VW Phaeton 2010 3.0TDI V6 EDC17
turbocip
Moon
C?ID=80803
Hi , i have a Phaeton 2010 and i have DTC about particle filter clogged ....
Can someone help me where i can view the details about ash load volume?
In VCDS Hex Can V2 i dont have label for this car
Also for dpf regeneration, i need security code for login ? I try and no success . I follow procdure for 3.0TDI V6 (uhds) and not work
Here is my full scan attached
Thank you in advance
Monday,02,April,2018,10:18:14:27059
VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
Dealer/Shop Name: [url]www.turbocip.ro[/url]
Workshop Code: xxxxxxxxxxxxxxx
VIN: WVWZZZ3DZA8001045   License Plate:
Mileage: 344600km-214124mi   Repair Order:
Chassis Type: 3D (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 34 36 37 38 42 46 47
          52 55 56 62 68 71 72 76 77
VIN: WVWZZZ3DZA8001045   Mileage: 344600km-214124miles
05-Acc/Start Auth. -- Status: Malfunction 1010
07-Control Head -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 1010
18-Aux. Heat -- Status: Sporadic communication error 1000
38-Roof Electronics -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
68-Wiper Electr. -- Status: Sporadic communication error 1000
71-Battery Charger -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 1010
Address 01: Engine (CEX)       Labels: None
   Part No SW: 3D0 907 401 G    HW: 3D0 907 401 D
   Component: 3.0TDI EDC17G000AG  0030
   Revision: --H02---    Serial number: VWX3Z0I1873107
   Coding: 0406002C191F0160
   Shop #: WSC 18560 935 591558
   VCID: 2310E61C37C3632F4FA-5184
005633 - Relay for Supply Voltage Terminal 30 (J317)
               P1601 - 000 - Implausible Signal
                    Voltage: 0.00 V
                    Inj. On Time: 0.00 ms
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    Temperature: -90.0°C
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 001 - Restricted/Clogged - MIL ON
                    Fault Status: 11100001
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:14
                    (no units): 16.5
                    (no units): 32.5
                    (no units): 0.0
                    (no units): 2.0
008194 - Particulate Trap Bank 1
               P2002 - 008 - Efficiency Below Threshold
                    Fault Status: 01101000
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:14
                    (no units): 16.5
                    (no units): 32.5
                    (no units): 0.0
                    (no units): 2.0
Readiness: 1 1 0 0 0
   Part No SW: 09L 927 760 R    HW: GS1 911 4
   Component: AG6 09L 3,0 TDI RdW 3606
   Revision: --H04---    Serial number:        4532033
   Coding: 0000001
   Shop #: WSC 01065 000 00000
   VCID: 46D65F88E4B17607084-5160
005913 - Functionality limited due to Engine Control Module
               P1719 - 002 -
                    Fault Status: 01100010
                    Fault Frequency: 29
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:10:57
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H35 0047
   Coding: 0008356
   VCID: 6B80CE3C9F936B6FB7A-51F2
            000 -  -  - Intermittent
   Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
   Component:    Kessy            6850
   Revision: 00H22072    Serial number: VWX3Z0I1873107
   Coding: 0004328
   VCID: 2A0E0B3850B9B2670CC-807E
00164 - Battery Monitoring Control Module (J367) in Emergency Mode
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 14
                    Reset counter: 5
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 14
                    Reset counter: 5
                    Date: 2064.00.00
                    Time: 00:00:14
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1720
   Coding: 0000003
   VCID: 77A8E24CD38BDF8F432-8022
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
01308 - Control Module for Roof Electronics (J528)
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0031
   Revision: ABH10001    Serial number: VWZ6Z7J0236033
   VCID: 6390A61C7713232F0FA-8036
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 L
   Component: Climatronic D1      2037
   Coding: 0000001
   Shop #: WSC 00367 211 194846
   VCID: 2708F20C43AB8F0F132-8072
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 N    HW: 3D0 937 049 N
   Component: J519                6900
   Revision: -4005---    Serial number: --------------
   Coding: 618C0000EB2115860100000000000000
   Shop #: WSC 00404 211 101502
   VCID: 353428448907ED9F91E-8060
10 Faults Found:
00576 - Terminal 15
01498 - Bulb for Parking Lamps; Right (M3)
01501 - Bulb for Blinkers; Rear Left (M6)
02499 - Right Low Beam Reflector Motor (V295)
   Part No: 3D0 909 601 E
   Component: 0H Airbag 8.4E+ H12 0935
   Coding: 0012360
   VCID: 2514F80439A79D1F21E-8070
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000012
   VCID: 47C8528CE3EB6F0FF32-8012
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No SW: 3D0 920 885 T    HW: 3D0 920 885 T
   Component: J285 KOMBI-INST.    0616
   Revision: KPH06V01
   Coding: 0039101
   Shop #: WSC 43726 001 1048576
   VCID: 3B203E7CAF633BEF67A-806E
15 Faults Found:
                    Fault Status: 00101110
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Reset counter: 206
                    Mileage: 344602 km
                    Date: 2017.12.28
                    Time: 15:12:58
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:01
                    Fault Frequency: 19
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:01
                    Fault Frequency: 15
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Fault Frequency: 15
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Fault Frequency: 56
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
                    Fault Frequency: 68
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
                    Fault Frequency: 68
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
00457 - Control Module for Network (J519)
                    Fault Frequency: 63
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 07:27:22
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Fault Frequency: 61
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
                    Fault Frequency: 65
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 07:27:22
                    Fault Frequency: 11
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
01304 - Radio
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:05
Address 18: Aux. Heat        Labels: None
   Part No: 3D0 815 005 AP
