2010 Audi S4 after some advice please..
raynard08
C?ID=330537
car was accident damaged , all is back to nomal now apart from airbag module.. has the crash data stored..
can i code in a new module with VCDS ? if so is it just a case of copying old coding and pasting into new module?
most of the fault codes in that scan are gone now just the airbag ones remain , not sure if am doing right or wrong by posting the full scan am sure i read when i signed up thou to post full scans if i am wrong i will delete haha sorry.
thanks in advance Paul.
also here is a full scan of it if anyone is interested
Friday,30,March,2018,14:10:09:24744
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUZZZ8K6AA104203   License Plate:
Mileage: 101220km-62895mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 30 3C 42 46 47 52 53
          55 56 5F 62 72
VIN: WAUZZZ8K6AA104203   Mileage: 101220km-62895miles
05-Acc/Start Auth. -- Status: Malfunction 1010
30-Special Function II -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
Address 01: Engine (J623-CAKA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551     HW: 8K0 907 551
   Component: 3.0T SIMOS84  X06 0006
   Revision: --X06---
   Coding: 0104000C240F0228
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS8K0907551 A02008
   ROD: EV_ECM30TFS0218K0907551C.rod
   VCID: 6E843E9730110FF7904-803A
6140 - Fan 1 Control Circuit
          P0691 00 [032] - Short to GND
                    Fault Frequency: 8
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:00:40
                    Engine speed: 0.00 /min
                    Coolant temperature: 6 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 10.968 V
                    Unlearning counter according OBD: 32
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 6.0 °C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
                    Vehicle speed: actual: 0 km/h
6443 - Power Supply Terminal 30
          P1602 00 [096] - Voltage too Low
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Coolant temperature (unfiltered): 34.5 °C
6487 - Engine Off Timer Performance
          P150A 00 [096] - -
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:02:57
                    Engine speed: 125.00 /min
                    Normed load value: 5.9 %
                    Coolant temperature: 27 °C
                    Intake air temperature: 3 °C
                    Voltage terminal 30: 10.562 V
                    Unlearning counter according OBD: 36
                    Engine speed: actual: 96 /min
                    Coolant temperature (unfiltered): 27.0 °C
                    Engine: operating status: ST
                    Battery voltage: 10.562500 V
Readiness: 0110 0001
   Part No SW: 8K1 927 156 B    HW: 0B5 927 156 E
   Component: 0B5 30TFSIRdW H03 0003
   Revision: --H03---    Serial number: 0000000731
   ASAM Dataset: EV_TCMDL501 A02043
   ROD: EV_TCMDL501.rod
   VCID: 3430ECFF1EBD6527A60-8060
8013 - Body Control Module (Central Electric)
          U0140 00 [032] - No Communications
                    Reset counter: 33
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:02:22
                    Engine speed: 0 /min
                    Transmission input speed: 0 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 9 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 290508
   VCID: 7AAC02C77CD953573CC-802E
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:25:37
                    Hex Value: 0x0000
                    Hex Value: 0x1082
                    Hex Value: 0x0003
                    Hex Value: 0x245E
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0326
   Coding: 011100
   VCID: 015E752B110F008F7D6-8054
   Subsystem 1 - Part No SW: 8T0 959 754 AG    HW: 8T0 959 754 AG
   Serial number: 0509000070410018
   Serial number: 0209000092452013
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:56:44
                    Reset counter: 94
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:56:55
                    Fault Status: 00101101
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 02:13:52
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D1000000    Serial number: 01081220090674
   Coding: 66140000
   VCID: 77AA1BF34FCB4E3F432-8022
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:00:17
            000 -  -  - Intermittent
                    Reset counter: 88
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:25:32
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000409252
   Coding: 260050914074AF010001000300001D0D0F1D430A00010141000000
   VCID: 3C20C4DF366DAD676E0-8068
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 011209  H05 0070
   Serial number: SWF09120010043
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10698807
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002711090984
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 96
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 02:11:00
                    Reset counter: 95
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Reset counter: 93
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:49:00
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:57:00
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:11:00
03423 - Control Module for Vehicle Positioning System Interface
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:01:00
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840933901072
   Coding: 10010D
