Screwed Up - ABS Module Coding
kcasner
C?ID=227060
2016 VW GTI Autobahn
What wasn't done:
1. Full backup from auto scan of all modules. Like it tells you to do, and I didn't listen. :banghead:
What was done:
1. ABS adaptation and coding to disable and change ESC, ASR, Starting Vibration, and XDS settings.
2. Reset all adaptation settings (assumed this would reset all to defaults). This is where the issues started I presume.
3. Reset all to factory defaults (noticed after, not sure the difference).
4. Reverted all settings found in the debug logs.
5. Unplugged VCDS and power cycled the car.
6. Drove a couple miles, stopped, power cycled the car.
What's wrong:
1. TPMS and ESC error's on MFD.
Goal:
Reset the module to factory defaults.
The fault codes
Sunday,01,April,2018,11:27:25:29806
VCDS Version: Release 18.2.0 (x64) Running on Windows 10 x64
Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
Control Module Part Number: 3Q0 907 379 T HW: 3Q0 907 379 C
Component and/or Version: ESC H32 0393
Software Coding: 01FA6BA15426096D0077020941CA6880D62A9000408216B6004300D1C009
Work Shop Code: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033 (VW37)
VCID: 4BD6A040E2B17E1CBD-801E
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 134
Date: 2018.04.01
Time: 11:25:50
16412 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Reset counter: 134
Mileage: 43387 km
Date: 2018.04.01
Time: 11:26:00
16413 - Display for Tire Pressure Monitoring
Reset counter: 134
Mileage: 43387 km
Date: 2018.04.01
Time: 11:26:00
vw754
C?ID=52227
take it to vw and act innocent say you started it and got the faults come up on the dash....be under warranty with it being a 16 plate........
kcasner
C?ID=227060
Car is flashed, fully built. Service Manager is a real douche as well @ VW Folsom. Tried denying a taillight because I put a bulb in it once, when it built up condensation despite there being a TSB. Had to build a JIG with water droplets to prove my case.
kcasner
C?ID=227060
Still reading all over, and found THIS thread. Would make sense since I reset all adaptations. First attempt, error is still there. In case I missed a step, going to give it another shot.
iichel
Eindhoven, NB, NL
C?ID=284912
have a look in your c:\whatever\ross-tech\vcds\debug folder and in the codinglog.txt and adaptationlog.txt. there you can find the values from where to where they changed.
kcasner
C?ID=227060
Did that already, step 4 I mentioned in the OP.
iichel
Eindhoven, NB, NL
C?ID=284912
okay well next step would be a full autoscan I guess
one error could be solved by doing a basic setting of the G85 steering angle sensor, the other two, about the TPMS display, I'm not sure.
kcasner
C?ID=227060
Thanks for the replies. Once the Steering Angle Senser was calibrated, the other errors went away by driving a short distance.
All I needed to do, was move the steering wheel lock to lock after running the basic setting as outlined in the article I linked.