   Component: J737__Standheizung  4405
   Revision: 00084000    Serial number: 09020869A00000
   Shop #: WSC 00091 211 89643
   VCID: 6B80CE3C9F836B6FB7A-803E
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3D0 920 885 T
   Component: J533  GW-K-CAN TP20 0616
   Coding: 7FF2F7AE3B011002
   VCID: 70BAD950B6A588B7828-8024
19 Faults Found:
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Reset counter: 206
                    Mileage: 344602 km
                    Date: 2017.12.28
                    Time: 15:12:58
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:05
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:01
                    Fault Frequency: 19
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:01
                    Fault Frequency: 15
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Fault Frequency: 15
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Fault Frequency: 56
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
                    Fault Frequency: 75
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 07:27:21
                    Fault Frequency: 68
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
                    Fault Frequency: 68
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
                    Fault Frequency: 63
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 07:27:22
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
                    Fault Frequency: 61
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:07:52
00908 - Control Module for Wiper Motor
                    Fault Frequency: 65
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 07:27:22
                    Fault Frequency: 65
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 07:27:22
                    Fault Frequency: 11
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:02
01304 - Radio
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:05
                    Reset counter: 208
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:05
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Shop #: WSC 43949 001 1048576
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1720
   Coding: 0000004
   VCID: 6FB8DA2CABDB974F9B2-803A
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3D0 035 680     HW: 3D0 035 680
   Component: RNS-MID       H10 0210
   Revision: AB001001    Serial number: VWZ6Z7J0236033
   Coding: 020500000000002200
   VCID: 5DE490E45D3715DF39E-8008
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 207
                    Mileage: 332912 km
                    Date: 2017.08.07
                    Time: 18:37:51
                    Reset counter: 206
                    Mileage: 344602 km
                    Date: 2017.12.28
                    Time: 15:31:32
                    Fault Frequency: 8
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2017.12.28
                    Time: 15:12:43
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 E
   Component: Dachmodul           0802
   Coding: 0004159
00926 - Terminal 30
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 M
   Component: 4Z HSG              8132
   Coding: 0000040
   VCID: 3A2E3B78A04902E77CC-4B00
   Subsystem 1 - Part No: 3D1 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 3D1 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 3D0 959 703 G
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 3D0 959 704 G
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 3D0 909 610 E
   Component: 3O HDSG             2530
   Subsystem 6 - Part No: 7L0 907 719 A
11 Faults Found:
00253 - Taillight Assembly - Rear Right
00318 - Supply Voltage for Rear Lid Control Module
   Part No SW: 3D0 035 466 B    HW: 3D0 035 466 B
   Component: R12___DSP 12 Kanal  0210
   Revision: DBH03001    Serial number: BP218794952846
   VCID: 211CEC142DCF713F5D6-8074
00871 - Bass Speaker Front Right (R23)
                    Fault Status: 00111011
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:15
                    Temperature: 11.0°C
00420 - Front Right DSP Midrange Speaker (R104)
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:15
                    Temperature: 11.0°C
                    Code Not Found: TNF 255 255
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:15
                    Temperature: 11.0°C
                    Raw, Index/Key Err.: 255 255 255
03741 - Tweeter 2; Front Right
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:15
                    Temperature: 200.0°C
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:12
                    Temperature: 0.0°C
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:12
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0136
   Coding: 2214081
   VCID: 3B203E7CAF233BEF67A-806E
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000033
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000033
02234 - Right Headlight Power Output Stage (J668)
                    Fault Frequency: 21
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2018.01.02
                    Time: 00:00:14
                    Voltage: 12.64 V
                        ABS 1
Address 56: Radio (J0506)       Labels: None
                    Reset counter: 207
                    Mileage: 332912 km
                    Date: 2017.08.07
                    Time: 18:37:51
                    Reset counter: 206
                    Mileage: 344602 km
                    Date: 2017.12.28
                    Time: 15:31:32
                    Fault Frequency: 8
                    Reset counter: 207
                    Mileage: 344602 km
                    Date: 2017.12.28
                    Time: 15:12:43
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D1 955 119 B
   Component: Front Wiper         3501
   Coding: 0013685
   Shop #: WSC 01065 000 376832
   VCID: 280AF1304EB580771A8-807C
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 2412E500329D6417360-8070
00086 - Parallel Battery Connection Relay (J581)
00576 - Terminal 15
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 E
   Component: 10 Einparkhilfe     1107
   VCID: 2C020D205A4DAC57FE0-8078
Address 77: Telephone
End----------(Elapsed Time: 02:45, VBatt start/end: 13.7V/13.9V)-----------
Try MVB 104. I think it should be something like this:
104.1 Particle Filter Oil Ash Volume
104.2 Particle Filter Carbon Mass (calculated)
104.3 Particle Filter Carbon Mass (actual)
For Security Access, try: 27971
turbocip
Moon
C?ID=80803
I will try next days .
I will let you know