   VCID: 40D8B02F5A85C987328-8014
01626 - Sensor for Parking-Aid; Front Right (G252)
                    Fault Status: 00101001
                    Reset counter: 94
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 01:24:28
                    Temperature: 5.0°C
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                    Fault Status: 01101001
                    Reset counter: 48
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:04:27
                    Temperature: 5.0°C
                    Reset counter: 88
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:25:43
                    Temperature: 14.0°C
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H08 0080
   Coding: 002B96
   VCID: 6FBA2393379B06FF9B2-803A
                    Reset counter: 88
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:50
                    Temperature: 29.0°C
                    Voltage: 11.90 V
                    Bin. Bits:    00000
                    Hex Value: 0x044B
                    Hex Value: 0x0044
                    Speed: 28.8 km/h
                    Lateral Accel.: -7.75 m/s^2
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD083V45
   Coding: 30363435363030303030554A3052384B3053
   VCID: 41DEB52B510FC08F3D6-8014
   Serial number: 6334MSME4E616C20I
   Serial number: 6344MSME4D443A49P
   Serial number: 6352QSME414556068
   Serial number: 6362QSME7C45060EQ
   Serial number: 63732SME4D464F002
   Serial number: 63832SME576745753
11 Faults Found:
          B1006 1B [137] - Resistance Too High
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:54
9442587 - Igniter for battery interrupt
          B1015 1B [136] - Resistance Too High
                    Fault Frequency: 9
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:00:30
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:54
          B1000 1B [136] - Resistance Too High
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:54
9437467 - Igniter 2 for Driver's Airbag
          B1001 1B [136] - Resistance Too High
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:54
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:55
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:01:06
9444137 - Front Passenger's Front Airbag Crash Sensor
          B101B 29 [136] - Signal Implausible
                    Mileage: 101224 km
                    Date: 2009.07.01
                    Time: 22:28:16
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [136] - Open or Short to Plus
                    Mileage: 100811 km
                    Date: 2017.08.01
                    Time: 01:21:45
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [136] - Open or Short to Plus
                    Mileage: 100811 km
                    Date: 2017.08.01
                    Time: 01:21:46
9447424 - Front crash data stored
          B1028 00 [137] -  -
                    Mileage: 101225 km
                    Date: 2017.11.03
                    Time: 20:11:51
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90319IL20002S
   Coding: 00003E
   VCID: 3E24CED72071BF77404-806A
                    Fault Frequency: 62
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:25:26
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:26:21
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:11:43
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 02:09:12
   Part No SW: 8K0 920 981     HW: 8K0 920 981
   Component: KOMBIINSTR.   H04 0255
   Revision: 00000000    Serial number: CJ932UGA9
   Coding: 2F07090006002600010000
   VCID: 70B820EF2AA51907828-8024
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09B2102AF
   Coding: 00C303
   VCID: 0058702F1A050987728-8054
   Component: J367-BDM  H06 0170
   Serial number: 1909E75E301109
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:06:45
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 10
                    Bin. Bits:    10010
                    Time: 25.40 s
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:11:44
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 10
                    Bin. Bits:    10011
                    Time: 25.40 s
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:11:44
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 10
                    Bin. Bits:    10011
                    Time: 25.40 s
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 92
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:51:00
                    Reset counter: 95
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 09:51:00
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 17
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:57:50
                    Bin. Bits:    10000
                    Voltage: 7.10 V
                    Count: 10
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02029164747464545425363E
   VCID: 3332EFE31B33621FBFA-8066
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000023827
   Coding: 01010101000000000000000102
   VCID: 2D06F99BFD1734EFE9E-8078
                    Reset counter: 89
                    Mileage: 94290 km
                    Date: 2014.11.30
                    Time: 03:14:38
                    Reset counter: 89
                    Mileage: 94521 km
                    Date: 2014.12.02
                    Time: 13:19:01
                    Reset counter: 89
                    Mileage: 94521 km
                    Date: 2014.12.02
