2010 Audi Q7 ACC Not working, 01044
jmjq7tdi
Lidingö, Sweden
C?ID=205446
All,
My ACC - and a few other electrical things related to keyless entry - are not working. I purchased this Q7 on 31 Jan 2018 at 109,xxx km and have not yet cleared the codes from the computer. I've had my VCDS for years for my old Q7, and have just finally scanned the codes on my 'newer' Q7 for the first time today, 5 April 2018. I will clear the codes, drive it around, and rescan it, but before doing that I wanted everyone's take on error code 01044 - Control Module Incorrectly Coded. I think this is what's preventing my adaptive cruise control from working, and I'd really like to have that available.
Thanks in advance!
Thursday,05,April,2018,15:12:03:49964
VCDS -- Windows Based VAG VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4L3AD0.....   License Plate:
Mileage: 115790km-71948mi   Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3C 42 46 47
          4F 52 55 56 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L3AD0.....   Mileage: 115790km-71948miles
05-Acc-Start Auth. -- Status: Malfunction 0010
69-Trailer -- Status: Not registered 0001
Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
   Component: 3.0TDI EDC17A100AG  0080
   Revision: --H02---    Serial number:
   Coding: 0121002C191F0268
   Shop #: WSC 40970 222 94360
   VCID: 2447ED83E718D3645C-8070
005663 - Glowplug for Cylinder 6 (Q15)
               P161F - 000 - Open Circuit
                    Mileage: 102235 km
                    Date: 2017.05.23
                    Time: 08:56:40
                    RPM: 966 per min
                    Speed: 5.6 kmph
                    Voltage: 11.55 V
                    Temperature: 18.0°C
                    Lambda: 22.7 %
                    Temperature: 14.4°C
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 KC    HW: 09D 927 750 KC
   Component: AL 750 6A           1470
   Revision: 00H78000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 79F9ECF7301A7E8C5F-802C
   Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
   Revision: 00H30001
   Coding: 0627857
   VCID: 326B1BDBADEC4DD4DE-8066
Address 05: Acc-Start Auth.        Labels:. 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601405096
   Coding: 0000135
   VCID: 2541F087EC222A6C4B-8070
   Subsystem 1 - Part No: 4F0 910 132 G
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Subsystem 3 - Part No: 4F0 910 220 K
   Component: FBSAUDIC6 IDG   H01 0040
00190 - Driver's Door Handle Touch Sensor (G415)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 131
                    Mileage: 97620 km
                    Date: 2017.01.19
                    Time: 14:00:17
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Reset counter: 131
                    Mileage: 97620 km
                    Date: 2017.01.19
                    Time: 14:00:17
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 131
                    Mileage: 97620 km
                    Date: 2017.01.19
                    Time: 14:00:17
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 01111011
                    Reset counter: 131
                    Mileage: 97620 km
                    Date: 2017.01.19
                    Time: 14:00:17
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000000212367
   Coding: 040816
   VCID: 2447ED832718D3645C-8070
   Part No SW: 4F0 910 279 R    HW: 4F0 907 279
   Component: ILM Fahrer      H25 0330
   Coding: 0033221
   VCID: 387F29F34B90A784E0-806C
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Fault Status: 00100111
                    Fault Frequency: 20
                    Reset counter: 32
                    Mileage: 113044 km
                    Date: 2018.03.10
                    Time: 17:52:00
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4L0 910 561 A    HW: 4L0 907 561
   Component: ABSTANDSREGELUNGH06 0160
   Revision: --------    Serial number: 00000000000000
   Coding: 0031168
   VCID: 275DFA8F962E387C79-8072
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 247
                    Mileage: 97620 km
                    Date: 2017.01.18
                    Time: 12:40:48
                    Temperature: 16.0°C
                    Voltage: 13.82 V
                    Bin. Bits:    01000
                    Hex Value: 0x0444
                    Hex Value: 0x0006
                    Speed: -3.6 kmph
                    Lateral Accel.: 0.00 mps^2
            000 -  -
                    Reset counter: 131
                    Mileage: 97620 km
                    Date: 2017.01.18
                    Time: 12:40:48
                    Temperature: 16.0°C
                    Voltage: 13.82 V
                    Bin. Bits:    01000
