Q7 4M Rear Reverse Camera
HuntAudi
C?ID=326007
Hi
Looking for help coding the rear reverse camera in a 2018 Q7 4M. Genuine camera fitted and wired in using Kufatec loom but unable to code via vagcom. Any help would be greatly appreciated.
Mark
I'm not confident anyone will have answers for this car, but an Auto-Scan that shows how the vehicle is equipped and configured would the first step toward determining that.
HuntAudi
C?ID=326007
Chassis Type: 4M-AU73 (8W5)
Scan: 01 02 03 06 08 09 15 16 17 19 28 29 2B 36 39 42 44 46 50 52
          5F 6C 6D 81 82 A5 AC BB BC D6 D7
VIN: WAUZZZ4M3JD013198   Mileage: 43km-26miles
50-Seat Adj. 3rd row -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H46 0006
   Revision: 91H46---
   Coding: 2A2A40320326050334080000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114M0907401 001010
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 66954BCF58EA6857E84-8032
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H05 1016
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B23CABB73E805BF67A-806E
Address 03: ABS Brakes (J104)       Labels:. 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Coding: 249830B230A30A99919F589A00855292E6A6D2240C0C50891A004A4967654B
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K.rod
   VCID: 45D7AC43052C434F01E-8010
12615680 - FlexRay Databus Defective
          U0080 00 [040] - -
          [FlexRay_controller_0_channel_A_no_synchronisation]
                    Mileage: 41 km
                    Date: 2018.03.20
                    Time: 14:01:07
   Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
   Component: MEM-BFS       008 0031
   Serial number: 00000271707882
   Coding: 003010000000B0410000010101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736.rod
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0100
   Coding: 6618003D5544451102220280800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678B46CB5FE0715FD32-8032
   Subsystem 1 - Part No SW: 4M2 820 021 A    HW: 4M2 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001808430
   Serial number: 2F01D1C800PAG0MUFU02
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501943E17900CD050D87145BAF80F911033100900000000000000020001A810A450132025601
   Shop #: WSC 11259 211 111111
   VCID: 025D775F5482B47764C-8056
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 170526  044 0893
   Serial number: 90125300401714600122
   Coding: 1BC7F7
   Serial number: 20372504X81A955547A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 17 07 2017  01037304
   Serial number: GX1CE105051723611480
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CB    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00471032
   Subsystem 6 - Part No SW: 4M0 925 301 K    HW: 4M0 925 301 K
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000132724
          U1101 00 [008] - Active
                    Mileage: 41 km
                    average_Voltage_terminals: 14.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 19.00 °C
                    interior_temperature: 21.00 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: OFF
                    Terminal control-Terminal 15 status signal: OFF
                    Terminal control-Terminal 15 via CAN: OFF
                    Terminal control-Term 75: qualification: OFF
   Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
   Component: Airbag10.44   H01 0106
   Serial number: 003UL0019DD4
   Coding: AACCF0D80C80000058F650F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 3D27C4A36DFC0B8F59E-8068
   Subsystem 1 - Part No SW: -----------    HW: 442 062 906 17
   Serial number: 3577Y00B52489D9291FF
   Subsystem 2 - Part No SW: -----------    HW: 442 063 006 17
   Serial number: 3587Y009D2439D11608/
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 807 17
   Serial number: 3517700B726B8786233B
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 807 17
   Serial number: 3527700B726B8785840F
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 707 17
   Serial number: 3557500BD27722745267
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 707 17
   Serial number: 3567500BB277227150C7
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 707 17
   Serial number: 2307500C12757C0132C
   Subsystem 8 - Part No SW: -----------    HW: 442 421 807 17
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00A324FCA30832L
   Subsystem 9 - Part No SW: -----------    HW: 442 421 807 17
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00A324FCA31341I
1066240 - Databus
          [NWD: 0x462 PSD_04 Timeout]
                    Mileage: 43 km
                    Date: 2018.04.12
                    Time: 09:50:55
   Part No SW: 4M0 907 129 HD    HW: 4M0 907 129 HD
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 79AF10B33954F7AF356-802C
   Part No SW: 4M0 920 790 C    HW: 4M0 920 790 C
   Component: FBenRDW       H18 0370
   Coding: 25A400D0288006000123E9601000000000000000
   VCID: 2F3BEEEBB790E91FDB2-807A
   Part No SW: 8W5 907 468 E    HW: 8W5 907 468 E
   Component: Gateway       H42 0118
   Revision: 6A020003    Serial number: 0386A805317817
   Coding: 03010001000086407F07000000590032481A0007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   ROD: EV_CGateCONTIAU491.rod
   VCID: 4BC39A7B2348B53FD7A-801E
   Component: J453 MFL  H06 0002
   Serial number: 20170807174329 01623
   Serial number: 1801724704
131689 - Rear View Camera System Control Module
          U104C 00 [008] - No communication
          [Timeout_Node_0x69_DiagAdress_6C_TopView]
                    Mileage: 43 km
                    Date: 2018.04.12
                    Time: 16:24:12
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0103
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3537DC8355CCD3CF91E-8060
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77AB168B0F40E1DF432-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000181301005
