lost ABS coding while testing park brake issue.
I have pr codes
Controller Software Versions:
ECU 1 = Engine 2371
ECU 2 = Auto Trans 1271
ECU 3 = ABS Brakes 0004
ECU 4 = Auto HVAC 0404
ECU 5 = Cent. Elect. 1501
Sub ECU 5 > 1 = Cent. Elect. 0101
Sub ECU 5 > 2 = Cent. Elect. 1110
ECU 6 = Digital Radio 0060
ECU 7 = Airbags 2521
Sub ECU 7 > 1 = Airbags 0000
ECU 8 = Steering wheel 0015
Sub ECU 8 > 1 = Steering wheel 2001
ECU 9 = Instruments Labels:
ECU 10 = CAN Gateway 0040
ECU 11 = Position Sensing 00
ECU 12 = Immobilizer 0364
Sub ECU 12 > 1 = Immobilizer 8038
ECU 13 =
ECU 14 = Door Elect, Driver
ECU 15 = Steering Assist 160
ECU 16 = Central Conv. 0213
ECU 17 = Door Elect, Pass. 2
ECU 18 = Parking Brake 0001
ECU 19 = Radio 0017
ECU 20 = Door, Rear Left 250
ECU 21 = Tire Pressure 0391
ECU 22 = Trunk Elect. 0405
Sub ECU 22 > 1 = Trunk Elect. 040
ECU 23 = Door, Rear Right 25
I have pr codes
Wednesday,28,March,2018,14:51:19:51327
VCDS Version: 18.2.0.3 (x64)
VIN: WVWPU73C57E009839 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
65 6D 72
VIN: WVWPU73C57E009839 Mileage: 199370km-123882miles
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 N HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2371
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 05311 000 00000
P1653 - 004 -
Mileage: 199377 km
Date: 2018.03.26
Time: 04:06:41
RPM: 1126 /min
Load: 62.7 %
Temperature: 61.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 10.287 V
P1653 - 001 -
Fault Status: 01100001
Mileage: 199377 km
Date: 2018.03.26
Time: 04:06:43
RPM: 1290 /min
Load: 46.6 %
Temperature: 15.0°C
Temperature: 17.0°C
Voltage: 11.811 V
Readiness: 0110 0101
Part No SW: 09G 927 750 HK HW: 09G 927 750 AJ
Component: AQ 250 6F 1271
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 02607 444 58981
Reset counter: 39
Mileage: 45057 km
Date: 2008.04.29
Time: 09:16:12
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0100007377
Coding: 0000000
Reset counter: 154
Time: 04:03:49
Reset counter: 154
Time: 04:03:49
Reset counter: 154
Time: 04:03:49
Reset counter: 154
Time: 04:03:49
Reset counter: 154
Time: 04:03:49
Fault Frequency: 9
Reset counter: 154
Mileage: 199377 km
Date: 2018.03.26
Time: 04:03:49
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005594134
Coding: F58C8F0340041A00470A00000F00000000285D435C0000
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 05311
01064 - Terminal 58d; Interior Dimming
Reset counter: 192
Time: 06:03:00
02092 - Enabling Heated Seat
Reset counter: 155
Time: 14:19:00
01335 - Drivers Seat/Mirror Position Control Module (J543)
Reset counter: 155
Time: 13:06:00
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 194
Mileage: 199377 km
Date: 2018.03.16
Time: 09:05:00
Voltage: 9.80 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F3017670
Reset counter: 194
Mileage: 199377 km
Date: 2018.03.26
Time: 00:36:08
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0P AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P7FFCEI
Coding: 0012368
Subsystem 1 - Part No: 000 000 000 00
Component: BF-Gewichtsens. 000 0000
Subsystem 2 - Serial number: 00000000000000
Subsystem 3 - Serial number: 0001.01.000000000000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0D186852Eÿ†63
Subsystem 5 - Serial number: 86852Eÿ†6342MSME1047326B6ÿ†63
Subsystem 6 - Serial number: 7326B6ÿ†6351HTS6TLLMEIJ2Qÿ†63
Subsystem 7 - Serial number: MEIJ2Qÿ†6361HTS6OLL6EP732ÿ†63
Subsystem 8 - Serial number: 6EP732ÿ†63727TS63IKI9KU2-ÿ†63
Subsystem 9 - Serial number: I9KU2-ÿ†63827TS61IKAOK52Hÿ
Subsystem 10 - Serial number: AOK52Hÿ
02511 - Control Module for Seat Occupied Recognition (J706)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
00591 - Seat Belt Switch; Driver (E24)
00592 - Seat Belt Switch; Passenger (E25)
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507P
Coding: 0002212
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Component: KOMBIINSTRUMENT VD1 4240
Revision: V0033000 Serial number: 00000000000000
Coding: 0007205
Reset counter: 194
Time: 14:19:19
Reset counter: 154
Time: 13:06:58
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Component: Gateway 007 0040
Coding: 3FFD0F0CD32002
Reset counter: 154
Time: 13:06:58
Reset counter: 194
Time: 14:19:19
Component: Kompass 001 0002
Component: IMMO 041 0364
Shop #: WSC 02607 444 14564
Component: ELV 028 0380
Address 36: Seat Mem. Drvr
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Component: Tuer-SG 024 2801
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Component: EPS_ZFLS Kl.5 D04 1607
Component: KSG PQ46 RDK 041 0213
Coding: 13900E88D1032E521804141FF00A8F0E081800
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Component: EPB VC8HC001 013 0001
Coding: 0010000
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Fault Status: 11111100
Reset counter: 154
Mileage: 199376 km
Date: 2018.03.26
Time: 00:35:03
Voltage: 12.53 V
Count: 86
Fault Status: 11101101
Reset counter: 155
Mileage: 199376 km
Date: 2018.03.26
Time: 19:45:06
Voltage: 11.70 V
Count: 220
Reset counter: 155
Mileage: 199376 km
Date: 2018.03.26
Time: 04:03:49
Voltage: 13.35 V
Count: 236
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Reset counter: 154
Mileage: 199376 km
Date: 2018.03.26
Time: 00:35:12
Voltage: 12.73 V
Count: 87
02431 - Right Parking Brake Motor (V283) Resistance to Movement
003 - Mechanical Failure - MIL ON
Fault Status: 11110011
Reset counter: 154
Mileage: 199376 km
Date: 2018.03.26
Time: 00:35:12
Voltage: 13.15 V
Count: 89
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0017
Revision: 00016000 Serial number: VWZ5Z7F2069037
Coding: 0040400
Shop #: WSC 05311 000 08193
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2507
Coding: 0000144
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: RDK 0391
Revision: 00041000 Serial number: VWZCZ000000000
Coding: 0100101
00667 - Ambient Temperature Signal
Fault Status: 00111000
Reset counter: 194
Mileage: 199377 km
Date: 2018.03.26
Time: 00:09:58
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H20001
Shop #: WSC 23250 384 715754
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0600H20001000A0006ÿ
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
End-------------------------(Elapsed Time: 02:20)--------------------------
ECU 1 = Engine 2371
ECU 13 =
ECU 19 = Radio 0017