                    Hex Value: 0x0411
                    Hex Value: 0x0006
                    Speed: -3.6 kmph
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D065B3G
   Coding: 0014128
   VCID: 2E530FABB9D46934BA-807A
   Subsystem 1 - Serial number: 6332QSME623A191AH
   Subsystem 2 - Serial number: 6342QSME703A32067
   Subsystem 3 - Serial number: 6352QSME4338322CE
   Subsystem 4 - Serial number: 6362QSME623A143AH
   Subsystem 5 - Serial number: 63734SME3136050EX
   Subsystem 6 - Serial number: 63834SME2F364400-
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092380094
   Coding: 0002052
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 931 J    HW: 4L0 920 931 J
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CNN432799
   Coding: 0F5663040C010008000000
   VCID: 326B1BDB6DEC4DD4DE-8066
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 265 105 M
   Component: Heizgeraet      H08 0120
   Revision: 0000000E    Serial number: 00000009014264
   Coding: 0000101
   VCID: 60CFA193B3808F4478-8034
00664 - Fuel gauge
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M098308025
   Coding: 000303
   VCID: 3A7B33FBB59CB59416-806E
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140159397
                    Reset counter: 247
                    Mileage: 97620 km
                    Date: 2017.01.18
                    Time: 12:40:52
                    Bin. Bits:    10111
                    Voltage: 13.80 V
                    Count: 7
                    Bin. Bits:    10011
            000 -  -
                    Reset counter: 131
                    Mileage: 97620 km
                    Date: 2017.01.18
                    Time: 12:40:55
                    Bin. Bits:    10111
                    Voltage: 13.80 V
                    Count: 7
   Part No SW: 4F0 857 511 J    HW: 4F0 857 511 G
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02019064747464545425363E
   VCID: 2F6D12AF7EDE603CB1-807A
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000352325
   Coding: 0000006
   VCID: 68DFB9B35BB0F704B0-803C
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 101994 km
                    Date: 2017.05.13
                    Time: 12:12:25
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 H    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7870
   Revision: --H03001    Serial number: 15.1528-0123.2
   Coding: 0015510
   VCID: 2F6D12AFBEDE603CB1-807A
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001346979
   Coding: 00581B00000011110000
   VCID: 316914D768EA76CCA7-8064
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0000101
   Component: J0770_SWA_Slave_H01 0040
   Subsystem 3 - Serial number: 5F21.07.0900H010003C910745ÿ
   Subsystem 4 - Serial number: 910745ÿ
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000101820752
   Coding: 011F52205E40440004
   VCID: 4683570BF164C17462-8012
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H09 0100
   Revision: 0100 ---    Serial number: 01219373360000
   Coding: 3547377
   VCID: 356120C75C825AECFB-8060
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
   Component: BOSE G3 AU716 H01 0100
   Revision: AH001500    Serial number: 00000000008395
   Coding: 0D000000
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000139275
   Coding: 0011101
   VCID: 5EB39F6B89F4B9B44A-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000101847220
   VCID: 45815007CC62CA6C6B-8010
                    Fault Status: 01101000
                    Reset counter: 33
                    Mileage: 97620 km
                    Date: 2017.01.18
                    Time: 12:40:48
   Part No SW: 4L0 910 357 A    HW: 4L0 907 357 A
   Component: AFS 1           H01 0030
   Coding: 0000032
   VCID: 2A5B03BB853C051466-807E
01310 - Level Control System Control Module (J197)
                    Fault Status: 00101101
                    Reset counter: 6
                    Mileage: 104226 km
                    Date: 2017.08.12
                    Time: 12:30:58
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H45 0020
   Revision: AB001007    Serial number: 341IZ097634851
   Coding: 010003010000000000
   VCID: 1C37D5631F68EBA4E4-8048
   Part No SW: 4L0 035 670     HW: 4L0 035 670
   Component: H-BNT-EU      H41 0047
   Revision: --------    Serial number: 474I6097515869
   Coding: 010100060004DBEF71000315EF6300030000
   VCID: 65C1B0876CA2EA6C8B-8030
   Subsystem 1 - Part No: 8R0 060 884 E
   Component: EUR 2009-2010  5805
   Component: DU7 High  H43 0306
   Serial number: 9356IZ091064728
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001400099
   Component:   CD-Database  1293
            000 -  -
                    Reset counter: 180
