Passat B5 ABS Coding Issue?
Robbo1992
Pirate
Morning All,
I know this issue has been covered plenty of times before but im getting no where with my own problem not been able to corrrectly code my ABS moduele.
I recently had to crack a full Dash out job to replace the V71 motor, all went back together ok including the Steering Angle Sensor, after completion i had the ESP, ABS and flashing Red brake warning lamp on my instrument cluster, so i followed the Guide on Ross Techs main website to recalibrate and recide the ABS module, as you've guessed at this point no luck!!
My main problem been that after i enter my login and coding details, a warning appears in the top right corner saying 'login lost due to dropped session' which iv been led to believe means iv entered the wrong login details. I have given my login and recode details below as well as my PR codes and a full scan if anyone would be kind enough to double check me.
Iv tried this procedure several times now but i do not get the faulty Steering Angle Sensor pop up each time, only every other time?
Iv triple check the wiring in and around the sensor and brake/clutch pedals, removed and replaced the sensor but still no luck in been able to recode and recalibrate the module. Would the faulty Sensor not allow recoding?
Below are my details;
Login - 09575
Coding - 04275
[/URL][/IMG]
And the Full scan.
[b]Removed.  Data from a clone/pirate copy of VCDS is not welcome here.[/b]
Any help on this issue would be massively appreciated.....its got me scratching my head now!!
Thanks in advance
South Molton, UK
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Why are you running a 3 year old version of VCDS?
Worth downloading the latest version and posting a new Auto-Scan using that - it might give more clues what the problem is.
Robbo1992
Pirate
Because everytime i try to update the software i run into a maze of problems trying to set it up!
South Molton, UK
If you update from a older version of VCDS there is no complicated setup, just run the installer and the new version is good to go.
Robbo1992
Pirate
Might be worth mentioning too, i am getting a reading from the G85 sensor in the Measuring blocks, it starts at 720° and reads a change whenever i move the wheel.
So this must mean my sensor is ok?
South Molton, UK
I was 99.9% certain he was using a rip-off clone once he baulked against running the latest version of VCDS.
When I saw the Photobucket fail before the scan, I thought he might just be someone who's behind the times. But then I double-checked...
As a side note, it's funny how these guys come in spurts. We had ~3 weeks without one, and now we have three in as many days.
andyhud
C?ID=32695
Sorry for the dumb question, never really looked in this forum group specifically, but how do you/we spot they are using a clone/pirate copy of VCDS? (By the way, I've got genuine stuff so this isn't mean trying to do any funny business, just curious)
Ta
There are many things that provide clues, but exactly how we make a final determination is considered a "trade secret". ;)
iichel
Eindhoven, NB, NL
C?ID=284912
Usually an ancient version like 12.12 or 15.7.1 is a good give away. Those used to be very popular on Aliexpress and eBay.
I'm sure Ross Tech have more tricks and they shouldn't give them away easily, this would just make producing clones and hacked software easier.
NostraJackAss
No tricks just the facts.......It's "ABOVE MAGIC!"
andyhud
C?ID=32695
Fair enough, I'll leave it in your capable decision making hands!
Cheers
Andy
