Level Control Module 7P0 907 553 N Calibration Touareg 7P
dean001
Australia
C?ID=277309
I have been going through countless posts on the furm regarding a 2013 7P Touareg with the Air suspension that has the level control module 7P0 907 553 N.
THe older process doesnt work and i have tried this process also but i am missing the options under basic settings http://forums.ross-tech.com/showthr...n-to-default-position&highlight=level+control
anyone experienced this or able to point me in the right direction.
Thursday,29,March,2018,18:36:40:48703
VCDS Version: 18.2.0.3 (x64)
VIN: WVGZZZ7PZDDxxxxxx   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
          6C 6D 72
VIN: WVGZZZ7PZDDxxxxxxx   Mileage: 58591km-36406miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A4012232E01020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 326B6F3F65915ED4DE-8066
   Part No SW: 0C8 927 750 BK    HW: 0C8 927 750 BK
   Component: AL1000 AISIN  001 2268
   Coding: 001568
   Shop #: WSC 46332 001 1048576
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031_002.rod
   VCID: 76E3932FC97902F432-8022
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 M    HW: 7P0 907 379 A
   Component: MK25A         H36 0436
   Revision: --------    Serial number: 418020010EC815
   Coding: 5B6B13C34B24255BDAFBC89AD2D4A450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 479D2EEBFE13CB7C99-8012
   Part No SW: 4H0 907 064 CM    HW: 4H0 907 064 CM
   Component: BCM2 2.0      H32 0421
   Coding: 01B60010000000000000
   VCID: 76E3932FC17902F432-8022
   Subsystem 1 - Part No SW: 7P6 959 754 AC    HW: 7P6 959 754 AC
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0512000037927002
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000122544007
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: 36A6200890
   VCID: 7EF38B0FE1494AB46A-802A
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001534979
   Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
   VCID: 73E5AA3BD20B17DC15-8026
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    120605  31  0020
   Serial number: 90243401120616070825
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10406765
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002806120826
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261217700706
   Coding: 508501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428B3FFFD531EE544E-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag00T H05 0025
   Revision: --------    Serial number: 003L0003ZLRO
   Coding: 000000000000000000000000000000003054
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 418930F3D037F54C57-8014
   Serial number: 3575LRB40551G0QO2HLS
   Serial number: 3585LRB40531G0QO80ID
   Serial number: 3515RRB400Q4UJ4O80N6
   Serial number: 3525RRB400S4UJ4OLGHW
   Serial number: 3555NRB400U4UIV8EHG-
   Serial number: 3565NRB400U4UIV8G96L
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 90815LG400024
   Coding: 000C35
   VCID: 387F5D178BEDB484E0-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0194831
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 881 G    HW: 7P6 920 881 G
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658030712592057
   Coding: 332731003A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 408F35F7DB3DFC4458-8014
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H10 6028
   Revision: --------    Serial number: 00000000587916
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3B75421BB2DB9F9C0D-806E
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650654330
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 12125000108011200181
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] -  -
                    Fault Frequency: 187
                    Reset counter: 193
                    Mileage: 45257 km
                    Date: 2017.11.16
                    Time: 09:51:51
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 34 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 N    HW: 7P0 907 553 N
   Component: PASM          H01 1550
   Revision: 00000000    Serial number: 00000121680815
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
          C10DA 13 [009] - Open Circuit
                    Fault Frequency: 165
                    Reset counter: 0
                    Mileage: 52992 km
                    Date: 2056.03.15
                    Time: 04:16:61
                    Default: 00
                    Default: 7D
                    Default: 00
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000128489700
   Coding: 011D0620D001451005080002
   VCID: 448739E7C725E0647C-8010
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 203
                    Mileage: 30949 km
                    Date: 2015.10.29
                    Time: 14:17:07
   Revision: 00002001    Serial number: 0176436158
   Coding: 011A162028B9109483200624010000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO16738223
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1701810Z
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000128274152
   Coding: 011D0620D001451005080000
   VCID: 3B75421BBADB9F9C0D-806E
                    Reset counter: 203
                    Mileage: 31017 km
                    Date: 2015.11.02
                    Time: 18:00:18
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1261400054
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3663532F89F942F4F2-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AE00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CF78107F75558A444-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227FY0C7604255
   Coding: 040005020100000003
   VCID: 214990733877D54C37-8074
   Part No SW: 7P6 035 764 C    HW: 7P6 035 764
   Component: H-BNT-RW      H46 0537
   Revision: --------    Serial number: 479F 0C7520308
   Coding: 010A01050040C1EF01000B0E00000003F00001030000000000
   VCID: 39795813B0E7AD8C1F-806C
   Subsystem 1 - Part No: 8R0 060 884 AJ
   Component: ROW 2012  0403
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7801HRL
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000128557747
   Coding: 011C04200001251005080000
   VCID: 3A7B471FB5E1A69416-806E
                    Fault Frequency: 11
                    Reset counter: 192
                    Mileage: 52850 km
                    Date: 2018.01.29
                    Time: 10:12:46
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 E    HW: 7P6 907 441 D
   Component: TopView       H05 0100
   Revision: 11001001    Serial number: 82330JF0045985
   Coding: 0100000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 157200978
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D714C03ACCF91AC33-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000128518525
                    Reset counter: 205
                    Mileage: 21565 km
                    Date: 2014.10.17
                    Time: 09:50:02
End-------------------------(Elapsed Time: 04:47)--------------------------
