2010 MK5 **TSI** Jetta Wolfsburg - P2279 & P0507
JerseyNoob
NJ, USA
C?ID=314110
Well, ugh.
So, I've been getting the P2279, and then the P0507 code. First got it last week while sitting at a traffic light. Thought nothing of it, and cleared them. Got them again yesterday, while at a traffic light. Cleared, and got it again this morning while at a traffic light. Car runs smooth and no bobbles at idle. RPM gauge reflects 750 to 800 rpm
2 1/2 weeks ago I got my intake manifold, fuel pump, and radiator replaced, which is about 1100 miles ago.
Week and a half ago I got my first code for a misfire in C3. Pulled and looked at plug, looked good, and swapped it with C2. Nothing more about misfires, so I don't know if this helps regarding this current issue.
Boost gauge registers -20.0 while at idle. Playing with dipstick while engine is running results in engine wanted to stall. Got a can of dechlorinated brake cleaner and sprayed around the various hoses and connections, no change in how the engine ran.
Noticed the hose that runs from the N80 to the charcoal canister had the clap not in place where said hose connects to the N80.
I noticed at lunch today that the hose that runs from the PVC to my intake manifold has wiggle room where it meets with the PVC. This it????
Not sure what else I could check.
Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: Release 18.2.0 Data version: 20180212 DS287.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,11,April,2018,14:53:36:57500
VIN: 3VWRA7AJ0AM072848 License Plate: ZLC94L
Mileage: 259380km-161171mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRA7AJ0AM072848 Mileage: 259380km-161171miles
Self-Diagnosis Log
Page 2
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AD
Component: 2.0l R4/4V TFSI 0030
Revision: E3H12--- Serial number:
Coding: 0403010818070160
Shop #: WSC 00066 000 00000
VCID: 70BAD848F6AD1A47828-8024
001287 - Idle Control System RPM
P0507 - 000 - Higher than Expected. - Intermittent
Mileage: 259377 km
Date: 2012.08.31
Time: 21:47:20
RPM: 936 /min
Load: 12.9 %
Temperature: 95.0°C
Temperature: 40.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
008825 - Leak in Air Intake System
P2279 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 259355 km
Date: 2012.08.31
Time: 12:04:39
RPM: 759 /min
Load: 12.9 %
Temperature: 70.0°C
Temperature: 19.0°C
Voltage: 13.970 V
Readiness: 0000 0001
Self-Diagnosis Log
Page 3
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492900FC881306E892210041300000
VCID: 78AAE06892DD42074A8-802C
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00185
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B4E95C854F3F6F51E-8020
Part No SW: 5K0 937 085 C HW: 5K0 937 085 C
Component: BCM PQ35 B++ 008 3019
Revision: BI008001
Coding: 65200B3F902F3EE480000005400000040740008643008D625C8020000000
Shop #: WSC 00066 123 12345
VCID: 33301744CB3B615FBFA-8066
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 19110 21 0512
Coding: 009795
Self-Diagnosis Log
Page 4
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM01RXYCoding:
0012340
VCID: 6E86C630EC990CB7904-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME4C2241455
Subsystem 3 - Serial number: 6342MSME4A41163BC
Subsystem 4 - Serial number: 6351HSME1D7156134
Subsystem 5 - Serial number: 6361HSME1D714B17D
Subsystem 6 - Serial number: 63727SME1E195C518
Subsystem 7 - Serial number: 63827SME1E1965333
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0000031
VCID: 025E8280C80118D764C-8056
Part No SW: 1K8 920 961 F HW: 1K8 920 961 F
Component: KOMBI H05 0308
Coding: 270700
Shop #: WSC 00066 000 00147
VCID: 3534295CC5CF7F6F91E-8060
Self-Diagnosis Log
Wednesday,11,April,2018,14:53:37:57500
Page 5
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 141009F2000484
Coding: E9807F07000602001002
VCID: 698CB52CD577EB8FC56-803C
01304 - Radio
Reset counter: 133
Mileage: 257836 km
Date: 2012.08.10
Time: 05:33:35
Component: IMMO H05 0308
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECA20DCF1E097CCC-803E
Self-Diagnosis Log
Page 6
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000083941
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 2708F3140F631DFF132-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004458159
Coding: 000490
66304 - Switch for Drivers Side Window Regulator
B11F0 29 [008] - Signal Implausible
Reset counter: 189
Mileage: 258446 km
Date: 2018.03.30
Time: 22:03:05
66818 - Switch for Mirror Adjustment
