- Apr 1, 2014
- 93
- 8
- Acton, Ontario, Canada
- C?ID=211204
I have an engine issue with my 1991 Passat and I wish to connect the vagcom and scan for fault codes. My issue is I don't have the typical OBD1 connectors on my vehicle that the 2X2 adapter can connect to and want to know if anyone has run into this and what to do.
Typically there is one white and one black connector on the vehicle to access the fault codes and the same on the 2X2 adapter and each of these connectors has a specific shape so they can't be connected incorrectly. I have one white and two blue on my vehicle and they are all the same shape. I believe that the two blue connectors are for the auto but not sure and one connector has only one terminal filled in on the connector.
2X2 adapter normal: http://www.ross-tech.com/vag-com/2x2.html
Any help would be appreciated. Thanks
