Parking aid ECU coding
Dave
C?ID=105353
Hello, I have a Mk7 Golf in for parking sensors not working. The optical parking sensor has been retrofitted to the car at some point in the cars history but have no information on this. I have found that buzzer section of the ECU has burn't out. I have replaced the ECU with a brand new item from VW with all matching part numbers. However no matter what code I am trying none will be accepted and just get error 31. I am logging into ECU each time using password. The old code from the ECU was 0031051011 but will not be accepted. Any ideas?
Friday,06,April,2018,15:33:00:58506
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZAUZEW329492   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 53 5F
VIN: WVWZZZAUZEW329492   Mileage: 47827km-29718miles
53-Parking Brake -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5518
   Revision: 84H22---
   Coding: 01250012036505092000
   ASAM Dataset: EV_ECM16TDI01104L906021N 002009
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 306401976BC7D9C4A8-8064
   Part No SW: 0CW 300 047 R    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501402136842
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 4A90737FED5B831486-801E
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6047400000021F
   Coding: 01FA8AA114220975037B060941C52580512890C06082A4F3F842F078C202
   VCID: 7CFCE5A7F70FEDA444-8028
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 1001
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 003127
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 356A308394A5FCECFB-8060
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011405603570
   Coding: 03001842C24102730BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 79F2FCB3F83DD88C5F-802C
   Component: WWS    140218  042 0551
   Serial number:         140221071141
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M02D28H01M42S29S6
   Coding: 00A8DD
   Serial number: 000000000ZY140344HZG
   Serial number: 00000000000058920761
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231304003174
   Coding: 0000000000
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 3A7023BFBDBB139416-806E
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 161
                    Mileage: 47827 km
                    Date: 2018.04.06
                    Time: 09:00:02
10487040 - invalid data record
          B2005 00 [009] -  -
                    Reset counter: 161
                    Mileage: 47827 km
                    Date: 2018.04.06
                    Time: 09:00:02
12715776 - Databus
                    Reset counter: 161
                    Mileage: 47827 km
                    Date: 2018.04.06
                    Time: 09:00:03
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 13021477030323
   Coding: 001C1300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3668378F89A3F7F4F2-8062
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR03YW2F
   VCID: 7F0612ABE619F6BC61-802A
   Belt Pretensioner left:
   Serial number: 34169677B26021440954
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B28021470672
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 702 14
   Serial number: 3576700000022CF00F0V
   Subsystem 4 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 358670000002C6200F0N
   Subsystem 5 - Part No SW: -----------    HW: 480 402 102 14
   Serial number: 3516502A9142B1C40370
   Subsystem 6 - Part No SW: -----------    HW: 480 402 102 14
   Serial number: 35265029F142B1C493CK
   Subsystem 7 - Part No SW: -----------    HW: 480 402 502 14
   Serial number: 3556502C3142B1C2F148
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 19021404401064
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 7BFEE6BBF201EA9C4D-802E
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         204 3400
   Coding: 27A41A082780260001882A01040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 2854E9F75317910470-807C
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001679250
   Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010_VW37.rod
   VCID: 3F8652ABA69936BC21-806A
   Component: E221__MFL-DC1  H15 0038
   Serial number: 29140000264660104085
   Coding: 2CFFFF
   Serial number: 2909442703
131666 - No Communications with Undefined Control Module
          U1126 00 [009] - -
                    Reset counter: 161
                    Mileage: 47827 km
                    Date: 2018.04.05
                    Time: 09:31:35
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 21021406071897
   Coding: 003002208001048000001000
   VCID: 3E782FAFA1933FB42A-806A
   Serial number: 00000000000001965194
   Coding: 1D0000
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41825453D06D404C57-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 14021402090429
   Coding: 003000208001048000801000
   VCID: 3D7A28A3AC9524AC33-8068
   Serial number: 00000000000001944219
   Coding: 050000
Address 53: Parking Brake
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C02702140267
   Coding: 02730000FF00000021111201002800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F46F22B065956BC01-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ703R1Q
End-------------------------(Elapsed Time: 04:53)--------------------------
Jef
HQ
Dave
C?ID=105353
Hello, I have also tried coding this ECU using ODIS but just get an invalid message back from VW due to vehicle not originally having parking sensors I believe. Not sure about the parking brake error, I cannot get into ECU but all is working correctly. I will have to check if ODIS can get in.
Jef
HQ
The ABS module handles the parking brake functions. This is why I wonder about the car is looking for address 53.
Dave
C?ID=105353
Not sure about that one, do you think it could cause my coding issue? I would find it odd if it did.
Jef
HQ
[Select]
[19-CAN Gateway]
[Installation List]
http://www.ross-tech.com/vcds/tour/installation-list.php
Scroll down the list and uncheck address 53.
[Save Coding]
Clear out fault codes and see if that helps... I doubt it, but may as well clean up some loose ends just to rule it out.
downtime
Finland
C?ID=280813
This is one of the problems and I remember correctly, it will prevent coding until there's correct configuration in the unit :
          B2005 00 [009] -  -
                    Reset counter: 161
                    Mileage: 47827 km
                    Date: 2018.04.06
                    Time: 09:00:02
For this unfortunately VCDS is no go and ODIS most likely neither as the car did not have parking assist from factory so configuration data upload won't go through with that. You need to find someone with VCP system.
