ABS long coding lost
Danilo78
Italy
C?ID=216246
Hi guys
I have a problem with a Polo 6R abs unit. I installed a new cluster and forgot to save abs unit long coding. Is not possibile to create by vcds.
Is possible on vw service only. I send you autoscan, can you create long coding for me?
Regards
Danilo
Monday,29,September,2014,22:48:54:05573
VCDS Version: 12.12.3.0
Data version: 20140822
Dealer/Shop Name: Danilo
VIN: WVWZZZ6RZAY258477   License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9694
   Revision: --------    Serial number:
   Coding: 001900D6200400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM12TFS02103F906070D 003014
   ROD: EV_ECM12TFS02103F906070D.rod
   VCID: 234E21652AC03D06A6F-8076
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 02069 000 00000
   VCID: 8200C4E1191A540E0D9-80D7
                    Fault Frequency: 22
                    Reset counter: 67
                    Mileage: 53421 km
                    Date: 2030.14.27
                    Time: 15:25:55
                    Hex Value: 0x4007
                    Hex Value: 0x0002
                    Hex Value: 0x3213
                    Hex Value: 0x1496
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Fault Frequency: 22
                    Reset counter: 67
                    Mileage: 53421 km
                    Date: 2030.14.27
                    Time: 15:25:55
                    Hex Value: 0x4007
                    Hex Value: 0x0002
                    Hex Value: 0x3251
                    Hex Value: 0x1B96
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Fault Frequency: 22
                    Reset counter: 67
                    Mileage: 53421 km
                    Date: 2030.14.27
                    Time: 15:25:55
                    Hex Value: 0x4007
                    Hex Value: 0x0002
                    Hex Value: 0x32E1
                    Hex Value: 0x1A96
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       24 0660
   Revision: 00 10 24
   VCID: 356AEF3D9C54B3B678B-8060
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 092100132
   Coding: 3CB02BBF08A10000003000003C2B9CD00048410F60060000200000000000
   Shop #: WSC 12469 483 00190
   VCID: 3E78F011A96270EEA91-806B
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Coding: 08BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag00G H08 0020
   Revision: --------    Serial number: 003GX000X4FI
   Coding: 003047
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A90ACC1EDAACC4E059-801F
   Serial number: 3572SRB40000B0150B1U
   Serial number: 3582SRB40000B00D091-
   Serial number: 3515RRB405T6DUG679E3
   Serial number: 3525RRB405P6NG4E59CV
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 336ED1259A20AD8656F-8066
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: F0E49E2923B6569EEBD-80A5
   Component: IMMO          H03 0505
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAD08C410D6AAC4EA59-80BF
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664346325
   Coding: 010100
   VCID: 2A50CC4145EAEC4EE59-807F
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F66DD55EA088966327-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K7087193
   Coding: 0100040002
   VCID: 6BDE09458A9035465EF-803E
Danilo78
Italy
C?ID=216246
Hi Keithuk
I don't find it in ross-tech wiki....
On Polo 6r coding is particular because it has some part of VIM number.
Can you help me for it?
@Sebastian can help me?
ESP8.2i (and similar extremely long coded controllers such as MK60EC1) modules are typically coded online using the dealer scan tool with a direct connection to VW/Audi headquarters. The process is called SVM, which is a system used by VW/Audi to flash update control modules, and in certain cases, to change their Coding, Adaptation and unlock Component Protection.
We do not have enough information at this point in time to build the long coding from scratch but if you have a scan saved with the original configuration we should be able to help you enter the proper coding. If you do not have a scan saved in the original condition I would send the vehicle to the dealer for coding.
I'm starting to like Seb's suggestion more and more: Automatically save every Auto-Scan done, whether the user wants it saved or not. ;)
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Hard to disagree.
I had figured your long-term direction on this class of problems (coding, immo, CP) would be Cloud-based, though.
Jason
NEtech
Denmark
C?ID=56995
If you really do not want to do SVM, i would come up with this:
210228E3217200BA842914E984D800401300
or:
210228E3217200BA842914E982D800401300
No guaranties at all!
Gone But Not Forgotten
Maybe this also give a try if 21 series base.
213f401209270002840f02eb90200004300000
Danilo78
Italy
C?ID=216246
Thanks to all for your help.
I will inform you about
Danillo78: Lots of folk throwing lots of coding strings at you, so I thought that I should too! Data comes from the auto-scan for my wife's Polo 6R
Your part number: 6R0 907 379 AF
My part number: 6R0 907 379 AS
My Coding String: 23DD2885412400C8C41C146C825200800905
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Guys, please do not randomly use coding values w/o any verification. These ESP systems will accept several incorrect values and not tell you that they are wrong, so just because it's accepted and no fault codes are stored doesn't mean it's a good value. There is only one value which is correct, the fact that you get two possible values from one source should already make you wonder. ;) No hard feelings Jack/Niels, but there is a reason why we don't give these values out just yet...
FWIW, Niels's values are closest I believe while whichever calculator Jack is using here - it's totally off base. :p
Okay cool
What is totally off base Sebastian...........?
Considering I have no Polo's here to play with............ I consider your additional smartass comment totally justified :)
However, I have had good luck starting with a wrong base coding, that takes a few different codes as you aforementioned, and then tweaking as I go to select the errors out I observe.
You have to have something in there that is accepted first based off the VIN, Engine data, and brake size,................ before you can make selection changes from a big FAT zero.
Personally I like the idea of mandatory strongly warned auto saved auto-scans!
A key called controller rescue config data folder based on VIN and IMMO ID for each file before you get started.
Its very own folder dedicated to it to be saved or exported.
Danilo78
Italy
C?ID=216246
Dear guys
This one is long coding accepted only:
Now I have one problem only:
Esp sensor unit calibration G419 and tpms doesn't work
With wiki procedure doesn't possible.
Some idea about?
Please elaborate how/why it isn't possible.
Danilo78
Italy
C?ID=216246
I use this procedure:
[Select]
[03 - ABS Brakes]
[Security Access - 16]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 069
[Go!]
Field 2 should show OK after a successful Calibration.
[Done, Go Back]
[Meas. Blocks - 08]
Group 010 Field 1/2 (Longitudinal Acceleration Sensor (G251))
Specification: ±1.25 m/s²
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
After security access, I go to basic settings and group 69 doesn't exist in my abs unit
This is my problem
Danilo78
Italy
C?ID=216246
Resolved
I did try Audi TT procedure.
Group was 63 for G419 calibration
Now all units checked by autoscan are ok.
Thank you very very much to all guys helped me.