                    Mileage: 106799 km
                    Date: 2017.10.25
                    Time: 13:21:40
                    Bin. Bits: 10001000 00000000
                    Bin. Bits: 00000100 00001110
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000101862201
   Coding: 010E50204040230004
   VCID: 43854E1FC256F45C45-8016
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00008200327685
   Coding: 0100000000000000
   Shop #: WSC 80093 222 69422
   Revision: --H03---    Serial number: 525PA8-J9940CA
   Coding: 1021001
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 D
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: 8K9827852  B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7C5A34F48DB24D4-8038
   Subsystem 3 - Serial number: RD16.09.09--H29001001A0322ÿ
   Subsystem 4 - Serial number: 1A0322ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003881240-----
   Coding: 0003587
   VCID: 2643F78B9124217442-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
   Revision:             Serial number: 0000101862200
                    Reset counter: 32
                    Mileage: 115754 km
                    Date: 2018.04.04
                    Time: 14:27:13
                    Reset counter: 16
                    Mileage: 115386 km
                    Date: 2018.03.29
                    Time: 16:43:32
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H02 0100
   Revision: 00H02000    Serial number: 85130925303084
   Coding: 0221166
   VCID: 2C5705A38FC81B2494-8078
End-------------------------(Elapsed Time: 03:43)--------------------------
I think the Incorrectly Coded DTCs are due to the Unregistered Trailer module. I would fix that first, then clear fault codes.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Thanks. I've been following the instructions located at http://wiki.ross-tech.com/wiki/index.php/Trailer_Hitch_Retrofitting_(4L), but they're not comprehensive enough for me to resolve this. One thing I realized is that this Q7 has an aftermarket trailer hitch system (Westfalia european system), so it looks like the installation was just not coded at all.
Here's what I did:
Updated the Installation List in the Gateway (J533 / #19) to include option 69
Updated the Engine Control Module (J623 / #01) Coding
Update the Brake Electronics (J104 / #03) Configuration
Here's what I wasn't able to do:
Everything else on that list. For module 69, I don't know if I have a diagnostic-capable unit, and there is not information in the coding assistant to guide me. For the rest, either there was no long coding assistant available, or in the case of two options that did have helpful information in a popup window, the coding options are only:
0=Not Installed
+1=Trailer Hitch Installed
+2=Optional Parking System Installed
On these two options, the number 2 was coded. Should this be coded as a 3 with the trailer hitch installed?
Here's the updated scan:
Thursday,05,April,2018,18:44:18:49964
          4F 52 55 56 5F 62 67 69 6C 6D 6F 72 76
   Coding: 0121002C191F0A68
   Coding: 0000504
   Revision: 00H30001
   Coding: 0627841
   Coding: 0000135
   Component: FBSAUDIC6 IDG   H01 0053
   Coding: 040816
   Coding: 0033221
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0031168
                    Reset counter: 247
                    Mileage: 115791 km
                    Date: 2018.04.05
                    Time: 18:40:50
                    Temperature: 36.0°C
                    Voltage: 11.39 V
                    Bin. Bits:    01000
                    Hex Value: 0x0444
                    Hex Value: 0x0006
                    Speed: -3.6 km/h
                    Lateral Accel.: 0.00 m/s^2
            000 -  -
                    Reset counter: 247
                    Mileage: 115791 km
                    Date: 2018.04.05
                    Time: 18:40:50
                    Temperature: 36.0°C
                    Voltage: 11.39 V
                    Bin. Bits:    01000
                    Hex Value: 0x0411
                    Hex Value: 0x0006
                    Speed: -3.6 km/h
   Coding: 0014128
   Coding: 0002052
   Coding: 0000101
   Coding: 000303
   Revision: AA001002
   Coding: 0000006
   Coding: 0015510
   Coding: 0000101
   Coding: 3547377
   Coding: 0D000000
   Coding: 0011101
                    Reset counter: 247
                    Mileage: 115791 km
                    Date: 2018.04.05
                    Time: 18:42:27
   Coding: 0000032
   Component: EUR 2009/2010  5805
Address 67: Voice Control
   Coding: 1021001
   Coding: 0003587
   Coding: 0221166
End-------------------------(Elapsed Time: 04:26)--------------------------
NEtech
Denmark
C?ID=56995
This should be other codings for Trailer.
