KEY-COM Dual-K VAG-COM Dongle Interface KC110135 Rev.B problems
ToddK
C?ID=31006
To Whom It May Concern,
I have been trying to get my KEY-COM Dual-K VAG-COM Dongle Interface KC110135 Rev.B scanner to work with my 2001 Jetta VR6, but it doesn't seem to want to cooperate. I am using a Ross-Tech SEC25 Serial Extension Cable - 25'(7.5m) to use with a Windows 7 Ultimate 64-bit computer with a serial connection. I made sure I detected and had the correct COM port for the serial connection in the Options / Port and Protocol Options and tried multiple auto scans with 9M - VW Jetta IV (1998 > 2014), but it doesn't seem to find any addresses. I also noticed the scanner tool would blink red and then go back to solid green. My device is found, but it can't seem to communicate with my vehicle. I am using the latest version of the VCDS 64-bit software 12.12.2 x64. I believe I can change the COM port to 1 on the serial port, but I didn't think it mattered as long as the correct port was chosen before scanning. There don't appear to be any IRQ conflicts with the serial port. I did not turn off the COM ports FIFO buffers, but I didn't have significant amount of time to troubleshoot because the PC was outside and it was getting ready to rain on me. Any help would be appreciated.
ToddK
Santos
What happens when you go into VCDS and hit options/test?
What is status of both K-Lines?
You're using a desktop PC? With a real serial port? Any chance the PC is over-clocked? We've seen some cases where an over-clocked desktop won't work with serial interfaces because the serial port has the same timing/clock source as the CPU, and when you change that frequency, it shifts the serial port's baud rate by the same amount.
What exactly do you get when you click [Options] -> [Test]?
ToddK
C?ID=31006
Uwe,
Yes it is an Asrock 4coredual-sata2 r2.0 and it is overclocked about 20%. I am running an intel E5700 3.0Ghz at 3.6Ghz.
ToddK
C?ID=31006
Santos,
I am not at home to test it, but from memory, they were both okay.
Todd, how easy is it for you to get it back to normal clock speed? Is it something in the BIOS, or do you have to do something with actual hardware?
ToddK
C?ID=31006
Overclock
Uwe,
Yes, I can just go into the BIOS and change the FSB to 200 from 240. I'll do that when I get home tonight and update this post with my findings. Thanks Uwe and Santos :)
It would be cool if you'd post the exact results you get when you do [Options] -> [Test] both overclocked and at rated speed.
ToddK
C?ID=31006
Will do. I can't do screen captures and paste them into the body can I?
Santos
not within the forum. You can paste directly into Imgur.com (image host) then post here.
Why use a screen-shot when all information is text? When the MessageBox with the results of [Options] -> [Test] appears (and is waiting for you to click [OK], do CTRL + C on your keyboard. That will put the text from the Messagebox into your Windows clipboard and you can certainly paste that in here, like this:
VCDS: Port Test
Port Status: OK
Interface: Found!
Type: HEX-NET
Version: 0.4010.4
Status: Firmware Update Required!
Please open VCDS-Mobile for a firmware update.
OK
ToddK
C?ID=31006
Thanks Santos, I noticed there was no other way to upload an image or video except from a URL. I just signed up at Imgur.com.
ToddK
C?ID=31006
Good point Uwe. I'll do it.:)
ToddK
C?ID=31006
Uwe,
Where is that text file stored? It does not appear to be in the Ross-Tech directory. I will just hand type it.
Overclocked:
Port Status:Ok; Interface Found!; Type: Ross-Tech KEY-COM; Version: 3.01; Status: Ready; K1: OK; K2: OK; CAN: Not Supported
It appears to be scanning now, even while it is overclocked.
Tuesday,11,March,2014,18:38:08:12311
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Mileage: 357260km-221991mi   Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
   Mileage: 357260km/221991miles
Address 01: Engine        Labels: 021-906-018-AFP.lbl
   Part No: 021 906 018 R
   Component:  MOTRONIC ME7.1 G   0004
   Coding: 00031
   Shop #: WSC 00066
   VCID: 1D2CF4409781D9F6901-515A
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
            P0030 - 35-00 - Malfunction / Open Circuit
16518 - Oxygen (Lambda) Sensor B1 S1
            P0134 - 35-00 - No Activity
Readiness: 0100 1001
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   Shop #: WSC 01317 785 00200
   VCID: 2B482A98893527461E5-515A
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 00066
   VCID: 2154C8B0ABF9FD16B49-515A
            37-10 - Faulty - Intermittent
   Part No: 6Q0 909 605 F
   Component: 04 AIRBAG VW6  0202 0004
   Coding: 12340
   Shop #: WSC 00066
   VCID: 3A661FDC266F8ECE953-515A
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 00066
   VCID: 30723DF4F013449E2B7-5248
   Part No: 1J0 920 925 D
   Component: A4-KOMBIINSTR. VDO V53
   Coding: 07232
   Shop #: WSC 00066
   VCID: 2A462F9CD6CF3E4EE53-515A
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0A3437751
   IMMO-IDENTNR: VWZ7Z0A3437751
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: F0F27DF4B093849EEB7-515A
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 A
   Component: Sitzverstellung FS 0003
   VCID: 2B482A98D93527461E5-515A
   Part No: 1J0 959 799 AJ
   Component: 6C Zentral-SG Komf. 0001
   Coding: 04098
   Shop #: WSC 00066
   VCID: 861E3B2CA217BA2E21B-4B64
   Subsystem 1 - Part No: 1J1959801C
   Component: 6C Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 6C Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 6C Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 6C Tõrsteuerger. HR0002r
            62-10 - No or Incorrect Adjustment - Intermittent
It appears to have worked. Thanks Uwe!!!!!!!!!
There is no file; my previous instructions regarding the text from a MessageBox just put the text in the Windows clipboard; from there you can paste it wherever you want.
So what did you do differently this time?
ToddK
C?ID=31006
Nothing, maybe I didn't screw the serial connection in far enough. Thanks again for your help ;)
ToddK
C?ID=31006
Uwe,
Actually, after I thought about it last night and this morning, I did turn off my aftermarket radio before doing my scan. Do you think this would have made the difference? I did see issues with aftermarket radios on the FAQ on the website.
Well, if something from your radio is connected to the K-Line that went to the factory radio, then that's certainly possible.
I spoke to Todd via email and suggested the same with the Radio. Keep us posted if this happens after removing the K-line from the aftermarket radio connector.
-Dana
Ref to E?ID=195635