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323DE79FA4A2C4F7B4C-8066
   Component: MEM-FS        008 0031
   Serial number: 00000271708245
   Coding: 002010000000B0410000010101010000110000313100000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736.rod
   Part No SW: 4M0 959 593 H    HW: 4M0 959 593 F
   Component: TSG FS        005 0125
   Serial number: 0000271875439
   Coding: 001F9A005001000000003082
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 41DFB85311046F6F3D6-8014
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000033487
   Coding: 90000001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 3431E1875EB6CAC7A60-8060
   Part No SW: 8W0 907 064 DD    HW: 8W0 907 064 DD
   Component: BCM2 MLBevo   019 0366
   Coding: 01351E002FB100406309A0000600180203020000804306502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU73.rod
   VCID: 015F78535184AF6F7D6-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1719029VL
   Subsystem 2 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223971864670
65569 - Databus
          [Passenger side rear door control module: TSG_HBFS_01: no signal/communication]
                    Mileage: 39 km
                    Date: 2018.02.26
                    Time: 07:16:40
                    Supply voltages-Supply voltage: Terminal 30: 12.011 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.038 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.011 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000273332488
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736.rod
   Part No SW: 4M0 959 592 H    HW: 4M0 959 592 F
   Component: TSG BFS       005 0125
   Serial number: 0000271879622
   Coding: 001F9A005C01000000003080
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   VCID: 40D9BD571A0E6667328-8014
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035 A    HW: 4M1 035 035
   Component: MU-P-LND-EU   034 1117
   Serial number: A641H0HB017037
   Coding: 01370601FF0A000053111101000A00332F001BE701700100DE
   VCID: 231312DBEB585D7F4FA-8076
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9HJ404SQL
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 18081700000000000042
   Compact Disc Database:
   Component: Gracenote2  --- 1016
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung]
                    Reset counter: 0
                    Mileage: 43 km
                    Date: 2018.04.12
                    Time: 16:02:03
                    Voltage terminal 30: 12.9 V
Address 6C: Back-up Cam. (J772)       Labels:* None
   Component: RVC Compact   H12 0250
   Coding: 0000000000000000000000
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 3333E29B5BB8CDFFBFA-8066
10490624 - No End-of-Line Programming
          B2013 00 [009] -  -
          [ECU no DataSet]
                    Reset counter: 111
                    Mileage: 15789 km
13636352 - Control module not coded
          U1013 00 [009] - -
          [ECU not coded]
                    Reset counter: 111
                    Mileage: 15789 km
10489856 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 111
                    Mileage: 15789 km
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31476282800000
   Coding: 0010
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 48C9A577323E5E27FA8-801C
   Part No SW: 4M2 713 041 E    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20170609000675
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 280905F7927EBE271A8-807C
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H29 1640
   Coding: 2A01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
   Part No SW: 4M0 907 217 E    HW: 4M0 907 217 E
   Component: BVS           H16 0050
   Coding: 0407030600000401024023A0A50000B400F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736.rod
   VCID: 3039ED97AAAEF6E7C28-8064
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 4M0 959 595 H    HW: 4M0 959 595 F
   Component: TSG HFS       005 0125
   Serial number: 0000271941076
   Coding: 000F98000001000000003080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 43D3B25B0B187D7F2FA-8016
   Component: TSG HBFS      005 0125
   Serial number: 0000271941073
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16753B0F280A38D7B84-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:07, VBatt start/end: 13.7V/14.1V)-----------
m87a
Bosnia and Herzegovina
C?ID=156900
you can't code this module because it's brand new and it's missing parameters, you need to find someone with VCP to fill parameters, then you will be able to code and to basic settings
DJAlix
London, United Kingdom
C?ID=238277
Seeing the you are in the UK I can parameterise this unit for you if you are around or can get to London. I do 3 to 4 units a week.
HuntAudi
C?ID=326007
Thanks all for the info.
We have filled parameters and managed to get the camera working, but as soon as we took the car out of reverse and back in again, the camera stopped working. Any ideas?
HuntAudi
C?ID=326007
We believe the issue is that the 5F control needs the video input switching on and we cannot find this. Any suggestions?
andyhud
C?ID=32695
What system did you fit? the Overhead 360 system or was it the High-Line or Low-Line Rear camera only?
If its the 360 kit then your last Byte in 09 is wrong. It should not be 01, it should be 0A
Andy
p.s. did you apply the parameter ZDC set from VCP?
Astrofit
C?ID=107629
Q7 Camera
Hi
Mark
Did you solve this problem
We have the same issue, did one last year and parameterised/coded it with no probs
Ours now works when you first engage reverse but doesnt work the second time however works the 3rd,4th,5th etc
cheers
Ben
HuntAudi
C?ID=326007
In the end we had to take it to sat nav systems to get coded. Not sure what they did but it works.
Astrofit
C?ID=107629
Cheers it’s something simple but we can’t find it
andyhud
C?ID=32695
Can you just ask them what they did?
Also, do you have a fresh AutoScan you can share with us after you got it working?