[13] 0031161
[34] 0015520
[3C] 0010101
[69] 0200000000000000
[6C] 1031001
[76] 0231166
For [6C Back-up Cam.] I have seen one case, where an DTC: Calibration needed, came after the coding !
Could have been an coincidence.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
[13] 0031161
[34] 0015520
[3C] 0010101
[6C] 1031001
[76] 0231166
Wow, thank you. I've updated all of my values except the ones for 69 and 6C, and error code 01044 is gone! Success!
I didn't modify module 69 because I have a Swedish-sold Q7, so it appears that the first two bits should be 01. According to the VCDS coding table for this module, these are the values:
1) 0000000000000000 - trailer hitch not installed (PR-1D0)
2) 0100000000000000 - Rest of World (RoW)
3) 0200000000000000 - North American Region (NAR-PR-B34/B35/B39)
4) 0300000000000000 - Australia/New Zealand (PR-B24/B30)
For 6C, did you have any problems performing the camera calibration in VCDS? I've copied down all of the existing measurements and would simply confirm/re-enter them in the calibration process if necessary (looks like it's not necessary - not sure what I lose by not changing this module).
The updated scan is as follows:
Thursday,05,April,2018,23:16:29:49964
Mileage: 115820km-71967mi   Repair Order:
VIN: WAUZZZ4L3AD0.....   Mileage: 115820km-71967miles
   Component: 3.0TDI EDC17A104AG  0080
   Coding: 0000504
   Revision: 00H30001
   Coding: 0627841
   Coding: 0000135
   Coding: 040816
   Coding: 0033221
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0031161
   Coding: 0014128
   Coding: 0002052
   Coding: 0000101
   Coding: 000303
                    Reset counter: 249
                    Mileage: 115825 km
                    Date: 2018.04.05
                    Time: 23:04:26
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10011
   Revision: AA001002
   Coding: 0000006
   Coding: 0015520
   Coding: 0010101
   Coding: 3547377
   Coding: 0D000000
   Coding: 0011101
                    Reset counter: 249
                    Mileage: 115825 km
                    Date: 2018.04.05
                    Time: 23:05:32
   Coding: 0000032
   Coding: 1021001
   Coding: 0003587
   Coding: 0231166
End-------------------------(Elapsed Time: 03:38)--------------------------
That looks a lot better! By default the RVC should turn off when a trailer is connected so I assume that's the only feature you are missing. I wouldn't mind a visual of the front of my trailer when in reverse on-screen in the vehicle .. especially if it was a flat open trailer and I wanted to see if a tarp over a pile of mulch still looked good at a red light. As you can tell, I'm a little over enthusiastic about garden season and we still have snow in the forecast!
Saving all of the original values should allow you to simply re-save them but some RVC modules need to see the aiming target before they allow calibration. I would skip it (because I don't have the proper aiming tools/target) but if you do proceed please let us know how it works out.
Unrelated, but:
That may be worth looking into before whatever is putting comfort CAN into single wire mode breaks it entirely. Do let us know if you need further assistance related to that. In short, CAN comfort is a 2 wire system and it must be in single wire (emergency) mode since that's a hard fault.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
...Unrelated, but:
Yes, I would really appreciate troubleshooting guidance or schematics of the CAN bus wires. I've been looking into this and reading about other peoples' experiences trying to find the broken wire. I'm going to have to fix this - it seems I have voltage drain.
Thanks for the explanation of the coding change for the backup camera. I will definitely leave it as is.
Speaking of snow, we just drove 2-1/2 hrs each way for a ski trip today. We had some pretty heavy snow this morning after our route turned north. On the way back we had beautiful weather and I used the ACC a lot. It was awesome to have the adaptive cruise control available (I had no cruise control at all until code 01044 could be cleared with your help last night). My previous Q7 had regular cruise control, so this is the first time I've experienced it.