                    Time: 13:19:01
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0001101
   VCID: 3C20C4DF3A6DAD676E0-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F05.12.0900H010003C320723ÿ
   Subsystem 4 - Serial number: 320723ÿ
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009739531
   Coding: 011C02205021410001
   VCID: 45D6A13B45A7ECAF01E-8010
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.08
                    Time: 12:57:45
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 02:25:41
   Revision: 00002001    Serial number: 0124501262
   Coding: 011B062200390C800030013280000000
   Shop #: WSC 06342 000 00000
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:14:59
03549 - Terminal 15 Locking Active
                    Reset counter: 91
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:14:59
00457 - Control Module for Network (J519)
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 04:11:42
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101011
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 08:56:50
                    Reset counter: 89
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:56:38
                    Reset counter: 94
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:57:54
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882000677701
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009749420
   VCID: 44D0BC3F4E9DD5A7160-8010
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.07
                    Time: 12:21:59
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.08
                    Time: 12:58:39
   Revision: 00000003    Serial number: 00000000514534
   VCID: 3430ECFF1E3D6527A60-8060
                    Reset counter: 49
                    Mileage: 101224 km
                    Date: 2009.06.27
                    Time: 01:57:53
                    Voltage: 7.20 V
                    Count: 44
                    Hex Value: 0x0163
                    Hex Value: 0x0088
                    Hex Value: 0x1010
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77AA1BF343CB4E3F432-8022
                    Fault Status: 11101010
                    Reset counter: 48
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:01:11
   Part No SW: 4F0 035 061 K    HW: 4F0 035 061
   Component: Radio U DAB   H45 0074
   Revision: AB001007    Serial number: 343KY097541912
   Coding: 010103010000000001
   VCID: 24101CBFAEDDF5A7360-8070
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.07
                    Time: 12:21:30
                    Voltage: 8.60 V
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.06
                    Time: 10:27:54
                    Voltage: 8.90 V
02984 - Connection between Impedance Converter 2 and Window Antenna
                    Fault Frequency: 218
                    Reset counter: 96
                    Mileage: 96648 km
                    Date: 2017.03.10
                    Time: 15:52:29
                    Voltage: 11.90 V
                    Reset counter: 89
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 88
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:00:46
                    Bin. Bits: 00000000 00000001
   Part No SW: 8T2 035 666 M    HW: 8T2 035 666 E
   Component: H-BN-EU       H45 0187
   Revision: --------    Serial number: 475L8097529493
   Coding: 01010100020689ED31000B1E000000030001
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H43 0306
   Serial number: 9356L0091148982
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000424604
   Component: CD-Database  1293
                    Reset counter: 89
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:26:14
                    Voltage: 6.10 V
                    Reset counter: 88
                    Mileage: 101224 km
                    Date: 2009.06.26
                    Time: 00:00:44
                    Bin. Bits: 00100000 00000000
                    Bin. Bits: 00000000 00000000
03367 - Supply Voltage for Display Module
                    Reset counter: 88
                    Mileage: 101225 km
                    Date: 2017.11.17
                    Time: 10:25:45
                    Voltage: 7.00 V
03606 - Antenna for Telphone Base-Plate
                    Reset counter: 86
                    Mileage: 101101 km
                    Date: 2017.10.28
                    Time: 19:58:17
                    Voltage: 15.10 V
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102467790
   Coding: 010C02204021210001
   VCID: 42DCBA275489DB9724C-8016
                    Reset counter: 89
   Revision:             Serial number: 0000102467752
                    Reset counter: 89
End----(Elapsed Time: 01:59, VBatt start/end: 12.3V/11.9V. VIgn 11.9V)-----
A full scan is always welcome!
Is it safe to assume that the "Crash Data Stored" code won't clear? Depending on the severity of the crash, many newer airbag modules do allow that code to be cleared.
VCDS can code a new airbag module, but I would suppose that in this car, a new module will throw a Component Protection fault, and that's something that will have to be dealt with at the dealer (or an independent workshop with access to Audi's servers).
raynard08
C?ID=330537
thanks mate will give it a whirl , ile replace belts first and side bag and try, i was just assuming it would have crash data stored , there is no actual fault code now for crash data come back once av cleard it
