia
Morocco
C?ID=374242
I feel kind of stupid...