B11F3 29 [008] - Signal Implausible
Reset counter: 204
Mileage: 258446 km
Date: 2018.03.30
Time: 22:03:05
66562 - Heated Exterior Mirror
B11F8 14 [009] - Open or Short to Ground
Reset counter: 134
Mileage: 257837 km
Date: 2018.03.23
Time: 07:04:04
Self-Diagnosis Log
Page 7
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F381B342B1345BFDB2-807A
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000095012
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 280AF028027D12871A8-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004414676
Coding: 000490
Reset counter: 134
Mileage: 257837 km
Date: 2018.03.23
Time: 07:04:03
Address 56: Radio
Self-Diagnosis Log
Page 8
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 008 0817
Coding: 018705
Self-Diagnosis Log
Page 9
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520265820
Coding: 412100
VCID: 290CF52C19F72B8F056-807C
03426 - Left Audio Channel
Reset counter: 133
Mileage: 257836 km
Date: 2012.08.10
Time: 05:34:41
03427 - Right Audio Channel
Reset counter: 133
Mileage: 257836 km
Date: 2012.08.10
Time: 05:34:41
01304 - Radio
Reset counter: 133
Mileage: 257836 km
Date: 2012.08.10
Time: 05:34:42
End----------(Elapsed Time: 01:07, VBatt start/end: 12.3V/12.2V)-----------
Admin note: Please don't use the PRINT function in VCDS to post scans here; the results are less than optimal, i.e. much harder to read than if you just copy & paste the original text.
PS: The two faults you have are pretty clear-cut. There's an intake leak somewhere.
JerseyNoob
NJ, USA
C?ID=314110
Does it mean anything that the P2279 code pop up before the P0507?
I don't think so. A leak in the intake can cause the idle rpm to increase, so I expect both codes have the same root source -- an intake leak somewhere.
JerseyNoob
NJ, USA
C?ID=314110
Only time I have high idle, is when starting the car on a cold engine, and the SAI system has rpms around 1200, then drops to 750/800rpms when SAI turns off.
Other than that, no idle changes. Just weird
I think the "Higher than Expected" may not necessarily mean be in terms of absolute RPM. I could see the ECU setting this code if it has to close the throttle more than it thinks it should have to, even if doing so is able to maintain the RPM in the range it wants.
NostraJackAss
VIN: 3VWRA7AJ0AM072848 Mileage: 259380km-161171miles <<<<<<<<<<<< Outside warranty range!
Wow that's a lot of parts....... :rolleyes:
I wonder if you car is FOD tuned and or modified?
Please reset all the fault memories of all controllers with a broadcast and post a fresh auto-scan before even starting the cars engine.
Interesting how these readiness monitors all but CAT pended?
It would seem to me that a flash update failed to be provided out of the crack of VW's Ass here for TSB 24AX or something similar?
1K0-907-115AL, AD, AF & AK are the base extract hardware for this CBFA MED17.1 right?
"AL" the controller you have has some "special upgrade measures" in PR code GP1 in extension
I would imagine you still have an air leak, please see this thread.
http://forums.ross-tech.com/showthr...gases-and-vacuum-amp-so-should-you!-Air-leaks!
You are going to want to check the EVAP N80 with a mighty vacuum tester for mechanically stuck open
JPPSG......
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
I would be curious if the later CBFA engine controllers, also being MED17.1 with the flash update for 24AX TSB would extinguish this issue?
Want to try an experimental ECU with a plug and play test unit and no VIN ID?
All you have to do is return unit in 10 days and pay freight both ways.
JerseyNoob
NJ, USA
C?ID=314110
K04 Turbo/tune for the past 90k miles.
Crap, didn't print out the whole thing properly.....
Section C is interesting. I got a misfire in C3 a few days before these codes came up, I wonder if they're related.......and I did read elsewhere as well that taking the oil cap off with engine running isn't a sure fire test. I wonder if there is damage to the diaphragm in my PVC.
Going back to the shop that did all the resent work for a few tests, and hopefully find out what the deal is.
This sounds tempting, but I don't have the tools nor another set of wheels to use while experimenting.
NostraJackAss
Oh FARTS FOD!
Double Farts!
Yeah it's not very scientific now is it?
Retracing your steps and returning the car to verified stock is a good start in the JPPSG process.
Start by un-pimping this thing........Take to STAGE NONE!
WHY!!!!!!!!!? :banghead:
