Audi Q7 2011 Sunroof Fault
Sojah
England, UK
C?ID=182247
Hiya got a problem with my friends Q7 the rear sunroof and rear blind works fine, the problem is with the front sunroof, the front blinds open and closes OK, the sunroof it self doesnt raise or lower. It is in the lower position or close position.
When i look at the front sunroof selective output test, its says 127.0 in the first box, If im correct should this number be 100.0?
Friday,13,April,2018,13:33:42:10786
VCDS Version: 18.2.0.3
VIN: WAUZZZ4L7BD027761   License Plate: White-Q7
Mileage: 139220km-86507mi   Repair Order: Front Sunroof Fault
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 47 4F 52 55 56
          57 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L7BD027761   Mileage: 139220km-86507miles
3D-Special Function -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CJGA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L1 910 401 H    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H37 0005
   Revision: 53H37---    Serial number:
   Coding: 2A2A4012A52701020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L1910401H 001010
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 285F222853D9390470-807C
   Part No SW: 0C8 927 750 AE    HW: 0C8 927 750 AE
   Component: AL1000 AISIN  001 1815
   Coding: 001578
   Shop #: WSC 40568 001 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_AU56.rod
   VCID: 6FED0934B6B72E3CF1-803A
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 2200673
   Shop #: WSC 00658 210 91781
   VCID: 3467C65857114DE4CC-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401768188
   Coding: 0000211
   VCID: 25412B1CECCB246C4B-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0060
   Revision: 00---022    Serial number: 00000000266888
   Coding: 01009416
   VCID: 25412B1C2CCB246C4B-8070
01273 - Fresh Air Blower (V2)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 3
                    Mileage: 139221 km
                    Date: 2018.04.13
                    Time: 13:13:29
                    Temperature: 25.0°C
                    (no units): 72.0
                    Load: 127.0 %
02874 - Control Module 2 for Central Convenience (J773)
                    Fault Status: 01101000
                    Reset counter: 3
                    Mileage: 139221 km
                    Date: 2018.04.13
                    Time: 13:13:29
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H29 0390
   Coding: 0033121
   VCID: 6FED09347EB72E3CF1-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D07KN75
   Coding: 0014129
   VCID: 2E53D430B93D6734BA-807A
   Subsystem 1 - Serial number: 6332QSME4C012C50B
   Subsystem 2 - Serial number: 6342QSME4C012962C
   Subsystem 3 - Serial number: 6352QSME750053669
   Subsystem 4 - Serial number: 6362QSME49060E76O
   Subsystem 5 - Serial number: 63734SME6602056E/
   Subsystem 6 - Serial number: 63834SME22030666R
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026110300674
   Coding: 0102142
   VCID: 275D211496C7367C79-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 983 T    HW: 4L0 920 983 T
   Component: KOMBIINSTR.   H10 0209
   Revision: 00000000    Serial number: FLN03E42C
   Coding: 2F56630400012600010400
   VCID: 43859584C2BFFA5C45-8016
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000101
   VCID: 60CF7A08B369814478-8034
   Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0047
   Revision: LB200032    Serial number: 3200L111160008
   Coding: 00CF07
   VCID: 3C77EE78BF4185A404-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790386353
   Serial number: 11028000641021200181
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 H    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7870
   Revision: --H04001    Serial number: 15.1528-0150.2
   Coding: 0015510
   VCID: 2F6DC934BE376E3CB1-807A
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440     HW: 8K0 907 440
   Component: STS             H04 0040
   Revision: S0H04000    Serial number: 00000000033088
   Coding: 01010101000000000000000202
   VCID: 6BD51D244AAFD21CDD-803E
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0004000214782
   Coding: 011F06205061440004
   VCID: 489F82A8FB99D90490-801C
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01429642110000
   Coding: 4071675
   VCID: 3561FB5C5C6B54ECFB-8060
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0160
   Revision: CH003000    Serial number: 00000000023094
   Coding: 030000
   Shop #: WSC 00658 210 99123
   VCID: 2959272C40D3000C6F-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000205177
   Coding: 0011101
   VCID: 5EB344F0891DB7B44A-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0004000207374
   VCID: 479D8194F687D67C99-8012
   Part No: 8P0 907 357 H
   Coding: 0000008
   VCID: 3F8D99746E579EBC21-806A
   Part No SW: 4G0 035 053 D    HW: 4G0 035 053
   Component: Radio U Basic H52 0094
   Revision: AB001007    Serial number: 496B 0B7643416
   Coding: 010003010000000000
   VCID: 1F4D39F40E97FEBC01-804A
Address 57: TV Tuner        Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Shop #: WSC 06335 000 00000
   VCID: 306FCA48630971C4A8-FFFE
No Faults Found
   Part No SW: 4L0 035 666 F    HW: 4L0 035 666 A
   Component: H-BN-EU       H51 0174
   Revision: --------    Serial number: 473BY0B7541186
   Coding: 010101060004D3EF01002315EF6300030000
   VCID: 306FCA48630971C4A8-8064
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466BS0B0441807
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001778584
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0004000213420
   Coding: 010E06204061230004
   VCID: 46838C90F18DCF7462-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000142342930
   Coding: 0100000000000000
   VCID: 3169CF4C680378CCA7-8064
   Revision: --H05---    Serial number: 525PA8-J11414U
   Coding: 1021001
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H56 0500
   Revision: --H56001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD71E384FA1D524D4-8038
   Subsystem 3 - Serial number: RD07.02.11--H56001001A0119ÿ
   Subsystem 4 - Serial number: 1A0119ÿ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 112844401-----
   Coding: 0003587
   VCID: 26432C1091CD2F7442-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
01512 - Control Module for Sliding Roof
                    Fault Status: 01100101
                    Reset counter: 3
                    Mileage: 139221 km
                    Date: 2018.04.13
                    Time: 13:14:40
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0004000213424
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37331102103547
   Coding: 0221066
   VCID: 2C57DE388F21152494-8078
End-------------------------(Elapsed Time: 04:23)--------------------------
Zenerdiode
Newcastle, England
C?ID=24330
Reset counter: 3
Mileage: 139221 km
Date: 2018.04.13
Time: 13:14:40
You need to carry out 'Basic Settings' then. :)
Two ways to do it; try the easy way first:
The control knob for the sunroof; pull to close as if the sunroof was tilted, keep it held in this position, in a few seconds the roof will start to move through its full range, tilting and sliding, no matter how tempting, please keep the control held. When the roof stops moving, wait for another few seconds and then release the control. Try clearing the code and test the sunroof control.
Report back please.
Sojah
England, UK
C?ID=182247
Cheers thank you ZenerDiode, it worked but after 5-10 minutes if it goes back to same. The person happy as it is to hold control and reset.
The cars back tomorrow to have a look at the Fresh Air Blower, thing it needs replacing.
Many Thanks once again.
Zenerdiode
Newcastle, England
C?ID=24330
You’re welcome. :)
The other way is to dismantle the roof panel, physically set the zero position of the motor, physically set the zero position of the sunroof carriage and frame, then perform Basic Settings - either invoked on the switch as above; or with VCDS Basic Settings function. (All detailed in the Workshop Manual - RTFB)
